[JAX-WS] Java first artifacts no longer being generated [message #375067] |
Thu, 19 March 2009 00:52  |
I had been running successfully with JAX-WS for a few weeks using Ganymede
SR1 with the latest STP code from the Ganymede update site. It generated the
artifacts for my web services when I run my code in the debugger and worked
correctly all the time. After a few days of work on code not related to web
services I did a system regression test and found it stopped generating the
artifacts and the services can't start. I have not added/removed anything
from eclipse. I did integrate Teneo support to persist my EMF models in the
same project with these web services. I am using Spring to load my JAX-WS
web services.
Any suggestions on what I should look at? Unfortunately, I am not
knowledgable about what triggers the JAX-WS and where to look.
Thanks in advance!
Derek
FUDForum. Page generated in 0.05190 seconds
