Home » Archived » Service Oriented Architecture Tools Platform (STP) » BPMN editor display
BPMN editor display [message #374570] |
Wed, 20 February 2008 08:49  |
Originally posted by: philip.kisloff.astrazeneca.com
Very new to eclipse, but thought I would try BPMN modelling plugin from
here
http://wiki.eclipse.org/Eclipse_con_2007_STP_BPMN_Tutorial_% 28Setup%29.
Having a lot a trouble viewing any objects. Eclipse starts up, and can
create a BPMN project, but any BPMN elements in the pool (e.g the initial
task shape) disappear. I can only see them when I click on the down arrow
in the top left corner of the pool - sorry don't know what the icon is
called) and it disappears immediately afterwards.
So I'm stuggling to create *anything*, and I figure something's wrong with
my set up.
I've installed eclipse-SDK-3.2.1-linux with JDK 1.6.0_04, and it's running
under opensuse 10.2 kernal 2.6.18.8-0.7.
The build id is M20060921-0945 and the BPMN plug-in versions are 1.0.0.061.
Any ideas, anyone ?
Phil
Re: BPMN editor display [message #374571 is a reply to message #374570] |
Wed, 20 February 2008 09:44   |
Originally posted by: atoulme.intalio.com
Philip,
you are using an old version of BPMN with an even older version of Eclipse.
Can you try gabbing the latest build of Eclipse (you can settle for the
runtime platform if you want to go light[0]) ?
Once you have a stable Eclipse, try getting BPMN through the STP update
site.
To do that, go to Help>Software Updates>Find and Install...
Create a new remote update site with the URL[1], then install BPMN by
selecting it in the dialog.
Hopefully that should run better.
Antoine
[0] :http://download.eclipse.org/eclipse/downloads/drops/R-3.3.1 .1-200710231652/download.php?dropFile=eclipse-platform-3.3.1 .1-linux-gtk.tar.gz
[1]:http://download.eclipse.org/stp/updates/site.xml
Philip Kisloff wrote:
> Hi
> here
> initial task shape) disappear. I can only see them when I click on the
> down arrow in the top left corner of the pool - sorry don't know what
> the icon is called) and it disappears immediately afterwards.
> with my set up.
> running under opensuse 10.2 kernal 2.6.18.8-0.7.
> Any ideas, anyone ?
> Thanks
> Phil
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website</a>
Re: BPMN editor display [message #374576 is a reply to message #374574] |
Thu, 21 February 2008 05:42   |
Philip, the all-in-one bundle doesn't contain the GMF, GEF and EMF
dependencies that you need.
To get the BPMN modeler and all its dependencies, you should use the
Ganymede update site.
So please take a pristine Eclipse platform, and use this remote update site:
http://www.eclipse.org/downloads/download.php?file=/releases /ganymede/site.xml&format=xml&protocol=http
You will have to select a mirror. Then you can see a list of all the
features that have been delivered for 3.4M5.
Go and select the BPMN modeler in the SOA Tools category. That should
raise errors regarding its dependencies. Don't panic, just click on
Select Required to get them all. If that doesn't work, expand the tree
(that's a known bug that the update committers will just not work on),
then click on Select Required again.
You should be able to install the whole thing that way. Apologies for
not giving the right directions the first time.
Antoine
> Hi Antoine
> I'm having great difficulties installing this. I found there was a lot
> of other plugins required, and so found myself in dependency hell. I
> then found
> http://download.eclipse.org/stp/downloads/drops/S-S200801091 442-200801091442/
> and downloaded
> stp-all-in-one-incubation-S-S200801091442-200801091442.zip, which
> helped a lot.
> Now when I run with eclipse-platform-3.4M4-linux-gtk i get a stack
> overflow error calling the BPMN diagram see below.
> I also tried the latest eclipse, but no BPMN example wizard was
> available. Which is latest stable release with an associated all-in-one
> zip file? The pages I see point to RCs and have dead links.
> thanks in advance
> Phil
> !SESSION 2008-02-20 22:40:03.274
> eclipse.buildId=I20071213-1700
> java.version=1.5.0_14
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_GB
> Command-line arguments: -os linux -ws gtk -arch x86
> !ENTRY org.eclipse.update.configurator 2008-02-20 22:40:08.669
> !MESSAGE Could not install bundle
> plugins/net.sourceforge.lpg.lpgjavaruntime.source_1.1.0.v200 711021030.jar
> Bundle "net.sourceforge.lpg.lpgjavaruntime.source" version
> "1.1.0.v200711021030" has already been installed from:
> update@plugins /net.sourceforge.lpg.lpgjavaruntime.source_1.1.0.v2007110210 30/
> !ENTRY org.eclipse.ui 4 0 2008-02-20 22:43:11.428
> !MESSAGE Unhandled event loop exception
> !STACK 0
> java.lang.StackOverflowError
Re: BPMN editor display [message #374581 is a reply to message #374578] |
Sat, 23 February 2008 13:27   |
Philip,
I'm getting wary of seeing so many people having trouble to get STP up
and running.
