Home » Archived » Service Oriented Architecture Tools Platform (STP) » JAX-WS RI 2.1.2 Create WSDL Error
JAX-WS RI 2.1.2 Create WSDL Error [message #374318] |
Fri, 12 October 2007 11:38  |
When creating a SOA Java First project, I select the JAX-WS RI runtime but
when the interface is saved the wsdl folder is created but no wsdl file is
created. There is no information in the log file either.
Re: [stp-newsgroup] Re: JAX-WS RI 2.1.2 Create WSDL Error [message #374516 is a reply to message #374515] |
Fri, 01 February 2008 04:23  |
------=_Part_22841_32671251.1201857815982
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Can you paste those java classes here.
IMHO, it may caused by some complex java types you are trying to use.
Johnson
On Jan 31, 2008 8:33 PM, Marcelo T. de Melo <marcelotmelo@gmail.com> wrote:
> Well, I am using Java 1.5 (that's what it says on my configuration
> details: java.version=1.5.0_13), and I also can not generate the wsdl file
> for my project. I also tried to use the cxf provided java2wdl command line
> tool, with no success. Weird is, there's nothing on my .log file, and no
> error messages are displayed. When I try to run the java2wdsl tool it
> says: JavaToWSDL Error : Fail to load class. I'm lost here... I've tried
> to google for the java2wsdl error, with no answers, and the CXF website
> doesn't help much, either.
> _______________________________________________
> stp-newsgroup mailing list
> stp-newsgroup@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/stp-newsgroup
Content-Type: text/html; charset=ISO-8859-1
Hi,<br><br>Can you paste those java classes here.<br><br>IMHO, it may caused by some complex java types you are trying to use. <br><br><br>Regards<br><br>Johnson<br><br><br><div class="gmail_quote">On Jan 31, 2008 8:33 PM, Marcelo T. de Melo <<a href="mailto:marcelotmelo@gmail.com">marcelotmelo@gmail.com</a>> wrote:<br>
<blockquote class="gmail_quote" style="border-left: 1px solid rgb(204, 204, 204); margin: 0pt 0pt 0pt 0.8ex; padding-left: 1ex;">Well, I am using Java 1.5 (that's what it says on my configuration<br>details: java.version=1.5.0_13), and I also can not generate the wsdl file<br>
for my project. I also tried to use the cxf provided java2wdl command line<br>tool, with no success. Weird is, there's nothing on my .log file, and no<br>error messages are displayed. When I try to run the java2wdsl tool it<br>
says: JavaToWSDL Error : Fail to load class. I'm lost here... I've tried<br>to google for the java2wsdl error, with no answers, and the CXF website<br>doesn't help much, either.<br><br><br>_______________________________________________ <br>
stp-newsgroup mailing list<br><a href="mailto:stp-newsgroup@eclipse.org">stp-newsgroup@eclipse.org</a><br><a href="https://dev.eclipse.org/mailman/listinfo/stp-newsgroup" target="_blank">https://dev.eclipse.org/mailman/listinfo/stp-newsgroup</a><br>
</blockquote></div><br>
------=_Part_22841_32671251.1201857815982--
Re: JAX-WS RI 2.1.2 Create WSDL Error [message #601158 is a reply to message #374318] |
Tue, 23 October 2007 08:51  |
--------------090200080008040200080109
> but when the interface is saved the wsdl folder is created but no wsdl
> file is created. There is no information in the log file either.
I have the same problem with
Eclipse 3.3 SDK I20070625-1500
stp-all-in-one-incubation-R-R200710161054-200710161054.zip
I have only installed this two packages, nothing else.
Until now I never got the SOA tools running until now. I tried it
several times according to some threads in this newsgroup.
I attached the errorlog
Mark
name="log"
Content-Disposition: inline;
filename="log"
IVNFU1NJT04gMjAwNy0xMC0yMiAxNzo0MDoxOS45MjEgLS0tLS0tLS0tLS0t LS0tLS0tLS0t
LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0NCmVjbGlwc2UuYnVpbGRJZD1N MjAwNzA5MjEt
MTE0NQ0KamF2YS52ZXJzaW9uPTEuNi4wXzAyDQpqYXZhLnZlbmRvcj1TdW4g TWljcm9zeXN0
ZW1zIEluYy4NCkJvb3RMb2FkZXIgY29uc3RhbnRzOiBPUz13aW4zMiwgQVJD SD14ODYsIFdT
PXdpbjMyLCBOTD1kZV9ERQ0KQ29tbWFuZC1saW5lIGFyZ3VtZW50czogIC1v cyB3aW4zMiAt
d3Mgd2luMzIgLWFyY2ggeDg2DQoNCiFFTlRSWSBvcmcuZWNsaXBzZS5vc2dp IDQgMCAyMDA3
LTEwLTIyIDE3OjQ5OjE4LjAzMQ0KIU1FU1NBR0UgQW4gZXJyb3Igb2NjdXJy ZWQgd2hpbGUg
YXV0b21hdGljYWxseSBhY3RpdmF0aW5nIGJ1bmRsZSBvcmcuZWNsaXBzZS5z dHAuYnBtbi52
YWxpZGF0aW9uICg0NDQpLg0KIVNUQUNLIDANCm9yZy5vc2dpLmZyYW1ld29y ay5CdW5kbGVF
eGNlcHRpb246IFRoZSBhY3RpdmF0b3Igb3JnLmVjbGlwc2Uuc3RwLmJwbW4u dmFsaWRhdGlv
bi5CcG1uVmFsaWRhdGlvblBsdWdpbiBmb3IgYnVuZGxlIG9yZy5lY2xpcHNl LnN0cC5icG1u
LnZhbGlkYXRpb24gaXMgaW52YWxpZA0KCWF0IG9yZy5lY2xpcHNlLm9zZ2ku ZnJhbWV3b3Jr
LmludGVybmFsLmNvcmUuQWJzdHJhY3RCdW5kbGUubG9hZEJ1bmRsZUFjdGl2 YXRvcihBYnN0
cmFjdEJ1bmRsZS5qYXZhOjE0MSkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZy YW1ld29yay5p
bnRlcm5hbC5jb3JlLkJ1bmRsZUNvbnRleHRJbXBsLnN0YXJ0KEJ1bmRsZUNv bnRleHRJbXBs
LmphdmE6OTcwKQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmlu dGVybmFsLmNv
cmUuQnVuZGxlSG9zdC5zdGFydFdvcmtlcihCdW5kbGVIb3N0LmphdmE6MzQ2 KQ0KCWF0IG9y
Zy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQWJzdHJh Y3RCdW5kbGUu
c3RhcnQoQWJzdHJhY3RCdW5kbGUuamF2YToyNjApDQoJYXQgb3JnLmVjbGlw c2Uub3NnaS5m
cmFtZXdvcmsudXRpbC5TZWN1cmVBY3Rpb24uc3RhcnQoU2VjdXJlQWN0aW9u LmphdmE6NDAw
KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUucnVudGltZS5pbnRlcm5hbC5hZGFw dG9yLkVjbGlw
c2VMYXp5U3RhcnRlci5wb3N0RmluZExvY2FsQ2xhc3MoRWNsaXBzZUxhenlT dGFydGVyLmph
dmE6MTExKQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuYmFzZWFkYXB0b3IubG9h ZGVyLkNsYXNz
cGF0aE1hbmFnZXIuZmluZExvY2FsQ2xhc3MoQ2xhc3NwYXRoTWFuYWdlci5q YXZhOjQxNykN
CglhdCBvcmcuZWNsaXBzZS5vc2dpLmludGVybmFsLmJhc2VhZGFwdG9yLkRl ZmF1bHRDbGFz
c0xvYWRlci5maW5kTG9jYWxDbGFzcyhEZWZhdWx0Q2xhc3NMb2FkZXIuamF2 YToxODkpDQoJ
YXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5C dW5kbGVMb2Fk
ZXIuZmluZExvY2FsQ2xhc3MoQnVuZGxlTG9hZGVyLmphdmE6MzQwKQ0KCWF0 IG9yZy5lY2xp
cHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVuZGxlTG9hZGVy LmZpbmRDbGFz
c0ludGVybmFsKEJ1bmRsZUxvYWRlci5qYXZhOjQwOCkNCglhdCBvcmcuZWNs aXBzZS5vc2dp
LmZyYW1ld29yay5pbnRlcm5hbC5jb3JlLkJ1bmRsZUxvYWRlci5maW5kQ2xh c3MoQnVuZGxl
TG9hZGVyLmphdmE6MzY5KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3 b3JrLmludGVy
bmFsLmNvcmUuQnVuZGxlTG9hZGVyLmZpbmRDbGFzcyhCdW5kbGVMb2FkZXIu amF2YTozNTcp
DQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5pbnRlcm5hbC5iYXNlYWRhcHRvci5E ZWZhdWx0Q2xh
c3NMb2FkZXIubG9hZENsYXNzKERlZmF1bHRDbGFzc0xvYWRlci5qYXZhOjgz KQ0KCWF0IGph
dmEubGFuZy5DbGFzc0xvYWRlci5sb2FkQ2xhc3MoVW5rbm93biBTb3VyY2Up DQoJYXQgb3Jn
LmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVM b2FkZXIubG9h
ZENsYXNzKEJ1bmRsZUxvYWRlci5qYXZhOjI4OSkNCglhdCBvcmcuZWNsaXBz ZS5vc2dpLmZy
YW1ld29yay5pbnRlcm5hbC5jb3JlLkJ1bmRsZUhvc3QubG9hZENsYXNzKEJ1 bmRsZUhvc3Qu
amF2YToyMjcpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50 ZXJuYWwuY29y
ZS5BYnN0cmFjdEJ1bmRsZS5sb2FkQ2xhc3MoQWJzdHJhY3RCdW5kbGUuamF2 YToxMjY5KQ0K
CWF0IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwucmVnaXN0cnkub3NnaS5S ZWdpc3RyeVN0
cmF0ZWd5T1NHSS5jcmVhdGVFeGVjdXRhYmxlRXh0ZW5zaW9uKFJlZ2lzdHJ5 U3RyYXRlZ3lP
U0dJLmphdmE6MTYwKQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwu cmVnaXN0cnku
RXh0ZW5zaW9uUmVnaXN0cnkuY3JlYXRlRXhlY3V0YWJsZUV4dGVuc2lvbihF eHRlbnNpb25S
ZWdpc3RyeS5qYXZhOjc4OCkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLmludGVy bmFsLnJlZ2lz
dHJ5LkNvbmZpZ3VyYXRpb25FbGVtZW50LmNyZWF0ZUV4ZWN1dGFibGVFeHRl bnNpb24oQ29u
ZmlndXJhdGlvbkVsZW1lbnQuamF2YToyNDMpDQoJYXQgb3JnLmVjbGlwc2Uu Y29yZS5pbnRl
cm5hbC5yZWdpc3RyeS5Db25maWd1cmF0aW9uRWxlbWVudEhhbmRsZS5jcmVh dGVFeGVjdXRh
YmxlRXh0ZW5zaW9uKENvbmZpZ3VyYXRpb25FbGVtZW50SGFuZGxlLmphdmE6 NTEpDQoJYXQg
b3JnLmVjbGlwc2UuZW1mLnZhbGlkYXRpb24uaW50ZXJuYWwuc2VydmljZS5D bGllbnRDb250
ZXh0LmluaXRpYWxpemVDdXN0b21TZWxlY3RvcihDbGllbnRDb250ZXh0Lmph dmE6MTg2KQ0K
CWF0IG9yZy5lY2xpcHNlLmVtZi52YWxpZGF0aW9uLmludGVybmFsLnNlcnZp Y2UuQ2xpZW50
Q29udGV4dC5pbml0aWFsaXplU2VsZWN0b3IoQ2xpZW50Q29udGV4dC5qYXZh OjEyMikNCglh
