Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Hiding Table
Hiding Table [message #375153] Thu, 02 October 2003 13:51 Go to next message
I have a Table in a composite with GridLayout. Now I want to hide it.
So I do "table.setVisible(false)" and then "shell.pack(true)" (because I
want the dialog resized). I also do a
((GridData)table.getLayoutData()).heightHint = 0 for hiding.
Now the table still occupies its place (well its not as big as it was
before - the heightHint=0 makes it one row high) even though it's not
visible - meaning: the space is not occupied by another control
Peschmä
Re: Hiding Table [message #375170 is a reply to message #375153] Fri, 03 October 2003 10:23 Go to previous messageGo to next message
Use setVisible(). The height and width hints are used as arguments to
computeSize() in place of SWT.DEFAULT.
"Simon Rutishauser" <simon.rutishauser@gmx.ch> wrote in message
news:pan.2003.10.02.17.51.01.802147@gmx.ch...
> Peschm
Re: Hiding Table [message #375175 is a reply to message #375170] Fri, 03 October 2003 12:44 Go to previous messageGo to next message
Yes, it _should_ definitely be setVisible().
But in my case a
table.setVisible(false); shell.pack(true);
causes the space where the table was to be grayed (like a composite with
nothin in it) instead of being used for other controls.
Little sample with buttons:
[snipp]
import org.eclipse.swt.*;
import org.eclipse.swt.events.*;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.layout.*;
public class Sample {
private Display display;
private Shell shell;
private Button b;
Sample() {
display = new Display();
shell = new Shell(display, SWT.DIALOG_TRIM);
GridLayout gl = new GridLayout();
shell.setLayout(gl);
Button tmp = new Button(shell, SWT.NULL);
tmp.setText("First; hide");
tmp.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
b.setVisible(false);
shell.pack(true);
b = new Button(shell, SWT.NULL);
b.setText("Middle");
tmp.setText("Last; show");
b.setVisible(true);
shell.pack(true);
shell.pack();
shell.open();
while(!shell.isDisposed())
display.readAndDispatch();
new Sample();
[/endsnipp]
Peschmä
Am Fri, 03 Oct 2003 10:23:02 -0400 schrieb Steve Northover:
>> Hi,
>> Peschmä
Re: Hiding Table [message #375178 is a reply to message #375175] Fri, 03 October 2003 13:34 Go to previous messageGo to next message
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
| But in my case a
I've had a similar problem where I had to show or hide a Composite and I used
a Control#setParent and Control#moveBelow; I created a dummy Shell which is
never displayed which I set as a parent when I want to hide the said
Composite. To show it, I'd set the parent back to original and use moveBelow
to put it in the right place (you should call pack() on the parent after that).
There may be better ways to do it, but this one certainly works (app in
question has been in production for a while).
Emir Alikadic
Software Developer
CollectiveBid Systems Inc.
"Our products just aren't engineered for security."
~ [Brian Valentine, Senior VP Windows Division, Microsoft]
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.1 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQE/fbMTuSy542G+Z7QRAhoxAJ4iDVOJFlUL1xIc9G8Nrs2Q0k3DCwCf dxFU
HTwMRndyYlLe9NoDvS03+no=
=GFzL
-----END PGP SIGNATURE-----
Re: Hiding Table [message #375180 is a reply to message #375178] Fri, 03 October 2003 16:35 Go to previous messageGo to next message
I've been doing such games for a while.
(In my case I used a FormLayout and changed the FormAttachments every time
:D, but here it grew too complicated)
Sounds like an ugly workaround. But I can live with that.
Thanks a lot
Peschmä
Am Fri, 03 Oct 2003 13:34:11 -0400 schrieb Emir Alikadic:
> Hash: SHA1
> | But in my case a
> | table.setVisible(false); shell.pack(true); causes the space where the
> | table was to be grayed (like a composite with nothin in it) instead of
> used a Control#setParent and Control#moveBelow; I created a dummy Shell
> which is never displayed which I set as a parent when I want to hide the
> said Composite. To show it, I'd set the parent back to original and use
> moveBelow to put it in the right place (you should call pack() on the
> parent after that).
> question has been in production for a while). - --
> Emir Alikadic
> Software Developer
> "Our products just aren't engineered for security." ~
> [Brian Valentine, Senior VP Windows Division, Microsoft] -----BEGIN PGP
> SIGNATURE-----
> =GFzL
Re: Hiding Table [message #375186 is a reply to message #375180] Sat, 04 October 2003 02:56 Go to previous messageGo to next message
I checked it out. It works.