I have packaged an Eclipse install, with GMF, EMF, GEF, the platform and
STP BPMN, and made it available here:
http://www.intalio.org/public/distribs/
Please feel free to grab it and play with it.
Someone else experienced the same StackOverflowError, and filed a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=219974
Apparently GMF now initiates the TextCompartmentEditPart differently,
and our old code doesn't comply. I'll investigate next week.
Antoine
> Thanks Antoine,
> I tried another way before reading your reply, and have been up and
> running with STP for a few days now (there's a lot to be said for brute
> force and ignorance).
> I downloaded both eclipse-platform-3.3.1.1-linux-gtk.tar.gz and "STP
> 0.7.0.200711162004 All In One". This may not be optimum in terms of
> functionality, but at least it works for me "out of the box".
> My background is SAP workflow, and this vendor is planning to move to a
> BPMN code -generating approach, so I was very keen to become familiar
> with BPMN, in an end-user capacity. I must say you guys have created an
> awesome product here.
> I've got a lot learn about eclipse, though.
> Many thanks
> Phil
Re: BPMN editor display [message #374618 is a reply to message #374576] |
Sun, 16 March 2008 21:32   |
Hi Antoine,
I have been using the BPMN both as user and developer for several months,
and have always liked to be up-to-date with the latest improvements in
each milestone. I know how to get a good stp-bpmn running, but I want to
see what's new in 3.4M5. However, at this time i'm having trouble, getting
the following error when creating or opening a model:
at
org.eclipse.gmf.runtime.diagram.ui.editparts.TextCompartment EditPart.getFigure(TextCompartmentEditPart.java:175)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.TextCompartment EditPart.getLabel(TextCompartmentEditPart.java:235)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.TextCompartment EditPart.createLabelDelegate(TextCompartmentEditPart.java:15 5)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.TextCompartment EditPart.getFigure(TextCompartmentEditPart.java:176)
at
at
The steps to reproduce are the following:
1. Get a pristine Eclipse 3.4M5 install.
2. Go to update sites, select Ganymede Discovery Site > STP > BPMN.
3. Click 'select required' to clear all dependency errors, click finnish.
4. Wait for everything to download and install.
5. Restart Eclipse.
6. Create a new BPMN diagram.
7. Boom!
Like I said, I know how to get your plugin working on another version,
Europa for instance, but I haven't been able to do so in Ganymede for this
reason. I'd dare to say it's something related to the new releases of EMF
or GMF, but I wouldn't be sure about how to fix it :(
Thanks a lot for your attention!
-Juan
Re: BPMN editor display [message #611061 is a reply to message #374570] |
Philip,
site.
Antoine
> Hi
> here
> with my set up.
> Any ideas, anyone ?
> Thanks
> Phil
Re: BPMN editor display [message #611064 is a reply to message #374572] |
Wed, 20 February 2008 18:03  |
Hi Antoine
I'm having great difficulties installing this. I found there was a lot of
other plugins required, and so found myself in dependency hell. I then
found
and downloaded
stp-all-in-one-incubation-S-S200801091442-200801091442.zip, which helped
a lot.
I also tried the latest eclipse, but no BPMN example wizard was available.
Which is latest stable release with an associated all-in-one zip file? The
thanks in advance
Phil
!STACK 0
Re: BPMN editor display [message #611066 is a reply to message #374574] |
Antoine
> Hi Antoine
> then found
> and downloaded
> helped a lot.
> thanks in advance
> Phil
> !STACK 0
Re: BPMN editor display [message #611068 is a reply to message #374576] |
Sat, 23 February 2008 12:47  |
Originally posted by: pkisloff.tiscali.co.uk
Thanks Antoine,
Many thanks
Phil
Re: BPMN editor display [message #611069 is a reply to message #374576] |
Sat, 23 February 2008 12:48  |
Originally posted by: philp.kisloff.astrazeneca.com
Thanks Antoine,
Many thanks
Phil
Re: BPMN editor display [message #611070 is a reply to message #374576] |
Sat, 23 February 2008 12:49  |
Thanks Antoine,
Many thanks
Phil
Re: BPMN editor display [message #611071 is a reply to message #374578] |
Philip,
and running.
Antoine
> Thanks Antoine,
> Many thanks
> Phil
Re: BPMN editor display [message #613853 is a reply to message #374576] |
Originally posted by: juanjosecg.gmail.com
Hi Antoine,
at
at
at
at
at
at
5. Restart Eclipse.
7. Boom!
-Juan
Re: BPMN editor display [message #613854 is a reply to message #374618] |
Sun, 16 March 2008 21:36  |
Oops, I'm so sorry, I didn't see at first that you are already aware of
this bug and are looking into it. Never meant to be pushy - hehe!
-Juan
Current Time: Mon Jul 21 05:11:58 EDT 2025
Powered by FUDForum. Page generated in 0.07889 seconds