dCBvcmcuZWNsaXBzZS5lbWYudmFsaWRhdGlvbi5pbnRlcm5hbC5zZXJ2aWNl LkNsaWVudENv
bnRleHQuPGluaXQ+KENsaWVudENvbnRleHQuamF2YTo3MikNCglhdCBvcmcu ZWNsaXBzZS5l
bWYudmFsaWRhdGlvbi5pbnRlcm5hbC5zZXJ2aWNlLkNsaWVudENvbnRleHRN YW5hZ2VyLmNv
bmZpZ3VyZUNsaWVudENvbnRleHRzKENsaWVudENvbnRleHRNYW5hZ2VyLmph dmE6MzIxKQ0K
Q29udGV4dE1hbmFnZXIuY29uZmlndXJlQ29uc3RyYWludEJpbmRpbmdzKENs aWVudENvbnRl
eHRNYW5hZ2VyLmphdmE6MzA0KQ0KCWF0IG9yZy5lY2xpcHNlLmVtZi52YWxp ZGF0aW9uLmlu
dGVybmFsLkVNRk1vZGVsVmFsaWRhdGlvblBsdWdpbiRJbXBsZW1lbnRhdGlv bi5jb25maWd1
cmVDb25zdHJhaW50QmluZGluZ3MoRU1GTW9kZWxWYWxpZGF0aW9uUGx1Z2lu LmphdmE6MjU2
KQ0KCWF0IG9yZy5lY2xpcHNlLmVtZi52YWxpZGF0aW9uLmludGVybmFsLkVN Rk1vZGVsVmFs
aWRhdGlvblBsdWdpbiRJbXBsZW1lbnRhdGlvbi5zdGFydChFTUZNb2RlbFZh bGlkYXRpb25Q
bHVnaW4uamF2YToyMjkpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdv cmsuaW50ZXJu
YWwuY29yZS5CdW5kbGVDb250ZXh0SW1wbCQyLnJ1bihCdW5kbGVDb250ZXh0 SW1wbC5qYXZh
Ojk5OSkNCglhdCBqYXZhLnNlY3VyaXR5LkFjY2Vzc0NvbnRyb2xsZXIuZG9Q cml2aWxlZ2Vk
KE5hdGl2ZSBNZXRob2QpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdv cmsuaW50ZXJu
YWwuY29yZS5CdW5kbGVDb250ZXh0SW1wbC5zdGFydEFjdGl2YXRvcihCdW5k bGVDb250ZXh0
SW1wbC5qYXZhOjk5MykNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29y ay5pbnRlcm5h
bC5jb3JlLkJ1bmRsZUNvbnRleHRJbXBsLnN0YXJ0KEJ1bmRsZUNvbnRleHRJ bXBsLmphdmE6
OTc0KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFs LmNvcmUuQnVu
ZGxlSG9zdC5zdGFydFdvcmtlcihCdW5kbGVIb3N0LmphdmE6MzQ2KQ0KCWF0 IG9yZy5lY2xp
cHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQWJzdHJhY3RCdW5k bGUuc3RhcnQo
QWJzdHJhY3RCdW5kbGUuamF2YToyNjApDQoJYXQgb3JnLmVjbGlwc2UudXBk YXRlLmludGVy
bmFsLmNvbmZpZ3VyYXRvci5Db25maWd1cmF0aW9uQWN0aXZhdG9yLmluc3Rh bGxCdW5kbGVz
KENvbmZpZ3VyYXRpb25BY3RpdmF0b3IuamF2YToyMTgpDQoJYXQgb3JnLmVj bGlwc2UudXBk
YXRlLm9wZXJhdGlvbnMuT3BlcmF0aW9uc01hbmFnZXIuYXBwbHlDaGFuZ2Vz Tm93KE9wZXJh
dGlvbnNNYW5hZ2VyLmphdmE6MjQzKQ0KCWF0IG9yZy5lY2xpcHNlLnVwZGF0 ZS5pbnRlcm5h
bC51aS5SZXN0YXJ0RGlhbG9nLm9wZW5RdWVzdGlvbihSZXN0YXJ0RGlhbG9n LmphdmE6NjIp
DQoJYXQgb3JnLmVjbGlwc2UudXBkYXRlLmludGVybmFsLnVpLlVwZGF0ZVVJ LnJlcXVlc3RS
ZXN0YXJ0KFVwZGF0ZVVJLmphdmE6MjczKQ0KCWF0IG9yZy5lY2xpcHNlLnVw ZGF0ZS5pbnRl
cm5hbC51aS53aXphcmRzLkluc3RhbGxXaXphcmQyJDQucnVuKEluc3RhbGxX aXphcmQyLmph
dmE6Mzc2KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLlJ1bm5hYmxl TG9jay5ydW4o
UnVubmFibGVMb2NrLmphdmE6MzUpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0Lndp ZGdldHMuU3lu
Y2hyb25pemVyLnJ1bkFzeW5jTWVzc2FnZXMoU3luY2hyb25pemVyLmphdmE6 MTIzKQ0KCWF0
IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLkRpc3BsYXkucnVuQXN5bmNNZXNz YWdlcyhEaXNw
bGF5LmphdmE6MzY1OSkNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5E aXNwbGF5LnJl
YWRBbmREaXNwYXRjaChEaXNwbGF5LmphdmE6MzI5NikNCglhdCBvcmcuZWNs aXBzZS51aS5p
bnRlcm5hbC5Xb3JrYmVuY2gucnVuRXZlbnRMb29wKFdvcmtiZW5jaC5qYXZh OjIzODkpDQoJ
YXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2JlbmNoLnJ1blVJKFdv cmtiZW5jaC5q
YXZhOjIzNTMpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2Jl bmNoLmFjY2Vz
cyQ0KFdvcmtiZW5jaC5qYXZhOjIyMTkpDQoJYXQgb3JnLmVjbGlwc2UudWku aW50ZXJuYWwu
V29ya2JlbmNoJDQucnVuKFdvcmtiZW5jaC5qYXZhOjQ2NikNCglhdCBvcmcu ZWNsaXBzZS5j
b3JlLmRhdGFiaW5kaW5nLm9ic2VydmFibGUuUmVhbG0ucnVuV2l0aERlZmF1 bHQoUmVhbG0u
amF2YToyODkpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2Jl bmNoLmNyZWF0
ZUFuZFJ1bldvcmtiZW5jaChXb3JrYmVuY2guamF2YTo0NjEpDQoJYXQgb3Jn LmVjbGlwc2Uu
dWkuUGxhdGZvcm1VSS5jcmVhdGVBbmRSdW5Xb3JrYmVuY2goUGxhdGZvcm1V SS5qYXZhOjE0
OSkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5pZGUuYXBwbGljYXRp b24uSURFQXBw
bGljYXRpb24uc3RhcnQoSURFQXBwbGljYXRpb24uamF2YToxMDYpDQoJYXQg b3JnLmVjbGlw
c2UuZXF1aW5veC5pbnRlcm5hbC5hcHAuRWNsaXBzZUFwcEhhbmRsZS5ydW4o RWNsaXBzZUFw
cEhhbmRsZS5qYXZhOjE2OSkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRp bWUuaW50ZXJu
YWwuYWRhcHRvci5FY2xpcHNlQXBwTGF1bmNoZXIucnVuQXBwbGljYXRpb24o RWNsaXBzZUFw
cExhdW5jaGVyLmphdmE6MTA2KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUucnVu dGltZS5pbnRl
cm5hbC5hZGFwdG9yLkVjbGlwc2VBcHBMYXVuY2hlci5zdGFydChFY2xpcHNl QXBwTGF1bmNo
ZXIuamF2YTo3NikNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUuYWRh cHRvci5FY2xp
cHNlU3RhcnRlci5ydW4oRWNsaXBzZVN0YXJ0ZXIuamF2YTozNjMpDQoJYXQg b3JnLmVjbGlw
c2UuY29yZS5ydW50aW1lLmFkYXB0b3IuRWNsaXBzZVN0YXJ0ZXIucnVuKEVj bGlwc2VTdGFy
dGVyLmphdmE6MTc2KQ0KCWF0IHN1bi5yZWZsZWN0Lk5hdGl2ZU1ldGhvZEFj Y2Vzc29ySW1w
bC5pbnZva2UwKE5hdGl2ZSBNZXRob2QpDQoJYXQgc3VuLnJlZmxlY3QuTmF0 aXZlTWV0aG9k
QWNjZXNzb3JJbXBsLmludm9rZShVbmtub3duIFNvdXJjZSkNCglhdCBzdW4u cmVmbGVjdC5E
ZWxlZ2F0aW5nTWV0aG9kQWNjZXNzb3JJbXBsLmludm9rZShVbmtub3duIFNv dXJjZSkNCglh
dCBqYXZhLmxhbmcucmVmbGVjdC5NZXRob2QuaW52b2tlKFVua25vd24gU291 cmNlKQ0KCWF0
IG9yZy5lY2xpcHNlLmVxdWlub3gubGF1bmNoZXIuTWFpbi5pbnZva2VGcmFt ZXdvcmsoTWFp
bi5qYXZhOjUwOCkNCglhdCBvcmcuZWNsaXBzZS5lcXVpbm94LmxhdW5jaGVy Lk1haW4uYmFz
aWNSdW4oTWFpbi5qYXZhOjQ0NykNCglhdCBvcmcuZWNsaXBzZS5lcXVpbm94 LmxhdW5jaGVy
Lk1haW4ucnVuKE1haW4uamF2YToxMTczKQ0KQ2F1c2VkIGJ5OiBqYXZhLmxh bmcuRXJyb3I6
IFVucmVzb2x2ZWQgY29tcGlsYXRpb24gcHJvYmxlbXM6IAoJVGhlIHR5cGUg TWFwIGlzIG5v
dCBnZW5lcmljOyBpdCBjYW5ub3QgYmUgcGFyYW1ldGVyaXplZCB3aXRoIGFy Z3VtZW50cyA8
U3RyaW5nLCBJUmVzb3VyY2VJbXBvcnRlcnNSZWdpc3RyeT4KCUNBQ0hFIGNh bm5vdCBiZSBy
ZXNvbHZlZAoJVGhlIHR5cGUgTWFwIGlzIG5vdCBnZW5lcmljOyBpdCBjYW5u b3QgYmUgcGFy
YW1ldGVyaXplZCB3aXRoIGFyZ3VtZW50cyA8U3RyaW5nLCBJUmVzb3VyY2VJ bXBvcnRlcnNS
ZWdpc3RyeT4KCVRoZSB0eXBlIE1hcCBpcyBub3QgZ2VuZXJpYzsgaXQgY2Fu bm90IGJlIHBh
cmFtZXRlcml6ZWQgd2l0aCBhcmd1bWVudHMgPFN0cmluZywgSVJlc291cmNl SW1wb3J0ZXJz
UmVnaXN0cnk+CglDQUNIRSBjYW5ub3QgYmUgcmVzb2x2ZWQKCVRoZSB0eXBl IE1hcC5FbnRy
eSBpcyBub3QgZ2VuZXJpYzsgaXQgY2Fubm90IGJlIHBhcmFtZXRlcml6ZWQg d2l0aCBhcmd1
bWVudHMgPFN0cmluZywgSVJlc291cmNlSW1wb3J0ZXJzUmVnaXN0cnk+CglD QUNIRSBjYW5u
b3QgYmUgcmVzb2x2ZWQKCUNBQ0hFIGNhbm5vdCBiZSByZXNvbHZlZAoJVGhl IHR5cGUgTWFw
IGlzIG5vdCBnZW5lcmljOyBpdCBjYW5ub3QgYmUgcGFyYW1ldGVyaXplZCB3 aXRoIGFyZ3Vt
ZW50cyA8U3RyaW5nLCBJUmVzb3VyY2VJbXBvcnRlcnNSZWdpc3RyeT4KCUNB Q0hFIGNhbm5v
dCBiZSByZXNvbHZlZAoJVGhlIHR5cGUgSGFzaE1hcCBpcyBub3QgZ2VuZXJp YzsgaXQgY2Fu
bm90IGJlIHBhcmFtZXRlcml6ZWQgd2l0aCBhcmd1bWVudHMgPFN0cmluZywg SVJlc291cmNl
SW1wb3J0ZXJzUmVnaXN0cnk+CglDQUNIRSBjYW5ub3QgYmUgcmVzb2x2ZWQK DQoJYXQgb3Jn
LmVjbGlwc2Uuc3RwLmJwbW4udmFsaWRhdGlvbi5CcG1uVmFsaWRhdGlvblBs dWdpbi48aW5p
dD4oQnBtblZhbGlkYXRpb25QbHVnaW4uamF2YTo1MSkNCglhdCBzdW4ucmVm bGVjdC5OYXRp
dmVDb25zdHJ1Y3RvckFjY2Vzc29ySW1wbC5uZXdJbnN0YW5jZTAoTmF0aXZl IE1ldGhvZCkN
CglhdCBzdW4ucmVmbGVjdC5OYXRpdmVDb25zdHJ1Y3RvckFjY2Vzc29ySW1w bC5uZXdJbnN0
YW5jZShVbmtub3duIFNvdXJjZSkNCglhdCBzdW4ucmVmbGVjdC5EZWxlZ2F0 aW5nQ29uc3Ry
dWN0b3JBY2Nlc3NvckltcGwubmV3SW5zdGFuY2UoVW5rbm93biBTb3VyY2Up DQoJYXQgamF2
YS5sYW5nLnJlZmxlY3QuQ29uc3RydWN0b3IubmV3SW5zdGFuY2UoVW5rbm93 biBTb3VyY2Up
DQoJYXQgamF2YS5sYW5nLkNsYXNzLm5ld0luc3RhbmNlMChVbmtub3duIFNv dXJjZSkNCglh
dCBqYXZhLmxhbmcuQ2xhc3MubmV3SW5zdGFuY2UoVW5rbm93biBTb3VyY2Up DQoJYXQgb3Jn
LmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5BYnN0cmFj dEJ1bmRsZS5s
b2FkQnVuZGxlQWN0aXZhdG9yKEFic3RyYWN0QnVuZGxlLmphdmE6MTM2KQ0K CS4uLiA2MiBt
b3JlDQpSb290IGV4Y2VwdGlvbjoNCmphdmEubGFuZy5FcnJvcjogVW5yZXNv bHZlZCBjb21w
aWxhdGlvbiBwcm9ibGVtczogCglUaGUgdHlwZSBNYXAgaXMgbm90IGdlbmVy aWM7IGl0IGNh
bm5vdCBiZSBwYXJhbWV0ZXJpemVkIHdpdGggYXJndW1lbnRzIDxTdHJpbmcs IElSZXNvdXJj
ZUltcG9ydGVyc1JlZ2lzdHJ5PgoJQ0FDSEUgY2Fubm90IGJlIHJlc29sdmVk CglUaGUgdHlw
ZSBNYXAgaXMgbm90IGdlbmVyaWM7IGl0IGNhbm5vdCBiZSBwYXJhbWV0ZXJp emVkIHdpdGgg
YXJndW1lbnRzIDxTdHJpbmcsIElSZXNvdXJjZUltcG9ydGVyc1JlZ2lzdHJ5 PgoJVGhlIHR5
cGUgTWFwIGlzIG5vdCBnZW5lcmljOyBpdCBjYW5ub3QgYmUgcGFyYW1ldGVy aXplZCB3aXRo
IGFyZ3VtZW50cyA8U3RyaW5nLCBJUmVzb3VyY2VJbXBvcnRlcnNSZWdpc3Ry eT4KCUNBQ0hF
IGNhbm5vdCBiZSByZXNvbHZlZAoJVGhlIHR5cGUgTWFwLkVudHJ5IGlzIG5v dCBnZW5lcmlj
OyBpdCBjYW5ub3QgYmUgcGFyYW1ldGVyaXplZCB3aXRoIGFyZ3VtZW50cyA8 U3RyaW5nLCBJ
UmVzb3VyY2VJbXBvcnRlcnNSZWdpc3RyeT4KCUNBQ0hFIGNhbm5vdCBiZSBy ZXNvbHZlZAoJ
Q0FDSEUgY2Fubm90IGJlIHJlc29sdmVkCglUaGUgdHlwZSBNYXAgaXMgbm90 IGdlbmVyaWM7
IGl0IGNhbm5vdCBiZSBwYXJhbWV0ZXJpemVkIHdpdGggYXJndW1lbnRzIDxT dHJpbmcsIElS