I'd never come up with the idea of using moveBelow()/moveAbove() for the
needed purpose. The apidoc seems to be quite wrong - or at least it sounds
to me as if I was ordering the controls' position in z-axis direction...
private Shell invisibleShell;
private Button b;
private Button b1, b2;
Sample() {
invisibleShell = new Shell(display, SWT.NULL);
b1 = new Button(shell, SWT.NULL);
b1.setText("First; hide");
b1.addSelectionListener(new SelectionAdapter() {
b.setParent(invisibleShell);
shell.pack(true);
b2 = new Button(shell, SWT.NULL);
b2.setText("Last; show");
b2.addSelectionListener(new SelectionAdapter() {
b.setParent(shell);
b.moveBelow(b1);
shell.pack(true);
shell.pack();
shell.open();
new Sample();
[/snipp]
Peschmä
Am Fri, 03 Oct 2003 22:35:01 +0200 schrieb Simon Rutishauser:
> Thanks
> I've been doing such games for a while. (In my case I used a FormLayout
> Thanks a lot
> Peschmä
>> Hash: SHA1
>> | But in my case a
>> parent after that).
>> question has been in production for a while). - -- Emir Alikadic
>> Software Developer
>> "Our products just aren't engineered for security." ~ [Brian Valentine,
>> Senior VP Windows Division, Microsoft] -----BEGIN PGP SIGNATURE-----
>> =GFzL
Re: Hiding Table [message #375256 is a reply to message #375186] Tue, 07 October 2003 10:13 Go to previous messageGo to next message
You are reordering the children. A better solution would probably be to use
FormLayout and change the attachments. Can you post a more complete example,
showing the effect that you are after? You mention that you want to hide a
table. Do you want another widget to take it's place in the grid? Thanks.
news:pan.2003.10.04.06.56.55.788010@gmx.ch...
> private Button b;
> Sample() {
> shell.pack(true);
> b.setParent(shell);
> b.moveBelow(b1);
> shell.pack(true);
> shell.pack();
> shell.open();
> public static void main(String[] args) {
> new Sample();
> [/snipp]
> Peschm
Re: Hiding Table [message #375284 is a reply to message #375256] Tue, 07 October 2003 12:06 Go to previous messageGo to next message
It works now.
I want the Shell to be resized. The other controls should remain about as
they are.
Using FormLayout is quite painful. Doing it with GridLayout and moving the
Table to an invisible Shell is easier.
It looks like this:
State 1: State2:
Some Controls Some Controls
Table Other Controls
Other Controls
Peschmä
Am Tue, 07 Oct 2003 10:13:14 -0400 schrieb Steve Northover:
> use FormLayout and change the attachments. Can you post a more complete
> example, showing the effect that you are after? You mention that you want
> to hide a table. Do you want another widget to take it's place in the
> grid? Thanks.
>> Hi,
>> sounds to me as if I was ordering the controls' position in z-axis
>> direction...
>> private Button b;
>> Sample() {
>> b1.addSelectionListener(new SelectionAdapter() { public void
>> widgetSelected(SelectionEvent e) { b.setParent(invisibleShell);
>> shell.pack(true);
>> b2.addSelectionListener(new SelectionAdapter() { public void
>> widgetSelected(SelectionEvent e) { b.setParent(shell);
>> b.moveBelow(b1);
>> shell.pack(true);
>> shell.pack();
>> shell.open();
>> public static void main(String[] args) { new Sample();
>> [/snipp]
>> Peschmä
>> > Thanks
>> > Thanks a lot
>> > Peschmä
>> >> Hash: SHA1
>> >> | But in my case a
>> >> | the table was to be grayed (like a composite with nothin in it)
>> >> | instead
> of
>> >> and
> I
>> >> Shell which is never displayed which I set as a parent when I want to
>> >> hide
> the
> use
>> >> parent after that).
>> >> in question has been in production for a while). - -- Emir Alikadic
>> >> Software Developer
>> >> SIGNATURE----- Version: GnuPG v1.2.1 (MingW32)
>> >> =GFzL
Re: Hiding Table [message #375293 is a reply to message #375284] Wed, 08 October 2003 11:20 Go to previous messageGo to next message
The only reason I mention this is that Control.setParent() is not
implemented on some platforms.
news:pan.2003.10.07.16.06.58.240580@gmx.ch...
