Home » Eclipse Projects » Subversive » trunk dir inside branch
trunk dir inside branch [message #37370] Thu, 13 November 2008 04:00 Go to next message
Previously I have been using Subclipse for connection to Subversion in
Eclipse, however to be honest I don't find it a very friendly or helpful
interface/tool. Therefore I decided to see what else was available and
came across Subversive, and I have to say it looks better, seems a little
faster, and generally nicer to user.
However, I have a problem.....
I removed Subclipse and installed Subversive, then checked out my project
afresh using the Find/Checkout As option to use the project wizard.
Everythings fine. However when I try and create a branch, everything
completes correctly, but if I view the repository, inside branch directory
is a directory with my branch name, but inside that rather than seeing
project, there is a directory called trunk, and the project is inside that.
Any ideas?
Re: trunk dir inside branch [message #37438 is a reply to message #37370] Thu, 13 November 2008 05:24 Go to previous messageGo to next message
Hello Tom,
Could you please provide following info:
1. Your repository sctructure, e.g.
[Root]/
trunk/
branches/
foo-1/
foo-2/
trunk
[project]
where [project] is interesting project.
2. How do you call Branch action e.g. from Package Explorer, Synchronize
View, SVN Repositories View etc.?
3. What exactly do you fill in Branch field in "Create Branch" dialog, e.g.
"my_branch_1"?
> that.
> Any ideas?
Re: trunk dir inside branch [message #37784 is a reply to message #37370] Fri, 14 November 2008 03:02 Go to previous messageGo to next message
> little faster, and generally nicer to user.
> project afresh using the Find/Checkout As option to use the project
> wizard. Everythings fine. However when I try and create a branch,
> everything completes correctly, but if I view the repository, inside
> branch directory is a directory with my branch name, but inside that
> rather than seeing project, there is a directory called trunk, and the
> Any ideas?
Might this be related to https://bugs.eclipse.org/246268? That bug is
about tags, but it is not difficult to imagine that the same goes for
branches as well
Jorrit
Re: trunk dir inside branch [message #37880 is a reply to message #37370] Fri, 14 November 2008 09:10 Go to previous messageGo to next message
Originally posted by: lorenzo.martinelli.tele2.it
Another "solution" is commit in trunk folder .project file.
See:
http://www.eclipse.org/newsportal/article.php?id=650&gro up=eclipse.technology.subversive#650
and specially:
http://www.eclipse.org/newsportal/article.php?id=755&gro up=eclipse.technology.subversive#755
In my opinion this is a bug (I don't want commit .project file!!!!) and so
I use TortoiseSVN for tagging and branching
Re: trunk dir inside branch [message #37946 is a reply to message #37784] Mon, 17 November 2008 04:06 Go to previous message
Hello Jorrit,
Thanks, you are right this problem relates to
>> Any ideas?
> branches as well
> Jorrit
Previous Topic:How to create new Reposity
Next Topic:Import of shared projects
Current Time: Sat Jul 26 18:44:04 EDT 2025
Powered by FUDForum. Page generated in 0.05215 seconds
