Home » Eclipse Projects » Mylyn » Error updating attributes - new Mylyn installation, new query
Error updating attributes - new Mylyn installation, new query [message #37481] Tue, 27 November 2007 12:43 Go to next message
I just created a new installation of eclipse 3.3.1.1 (Europa fall
release) and got Mylyn from the update manager, Europa discovery site.
I started reading the online tutorial at
http://www.ibm.com/developerworks/java/library/j-mylyn1/inde x.html
but got stuck editing a repository query for Eclipse.org's bugzilla.
I make a new query, create query using form, and I get:
Update Failed, Error updating attributes.
The element type "input" must be terminated by the matching end-tag
"</input>".
I get the same error if I click the "Update Attributes from Repository"
button.
I looked around and it sounds like a known error that was resolved
over a month ago, and no reports of similar new-user errors since then.
What did I do wrong?
Thanks.
....Beth
Re: Error updating attributes - new Mylyn installation, new query [message #37516 is a reply to message #37481] Tue, 27 November 2007 13:53 Go to previous messageGo to next message
Well, for some strange reason, this suddenly started getting Mylyn info
popups and things are working.
I have no idea what happened.
....Beth
Re: Error updating attributes - new Mylyn installation, new query [message #37608 is a reply to message #37516] Wed, 28 November 2007 20:45 Go to previous messageGo to next message
Originally posted by: beatmik.acm.org
Hi Beth,
Due to server load, the bugs.eclipse.org "Attributes" configuration is
mirrored across servers. It looks like you got a partly-mirrored copy.
We have worked with the Eclipse webmaster to ensure that the chances
of this happening are minimized, so if you or anyone else ever sees this
again please file a bug.
Rob: if this gets reported again we should consider retrying the
attribute update.
Mik
> ...Beth
Re: Error updating attributes - new Mylyn installation, new query [message #37634 is a reply to message #37516] Thu, 29 November 2007 14:36 Go to previous message
Maybe bug 206739: Bugzilla caching and redirecting config.cgi results in
stale caches
https://bugs.eclipse.org/bugs/show_bug.cgi?id=206739
is back on due to stale mirrors
Re: Error updating attributes - new Mylyn installation, new query [message #585250 is a reply to message #37481] Tue, 27 November 2007 13:53 Go to previous message
....Beth
Re: Error updating attributes - new Mylyn installation, new query [message #585321 is a reply to message #37516] Wed, 28 November 2007 20:45 Go to previous message
Hi Beth,
attribute update.
Mik
> ...Beth
Re: Error updating attributes - new Mylyn installation, new query [message #585329 is a reply to message #37516] Thu, 29 November 2007 14:36 Go to previous message
stale caches
Previous Topic:Mylyn not able to update bugzilla.
Next Topic:Mylyn Webinar
Current Time: Sat Jul 19 00:53:54 EDT 2025
Powered by FUDForum. Page generated in 0.04535 seconds
