Unresolved element when validate using DOM format [message #37111] |
Wed, 11 February 2004 18:09  |
When I parsed the xsd file as DOM and set it to XSDSchema for validation,
it
gave me the following error.
At node [xsd:element], XSD: Element Reference 'http://xyz.com#properties'
is unresolved
However, if I parsed the xsd file directly, it works fine. Any idea?
Here is the XSD file. The properties element does exist in the "xyz.xsd"
schema file in the given location.
<xsd:schema xmlns:cm="http://xyz.com"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:import namespace="http://xyz.com"
schemaLocation="file:///c:/tmp/xyz.xsd" />
<xsd:element name="Simple30">
<xsd:complexType>
<xsd:sequence>
<xsd:element maxOccurs="1" minOccurs="0" ref="cm:properties"/>
</xsd:sequence>
<xsd:attribute name="varchar200" use="optional" default="Hello">
<xsd:simpleType>
<xsd:restriction base="xsd:string">
<xsd:maxLength value="200" />
</xsd:restriction>
</xsd:simpleType>
</xsd:attribute>
</xsd:complexType>
</xsd:element>
</xsd:schema>
Here is how I validate the schema.
Element schemaElem = xsdDOMObject.getDocumentElement();
if (schemaElem.getLocalName().equals("schema")
XSDConstants.isSchemaForSchemaNamespace(schemaElem.getNamesp aceURI())) {
xsdSchema = xsdFactory.createXSDSchema();
xsdSchema.setElement(schemaElem);
xsdSchema.validate();
// Check the result of parsing schema
checkDiagnostics(xsdSchema);
} else {
// Throw an exception
Thanks.
Joshua
Re: Unresolved element when validate using DOM format [message #37214 is a reply to message #37111] |
Thu, 12 February 2004 09:32  |
Joshua,
Unless your schema is in a resource in a resource set, it won't be able to
demand load any imported or included schemas, i.e., all external references
will fail to resolve.
Joshua Hui wrote:
> it
> is unresolved
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:attribute>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
> } else {
> Thanks.
> Joshua
Re: Unresolved element when validate using DOM format [message #583445 is a reply to message #37111] |
Joshua,
Joshua Hui wrote:
> it
> is unresolved
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:attribute>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
> } else {
> Thanks.
> Joshua
FUDForum. Page generated in 0.03178 seconds
