Home » Archived » M2M (model-to-model transformation) » Composite Class
Composite Class [message #37346] Fri, 11 May 2007 20:58 Go to next message
Originally posted by: mpitanga.gmail.com
I have the following situation:
Class A {
method1,
method2
Class B {
method3,
method4
and I need to create a third Class, for example:
Class C {
method1, // copy from Class A
method2, // copy from Class A
method3, // copy from Class B
method4 // copy from Class B
ps. Class A and Class B belong to the same model.
In the end of the transformation process my model will have 3 classes
Class A {
method1,
method2
Class B {
method3,
method4
Class C {
method4 // copy from Class C
has someone an example?
[ATL] Re: Composite Class [message #37380 is a reply to message #37346] Sat, 12 May 2007 06:42 Go to previous messageGo to next message
"Marcelo Alves" <mpitanga@gmail.com> wrote in message
news:f233ea$j4a$1@build.eclipse.org...
> Class A {
> method1,
> method2
> Class B {
> method3,
> method4
> Class C {
> Class A {
> method1,
> method2
> Class B {
> method3,
> method4
> Class C {
> Thanks
Re: [ATL] Re: Composite Class [message #37482 is a reply to message #37380] Mon, 14 May 2007 06:10 Go to previous messageGo to next message
Originally posted by: rchevrel.sodius.com
I Marcello,
I'm not sure to completely understand what you want to do but you can try:
-- to keep the existing classes
rule ClassToClass {
from
in_cls : MMa!Class
to
out_cls : MMa!Class (
methods <- in_cls.methods...
-- to create the composites classes
rule ClassToComposite {
from
in_cls1 : MMa!Class,
in_cls2 : MMa:Class (
cls1 <> cls2
to
out_comp_cls : MMa!Class (
methods <- in_cls1.methods->union(in_cls2.methods)...
rule MethodToMethod {
It can work only if MMA!Class.methods is not a container feature
(because an element cannot be contained by two element).
If it is a container feature, you have to duplicate the "method"
(probably with a CalledRule). Send a mail more precise if you have some
problems.
Cordially,
*Régis CHEVREL* <mailto:rchevrel@sodius.com>
SODIUS*
*6, rue Cornouaille
44319 Nantes - France
Phone: +33 (0)2 28 23 54 34
***www.mdworkbench.com* <http://www.mdworkbench.com/>* *
Draw more value from your model
Re: [ATL] Re: Composite Class [message #37515 is a reply to message #37482] Mon, 14 May 2007 08:13 Go to previous messageGo to next message
Hi Régis,
Thank you for reply
You said:
"It can work only if MMA!Class.methods is not a container feature (because
If it is a container feature, you have to duplicate the "method" (probably
with a CalledRule). "
and this is my problem.
is possible duplicate a container feature and to point for another class?
Marcelo
Re: [ATL] Re: Composite Class [message #37652 is a reply to message #37515] Tue, 15 May 2007 01:12 Go to previous messageGo to next message
> (probably with a CalledRule). "
As Régis suggested, you may use a called rule. However, I would rather
advise to stick with declarative style, and use a lazy rule ;-).
You only need to add the "lazy" keyword to the beginning of the rule
that transformed the contained elements (i.e., rule Method2Method in
your case), and call the lazy rule by writing something like:
method_list->collect(e | thisModule.Method2Method(e))
where method_list is the list of methods:
- in_cls.methods in rule Class2Class
- in_cls1.methods->union(in_cls2.methods) in rule Class2Composite
Frédéric Jouault
Re: [ATL] Re: Composite Class [message #38619 is a reply to message #37652] Wed, 16 May 2007 10:00 Go to previous message
Hi Frédéric,
The one that you suggested worked fine.
Thank you very much also for the Régis.
Marcelo
Previous Topic:[ATL] how to find an already generated element in non-declarative rules ?
Next Topic:[ATL] Libraries and Prequesites to launch ATL transformations programaticallly from Java
Current Time: Thu Nov 06 01:29:55 EST 2025
Powered by FUDForum. Page generated in 0.03823 seconds