ZXNvdXJjZUltcG9ydGVyc1JlZ2lzdHJ5PgoJQ0FDSEUgY2Fubm90IGJlIHJl c29sdmVkCglU
aGUgdHlwZSBIYXNoTWFwIGlzIG5vdCBnZW5lcmljOyBpdCBjYW5ub3QgYmUg cGFyYW1ldGVy
aXplZCB3aXRoIGFyZ3VtZW50cyA8U3RyaW5nLCBJUmVzb3VyY2VJbXBvcnRl cnNSZWdpc3Ry
eT4KCUNBQ0hFIGNhbm5vdCBiZSByZXNvbHZlZAoNCglhdCBvcmcuZWNsaXBz ZS5zdHAuYnBt
bi52YWxpZGF0aW9uLkJwbW5WYWxpZGF0aW9uUGx1Z2luLjxpbml0PihCcG1u VmFsaWRhdGlv
blBsdWdpbi5qYXZhOjUxKQ0KCWF0IHN1bi5yZWZsZWN0Lk5hdGl2ZUNvbnN0 cnVjdG9yQWNj
ZXNzb3JJbXBsLm5ld0luc3RhbmNlMChOYXRpdmUgTWV0aG9kKQ0KCWF0IHN1 bi5yZWZsZWN0
Lk5hdGl2ZUNvbnN0cnVjdG9yQWNjZXNzb3JJbXBsLm5ld0luc3RhbmNlKFVu a25vd24gU291
cmNlKQ0KCWF0IHN1bi5yZWZsZWN0LkRlbGVnYXRpbmdDb25zdHJ1Y3RvckFj Y2Vzc29ySW1w
bC5uZXdJbnN0YW5jZShVbmtub3duIFNvdXJjZSkNCglhdCBqYXZhLmxhbmcu cmVmbGVjdC5D
b25zdHJ1Y3Rvci5uZXdJbnN0YW5jZShVbmtub3duIFNvdXJjZSkNCglhdCBq YXZhLmxhbmcu
Q2xhc3MubmV3SW5zdGFuY2UwKFVua25vd24gU291cmNlKQ0KCWF0IGphdmEu bGFuZy5DbGFz
cy5uZXdJbnN0YW5jZShVbmtub3duIFNvdXJjZSkNCglhdCBvcmcuZWNsaXBz ZS5vc2dpLmZy
YW1ld29yay5pbnRlcm5hbC5jb3JlLkFic3RyYWN0QnVuZGxlLmxvYWRCdW5k bGVBY3RpdmF0
b3IoQWJzdHJhY3RCdW5kbGUuamF2YToxMzYpDQoJYXQgb3JnLmVjbGlwc2Uu b3NnaS5mcmFt
ZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVDb250ZXh0SW1wbC5zdGFydChC dW5kbGVDb250
ZXh0SW1wbC5qYXZhOjk3MCkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1l d29yay5pbnRl
cm5hbC5jb3JlLkJ1bmRsZUhvc3Quc3RhcnRXb3JrZXIoQnVuZGxlSG9zdC5q YXZhOjM0NikN
CglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5pbnRlcm5hbC5jb3Jl LkFic3RyYWN0
QnVuZGxlLnN0YXJ0KEFic3RyYWN0QnVuZGxlLmphdmE6MjYwKQ0KCWF0IG9y Zy5lY2xpcHNl
Lm9zZ2kuZnJhbWV3b3JrLnV0aWwuU2VjdXJlQWN0aW9uLnN0YXJ0KFNlY3Vy ZUFjdGlvbi5q
YXZhOjQwMCkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUuaW50ZXJu YWwuYWRhcHRv
ci5FY2xpcHNlTGF6eVN0YXJ0ZXIucG9zdEZpbmRMb2NhbENsYXNzKEVjbGlw c2VMYXp5U3Rh
cnRlci5qYXZhOjExMSkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmJhc2VhZGFw dG9yLmxvYWRl
ci5DbGFzc3BhdGhNYW5hZ2VyLmZpbmRMb2NhbENsYXNzKENsYXNzcGF0aE1h bmFnZXIuamF2
YTo0MTcpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5pbnRlcm5hbC5iYXNlYWRh cHRvci5EZWZh
dWx0Q2xhc3NMb2FkZXIuZmluZExvY2FsQ2xhc3MoRGVmYXVsdENsYXNzTG9h ZGVyLmphdmE6
MTg5KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFs LmNvcmUuQnVu
ZGxlTG9hZGVyLmZpbmRMb2NhbENsYXNzKEJ1bmRsZUxvYWRlci5qYXZhOjM0 MCkNCglhdCBv
cmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5pbnRlcm5hbC5jb3JlLkJ1bmRs ZUxvYWRlci5m
aW5kQ2xhc3NJbnRlcm5hbChCdW5kbGVMb2FkZXIuamF2YTo0MDgpDQoJYXQg b3JnLmVjbGlw
c2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVMb2FkZXIu ZmluZENsYXNz
KEJ1bmRsZUxvYWRlci5qYXZhOjM2OSkNCglhdCBvcmcuZWNsaXBzZS5vc2dp LmZyYW1ld29y
ay5pbnRlcm5hbC5jb3JlLkJ1bmRsZUxvYWRlci5maW5kQ2xhc3MoQnVuZGxl TG9hZGVyLmph
dmE6MzU3KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuaW50ZXJuYWwuYmFzZWFk YXB0b3IuRGVm
YXVsdENsYXNzTG9hZGVyLmxvYWRDbGFzcyhEZWZhdWx0Q2xhc3NMb2FkZXIu amF2YTo4MykN
CglhdCBqYXZhLmxhbmcuQ2xhc3NMb2FkZXIubG9hZENsYXNzKFVua25vd24g U291cmNlKQ0K
CWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUu QnVuZGxlTG9h
ZGVyLmxvYWRDbGFzcyhCdW5kbGVMb2FkZXIuamF2YToyODkpDQoJYXQgb3Jn LmVjbGlwc2Uu
b3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVIb3N0LmxvYWRD bGFzcyhCdW5k
bGVIb3N0LmphdmE6MjI3KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3 b3JrLmludGVy
bmFsLmNvcmUuQWJzdHJhY3RCdW5kbGUubG9hZENsYXNzKEFic3RyYWN0QnVu ZGxlLmphdmE6
MTI2OSkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFsLnJlZ2lzdHJ5 Lm9zZ2kuUmVn
aXN0cnlTdHJhdGVneU9TR0kuY3JlYXRlRXhlY3V0YWJsZUV4dGVuc2lvbihS ZWdpc3RyeVN0
cmF0ZWd5T1NHSS5qYXZhOjE2MCkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLmlu dGVybmFsLnJl
Z2lzdHJ5LkV4dGVuc2lvblJlZ2lzdHJ5LmNyZWF0ZUV4ZWN1dGFibGVFeHRl bnNpb24oRXh0
ZW5zaW9uUmVnaXN0cnkuamF2YTo3ODgpDQoJYXQgb3JnLmVjbGlwc2UuY29y ZS5pbnRlcm5h
bC5yZWdpc3RyeS5Db25maWd1cmF0aW9uRWxlbWVudC5jcmVhdGVFeGVjdXRh YmxlRXh0ZW5z
aW9uKENvbmZpZ3VyYXRpb25FbGVtZW50LmphdmE6MjQzKQ0KCWF0IG9yZy5l Y2xpcHNlLmNv
cmUuaW50ZXJuYWwucmVnaXN0cnkuQ29uZmlndXJhdGlvbkVsZW1lbnRIYW5k bGUuY3JlYXRl
RXhlY3V0YWJsZUV4dGVuc2lvbihDb25maWd1cmF0aW9uRWxlbWVudEhhbmRs ZS5qYXZhOjUx
KQ0KCWF0IG9yZy5lY2xpcHNlLmVtZi52YWxpZGF0aW9uLmludGVybmFsLnNl cnZpY2UuQ2xp
ZW50Q29udGV4dC5pbml0aWFsaXplQ3VzdG9tU2VsZWN0b3IoQ2xpZW50Q29u dGV4dC5qYXZh
OjE4NikNCglhdCBvcmcuZWNsaXBzZS5lbWYudmFsaWRhdGlvbi5pbnRlcm5h bC5zZXJ2aWNl
LkNsaWVudENvbnRleHQuaW5pdGlhbGl6ZVNlbGVjdG9yKENsaWVudENvbnRl eHQuamF2YTox
MjIpDQoJYXQgb3JnLmVjbGlwc2UuZW1mLnZhbGlkYXRpb24uaW50ZXJuYWwu c2VydmljZS5D
bGllbnRDb250ZXh0Ljxpbml0PihDbGllbnRDb250ZXh0LmphdmE6NzIpDQoJ YXQgb3JnLmVj
bGlwc2UuZW1mLnZhbGlkYXRpb24uaW50ZXJuYWwuc2VydmljZS5DbGllbnRD b250ZXh0TWFu
YWdlci5jb25maWd1cmVDbGllbnRDb250ZXh0cyhDbGllbnRDb250ZXh0TWFu YWdlci5qYXZh
OjMyMSkNCglhdCBvcmcuZWNsaXBzZS5lbWYudmFsaWRhdGlvbi5pbnRlcm5h bC5zZXJ2aWNl
LkNsaWVudENvbnRleHRNYW5hZ2VyLmNvbmZpZ3VyZUNvbnN0cmFpbnRCaW5k aW5ncyhDbGll
bnRDb250ZXh0TWFuYWdlci5qYXZhOjMwNCkNCglhdCBvcmcuZWNsaXBzZS5l bWYudmFsaWRh
dGlvbi5pbnRlcm5hbC5FTUZNb2RlbFZhbGlkYXRpb25QbHVnaW4kSW1wbGVt ZW50YXRpb24u
Y29uZmlndXJlQ29uc3RyYWludEJpbmRpbmdzKEVNRk1vZGVsVmFsaWRhdGlv blBsdWdpbi5q
YXZhOjI1NikNCglhdCBvcmcuZWNsaXBzZS5lbWYudmFsaWRhdGlvbi5pbnRl cm5hbC5FTUZN
b2RlbFZhbGlkYXRpb25QbHVnaW4kSW1wbGVtZW50YXRpb24uc3RhcnQoRU1G TW9kZWxWYWxp
ZGF0aW9uUGx1Z2luLmphdmE6MjI5KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2ku ZnJhbWV3b3Jr
LmludGVybmFsLmNvcmUuQnVuZGxlQ29udGV4dEltcGwkMi5ydW4oQnVuZGxl Q29udGV4dElt
cGwuamF2YTo5OTkpDQoJYXQgamF2YS5zZWN1cml0eS5BY2Nlc3NDb250cm9s bGVyLmRvUHJp
dmlsZWdlZChOYXRpdmUgTWV0aG9kKQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2ku ZnJhbWV3b3Jr
LmludGVybmFsLmNvcmUuQnVuZGxlQ29udGV4dEltcGwuc3RhcnRBY3RpdmF0 b3IoQnVuZGxl
Q29udGV4dEltcGwuamF2YTo5OTMpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5m cmFtZXdvcmsu
aW50ZXJuYWwuY29yZS5CdW5kbGVDb250ZXh0SW1wbC5zdGFydChCdW5kbGVD b250ZXh0SW1w
bC5qYXZhOjk3NCkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5p bnRlcm5hbC5j
b3JlLkJ1bmRsZUhvc3Quc3RhcnRXb3JrZXIoQnVuZGxlSG9zdC5qYXZhOjM0 NikNCglhdCBv
cmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5pbnRlcm5hbC5jb3JlLkFic3Ry YWN0QnVuZGxl
LnN0YXJ0KEFic3RyYWN0QnVuZGxlLmphdmE6MjYwKQ0KCWF0IG9yZy5lY2xp cHNlLnVwZGF0
ZS5pbnRlcm5hbC5jb25maWd1cmF0b3IuQ29uZmlndXJhdGlvbkFjdGl2YXRv ci5pbnN0YWxs
QnVuZGxlcyhDb25maWd1cmF0aW9uQWN0aXZhdG9yLmphdmE6MjE4KQ0KCWF0 IG9yZy5lY2xp
cHNlLnVwZGF0ZS5vcGVyYXRpb25zLk9wZXJhdGlvbnNNYW5hZ2VyLmFwcGx5 Q2hhbmdlc05v
dyhPcGVyYXRpb25zTWFuYWdlci5qYXZhOjI0MykNCglhdCBvcmcuZWNsaXBz ZS51cGRhdGUu
aW50ZXJuYWwudWkuUmVzdGFydERpYWxvZy5vcGVuUXVlc3Rpb24oUmVzdGFy dERpYWxvZy5q
YXZhOjYyKQ0KCWF0IG9yZy5lY2xpcHNlLnVwZGF0ZS5pbnRlcm5hbC51aS5V cGRhdGVVSS5y
ZXF1ZXN0UmVzdGFydChVcGRhdGVVSS5qYXZhOjI3MykNCglhdCBvcmcuZWNs aXBzZS51cGRh
dGUuaW50ZXJuYWwudWkud2l6YXJkcy5JbnN0YWxsV2l6YXJkMiQ0LnJ1bihJ bnN0YWxsV2l6
YXJkMi5qYXZhOjM3NikNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5S dW5uYWJsZUxv
Y2sucnVuKFJ1bm5hYmxlTG9jay5qYXZhOjM1KQ0KCWF0IG9yZy5lY2xpcHNl LnN3dC53aWRn
ZXRzLlN5bmNocm9uaXplci5ydW5Bc3luY01lc3NhZ2VzKFN5bmNocm9uaXpl ci5qYXZhOjEy
MykNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5EaXNwbGF5LnJ1bkFz eW5jTWVzc2Fn
ZXMoRGlzcGxheS5qYXZhOjM2NTkpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0Lndp ZGdldHMuRGlz
cGxheS5yZWFkQW5kRGlzcGF0Y2goRGlzcGxheS5qYXZhOjMyOTYpDQoJYXQg b3JnLmVjbGlw
c2UudWkuaW50ZXJuYWwuV29ya2JlbmNoLnJ1bkV2ZW50TG9vcChXb3JrYmVu Y2guamF2YToy
Mzg5KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLldvcmtiZW5jaC5y dW5VSShXb3Jr
YmVuY2guamF2YToyMzUzKQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFs LldvcmtiZW5j
aC5hY2Nlc3MkNChXb3JrYmVuY2guamF2YToyMjE5KQ0KCWF0IG9yZy5lY2xp cHNlLnVpLmlu
dGVybmFsLldvcmtiZW5jaCQ0LnJ1bihXb3JrYmVuY2guamF2YTo0NjYpDQoJ YXQgb3JnLmVj
bGlwc2UuY29yZS5kYXRhYmluZGluZy5vYnNlcnZhYmxlLlJlYWxtLnJ1bldp dGhEZWZhdWx0
KFJlYWxtLmphdmE6Mjg5KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFs LldvcmtiZW5j
aC5jcmVhdGVBbmRSdW5Xb3JrYmVuY2goV29ya2JlbmNoLmphdmE6NDYxKQ0K CWF0IG9yZy5l
Y2xpcHNlLnVpLlBsYXRmb3JtVUkuY3JlYXRlQW5kUnVuV29ya2JlbmNoKFBs YXRmb3JtVUku
