| turn off php syntax checker [message #34818] |
Tue, 10 July 2007 10:18  |
Originally posted by: pobox.verysmall.org
Is it possible to turn off the php syntax checker?
It seems it checks the syntax virtually after every pressed key and
since in Europa PDT is quite slow, I was wondering if this is going to
speed things up.
Iavor
| Re: turn off php syntax checker [message #37232 is a reply to message #36028] |
Thu, 19 July 2007 08:58  |
I guess you can use the latest integration build.
Guy.
"Iavor Raytchev" <pobox@verysmall.org> wrote in message
news:f7i6un$a8u$1@build.eclipse.org...
> Guy Gurfinkel wrote:
>> Hi,
>> What you call syntax checker, is actually builds the data for the
>> outlines, code assist etc.
>> The bad news is you can't disable it, and the good news is that the
>> mechanism was changed and it should work better now.
>> The next build will be ready tomorrow.
> Yes, you are completely right.
> Since Europe on every pressed key everything seems to be re-build (I
> noticed how the Subclipse icons get constantly re-drawn).
> Is 'tomorrow' the 16th?
> The Eclipse updater still does not get any updates, or do you mean it's in
> the nightly? If yes, do you know when it is going to be released?
> Iavor
FUDForum. Page generated in 0.09034 seconds
