Home » Archived » Service Oriented Architecture Tools Platform (STP) » B2J execution fails
B2J execution fails [message #374112] Wed, 04 July 2007 04:55 Go to next message
Hi all,
I am trying to run the example B2J from the beginners tutorial with the
last Europa release. When executing, I get the following error message:
An internal error occurred during: "Launching B2J_Test".
Lbpel_3_1183539276983/xmlns/http___www_eclipse_org_stp_b2j_2 006_02/_Address;
And in the error log is this stack trace:
java.lang.NoClassDefFoundError:
Lbpel_2_1183539076745/xmlns/http___www_eclipse_org_stp_b2j_2 006_02/_Address;
at java.lang.Class.getDeclaredFields0(Native Method)
at java.lang.Class.privateGetDeclaredFields(Class.java:2232)
at java.lang.Class.getDeclaredField(Class.java:1852)
at
org.eclipse.stp.b2j.core.jengine.internal.miniengine.MiniCon troller.launchRunner(MiniController.java:368)
at
org.eclipse.stp.b2j.core.jengine.internal.miniengine.MiniCon troller.launchRunner(MiniController.java:345)
at
org.eclipse.stp.b2j.core.publicapi.engine.WorkbenchBPELEngin e.runInternal(WorkbenchBPELEngine.java:509)
at
org.eclipse.stp.b2j.core.publicapi.engine.WorkbenchBPELEngin e.runProgram(WorkbenchBPELEngine.java:139)
at
org.eclipse.stp.b2j.core.publicapi.engine.WorkbenchBPELEngin e.runProgram(WorkbenchBPELEngine.java:125)
at
org.eclipse.stp.b2j.ui.internal.launchconfig.LaunchConfigDel egate.launch(LaunchConfigDelegate.java:304)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
Any ideas?
Krassimir
Re: B2J execution fails [message #374221 is a reply to message #374112] Tue, 04 September 2007 09:11 Go to previous messageGo to next message
Originally posted by: steenbrahe.gmail.com
I get the exact same failure as Krassimir when I follow the B2J tutorial
and executes the example bpel file. The concole output that is written
before the error dialog appears can be seen below.
I am using the Eclipse 3.3 Europa distribution.
Do anyone have a solution to the problem - it will be highly appriciated:o)
Cheers
Steen
CONSOLE OUTPUT:
BPEL File: test_general.bpel
Generating engine program...
XSD Translator: ignored element [complexType]
Java Binding: : WSIF Java Binding return type required but no return
type specified
type specified
XSDTranslator: UNIMPLEMENTED: unable to map top level elements to types
(null)
XSDTranslator: making direct alias from
http://www.eclipse.org/stp/b2j/2006/02:Address to
Generated engine program (3sec)
Connecting to engine daemon...
Connecting to in-jvm mini engine daemon
Connected to engine daemon (0sec)
Creating engine instance...
Created engine instance (0sec)
Setting engine program...
Set engine program (0sec)
Turning on only warning and error logging
Total launch time 3sec
Launching engine program
Re: B2J execution fails [message #374326 is a reply to message #374221] Wed, 24 October 2007 08:13 Go to previous message
Originally posted by: antony.scapatech.com
Bug 207289 reported in Bugzilla to address this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=207289
A fix has been checked into CVS HEAD and the B2J in-jvm engine should
again be able to run the same sample files as the distributed engine.
It is worth mentioning though that some of the sample files are out of
date and do not work - such as the test_messaging.bpel sample file.
I have reported a new bug (207291) for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=207291
thanks
Antony
Georgiew, Emanuel wrote:
> Hi!
> Try selecting the distributed execution environment instead of the
> localhost option, when configuring the "Run As" dialogue ... There
> should be an entry for the localhost machine too. This worked for me for
> most of the examples.
> Kind regards,
> Emanuel
> On Tue, 04 Sep 2007 15:11:23 +0200, Steen Brahe <steenbrahe@gmail.com>
> wrote:
>> Hi,
>> tutorial and executes the example bpel file. The concole output that
>> is written before the error dialog appears can be seen below.
>> appriciated:o)
>> Cheers
>> Steen
>> CONSOLE OUTPUT:
>> type specified
>> type specified
>> types (null)
Re: B2J execution fails [message #593028 is a reply to message #374112] Tue, 04 September 2007 09:11 Go to previous message
Cheers
Steen
CONSOLE OUTPUT:
type specified
type specified
(null)
Re: B2J execution fails [message #594041 is a reply to message #374221] Wed, 03 October 2007 13:24 Go to previous message
Originally posted by: georgiew.emanuel.alice-dsl.net
Hi!
localhost option, when configuring the "Run As" dialogue ... There should
be an entry for the localhost machine too. This worked for me for most of
the examples.
Kind regards,
Emanuel
wrote:
> appriciated:o)
> Cheers
> Steen
> CONSOLE OUTPUT:
> type specified
> type specified
> (null)
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: B2J execution fails [message #601179 is a reply to message #594041] Wed, 24 October 2007 08:13 Go to previous message
thanks
Antony
> Hi!
> Kind regards,
> Emanuel
> wrote:
>> Hi,
>> appriciated:o)
>> Cheers
>> Steen
>> CONSOLE OUTPUT:
>> type specified
>> type specified
>> types (null)
Previous Topic:BPM Specification metamodels
Next Topic:B2J generated files do not compile
Current Time: Fri Jul 25 22:52:01 EDT 2025
Powered by FUDForum. Page generated in 0.06556 seconds