amF2YToxNDkpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuaWRlLmFw cGxpY2F0aW9u
LklERUFwcGxpY2F0aW9uLnN0YXJ0KElERUFwcGxpY2F0aW9uLmphdmE6MTA2 KQ0KCWF0IG9y
Zy5lY2xpcHNlLmVxdWlub3guaW50ZXJuYWwuYXBwLkVjbGlwc2VBcHBIYW5k bGUucnVuKEVj
bGlwc2VBcHBIYW5kbGUuamF2YToxNjkpDQoJYXQgb3JnLmVjbGlwc2UuY29y ZS5ydW50aW1l
LmludGVybmFsLmFkYXB0b3IuRWNsaXBzZUFwcExhdW5jaGVyLnJ1bkFwcGxp Y2F0aW9uKEVj
bGlwc2VBcHBMYXVuY2hlci5qYXZhOjEwNikNCglhdCBvcmcuZWNsaXBzZS5j b3JlLnJ1bnRp
bWUuaW50ZXJuYWwuYWRhcHRvci5FY2xpcHNlQXBwTGF1bmNoZXIuc3RhcnQo RWNsaXBzZUFw
cExhdW5jaGVyLmphdmE6NzYpDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5ydW50 aW1lLmFkYXB0
b3IuRWNsaXBzZVN0YXJ0ZXIucnVuKEVjbGlwc2VTdGFydGVyLmphdmE6MzYz KQ0KCWF0IG9y
Zy5lY2xpcHNlLmNvcmUucnVudGltZS5hZGFwdG9yLkVjbGlwc2VTdGFydGVy LnJ1bihFY2xp
cHNlU3RhcnRlci5qYXZhOjE3NikNCglhdCBzdW4ucmVmbGVjdC5OYXRpdmVN ZXRob2RBY2Nl
c3NvckltcGwuaW52b2tlMChOYXRpdmUgTWV0aG9kKQ0KCWF0IHN1bi5yZWZs ZWN0Lk5hdGl2
ZU1ldGhvZEFjY2Vzc29ySW1wbC5pbnZva2UoVW5rbm93biBTb3VyY2UpDQoJ YXQgc3VuLnJl
ZmxlY3QuRGVsZWdhdGluZ01ldGhvZEFjY2Vzc29ySW1wbC5pbnZva2UoVW5r bm93biBTb3Vy
Y2UpDQoJYXQgamF2YS5sYW5nLnJlZmxlY3QuTWV0aG9kLmludm9rZShVbmtu b3duIFNvdXJj
ZSkNCglhdCBvcmcuZWNsaXBzZS5lcXVpbm94LmxhdW5jaGVyLk1haW4uaW52 b2tlRnJhbWV3
b3JrKE1haW4uamF2YTo1MDgpDQoJYXQgb3JnLmVjbGlwc2UuZXF1aW5veC5s YXVuY2hlci5N
YWluLmJhc2ljUnVuKE1haW4uamF2YTo0NDcpDQoJYXQgb3JnLmVjbGlwc2Uu ZXF1aW5veC5s
YXVuY2hlci5NYWluLnJ1bihNYWluLmphdmE6MTE3MykNCg0KIUVOVFJZIG9y Zy5lY2xpcHNl
LmVxdWlub3gucmVnaXN0cnkgNCAxIDIwMDctMTAtMjIgMTc6NDk6MTguMDMx DQohTUVTU0FH
RSBQbHVnLWluIG9yZy5lY2xpcHNlLnN0cC5icG1uLnZhbGlkYXRpb24gd2Fz IHVuYWJsZSB0
byBsb2FkIGNsYXNzIG9yZy5lY2xpcHNlLnN0cC5icG1uLnZhbGlkYXRpb24u VmFsaWRhdGlv
bkRlbGVnYXRlQ2xpZW50U2VsZWN0b3IuDQohU1RBQ0sgMA0Kb3JnLmVjbGlw c2UuY29yZS5y
dW50aW1lLmludGVybmFsLmFkYXB0b3IuRWNsaXBzZUxhenlTdGFydGVyJFRl cm1pbmF0aW5n
Q2xhc3NOb3RGb3VuZEV4Y2VwdGlvbjogQW4gZXJyb3Igb2NjdXJyZWQgd2hp bGUgYXV0b21h
dGljYWxseSBhY3RpdmF0aW5nIGJ1bmRsZSBvcmcuZWNsaXBzZS5zdHAuYnBt bi52YWxpZGF0
aW9uICg0NDQpLg0KCWF0IG9yZy5lY2xpcHNlLmNvcmUucnVudGltZS5pbnRl cm5hbC5hZGFw
dG9yLkVjbGlwc2VMYXp5U3RhcnRlci5wb3N0RmluZExvY2FsQ2xhc3MoRWNs aXBzZUxhenlT
dGFydGVyLmphdmE6MTI1KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuYmFzZWFk YXB0b3IubG9h
ZGVyLkNsYXNzcGF0aE1hbmFnZXIuZmluZExvY2FsQ2xhc3MoQ2xhc3NwYXRo TWFuYWdlci5q
YXZhOjQxNykNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmludGVybmFsLmJhc2Vh ZGFwdG9yLkRl
ZmF1bHRDbGFzc0xvYWRlci5maW5kTG9jYWxDbGFzcyhEZWZhdWx0Q2xhc3NM b2FkZXIuamF2
YToxODkpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJu YWwuY29yZS5C
dW5kbGVMb2FkZXIuZmluZExvY2FsQ2xhc3MoQnVuZGxlTG9hZGVyLmphdmE6 MzQwKQ0KCWF0
IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVu ZGxlTG9hZGVy
LmZpbmRDbGFzc0ludGVybmFsKEJ1bmRsZUxvYWRlci5qYXZhOjQwOCkNCglh dCBvcmcuZWNs
aXBzZS5vc2dpLmZyYW1ld29yay5pbnRlcm5hbC5jb3JlLkJ1bmRsZUxvYWRl ci5maW5kQ2xh
c3MoQnVuZGxlTG9hZGVyLmphdmE6MzY5KQ0KCWF0IG9yZy5lY2xpcHNlLm9z Z2kuZnJhbWV3
b3JrLmludGVybmFsLmNvcmUuQnVuZGxlTG9hZGVyLmZpbmRDbGFzcyhCdW5k bGVMb2FkZXIu
amF2YTozNTcpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5pbnRlcm5hbC5iYXNl YWRhcHRvci5E
ZWZhdWx0Q2xhc3NMb2FkZXIubG9hZENsYXNzKERlZmF1bHRDbGFzc0xvYWRl ci5qYXZhOjgz
KQ0KCWF0IGphdmEubGFuZy5DbGFzc0xvYWRlci5sb2FkQ2xhc3MoVW5rbm93 biBTb3VyY2Up
DQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29y ZS5CdW5kbGVM
b2FkZXIubG9hZENsYXNzKEJ1bmRsZUxvYWRlci5qYXZhOjI4OSkNCglhdCBv cmcuZWNsaXBz
ZS5vc2dpLmZyYW1ld29yay5pbnRlcm5hbC5jb3JlLkJ1bmRsZUhvc3QubG9h ZENsYXNzKEJ1
bmRsZUhvc3QuamF2YToyMjcpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFt ZXdvcmsuaW50
ZXJuYWwuY29yZS5BYnN0cmFjdEJ1bmRsZS5sb2FkQ2xhc3MoQWJzdHJhY3RC dW5kbGUuamF2
YToxMjY5KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwucmVnaXN0 cnkub3NnaS5S
ZWdpc3RyeVN0cmF0ZWd5T1NHSS5jcmVhdGVFeGVjdXRhYmxlRXh0ZW5zaW9u KFJlZ2lzdHJ5
U3RyYXRlZ3lPU0dJLmphdmE6MTYwKQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUu aW50ZXJuYWwu
cmVnaXN0cnkuRXh0ZW5zaW9uUmVnaXN0cnkuY3JlYXRlRXhlY3V0YWJsZUV4 dGVuc2lvbihF
eHRlbnNpb25SZWdpc3RyeS5qYXZhOjc4OCkNCglhdCBvcmcuZWNsaXBzZS5j b3JlLmludGVy
bmFsLnJlZ2lzdHJ5LkNvbmZpZ3VyYXRpb25FbGVtZW50LmNyZWF0ZUV4ZWN1 dGFibGVFeHRl
bnNpb24oQ29uZmlndXJhdGlvbkVsZW1lbnQuamF2YToyNDMpDQoJYXQgb3Jn LmVjbGlwc2Uu
Y29yZS5pbnRlcm5hbC5yZWdpc3RyeS5Db25maWd1cmF0aW9uRWxlbWVudEhh bmRsZS5jcmVh
dGVFeGVjdXRhYmxlRXh0ZW5zaW9uKENvbmZpZ3VyYXRpb25FbGVtZW50SGFu ZGxlLmphdmE6
NTEpDQoJYXQgb3JnLmVjbGlwc2UuZW1mLnZhbGlkYXRpb24uaW50ZXJuYWwu c2VydmljZS5D
bGllbnRDb250ZXh0LmluaXRpYWxpemVDdXN0b21TZWxlY3RvcihDbGllbnRD b250ZXh0Lmph
dmE6MTg2KQ0KCWF0IG9yZy5lY2xpcHNlLmVtZi52YWxpZGF0aW9uLmludGVy bmFsLnNlcnZp
Y2UuQ2xpZW50Q29udGV4dC5pbml0aWFsaXplU2VsZWN0b3IoQ2xpZW50Q29u dGV4dC5qYXZh
OjEyMikNCglhdCBvcmcuZWNsaXBzZS5lbWYudmFsaWRhdGlvbi5pbnRlcm5h bC5zZXJ2aWNl
LkNsaWVudENvbnRleHQuPGluaXQ+KENsaWVudENvbnRleHQuamF2YTo3MikN CglhdCBvcmcu
ZWNsaXBzZS5lbWYudmFsaWRhdGlvbi5pbnRlcm5hbC5zZXJ2aWNlLkNsaWVu dENvbnRleHRN
YW5hZ2VyLmNvbmZpZ3VyZUNsaWVudENvbnRleHRzKENsaWVudENvbnRleHRN YW5hZ2VyLmph
dmE6MzIxKQ0KCWF0IG9yZy5lY2xpcHNlLmVtZi52YWxpZGF0aW9uLmludGVy bmFsLnNlcnZp
Y2UuQ2xpZW50Q29udGV4dE1hbmFnZXIuY29uZmlndXJlQ29uc3RyYWludEJp bmRpbmdzKENs
aWVudENvbnRleHRNYW5hZ2VyLmphdmE6MzA0KQ0KCWF0IG9yZy5lY2xpcHNl LmVtZi52YWxp
ZGF0aW9uLmludGVybmFsLkVNRk1vZGVsVmFsaWRhdGlvblBsdWdpbiRJbXBs ZW1lbnRhdGlv
bi5jb25maWd1cmVDb25zdHJhaW50QmluZGluZ3MoRU1GTW9kZWxWYWxpZGF0 aW9uUGx1Z2lu
LmphdmE6MjU2KQ0KCWF0IG9yZy5lY2xpcHNlLmVtZi52YWxpZGF0aW9uLmlu dGVybmFsLkVN
Rk1vZGVsVmFsaWRhdGlvblBsdWdpbiRJbXBsZW1lbnRhdGlvbi5zdGFydChF TUZNb2RlbFZh
bGlkYXRpb25QbHVnaW4uamF2YToyMjkpDQoJYXQgb3JnLmVjbGlwc2Uub3Nn aS5mcmFtZXdv
cmsuaW50ZXJuYWwuY29yZS5CdW5kbGVDb250ZXh0SW1wbCQyLnJ1bihCdW5k bGVDb250ZXh0
SW1wbC5qYXZhOjk5OSkNCglhdCBqYXZhLnNlY3VyaXR5LkFjY2Vzc0NvbnRy b2xsZXIuZG9Q
cml2aWxlZ2VkKE5hdGl2ZSBNZXRob2QpDQoJYXQgb3JnLmVjbGlwc2Uub3Nn aS5mcmFtZXdv
cmsuaW50ZXJuYWwuY29yZS5CdW5kbGVDb250ZXh0SW1wbC5zdGFydEFjdGl2 YXRvcihCdW5k
bGVDb250ZXh0SW1wbC5qYXZhOjk5MykNCglhdCBvcmcuZWNsaXBzZS5vc2dp LmZyYW1ld29y
ay5pbnRlcm5hbC5jb3JlLkJ1bmRsZUNvbnRleHRJbXBsLnN0YXJ0KEJ1bmRs ZUNvbnRleHRJ
bXBsLmphdmE6OTc0KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3Jr LmludGVybmFs
LmNvcmUuQnVuZGxlSG9zdC5zdGFydFdvcmtlcihCdW5kbGVIb3N0LmphdmE6 MzQ2KQ0KCWF0
IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQWJz dHJhY3RCdW5k
bGUuc3RhcnQoQWJzdHJhY3RCdW5kbGUuamF2YToyNjApDQoJYXQgb3JnLmVj bGlwc2UudXBk
YXRlLmludGVybmFsLmNvbmZpZ3VyYXRvci5Db25maWd1cmF0aW9uQWN0aXZh dG9yLmluc3Rh
bGxCdW5kbGVzKENvbmZpZ3VyYXRpb25BY3RpdmF0b3IuamF2YToyMTgpDQoJ YXQgb3JnLmVj
bGlwc2UudXBkYXRlLm9wZXJhdGlvbnMuT3BlcmF0aW9uc01hbmFnZXIuYXBw bHlDaGFuZ2Vz
Tm93KE9wZXJhdGlvbnNNYW5hZ2VyLmphdmE6MjQzKQ0KCWF0IG9yZy5lY2xp cHNlLnVwZGF0
ZS5pbnRlcm5hbC51aS5SZXN0YXJ0RGlhbG9nLm9wZW5RdWVzdGlvbihSZXN0 YXJ0RGlhbG9n
LmphdmE6NjIpDQoJYXQgb3JnLmVjbGlwc2UudXBkYXRlLmludGVybmFsLnVp LlVwZGF0ZVVJ
LnJlcXVlc3RSZXN0YXJ0KFVwZGF0ZVVJLmphdmE6MjczKQ0KCWF0IG9yZy5l Y2xpcHNlLnVw
ZGF0ZS5pbnRlcm5hbC51aS53aXphcmRzLkluc3RhbGxXaXphcmQyJDQucnVu KEluc3RhbGxX
aXphcmQyLmphdmE6Mzc2KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRz LlJ1bm5hYmxl
TG9jay5ydW4oUnVubmFibGVMb2NrLmphdmE6MzUpDQoJYXQgb3JnLmVjbGlw c2Uuc3d0Lndp
ZGdldHMuU3luY2hyb25pemVyLnJ1bkFzeW5jTWVzc2FnZXMoU3luY2hyb25p emVyLmphdmE6
MTIzKQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLkRpc3BsYXkucnVu QXN5bmNNZXNz
YWdlcyhEaXNwbGF5LmphdmE6MzY1OSkNCglhdCBvcmcuZWNsaXBzZS5zd3Qu d2lkZ2V0cy5E
aXNwbGF5LnJlYWRBbmREaXNwYXRjaChEaXNwbGF5LmphdmE6MzI5NikNCglh dCBvcmcuZWNs
aXBzZS51aS5pbnRlcm5hbC5Xb3JrYmVuY2gucnVuRXZlbnRMb29wKFdvcmti ZW5jaC5qYXZh
OjIzODkpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2JlbmNo LnJ1blVJKFdv
cmtiZW5jaC5qYXZhOjIzNTMpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJu YWwuV29ya2Jl
bmNoLmFjY2VzcyQ0KFdvcmtiZW5jaC5qYXZhOjIyMTkpDQoJYXQgb3JnLmVj bGlwc2UudWku
aW50ZXJuYWwuV29ya2JlbmNoJDQucnVuKFdvcmtiZW5jaC5qYXZhOjQ2NikN CglhdCBvcmcu
ZWNsaXBzZS5jb3JlLmRhdGFiaW5kaW5nLm9ic2VydmFibGUuUmVhbG0ucnVu V2l0aERlZmF1
bHQoUmVhbG0uamF2YToyODkpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJu YWwuV29ya2Jl
