Home » Modeling » Epsilon » Operation, asInteger() and EOLInteger constructor
Operation, asInteger() and EOLInteger constructor [message #369106] Tue, 28 July 2009 11:57 Go to next message
Hi there,
Just a quick note really.
The other day I was applying asInteger() to certain Strings (which would
usually be number characters). In the Epsilon book, I saw that an error
would be raised if the Strings weren't of an acceptable form (pg. 33). But
I found this not to be the case.
Looking in the EOLInteger constructor (which I believe asInteger() uses),
I see that if the String isn't of a valid form, the EOLInteger object is
set to 0. And in practice, this was the behaviour I was experiencing,
i.e., I didn't get an error even when the String wasn't a number, e.g.,
'Tilly the cat'.
Given this behaviour, I use the following rather pointless looking
operation to determine if a String can be parsed as an integer:
operation String isInteger() : Boolean {
if(self = '0') {
return true;
else if(not(self.asInteger()=0)) {
return true;
else {
return false;
Would it make sense to add an operation to EOLString, which could check if
it could indeed be parsed as an integer? I guess I only suggest this
because if an error was raised after trying to parse an unacceptable
String as an integer, I wouldn't know how to handle the error in Epsilon,
e.g., if the error was an exception thrown by the underpinning Java.
Moreover, it would allow you to check for such cases at runtime without
your application stopping.
Anyway,
Best,
Edd
Re: Operation, asInteger() and EOLInteger constructor [message #369250 is a reply to message #369106] Tue, 28 July 2009 17:41 Go to previous messageGo to next message
Hi Edd,
Sounds like a reasonable enhancement indeed :) Could you please file an
enhancement request in the bugzilla and post the link here?
Dimitris
Edward Turner wrote:
> Hi there,
> But I found this not to be the case.
> uses), I see that if the String isn't of a valid form, the EOLInteger
> object is set to 0. And in practice, this was the behaviour I was
> experiencing, i.e., I didn't get an error even when the String wasn't a
> number, e.g., 'Tilly the cat'.
> if(self = '0') {
> return true;
> return true;
> else {
> return false;
> if it could indeed be parsed as an integer? I guess I only suggest this
> Epsilon, e.g., if the error was an exception thrown by the underpinning
> Java. Moreover, it would allow you to check for such cases at runtime
> without your application stopping.
> Anyway,
> Best,
> Edd
Re: Operation, asInteger() and EOLInteger constructor [message #372650 is a reply to message #369250] Wed, 29 July 2009 06:16 Go to previous message
K, have done, the bug enhancement is here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=284987
PS. I hope I filled in the enhancement request properly, and it doesn't
show up as a bug?!
Ta,
Edd
Re: Operation, asInteger() and EOLInteger constructor [message #571535 is a reply to message #369106] Tue, 28 July 2009 17:41 Go to previous message
Hi Edd,
Dimitris
> Hi there,
> if(self = '0') {
> return true;
> return true;
> else {
> return false;
> Anyway,
> Best,
> Edd
Re: Operation, asInteger() and EOLInteger constructor [message #571568 is a reply to message #369250] Wed, 29 July 2009 06:16 Go to previous message
show up as a bug?!
Ta,
Edd
Previous Topic:Operation, asInteger() and EOLInteger constructor
Next Topic:Loading an instanciated model via EGL loadModel
Current Time: Sun Jul 27 11:24:48 EDT 2025
Powered by FUDForum. Page generated in 0.04067 seconds