> It works now.
> they are.
> It looks like this:
> State 1: State2:
> Other Controls
> Peschm
Re: Hiding Table [message #375303 is a reply to message #375293] Thu, 09 October 2003 04:13 Go to previous messageGo to next message
On which ones not?
I tested it on Win2k and Linux (with motif, gtk2 and fox) and all those
worked.
Peschmä
Am Wed, 08 Oct 2003 11:20:43 -0400 schrieb Steve Northover:
>> It works now.
>> as they are.
>> the Table to an invisible Shell is easier.
>> It looks like this:
>> State 1: State2:
>> Other Controls
>> Peschmä
>> > to use FormLayout and change the attachments. Can you post a more
>> > complete example, showing the effect that you are after? You mention
>> > that you
> want
>> > grid? Thanks.
>> >> Hi,
> the
>> >> direction...
>> >> private Button b;
>> >> Sample() {
>> >> shell.pack(true);
>> >> b.moveBelow(b1);
>> >> shell.pack(true);
>> >> shell.pack();
>> >> shell.open();
>> >> [/snipp]
>> >> Peschmä
>> >> > Thanks
>> >> > Thanks a lot
>> >> > Peschmä
>> >> >> Hash: SHA1
>> >> >> | But in my case a
>> >> >> | where the table was to be grayed (like a composite with nothin
>> >> >> | in it) instead
>> > of
>> >> >> and
>> > I
> to
>> >> >> hide
>> > the
>> >> >> and
>> > use
> the
>> >> >> parent after that).
>> >> >> (app in question has been in production for a while). - -- Emir
>> >> >> Alikadic Software Developer
>> >> >> SIGNATURE----- Version: GnuPG v1.2.1 (MingW32) Comment: Using
>> >> >> =GFzL
Re: Hiding Table [message #375311 is a reply to message #375303] Thu, 09 October 2003 09:45 Go to previous messageGo to next message
Not implemented on Motif or Mac.
news:pan.2003.10.09.08.13.22.668475@gmx.ch...
> On which ones not?
> worked.
> Peschm
Re: Hiding Table [message #375341 is a reply to message #375311] Fri, 10 October 2003 03:29 Go to previous message
oops, you're right there. Well, I'll have to rethink this.
Peschmä
Am Thu, 09 Oct 2003 09:45:56 -0400 schrieb Steve Northover:
>> On which ones not?
>> worked.
>> Peschmä
>> >> It works now.
>> >> about as they are.
>> >> moving the Table to an invisible Shell is easier.
>> >> It looks like this:
>> >> State 1: State2:
>> >> Other Controls
>> >> Peschmä
>> >> > be to use FormLayout and change the attachments. Can you post a
>> >> > more complete example, showing the effect that you are after? You
>> >> > mention that you
>> > want
> the
>> >> > grid? Thanks.
>> >> >> Hi,
>> >> >> for
>> > the
>> >> >> it sounds to me as if I was ordering the controls' position in
>> >> >> z-axis direction...
>> >> >> private Button b;
>> >> >> Sample() {
>> >> >> shell.pack(true);
>> >> >> b.moveBelow(b1);
>> >> >> shell.pack(true);
>> >> >> shell.pack();
>> >> >> shell.open();
>> >> >> [/snipp]
>> >> >> Peschmä
>> >> >> > Thanks
>> >> >> > Thanks a lot
>> >> >> > Peschmä
>> >> >> >> Hash: SHA1
>> >> >> >> | But in my case a
>> >> > of
> Composite
>> >> >> >> and
>> >> > I
>> >> >> >> dummy Shell which is never displayed which I set as a parent
>> >> >> >> when I
> want
>> > to
>> >> >> >> hide
>> >> > the
>> >> >> >> original and
>> >> > use
>> >> >> >> on
>> > the
>> >> >> >> parent after that).
>> >> >> >> PGP SIGNATURE----- Version: GnuPG v1.2.1 (MingW32) Comment:
>> >> >> >> =GFzL
Previous Topic:Access Windows Registry?
Next Topic:integration with outlook
Current Time: Fri Sep 26 02:44:23 EDT 2025
Powered by FUDForum. Page generated in 0.08165 seconds