bmNoLmNyZWF0ZUFuZFJ1bldvcmtiZW5jaChXb3JrYmVuY2guamF2YTo0NjEp DQoJYXQgb3Jn
LmVjbGlwc2UudWkuUGxhdGZvcm1VSS5jcmVhdGVBbmRSdW5Xb3JrYmVuY2go UGxhdGZvcm1V
SS5qYXZhOjE0OSkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5pZGUu YXBwbGljYXRp
b24uSURFQXBwbGljYXRpb24uc3RhcnQoSURFQXBwbGljYXRpb24uamF2YTox MDYpDQoJYXQg
b3JnLmVjbGlwc2UuZXF1aW5veC5pbnRlcm5hbC5hcHAuRWNsaXBzZUFwcEhh bmRsZS5ydW4o
RWNsaXBzZUFwcEhhbmRsZS5qYXZhOjE2OSkNCglhdCBvcmcuZWNsaXBzZS5j b3JlLnJ1bnRp
bWUuaW50ZXJuYWwuYWRhcHRvci5FY2xpcHNlQXBwTGF1bmNoZXIucnVuQXBw bGljYXRpb24o
RWNsaXBzZUFwcExhdW5jaGVyLmphdmE6MTA2KQ0KCWF0IG9yZy5lY2xpcHNl LmNvcmUucnVu
dGltZS5pbnRlcm5hbC5hZGFwdG9yLkVjbGlwc2VBcHBMYXVuY2hlci5zdGFy dChFY2xpcHNl
QXBwTGF1bmNoZXIuamF2YTo3NikNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1 bnRpbWUuYWRh
cHRvci5FY2xpcHNlU3RhcnRlci5ydW4oRWNsaXBzZVN0YXJ0ZXIuamF2YToz NjMpDQoJYXQg
b3JnLmVjbGlwc2UuY29yZS5ydW50aW1lLmFkYXB0b3IuRWNsaXBzZVN0YXJ0 ZXIucnVuKEVj
bGlwc2VTdGFydGVyLmphdmE6MTc2KQ0KCWF0IHN1bi5yZWZsZWN0Lk5hdGl2 ZU1ldGhvZEFj
Y2Vzc29ySW1wbC5pbnZva2UwKE5hdGl2ZSBNZXRob2QpDQoJYXQgc3VuLnJl ZmxlY3QuTmF0
aXZlTWV0aG9kQWNjZXNzb3JJbXBsLmludm9rZShVbmtub3duIFNvdXJjZSkN CglhdCBzdW4u
cmVmbGVjdC5EZWxlZ2F0aW5nTWV0aG9kQWNjZXNzb3JJbXBsLmludm9rZShV bmtub3duIFNv
dXJjZSkNCglhdCBqYXZhLmxhbmcucmVmbGVjdC5NZXRob2QuaW52b2tlKFVu a25vd24gU291
cmNlKQ0KCWF0IG9yZy5lY2xpcHNlLmVxdWlub3gubGF1bmNoZXIuTWFpbi5p bnZva2VGcmFt
ZXdvcmsoTWFpbi5qYXZhOjUwOCkNCglhdCBvcmcuZWNsaXBzZS5lcXVpbm94 LmxhdW5jaGVy
Lk1haW4uYmFzaWNSdW4oTWFpbi5qYXZhOjQ0NykNCglhdCBvcmcuZWNsaXBz ZS5lcXVpbm94
LmxhdW5jaGVyLk1haW4ucnVuKE1haW4uamF2YToxMTczKQ0KQ2F1c2VkIGJ5 OiBvcmcub3Nn
aS5mcmFtZXdvcmsuQnVuZGxlRXhjZXB0aW9uOiBUaGUgYWN0aXZhdG9yIG9y Zy5lY2xpcHNl
LnN0cC5icG1uLnZhbGlkYXRpb24uQnBtblZhbGlkYXRpb25QbHVnaW4gZm9y IGJ1bmRsZSBv
cmcuZWNsaXBzZS5zdHAuYnBtbi52YWxpZGF0aW9uIGlzIGludmFsaWQNCglh dCBvcmcuZWNs
aXBzZS5vc2dpLmZyYW1ld29yay5pbnRlcm5hbC5jb3JlLkFic3RyYWN0QnVu ZGxlLmxvYWRC
dW5kbGVBY3RpdmF0b3IoQWJzdHJhY3RCdW5kbGUuamF2YToxNDEpDQoJYXQg b3JnLmVjbGlw
c2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVDb250ZXh0 SW1wbC5zdGFy
dChCdW5kbGVDb250ZXh0SW1wbC5qYXZhOjk3MCkNCglhdCBvcmcuZWNsaXBz ZS5vc2dpLmZy
YW1ld29yay5pbnRlcm5hbC5jb3JlLkJ1bmRsZUhvc3Quc3RhcnRXb3JrZXIo QnVuZGxlSG9z
dC5qYXZhOjM0NikNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5p bnRlcm5hbC5j
b3JlLkFic3RyYWN0QnVuZGxlLnN0YXJ0KEFic3RyYWN0QnVuZGxlLmphdmE6 MjYwKQ0KCWF0
IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLnV0aWwuU2VjdXJlQWN0aW9u LnN0YXJ0KFNl
Y3VyZUFjdGlvbi5qYXZhOjQwMCkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1 bnRpbWUuaW50
ZXJuYWwuYWRhcHRvci5FY2xpcHNlTGF6eVN0YXJ0ZXIucG9zdEZpbmRMb2Nh bENsYXNzKEVj
bGlwc2VMYXp5U3RhcnRlci5qYXZhOjExMSkNCgkuLi4gNTcgbW9yZQ0KQ2F1 c2VkIGJ5OiBq
YXZhLmxhbmcuRXJyb3I6IFVucmVzb2x2ZWQgY29tcGlsYXRpb24gcHJvYmxl bXM6IAoJVGhl
IHR5cGUgTWFwIGlzIG5vdCBnZW5lcmljOyBpdCBjYW5ub3QgYmUgcGFyYW1l dGVyaXplZCB3
aXRoIGFyZ3VtZW50cyA8U3RyaW5nLCBJUmVzb3VyY2VJbXBvcnRlcnNSZWdp c3RyeT4KCUNB
Q0hFIGNhbm5vdCBiZSByZXNvbHZlZAoJVGhlIHR5cGUgTWFwIGlzIG5vdCBn ZW5lcmljOyBp
dCBjYW5ub3QgYmUgcGFyYW1ldGVyaXplZCB3aXRoIGFyZ3VtZW50cyA8U3Ry aW5nLCBJUmVz
b3VyY2VJbXBvcnRlcnNSZWdpc3RyeT4KCVRoZSB0eXBlIE1hcCBpcyBub3Qg Z2VuZXJpYzsg
aXQgY2Fubm90IGJlIHBhcmFtZXRlcml6ZWQgd2l0aCBhcmd1bWVudHMgPFN0 cmluZywgSVJl
c291cmNlSW1wb3J0ZXJzUmVnaXN0cnk+CglDQUNIRSBjYW5ub3QgYmUgcmVz b2x2ZWQKCVRo
ZSB0eXBlIE1hcC5FbnRyeSBpcyBub3QgZ2VuZXJpYzsgaXQgY2Fubm90IGJl IHBhcmFtZXRl
cml6ZWQgd2l0aCBhcmd1bWVudHMgPFN0cmluZywgSVJlc291cmNlSW1wb3J0 ZXJzUmVnaXN0
cnk+CglDQUNIRSBjYW5ub3QgYmUgcmVzb2x2ZWQKCUNBQ0hFIGNhbm5vdCBi ZSByZXNvbHZl
ZAoJVGhlIHR5cGUgTWFwIGlzIG5vdCBnZW5lcmljOyBpdCBjYW5ub3QgYmUg cGFyYW1ldGVy
eT4KCUNBQ0hFIGNhbm5vdCBiZSByZXNvbHZlZAoJVGhlIHR5cGUgSGFzaE1h cCBpcyBub3Qg
Z2VuZXJpYzsgaXQgY2Fubm90IGJlIHBhcmFtZXRlcml6ZWQgd2l0aCBhcmd1 bWVudHMgPFN0
cmluZywgSVJlc291cmNlSW1wb3J0ZXJzUmVnaXN0cnk+CglDQUNIRSBjYW5u b3QgYmUgcmVz
b2x2ZWQKDQoJYXQgb3JnLmVjbGlwc2Uuc3RwLmJwbW4udmFsaWRhdGlvbi5C cG1uVmFsaWRh
dGlvblBsdWdpbi48aW5pdD4oQnBtblZhbGlkYXRpb25QbHVnaW4uamF2YTo1 MSkNCglhdCBz
dW4ucmVmbGVjdC5OYXRpdmVDb25zdHJ1Y3RvckFjY2Vzc29ySW1wbC5uZXdJ bnN0YW5jZTAo
TmF0aXZlIE1ldGhvZCkNCglhdCBzdW4ucmVmbGVjdC5OYXRpdmVDb25zdHJ1 Y3RvckFjY2Vz
c29ySW1wbC5uZXdJbnN0YW5jZShVbmtub3duIFNvdXJjZSkNCglhdCBzdW4u cmVmbGVjdC5E
ZWxlZ2F0aW5nQ29uc3RydWN0b3JBY2Nlc3NvckltcGwubmV3SW5zdGFuY2Uo VW5rbm93biBT
b3VyY2UpDQoJYXQgamF2YS5sYW5nLnJlZmxlY3QuQ29uc3RydWN0b3IubmV3 SW5zdGFuY2Uo
VW5rbm93biBTb3VyY2UpDQoJYXQgamF2YS5sYW5nLkNsYXNzLm5ld0luc3Rh bmNlMChVbmtu
b3duIFNvdXJjZSkNCglhdCBqYXZhLmxhbmcuQ2xhc3MubmV3SW5zdGFuY2Uo VW5rbm93biBT
b3VyY2UpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJu YWwuY29yZS5B
YnN0cmFjdEJ1bmRsZS5sb2FkQnVuZGxlQWN0aXZhdG9yKEFic3RyYWN0QnVu ZGxlLmphdmE6
MTM2KQ0KCS4uLiA2MiBtb3JlDQoNCiFFTlRSWSBvcmcuZWNsaXBzZS5lbWYu dmFsaWRhdGlv
biA0IDEyMSAyMDA3LTEwLTIyIDE3OjQ5OjE4LjAzMQ0KIU1FU1NBR0UgQ2xp ZW50IGNvbnRl
eHQgb3JnLmVjbGlwc2Uuc3RwLmJwbW4udmFsaWRhdGlvbi5zcGVjaWZpY2F0 aW9uQ29udGV4
dCBkb2VzIG5vdCBleGlzdCBpbiBjb25zdHJhaW50IGJpbmRpbmcgZGVmaW5l ZCBieSBwbHVn
LWluIG9yZy5lY2xpcHNlLnN0cC5icG1uLnZhbGlkYXRpb24uDQoNCiFFTlRS WSBvcmcuZWNs
aXBzZS51cGRhdGUuY29uZmlndXJhdG9yIDIwMDctMTAtMjIgMTc6NDk6MTgu NDY4DQohTUVT
U0FHRSBDb3VsZCBub3QgaW5zdGFsbCBidW5kbGUgdXBkYXRlQHBsdWdpbnMv b3JnLmVjbGlw
c2UuZ21mLnJ1bnRpbWUuZW1mLmNsaXBib2FyZC5jb3JlXzEuMC4xMDAudjIw MDcwODA5LTAw
MDAuamFyICAgRXhjZXB0aW9uIGluIG9yZy5lY2xpcHNlLmdtZi5ydW50aW1l LmVtZi5jbGlw
Ym9hcmQuY29yZS5pbnRlcm5hbC5DbGlwYm9hcmRQbHVnaW4kSW1wbGVtZW50 YXRpb24uc3Rh
cnQoKSBvZiBidW5kbGUgb3JnLmVjbGlwc2UuZ21mLnJ1bnRpbWUuZW1mLmNs aXBib2FyZC5j
b3JlLg0KDQohRU5UUlkgb3JnLmVjbGlwc2UudXBkYXRlLmNvbmZpZ3VyYXRv ciAyMDA3LTEw
LTIyIDE3OjQ5OjE5LjM5MA0KIU1FU1NBR0UgQ291bGQgbm90IGluc3RhbGwg YnVuZGxlIHVw
ZGF0ZUBwbHVnaW5zL29yZy5lY2xpcHNlLnN0cC5icG1uLmRpYWdyYW1fMS4x LjAuMDAwLmph
ciAgIFRoZSBhY3RpdmF0b3Igb3JnLmVjbGlwc2Uuc3RwLmJwbW4uZGlhZ3Jh bS5wYXJ0LkJw
bW5EaWFncmFtRWRpdG9yUGx1Z2luIGZvciBidW5kbGUgb3JnLmVjbGlwc2Uu c3RwLmJwbW4u
ZGlhZ3JhbSBpcyBpbnZhbGlkDQoNCiFFTlRSWSBvcmcuZWNsaXBzZS5vc2dp IDQgMCAyMDA3
LTEwLTIyIDE3OjQ5OjE5LjM5MA0KIU1FU1NBR0UgQW4gdW5leHBlY3RlZCBy dW50aW1lIGVy
cm9yIGhhcyBvY2N1cnJlZC4NCiFTVEFDSyAwDQpqYXZhLmxhbmcuTnVsbFBv aW50ZXJFeGNl
cHRpb24NCglhdCBvcmcuZWNsaXBzZS53c3Quc2VydmVyLmNvcmUuaW50ZXJu YWwuUmVzb3Vy
Y2VNYW5hZ2VyLmlzQWN0aXZlQnVuZGxlKFJlc291cmNlTWFuYWdlci5qYXZh OjMxOSkNCglh
dCBvcmcuZWNsaXBzZS53c3Quc2VydmVyLmNvcmUuaW50ZXJuYWwuU2VydmVy UGx1Z2luJDEu
YnVuZGxlQ2hhbmdlZChTZXJ2ZXJQbHVnaW4uamF2YToyNzIpDQoJYXQgb3Jn LmVjbGlwc2Uu
b3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVDb250ZXh0SW1w bC5kaXNwYXRj
aEV2ZW50KEJ1bmRsZUNvbnRleHRJbXBsLmphdmE6MTIxMCkNCglhdCBvcmcu ZWNsaXBzZS5v
c2dpLmZyYW1ld29yay5ldmVudG1nci5FdmVudE1hbmFnZXIuZGlzcGF0Y2hF dmVudChFdmVu
dE1hbmFnZXIuamF2YToxOTUpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFt ZXdvcmsuZXZl
bnRtZ3IuRXZlbnRNYW5hZ2VyJEV2ZW50VGhyZWFkLnJ1bihFdmVudE1hbmFn ZXIuamF2YToy
OTcpDQoNCiFFTlRSWSBvcmcuZWNsaXBzZS53c3Quc2VydmVyLmNvcmUgNCAw IDIwMDctMTAt
MjIgMTc6NDk6MTkuNDA2DQohTUVTU0FHRSANCiFTVEFDSyAwDQpqYXZhLmxh bmcuTnVsbFBv
aW50ZXJFeGNlcHRpb24NCglhdCBvcmcuZWNsaXBzZS53c3Quc2VydmVyLmNv cmUuaW50ZXJu
YWwuUmVzb3VyY2VNYW5hZ2VyLmlzQWN0aXZlQnVuZGxlKFJlc291cmNlTWFu YWdlci5qYXZh
OjMxOSkNCglhdCBvcmcuZWNsaXBzZS53c3Quc2VydmVyLmNvcmUuaW50ZXJu YWwuU2VydmVy
UGx1Z2luJDEuYnVuZGxlQ2hhbmdlZChTZXJ2ZXJQbHVnaW4uamF2YToyNzIp DQoJYXQgb3Jn
LmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVD b250ZXh0SW1w
bC5kaXNwYXRjaEV2ZW50KEJ1bmRsZUNvbnRleHRJbXBsLmphdmE6MTIxMCkN CglhdCBvcmcu
ZWNsaXBzZS5vc2dpLmZyYW1ld29yay5ldmVudG1nci5FdmVudE1hbmFnZXIu ZGlzcGF0Y2hF
dmVudChFdmVudE1hbmFnZXIuamF2YToxOTUpDQoJYXQgb3JnLmVjbGlwc2Uu b3NnaS5mcmFt
ZXdvcmsuZXZlbnRtZ3IuRXZlbnRNYW5hZ2VyJEV2ZW50VGhyZWFkLnJ1bihF dmVudE1hbmFn
ZXIuamF2YToyOTcpDQoNCiFFTlRSWSBvcmcuZWNsaXBzZS51cGRhdGUuY29u ZmlndXJhdG9y
IDIwMDctMTAtMjIgMTc6NDk6MTkuNDA2DQohTUVTU0FHRSBDb3VsZCBub3Qg aW5zdGFsbCBi
dW5kbGUgdXBkYXRlQHBsdWdpbnMvb3JnLmVjbGlwc2Uuc3RwLmJwbW4uZWRp dF8xLjEuMC4w
MDAuamFyICAgVGhlIGFjdGl2YXRvciBvcmcuZWNsaXBzZS5zdHAuYnBtbi5w cm92aWRlci5C
cG1uRWRpdFBsdWdpbiRJbXBsZW1lbnRhdGlvbiBmb3IgYnVuZGxlIG9yZy5l Y2xpcHNlLnN0
cC5icG1uLmVkaXQgaXMgaW52YWxpZA0KDQohRU5UUlkgb3JnLmVjbGlwc2Uu b3NnaSA0IDAg
MjAwNy0xMC0yMiAxNzo0OToxOS40MDYNCiFNRVNTQUdFIEFuIHVuZXhwZWN0 ZWQgcnVudGlt
ZSBlcnJvciBoYXMgb2NjdXJyZWQuDQohU1RBQ0sgMA0KamF2YS5sYW5nLk51 bGxQb2ludGVy
RXhjZXB0aW9uDQoJYXQgb3JnLmVjbGlwc2Uud3N0LnNlcnZlci5jb3JlLmlu dGVybmFsLlJl
c291cmNlTWFuYWdlci5pc0FjdGl2ZUJ1bmRsZShSZXNvdXJjZU1hbmFnZXIu amF2YTozMTkp
DQoJYXQgb3JnLmVjbGlwc2Uud3N0LnNlcnZlci5jb3JlLmludGVybmFsLlNl cnZlclBsdWdp
biQxLmJ1bmRsZUNoYW5nZWQoU2VydmVyUGx1Z2luLmphdmE6MjcyKQ0KCWF0 IG9yZy5lY2xp
cHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVuZGxlQ29udGV4 dEltcGwuZGlz
cGF0Y2hFdmVudChCdW5kbGVDb250ZXh0SW1wbC5qYXZhOjEyMTApDQoJYXQg b3JnLmVjbGlw
c2Uub3NnaS5mcmFtZXdvcmsuZXZlbnRtZ3IuRXZlbnRNYW5hZ2VyLmRpc3Bh dGNoRXZlbnQo
RXZlbnRNYW5hZ2VyLmphdmE6MTk1KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2ku ZnJhbWV3b3Jr
LmV2ZW50bWdyLkV2ZW50TWFuYWdlciRFdmVudFRocmVhZC5ydW4oRXZlbnRN YW5hZ2VyLmph
dmE6Mjk3KQ0KDQohRU5UUlkgb3JnLmVjbGlwc2Uud3N0LnNlcnZlci5jb3Jl IDQgMCAyMDA3
LTEwLTIyIDE3OjQ5OjE5LjQwNg0KIU1FU1NBR0UgDQohU1RBQ0sgMA0KamF2 YS5sYW5nLk51
bGxQb2ludGVyRXhjZXB0aW9uDQoJYXQgb3JnLmVjbGlwc2Uud3N0LnNlcnZl ci5jb3JlLmlu
dGVybmFsLlJlc291cmNlTWFuYWdlci5pc0FjdGl2ZUJ1bmRsZShSZXNvdXJj ZU1hbmFnZXIu
amF2YTozMTkpDQoJYXQgb3JnLmVjbGlwc2Uud3N0LnNlcnZlci5jb3JlLmlu dGVybmFsLlNl
cnZlclBsdWdpbiQxLmJ1bmRsZUNoYW5nZWQoU2VydmVyUGx1Z2luLmphdmE6 MjcyKQ0KCWF0
IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVu ZGxlQ29udGV4
dEltcGwuZGlzcGF0Y2hFdmVudChCdW5kbGVDb250ZXh0SW1wbC5qYXZhOjEy MTApDQoJYXQg
b3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuZXZlbnRtZ3IuRXZlbnRNYW5h Z2VyLmRpc3Bh
dGNoRXZlbnQoRXZlbnRNYW5hZ2VyLmphdmE6MTk1KQ0KCWF0IG9yZy5lY2xp cHNlLm9zZ2ku
ZnJhbWV3b3JrLmV2ZW50bWdyLkV2ZW50TWFuYWdlciRFdmVudFRocmVhZC5y dW4oRXZlbnRN
YW5hZ2VyLmphdmE6Mjk3KQ0KDQohRU5UUlkgb3JnLmVjbGlwc2UudXBkYXRl LmNvbmZpZ3Vy
YXRvciAyMDA3LTEwLTIyIDE3OjQ5OjE5LjQwNg0KIU1FU1NBR0UgQ291bGQg bm90IGluc3Rh
bGwgYnVuZGxlIHVwZGF0ZUBwbHVnaW5zL29yZy5lY2xpcHNlLnN0cC5jb3Jl LmluZnJhc3Ry
dWN0dXJlLmVtZl8wLjcuMC4yMDA3MDkyNzE3MDEuamFyICAgVGhlIGFjdGl2 YXRvciBvcmcu
ZWNsaXBzZS5zdHAuY29yZS5pbnRlcm5hbC5pbmZyYXN0cnVjdHVyZS5lbWYu RU1GSW5mcmFz
dHJ1Y3R1cmVQbHVnaW4gZm9yIGJ1bmRsZSBvcmcuZWNsaXBzZS5zdHAuY29y ZS5pbmZyYXN0
cnVjdHVyZS5lbWYgaXMgaW52YWxpZA0KDQohRU5UUlkgb3JnLmVjbGlwc2Uu b3NnaSA0IDAg
bGwgYnVuZGxlIHVwZGF0ZUBwbHVnaW5zL29yZy5lY2xpcHNlLnN0cC5jb3Jl XzAuNy4wLjIw
MDcwOTI3MTcwMS5qYXIgICBUaGUgYWN0aXZhdG9yIG9yZy5lY2xpcHNlLnN0 cC5jb3JlLmlu
dGVybmFsLlNUUENvcmVQbHVnaW4kSW1wbGVtZW50YXRpb24gZm9yIGJ1bmRs ZSBvcmcuZWNs
aXBzZS5zdHAuY29yZSBpcyBpbnZhbGlkDQoNCiFFTlRSWSBvcmcuZWNsaXBz ZS5vc2dpIDQg
MCAyMDA3LTEwLTIyIDE3OjQ5OjE5LjQwNg0KIU1FU1NBR0UgQW4gdW5leHBl Y3RlZCBydW50
aW1lIGVycm9yIGhhcyBvY2N1cnJlZC4NCiFTVEFDSyAwDQpqYXZhLmxhbmcu TnVsbFBvaW50
ZXJFeGNlcHRpb24NCglhdCBvcmcuZWNsaXBzZS53c3Quc2VydmVyLmNvcmUu aW50ZXJuYWwu
UmVzb3VyY2VNYW5hZ2VyLmlzQWN0aXZlQnVuZGxlKFJlc291cmNlTWFuYWdl ci5qYXZhOjMx
OSkNCglhdCBvcmcuZWNsaXBzZS53c3Quc2VydmVyLmNvcmUuaW50ZXJuYWwu U2VydmVyUGx1
Z2luJDEuYnVuZGxlQ2hhbmdlZChTZXJ2ZXJQbHVnaW4uamF2YToyNzIpDQoJ YXQgb3JnLmVj
bGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVDb250 ZXh0SW1wbC5k
aXNwYXRjaEV2ZW50KEJ1bmRsZUNvbnRleHRJbXBsLmphdmE6MTIxMCkNCglh dCBvcmcuZWNs
aXBzZS5vc2dpLmZyYW1ld29yay5ldmVudG1nci5FdmVudE1hbmFnZXIuZGlz cGF0Y2hFdmVu
dChFdmVudE1hbmFnZXIuamF2YToxOTUpDQoJYXQgb3JnLmVjbGlwc2Uub3Nn aS5mcmFtZXdv
cmsuZXZlbnRtZ3IuRXZlbnRNYW5hZ2VyJEV2ZW50VGhyZWFkLnJ1bihFdmVu dE1hbmFnZXIu
amF2YToyOTcpDQoNCiFFTlRSWSBvcmcuZWNsaXBzZS53c3Quc2VydmVyLmNv cmUgNCAwIDIw
MDctMTAtMjIgMTc6NDk6MTkuNDA2DQohTUVTU0FHRSANCiFTVEFDSyAwDQpq YXZhLmxhbmcu
TnVsbFBvaW50ZXJFeGNlcHRpb24NCglhdCBvcmcuZWNsaXBzZS53c3Quc2Vy dmVyLmNvcmUu
aW50ZXJuYWwuUmVzb3VyY2VNYW5hZ2VyLmlzQWN0aXZlQnVuZGxlKFJlc291 cmNlTWFuYWdl
ci5qYXZhOjMxOSkNCglhdCBvcmcuZWNsaXBzZS53c3Quc2VydmVyLmNvcmUu aW50ZXJuYWwu
U2VydmVyUGx1Z2luJDEuYnVuZGxlQ2hhbmdlZChTZXJ2ZXJQbHVnaW4uamF2 YToyNzIpDQoJ
YXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5C dW5kbGVDb250
ZXh0SW1wbC5kaXNwYXRjaEV2ZW50KEJ1bmRsZUNvbnRleHRJbXBsLmphdmE6 MTIxMCkNCglh
dCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5ldmVudG1nci5FdmVudE1h bmFnZXIuZGlz
cGF0Y2hFdmVudChFdmVudE1hbmFnZXIuamF2YToxOTUpDQoJYXQgb3JnLmVj bGlwc2Uub3Nn
aS5mcmFtZXdvcmsuZXZlbnRtZ3IuRXZlbnRNYW5hZ2VyJEV2ZW50VGhyZWFk LnJ1bihFdmVu
dE1hbmFnZXIuamF2YToyOTcpDQoNCiFFTlRSWSBvcmcuZWNsaXBzZS51cGRh dGUuY29uZmln
dXJhdG9yIDIwMDctMTAtMjIgMTc6NDk6MTkuNDM3DQohTUVTU0FHRSBDb3Vs ZCBub3QgaW5z
dGFsbCBidW5kbGUgdXBkYXRlQHBsdWdpbnMvb3JnLmVjbGlwc2Uuc3RwLnhl Zl8wLjcuMC8g
ICBUaGUgYWN0aXZhdG9yIG9yZy5lY2xpcHNlLnN0cC51aS54ZWYuWGVmUGx1 Z2luIGZvciBi
dW5kbGUgb3JnLmVjbGlwc2Uuc3RwLnhlZiBpcyBpbnZhbGlkDQoNCiFFTlRS WSBvcmcuZWNs
aXBzZS5vc2dpIDQgMCAyMDA3LTEwLTIyIDE3OjQ5OjE5LjQzNw0KIU1FU1NB R0UgQW4gdW5l
eHBlY3RlZCBydW50aW1lIGVycm9yIGhhcyBvY2N1cnJlZC4NCiFTVEFDSyAw DQpqYXZhLmxh
bmcuTnVsbFBvaW50ZXJFeGNlcHRpb24NCglhdCBvcmcuZWNsaXBzZS53c3Qu c2VydmVyLmNv
cmUuaW50ZXJuYWwuUmVzb3VyY2VNYW5hZ2VyLmlzQWN0aXZlQnVuZGxlKFJl c291cmNlTWFu
YWdlci5qYXZhOjMxOSkNCglhdCBvcmcuZWNsaXBzZS53c3Quc2VydmVyLmNv cmUuaW50ZXJu
YWwuU2VydmVyUGx1Z2luJDEuYnVuZGxlQ2hhbmdlZChTZXJ2ZXJQbHVnaW4u amF2YToyNzIp
DQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29y ZS5CdW5kbGVD
b250ZXh0SW1wbC5kaXNwYXRjaEV2ZW50KEJ1bmRsZUNvbnRleHRJbXBsLmph dmE6MTIxMCkN
CglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5ldmVudG1nci5FdmVu dE1hbmFnZXIu
ZGlzcGF0Y2hFdmVudChFdmVudE1hbmFnZXIuamF2YToxOTUpDQoJYXQgb3Jn LmVjbGlwc2Uu
b3NnaS5mcmFtZXdvcmsuZXZlbnRtZ3IuRXZlbnRNYW5hZ2VyJEV2ZW50VGhy ZWFkLnJ1bihF
dmVudE1hbmFnZXIuamF2YToyOTcpDQoNCiFFTlRSWSBvcmcuZWNsaXBzZS53 c3Quc2VydmVy
LmNvcmUgNCAwIDIwMDctMTAtMjIgMTc6NDk6MTkuNDM3DQohTUVTU0FHRSAN CiFTVEFDSyAw
DQpqYXZhLmxhbmcuTnVsbFBvaW50ZXJFeGNlcHRpb24NCglhdCBvcmcuZWNs aXBzZS53c3Qu
c2VydmVyLmNvcmUuaW50ZXJuYWwuUmVzb3VyY2VNYW5hZ2VyLmlzQWN0aXZl QnVuZGxlKFJl
c291cmNlTWFuYWdlci5qYXZhOjMxOSkNCglhdCBvcmcuZWNsaXBzZS53c3Qu c2VydmVyLmNv
cmUuaW50ZXJuYWwuU2VydmVyUGx1Z2luJDEuYnVuZGxlQ2hhbmdlZChTZXJ2 ZXJQbHVnaW4u
amF2YToyNzIpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50 ZXJuYWwuY29y
ZS5CdW5kbGVDb250ZXh0SW1wbC5kaXNwYXRjaEV2ZW50KEJ1bmRsZUNvbnRl eHRJbXBsLmph
dmE6MTIxMCkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5ldmVu dG1nci5FdmVu
dE1hbmFnZXIuZGlzcGF0Y2hFdmVudChFdmVudE1hbmFnZXIuamF2YToxOTUp DQoJYXQgb3Jn
LmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuZXZlbnRtZ3IuRXZlbnRNYW5hZ2Vy JEV2ZW50VGhy
ZWFkLnJ1bihFdmVudE1hbmFnZXIuamF2YToyOTcpDQoNCiFFTlRSWSBvcmcu ZWNsaXBzZS5q
ZmFjZSA0IDAgMjAwNy0xMC0yMiAxNzo0OToyMy44NzUNCiFNRVNTQUdFIFVu ZGVmaW5lZCBj
b250ZXh0IHdoaWxlIGZpbHRlcmluZyBkaWFsb2cvd2luZG93IGNvbnRleHRz DQohU1RBQ0sg
MA0Kb3JnLmVjbGlwc2UuY29yZS5jb21tYW5kcy5jb21tb24uTm90RGVmaW5l ZEV4Y2VwdGlv
bjogQ2Fubm90IGdldCB0aGUgcGFyZW50IGlkZW50aWZpZXIgZnJvbSBhbiB1 bmRlZmluZWQg
Y29udGV4dC4gb3JnLmVjbGlwc2UuamR0LnVpLkFfT3BlbkFjdGlvblNldA0K CWF0IG9yZy5l
Y2xpcHNlLmNvcmUuY29tbWFuZHMuY29udGV4dHMuQ29udGV4dC5nZXRQYXJl bnRJZChDb250
ZXh0LmphdmE6MjAxKQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLmJpbmRpbmdz LkJpbmRpbmdN
YW5hZ2VyLmNyZWF0ZUZpbHRlcmVkQ29udGV4dFRyZWVGb3IoQmluZGluZ01h bmFnZXIuamF2
YTo4MjUpDQoJYXQgb3JnLmVjbGlwc2UuamZhY2UuYmluZGluZ3MuQmluZGlu Z01hbmFnZXIu
cmVjb21wdXRlQmluZGluZ3MoQmluZGluZ01hbmFnZXIuamF2YToxNzIwKQ0K CWF0IG9yZy5l
Y2xpcHNlLmpmYWNlLmJpbmRpbmdzLkJpbmRpbmdNYW5hZ2VyLmNvbnRleHRN YW5hZ2VyQ2hh
bmdlZChCaW5kaW5nTWFuYWdlci5qYXZhOjY4OSkNCglhdCBvcmcuZWNsaXBz ZS5jb3JlLmNv
bW1hbmRzLmNvbnRleHRzLkNvbnRleHRNYW5hZ2VyLmZpcmVDb250ZXh0TWFu YWdlckNoYW5n
ZWQoQ29udGV4dE1hbmFnZXIuamF2YToxNTIpDQoJYXQgb3JnLmVjbGlwc2Uu Y29yZS5jb21t
YW5kcy5jb250ZXh0cy5Db250ZXh0TWFuYWdlci5zZXRFdmVudENhY2hpbmco Q29udGV4dE1h
bmFnZXIuamF2YTozMTEpDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5jb21tYW5k cy5jb250ZXh0
cy5Db250ZXh0TWFuYWdlci5hZGRBY3RpdmVDb250ZXh0KENvbnRleHRNYW5h Z2VyLmphdmE6
ODApDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuY29udGV4dHMuQ29u dGV4dEF1dGhv
cml0eS5zb3VyY2VDaGFuZ2VkKENvbnRleHRBdXRob3JpdHkuamF2YTo2ODIp DQoJYXQgb3Jn
LmVjbGlwc2UudWkuaW50ZXJuYWwuc2VydmljZXMuRXhwcmVzc2lvbkF1dGhv cml0eS5zb3Vy
Y2VDaGFuZ2VkKEV4cHJlc3Npb25BdXRob3JpdHkuamF2YTozMDUpDQoJYXQg b3JnLmVjbGlw
c2UudWkuaW50ZXJuYWwuc2VydmljZXMuRXhwcmVzc2lvbkF1dGhvcml0eS5z b3VyY2VDaGFu
Z2VkKEV4cHJlc3Npb25BdXRob3JpdHkuamF2YToyODUpDQoJYXQgb3JnLmVj bGlwc2UudWku
QWJzdHJhY3RTb3VyY2VQcm92aWRlci5maXJlU291cmNlQ2hhbmdlZChBYnN0 cmFjdFNvdXJj
ZVByb3ZpZGVyLmphdmE6OTgpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJu YWwuc2Vydmlj
ZXMuQWN0aXZlU2hlbGxTb3VyY2VQcm92aWRlci5hY2Nlc3MkOShBY3RpdmVT aGVsbFNvdXJj
ZVByb3ZpZGVyLmphdmE6MSkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5h bC5zZXJ2aWNl
cy5BY3RpdmVTaGVsbFNvdXJjZVByb3ZpZGVyJDIuaGFuZGxlRXZlbnQoQWN0 aXZlU2hlbGxT
b3VyY2VQcm92aWRlci5qYXZhOjIwOSkNCglhdCBvcmcuZWNsaXBzZS5zd3Qu d2lkZ2V0cy5F
dmVudFRhYmxlLnNlbmRFdmVudChFdmVudFRhYmxlLmphdmE6NjYpDQoJYXQg b3JnLmVjbGlw
c2Uuc3d0LndpZGdldHMuRGlzcGxheS5maWx0ZXJFdmVudChEaXNwbGF5Lmph dmE6MTE0MSkN
CglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5XaWRnZXQuc2VuZEV2ZW50 KFdpZGdldC5q
YXZhOjkzNykNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5XaWRnZXQu c2VuZEV2ZW50
KFdpZGdldC5qYXZhOjk2MikNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0 cy5XaWRnZXQu
c2VuZEV2ZW50KFdpZGdldC5qYXZhOjk0MykNCglhdCBvcmcuZWNsaXBzZS5z d3Qud2lkZ2V0
cy5EZWNvcmF0aW9ucy5XTV9BQ1RJVkFURShEZWNvcmF0aW9ucy5qYXZhOjE1 OTEpDQoJYXQg
b3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuU2hlbGwuV01fQUNUSVZBVEUoU2hl bGwuamF2YTox
ODMzKQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLkNvbnRyb2wud2lu ZG93UHJvYyhD
b250cm9sLmphdmE6MzY3MCkNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0 cy5DYW52YXMu
d2luZG93UHJvYyhDYW52YXMuamF2YToyOTEpDQoJYXQgb3JnLmVjbGlwc2Uu c3d0LndpZGdl
dHMuRGVjb3JhdGlvbnMud2luZG93UHJvYyhEZWNvcmF0aW9ucy5qYXZhOjE1 NTQpDQoJYXQg
b3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuU2hlbGwud2luZG93UHJvYyhTaGVs bC5qYXZhOjE3
NTMpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuRGlzcGxheS53aW5k b3dQcm9jKERp
c3BsYXkuamF2YTo0MzUxKQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC5pbnRlcm5h bC53aW4zMi5P
Uy5TZXRBY3RpdmVXaW5kb3coTmF0aXZlIE1ldGhvZCkNCglhdCBvcmcuZWNs aXBzZS5zd3Qu
d2lkZ2V0cy5TaGVsbC5maXhBY3RpdmVTaGVsbChTaGVsbC5qYXZhOjc0NCkN CglhdCBvcmcu
ZWNsaXBzZS5zd3Qud2lkZ2V0cy5TaGVsbC5kZXN0cm95V2lkZ2V0KFNoZWxs LmphdmE6NjM1
KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLldpZGdldC5yZWxlYXNl KFdpZGdldC5q
YXZhOjc1MCkNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5XaWRnZXQu ZGlzcG9zZShX
aWRnZXQuamF2YTo0MTApDQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMu RGVjb3JhdGlv
bnMuZGlzcG9zZShEZWNvcmF0aW9ucy5qYXZhOjQ0MSkNCglhdCBvcmcuZWNs aXBzZS5zd3Qu
d2lkZ2V0cy5TaGVsbC5kaXNwb3NlKFNoZWxsLmphdmE6NjUzKQ0KCWF0IG9y Zy5lY2xpcHNl
LmpmYWNlLndpbmRvdy5XaW5kb3cuY2xvc2UoV2luZG93LmphdmE6MzMwKQ0K CWF0IG9yZy5l
Y2xpcHNlLmpmYWNlLmRpYWxvZ3MuRGlhbG9nLmNsb3NlKERpYWxvZy5qYXZh Ojk3MSkNCglh
dCBvcmcuZWNsaXBzZS5qZmFjZS5kaWFsb2dzLk1lc3NhZ2VEaWFsb2cuYnV0 dG9uUHJlc3Nl
ZChNZXNzYWdlRGlhbG9nLmphdmE6MTY3KQ0KCWF0IG9yZy5lY2xpcHNlLmpm YWNlLmRpYWxv
Z3MuRGlhbG9nJDIud2lkZ2V0U2VsZWN0ZWQoRGlhbG9nLmphdmE6NjE2KQ0K CWF0IG9yZy5l
Y2xpcHNlLnN3dC53aWRnZXRzLlR5cGVkTGlzdGVuZXIuaGFuZGxlRXZlbnQo VHlwZWRMaXN0
ZW5lci5qYXZhOjIyNykNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5F dmVudFRhYmxl
LnNlbmRFdmVudChFdmVudFRhYmxlLmphdmE6NjYpDQoJYXQgb3JnLmVjbGlw c2Uuc3d0Lndp
ZGdldHMuV2lkZ2V0LnNlbmRFdmVudChXaWRnZXQuamF2YTo5MzgpDQoJYXQg b3JnLmVjbGlw
c2Uuc3d0LndpZGdldHMuRGlzcGxheS5ydW5EZWZlcnJlZEV2ZW50cyhEaXNw bGF5LmphdmE6
MzY4MikNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5EaXNwbGF5LnJl YWRBbmREaXNw
YXRjaChEaXNwbGF5LmphdmE6MzI5MykNCglhdCBvcmcuZWNsaXBzZS5qZmFj ZS53aW5kb3cu
V2luZG93LnJ1bkV2ZW50TG9vcChXaW5kb3cuamF2YTo4MjApDQoJYXQgb3Jn LmVjbGlwc2Uu
amZhY2Uud2luZG93LldpbmRvdy5vcGVuKFdpbmRvdy5qYXZhOjc5NikNCglh dCBvcmcuZWNs
aXBzZS5qZmFjZS5kaWFsb2dzLk1lc3NhZ2VEaWFsb2cub3BlblF1ZXN0aW9u KE1lc3NhZ2VE
aWFsb2cuamF2YTozNzEpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwu V29ya2JlbmNo
UGFnZSQyMS5ydW4oV29ya2JlbmNoUGFnZS5qYXZhOjQ4NDIpDQoJYXQgb3Jn LmVjbGlwc2Uu
c3d0LndpZGdldHMuUnVubmFibGVMb2NrLnJ1bihSdW5uYWJsZUxvY2suamF2 YTozNSkNCglh
dCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5TeW5jaHJvbml6ZXIucnVuQXN5 bmNNZXNzYWdl
cyhTeW5jaHJvbml6ZXIuamF2YToxMjMpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0 LndpZGdldHMu
RGlzcGxheS5ydW5Bc3luY01lc3NhZ2VzKERpc3BsYXkuamF2YTozNjU5KQ0K CWF0IG9yZy5l
Y2xpcHNlLnN3dC53aWRnZXRzLkRpc3BsYXkucmVhZEFuZERpc3BhdGNoKERp c3BsYXkuamF2
YTozMjk2KQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLndpbmRvdy5XaW5kb3cu cnVuRXZlbnRM
b29wKFdpbmRvdy5qYXZhOjgyMCkNCglhdCBvcmcuZWNsaXBzZS5qZmFjZS53 aW5kb3cuV2lu
ZG93Lm9wZW4oV2luZG93LmphdmE6Nzk2KQ0KCWF0IG9yZy5lY2xpcHNlLmpm YWNlLmRpYWxv
Z3MuTWVzc2FnZURpYWxvZ1dpdGhUb2dnbGUub3Blbk9rQ2FuY2VsQ29uZmly bShNZXNzYWdl
RGlhbG9nV2l0aFRvZ2dsZS5qYXZhOjE4NikNCglhdCBvcmcuZWNsaXBzZS51 aS5pbnRlcm5h
bC5pZGUuYXBwbGljYXRpb24uSURFV29ya2JlbmNoV2luZG93QWR2aXNvci5w cmVXaW5kb3dT
aGVsbENsb3NlKElERVdvcmtiZW5jaFdpbmRvd0Fkdmlzb3IuamF2YToxNzMp DQoJYXQgb3Jn
LmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2JlbmNoV2luZG93LmZpcmVXaW5k b3dTaGVsbENs
b3NpbmcoV29ya2JlbmNoV2luZG93LmphdmE6MTIxNSkNCglhdCBvcmcuZWNs aXBzZS51aS5p
bnRlcm5hbC5Xb3JrYmVuY2hXaW5kb3cuY2FuSGFuZGxlU2hlbGxDbG9zZUV2 ZW50KFdvcmti
ZW5jaFdpbmRvdy5qYXZhOjc4MCkNCglhdCBvcmcuZWNsaXBzZS5qZmFjZS53 aW5kb3cuV2lu
ZG93JDMuc2hlbGxDbG9zZWQoV2luZG93LmphdmE6NjgxKQ0KCWF0IG9yZy5l Y2xpcHNlLnN3
dC53aWRnZXRzLlR5cGVkTGlzdGVuZXIuaGFuZGxlRXZlbnQoVHlwZWRMaXN0 ZW5lci5qYXZh
OjkxKQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLkV2ZW50VGFibGUu c2VuZEV2ZW50
KEV2ZW50VGFibGUuamF2YTo2NikNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lk Z2V0cy5XaWRn
ZXQuc2VuZEV2ZW50KFdpZGdldC5qYXZhOjkzOCkNCglhdCBvcmcuZWNsaXBz ZS5zd3Qud2lk
Z2V0cy5XaWRnZXQuc2VuZEV2ZW50KFdpZGdldC5qYXZhOjk2MikNCglhdCBv cmcuZWNsaXBz
ZS5zd3Qud2lkZ2V0cy5XaWRnZXQuc2VuZEV2ZW50KFdpZGdldC5qYXZhOjk0 NykNCglhdCBv
cmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5EZWNvcmF0aW9ucy5jbG9zZVdpZGdl dChEZWNvcmF0
aW9ucy5qYXZhOjMwMSkNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5E ZWNvcmF0aW9u
cy5XTV9DTE9TRShEZWNvcmF0aW9ucy5qYXZhOjE2MjEpDQoJYXQgb3JnLmVj bGlwc2Uuc3d0
LndpZGdldHMuQ29udHJvbC53aW5kb3dQcm9jKENvbnRyb2wuamF2YTozNjc0 KQ0KCWF0IG9y
Zy5lY2xpcHNlLnN3dC53aWRnZXRzLkNhbnZhcy53aW5kb3dQcm9jKENhbnZh cy5qYXZhOjI5
MSkNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5EZWNvcmF0aW9ucy53 aW5kb3dQcm9j
KERlY29yYXRpb25zLmphdmE6MTU1NCkNCglhdCBvcmcuZWNsaXBzZS5zd3Qu d2lkZ2V0cy5T
aGVsbC53aW5kb3dQcm9jKFNoZWxsLmphdmE6MTc1MykNCglhdCBvcmcuZWNs aXBzZS5zd3Qu
d2lkZ2V0cy5EaXNwbGF5LndpbmRvd1Byb2MoRGlzcGxheS5qYXZhOjQzNTEp DQoJYXQgb3Jn
LmVjbGlwc2Uuc3d0LmludGVybmFsLndpbjMyLk9TLkRlZldpbmRvd1Byb2NX KE5hdGl2ZSBN
ZXRob2QpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0LmludGVybmFsLndpbjMyLk9T LkRlZldpbmRv
d1Byb2MoT1MuamF2YToyMjYwKQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRn ZXRzLlNoZWxs
LmNhbGxXaW5kb3dQcm9jKFNoZWxsLmphdmE6NDU2KQ0KCWF0IG9yZy5lY2xp cHNlLnN3dC53
aWRnZXRzLkNvbnRyb2wud2luZG93UHJvYyhDb250cm9sLmphdmE6Mzc2MCkN CglhdCBvcmcu
ZWNsaXBzZS5zd3Qud2lkZ2V0cy5DYW52YXMud2luZG93UHJvYyhDYW52YXMu amF2YToyOTEp
DQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuRGVjb3JhdGlvbnMud2lu ZG93UHJvYyhE
ZWNvcmF0aW9ucy5qYXZhOjE1NTQpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0Lndp ZGdldHMuU2hl
bGwud2luZG93UHJvYyhTaGVsbC5qYXZhOjE3NTMpDQoJYXQgb3JnLmVjbGlw c2Uuc3d0Lndp
ZGdldHMuRGlzcGxheS53aW5kb3dQcm9jKERpc3BsYXkuamF2YTo0MzUxKQ0K CWF0IG9yZy5l
Y2xpcHNlLnN3dC5pbnRlcm5hbC53aW4zMi5PUy5EZWZXaW5kb3dQcm9jVyhO YXRpdmUgTWV0
aG9kKQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC5pbnRlcm5hbC53aW4zMi5PUy5E ZWZXaW5kb3dQ
cm9jKE9TLmphdmE6MjI2MCkNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0 cy5TaGVsbC5j
YWxsV2luZG93UHJvYyhTaGVsbC5qYXZhOjQ1NikNCglhdCBvcmcuZWNsaXBz ZS5zd3Qud2lk
Z2V0cy5Db250cm9sLndpbmRvd1Byb2MoQ29udHJvbC5qYXZhOjM3NjApDQoJ YXQgb3JnLmVj
bGlwc2Uuc3d0LndpZGdldHMuQ2FudmFzLndpbmRvd1Byb2MoQ2FudmFzLmph dmE6MjkxKQ0K
CWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLkRlY29yYXRpb25zLndpbmRv d1Byb2MoRGVj
b3JhdGlvbnMuamF2YToxNTU0KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRn ZXRzLlNoZWxs
LndpbmRvd1Byb2MoU2hlbGwuamF2YToxNzUzKQ0KCWF0IG9yZy5lY2xpcHNl LnN3dC53aWRn
ZXRzLkRpc3BsYXkud2luZG93UHJvYyhEaXNwbGF5LmphdmE6NDM1MSkNCglh dCBvcmcuZWNs
aXBzZS5zd3QuaW50ZXJuYWwud2luMzIuT1MuRGlzcGF0Y2hNZXNzYWdlVyhO YXRpdmUgTWV0
aG9kKQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC5pbnRlcm5hbC53aW4zMi5PUy5E aXNwYXRjaE1l
c3NhZ2UoT1MuamF2YToyMjY1KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRn ZXRzLkRpc3Bs
YXkucmVhZEFuZERpc3BhdGNoKERpc3BsYXkuamF2YTozMjkxKQ0KCWF0IG9y Zy5lY2xpcHNl
LnVpLmludGVybmFsLldvcmtiZW5jaC5ydW5FdmVudExvb3AoV29ya2JlbmNo LmphdmE6MjM4
OSkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5Xb3JrYmVuY2gucnVu VUkoV29ya2Jl
bmNoLmphdmE6MjM1MykNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5X b3JrYmVuY2gu
YWNjZXNzJDQoV29ya2JlbmNoLmphdmE6MjIxOSkNCglhdCBvcmcuZWNsaXBz ZS51aS5pbnRl
cm5hbC5Xb3JrYmVuY2gkNC5ydW4oV29ya2JlbmNoLmphdmE6NDY2KQ0KCWF0 IG9yZy5lY2xp
cHNlLmNvcmUuZGF0YWJpbmRpbmcub2JzZXJ2YWJsZS5SZWFsbS5ydW5XaXRo RGVmYXVsdChS
ZWFsbS5qYXZhOjI4OSkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5X b3JrYmVuY2gu
Y3JlYXRlQW5kUnVuV29ya2JlbmNoKFdvcmtiZW5jaC5qYXZhOjQ2MSkNCglh dCBvcmcuZWNs
aXBzZS51aS5QbGF0Zm9ybVVJLmNyZWF0ZUFuZFJ1bldvcmtiZW5jaChQbGF0 Zm9ybVVJLmph
dmE6MTQ5KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLmlkZS5hcHBs aWNhdGlvbi5J
REVBcHBsaWNhdGlvbi5zdGFydChJREVBcHBsaWNhdGlvbi5qYXZhOjEwNikN CglhdCBvcmcu
ZWNsaXBzZS5lcXVpbm94LmludGVybmFsLmFwcC5FY2xpcHNlQXBwSGFuZGxl LnJ1bihFY2xp
cHNlQXBwSGFuZGxlLmphdmE6MTY5KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUu cnVudGltZS5p
bnRlcm5hbC5hZGFwdG9yLkVjbGlwc2VBcHBMYXVuY2hlci5ydW5BcHBsaWNh dGlvbihFY2xp
cHNlQXBwTGF1bmNoZXIuamF2YToxMDYpDQoJYXQgb3JnLmVjbGlwc2UuY29y ZS5ydW50aW1l
LmludGVybmFsLmFkYXB0b3IuRWNsaXBzZUFwcExhdW5jaGVyLnN0YXJ0KEVj bGlwc2VBcHBM
YXVuY2hlci5qYXZhOjc2KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUucnVudGlt ZS5hZGFwdG9y
LkVjbGlwc2VTdGFydGVyLnJ1bihFY2xpcHNlU3RhcnRlci5qYXZhOjM2MykN CglhdCBvcmcu
ZWNsaXBzZS5jb3JlLnJ1bnRpbWUuYWRhcHRvci5FY2xpcHNlU3RhcnRlci5y dW4oRWNsaXBz
ZVN0YXJ0ZXIuamF2YToxNzYpDQoJYXQgc3VuLnJlZmxlY3QuTmF0aXZlTWV0 aG9kQWNjZXNz
b3JJbXBsLmludm9rZTAoTmF0aXZlIE1ldGhvZCkNCglhdCBzdW4ucmVmbGVj dC5OYXRpdmVN
ZXRob2RBY2Nlc3NvckltcGwuaW52b2tlKFVua25vd24gU291cmNlKQ0KCWF0 IHN1bi5yZWZs
ZWN0LkRlbGVnYXRpbmdNZXRob2RBY2Nlc3NvckltcGwuaW52b2tlKFVua25v d24gU291cmNl
KQ0KCWF0IGphdmEubGFuZy5yZWZsZWN0Lk1ldGhvZC5pbnZva2UoVW5rbm93 biBTb3VyY2Up
DQoJYXQgb3JnLmVjbGlwc2UuZXF1aW5veC5sYXVuY2hlci5NYWluLmludm9r ZUZyYW1ld29y
ayhNYWluLmphdmE6NTA4KQ0KCWF0IG9yZy5lY2xpcHNlLmVxdWlub3gubGF1 bmNoZXIuTWFp
bi5iYXNpY1J1bihNYWluLmphdmE6NDQ3KQ0KCWF0IG9yZy5lY2xpcHNlLmVx dWlub3gubGF1
bmNoZXIuTWFpbi5ydW4oTWFpbi5qYXZhOjExNzMpDQoNCiFFTlRSWSBvcmcu ZWNsaXBzZS5q
Y29udGV4dC4gb3JnLmVjbGlwc2UudWkuZWRpdC50ZXh0LmFjdGlvblNldC5u YXZpZ2F0aW9u
DQoJYXQgb3JnLmVjbGlwc2UuY29yZS5jb21tYW5kcy5jb250ZXh0cy5Db250 ZXh0LmdldFBh
cmVudElkKENvbnRleHQuamF2YToyMDEpDQoJYXQgb3JnLmVjbGlwc2UuamZh Y2UuYmluZGlu
Z3MuQmluZGluZ01hbmFnZXIuY3JlYXRlRmlsdGVyZWRDb250ZXh0VHJlZUZv cihCaW5kaW5n
TWFuYWdlci5qYXZhOjgyNSkNCglhdCBvcmcuZWNsaXBzZS5qZmFjZS5iaW5k aW5ncy5CaW5k
aW5nTWFuYWdlci5yZWNvbXB1dGVCaW5kaW5ncyhCaW5kaW5nTWFuYWdlci5q YXZhOjE3MjAp
DQoJYXQgb3JnLmVjbGlwc2UuamZhY2UuYmluZGluZ3MuQmluZGluZ01hbmFn ZXIuY29udGV4
dE1hbmFnZXJDaGFuZ2VkKEJpbmRpbmdNYW5hZ2VyLmphdmE6Njg5KQ0KCWF0 IG9yZy5lY2xp
cHNlLmNvcmUuY29tbWFuZHMuY29udGV4dHMuQ29udGV4dE1hbmFnZXIuZmly ZUNvbnRleHRN
YW5hZ2VyQ2hhbmdlZChDb250ZXh0TWFuYWdlci5qYXZhOjE1MikNCglhdCBv cmcuZWNsaXBz
ZS5jb3JlLmNvbW1hbmRzLmNvbnRleHRzLkNvbnRleHRNYW5hZ2VyLnNldEV2 ZW50Q2FjaGlu
ZyhDb250ZXh0TWFuYWdlci5qYXZhOjMxMSkNCglhdCBvcmcuZWNsaXBzZS5j b3JlLmNvbW1h
bmRzLmNvbnRleHRzLkNvbnRleHRNYW5hZ2VyLmFkZEFjdGl2ZUNvbnRleHQo Q29udGV4dE1h
bmFnZXIuamF2YTo4MCkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5j b250ZXh0cy5D
b250ZXh0QXV0aG9yaXR5LnNvdXJjZUNoYW5nZWQoQ29udGV4dEF1dGhvcml0 eS5qYXZhOjY4
MikNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5zZXJ2aWNlcy5FeHBy ZXNzaW9uQXV0
aG9yaXR5LnNvdXJjZUNoYW5nZWQoRXhwcmVzc2lvbkF1dGhvcml0eS5qYXZh OjMwNSkNCglh
dCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5zZXJ2aWNlcy5FeHByZXNzaW9u QXV0aG9yaXR5
LnNvdXJjZUNoYW5nZWQoRXhwcmVzc2lvbkF1dGhvcml0eS5qYXZhOjI4NSkN CglhdCBvcmcu
ZWNsaXBzZS51aS5BYnN0cmFjdFNvdXJjZVByb3ZpZGVyLmZpcmVTb3VyY2VD aGFuZ2VkKEFi
c3RyYWN0U291cmNlUHJvdmlkZXIuamF2YTo5OCkNCglhdCBvcmcuZWNsaXBz ZS51aS5pbnRl
cm5hbC5zZXJ2aWNlcy5BY3RpdmVTaGVsbFNvdXJjZVByb3ZpZGVyLmFjY2Vz cyQ5KEFjdGl2
ZVNoZWxsU291cmNlUHJvdmlkZXIuamF2YToxKQ0KCWF0IG9yZy5lY2xpcHNl LnVpLmludGVy
bmFsLnNlcnZpY2VzLkFjdGl2ZVNoZWxsU291cmNlUHJvdmlkZXIkMi5oYW5k bGVFdmVudChB
Y3RpdmVTaGVsbFNvdXJjZVByb3ZpZGVyLmphdmE6MjA5KQ0KCWF0IG9yZy5l Y2xpcHNlLnN3
dC53aWRnZXRzLkV2ZW50VGFibGUuc2VuZEV2ZW50KEV2ZW50VGFibGUuamF2 YTo2NikNCglh
dCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5EaXNwbGF5LmZpbHRlckV2ZW50 KERpc3BsYXku
amF2YToxMTQxKQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLldpZGdl dC5zZW5kRXZl
bnQoV2lkZ2V0LmphdmE6OTM3KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRn ZXRzLldpZGdl
dC5zZW5kRXZlbnQoV2lkZ2V0LmphdmE6OTYyKQ0KCWF0IG9yZy5lY2xpcHNl LnN3dC53aWRn
ZXRzLldpZGdldC5zZW5kRXZlbnQoV2lkZ2V0LmphdmE6OTQzKQ0KCWF0IG9y Zy5lY2xpcHNl
LnN3dC53aWRnZXRzLkRlY29yYXRpb25zLldNX0FDVElWQVRFKERlY29yYXRp b25zLmphdmE6
MTU5MSkNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5TaGVsbC5XTV9B Q1RJVkFURShT
aGVsbC5qYXZhOjE4MzMpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMu Q29udHJvbC53
aW5kb3dQcm9jKENvbnRyb2wuamF2YTozNjcwKQ0KCWF0IG9yZy5lY2xpcHNl LnN3dC53aWRn
ZXRzLkNhbnZhcy53aW5kb3dQcm9jKENhbnZhcy5qYXZhOjI5MSkNCglhdCBv cmcuZWNsaXBz
ZS5zd3Qud2lkZ2V0cy5EZWNvcmF0aW9ucy53aW5kb3dQcm9jKERlY29yYXRp b25zLmphdmE6
MTU1NCkNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5TaGVsbC53aW5k b3dQcm9jKFNo
ZWxsLmphdmE6MTc1MykNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5E aXNwbGF5Lndp
bmRvd1Byb2MoRGlzcGxheS5qYXZhOjQzNTEpDQoJYXQgb3JnLmVjbGlwc2Uu c3d0LmludGVy
bmFsLndpbjMyLk9TLlNldEFjdGl2ZVdpbmRvdyhOYXRpdmUgTWV0aG9kKQ0K CWF0IG9yZy5l
Y2xpcHNlLnN3dC53aWRnZXRzLlNoZWxsLmZpeEFjdGl2ZVNoZWxsKFNoZWxs LmphdmE6NzQ0
KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLlNoZWxsLmRlc3Ryb3lX aWRnZXQoU2hl
bGwuamF2YTo2MzUpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuV2lk Z2V0LnJlbGVh
c2UoV2lkZ2V0LmphdmE6NzUwKQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRn ZXRzLldpZGdl
dC5kaXNwb3NlKFdpZGdldC5qYXZhOjQxMCkNCglhdCBvcmcuZWNsaXBzZS5z d3Qud2lkZ2V0
cy5EZWNvcmF0aW9ucy5kaXNwb3NlKERlY29yYXRpb25zLmphdmE6NDQxKQ0K CWF0IG9yZy5l
Y2xpcHNlLnN3dC53aWRnZXRzLlNoZWxsLmRpc3Bvc2UoU2hlbGwuamF2YTo2 NTMpDQoJYXQg
b3JnLmVjbGlwc2UuamZhY2Uud2luZG93LldpbmRvdy5jbG9zZShXaW5kb3cu amF2YTozMzAp
DQoJYXQgb3JnLmVjbGlwc2UuamZhY2UuZGlhbG9ncy5EaWFsb2cuY2xvc2Uo RGlhbG9nLmph
dmE6OTcxKQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLmRpYWxvZ3MuTWVzc2Fn ZURpYWxvZy5i
dXR0b25QcmVzc2VkKE1lc3NhZ2VEaWFsb2cuamF2YToxNjcpDQoJYXQgb3Jn LmVjbGlwc2Uu
amZhY2UuZGlhbG9ncy5EaWFsb2ckMi53aWRnZXRTZWxlY3RlZChEaWFsb2cu amF2YTo2MTYp
DQoJYXQ
Re: JAX-WS RI 2.1.2 Create WSDL Error [message #601203 is a reply to message #374324] |
Wed, 24 October 2007 09:00  |
> !SESSION 2007-10-22 17:40:19.921 -----------------------------------------------
> eclipse.buildId=M20070921-1145
> java.version=1.6.0_02
Just speculating here Mark as the bundles themselves seem to have been
packaged fine. You are running Java 1.6, but we only compile for 1.5. Have you
tested this in a Java 1.5 environment?
Adrian.
Re: JAX-WS RI 2.1.2 Create WSDL Error [message #610566 is a reply to message #374329] |
Thu, 31 January 2008 07:33  |
Re: [stp-newsgroup] Re: JAX-WS RI 2.1.2 Create WSDL Error [message #610567 is a reply to message #374515] |
Fri, 01 February 2008 04:23  |
Johnson
Current Time: Wed Jul 23 06:06:54 EDT 2025
Powered by FUDForum. Page generated in 1.16090 seconds
