Home » Eclipse Projects » Standard Widget Toolkit (SWT) » unable to start eclipse with j2sdk 1.4.2
unable to start eclipse with j2sdk 1.4.2 [message #371654] Sun, 13 July 2003 13:04 Go to next message
Originally posted by: devsteff.gmx.de
After installing the new sun J2SDK 1.4.2 my eclipse isn't startable
anymore. There should is a problem with swt DrawText (see below). My OS is
Microsoft Windows XP. On NT4 I have the same software (vm & eclipse) and
no problems at all.
Any hints? Thanks.
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x77D5C059
Function=[Unknown.]
Library=C:\WINDOWS\system32\USER32.dll
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
at org.eclipse.swt.internal.win32.OS.DrawTextW(Native Method)
at org.eclipse.swt.internal.win32.OS.DrawText(OS.java:1244)
at org.eclipse.swt.graphics.GC.drawText(GC.java:1265)
at org.eclipse.swt.graphics.GC.drawText(GC.java:1216)
at org.eclipse.swt.custom.CLabel.onPaint(CLabel.java:380)
at org.eclipse.swt.custom.CLabel.access$0(CLabel.java:287)
at org.eclipse.swt.custom.CLabel$1.paintControl(CLabel.java:102 )
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:80)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:66 5)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2726 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:1992 )
at org.eclipse.swt.internal.win32.OS.UpdateWindow(Native Method)
at org.eclipse.swt.widgets.Decorations.setVisible(Decorations.j ava:1247)
at org.eclipse.swt.widgets.Shell.setVisible(Shell.java:1012)
at org.eclipse.swt.widgets.Shell.open(Shell.java:676)
at org.eclipse.jface.window.Window.open(Window.java:538)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:357)
at
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:750)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:581)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1319)
at
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:831)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
Dynamic libraries:
0x00400000 - 0x00407000 C:\WINDOWS\system32\javaw.exe
0x77F40000 - 0x77FEE000 C:\WINDOWS\System32\ntdll.dll
0x77E40000 - 0x77F38000 C:\WINDOWS\system32\kernel32.dll
0x77DA0000 - 0x77E3C000 C:\WINDOWS\system32\ADVAPI32.dll
0x78000000 - 0x7807F000 C:\WINDOWS\system32\RPCRT4.dll
0x77D10000 - 0x77D96000 C:\WINDOWS\system32\USER32.dll
0x77C40000 - 0x77C80000 C:\WINDOWS\system32\GDI32.dll
0x77BE0000 - 0x77C33000 C:\WINDOWS\system32\MSVCRT.dll
0x08000000 - 0x08136000 C:\Programme\Java\j2re1.4.2\bin\client\jvm.dll
0x76AF0000 - 0x76B1D000 C:\WINDOWS\system32\WINMM.dll
0x10000000 - 0x10007000 C:\Programme\Java\j2re1.4.2\bin\hpi.dll
0x00820000 - 0x0082E000 C:\Programme\Java\j2re1.4.2\bin\verify.dll
0x00830000 - 0x00848000 C:\Programme\Java\j2re1.4.2\bin\java.dll
0x00850000 - 0x0085D000 C:\Programme\Java\j2re1.4.2\bin\zip.dll
0x03270000 - 0x032B5000
D:\Programme\eclipse2x1\plugins\org.eclipse.swt.win32_2.0.2\ os\win32\x86\swt-win32-2052.dll
0x77180000 - 0x772A1000 C:\WINDOWS\system32\ole32.dll
0x77310000 - 0x7739B000 C:\WINDOWS\system32\COMCTL32.dll
0x76350000 - 0x76396000 C:\WINDOWS\system32\comdlg32.dll
0x032C0000 - 0x03324000 C:\WINDOWS\system32\SHLWAPI.dll
0x773A0000 - 0x77B9C000 C:\WINDOWS\system32\SHELL32.dll
0x770F0000 - 0x7717B000 C:\WINDOWS\system32\OLEAUT32.dll
0x76330000 - 0x7634C000 C:\WINDOWS\system32\IMM32.dll
0x78090000 - 0x78174000
C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595 b64144ccf1df_6.0.10.0_x-ww_f7fb5805\comctl32.dll
0x5B0F0000 - 0x5B124000 C:\WINDOWS\System32\uxtheme.dll
0x746A0000 - 0x746E4000 C:\WINDOWS\System32\MSCTF.dll
0x74C00000 - 0x74C2C000 C:\WINDOWS\system32\oleacc.dll
0x76020000 - 0x76081000 C:\WINDOWS\system32\MSVCP60.dll
0x76C50000 - 0x76C72000 C:\WINDOWS\system32\imagehlp.dll
0x6DA00000 - 0x6DA7D000 C:\WINDOWS\system32\DBGHELP.dll
0x77BD0000 - 0x77BD7000 C:\WINDOWS\system32\VERSION.dll
0x76BB0000 - 0x76BBB000 C:\WINDOWS\system32\PSAPI.DLL
Heap at VM Abort:
Heap
def new generation total 576K, used 231K [0x10010000, 0x100b0000,
0x104f0000)
eden space 512K, 43% used [0x10010000, 0x10047318, 0x10090000)
from space 64K, 17% used [0x10090000, 0x10092c88, 0x100a0000)
to space 64K, 0% used [0x100a0000, 0x100a0000, 0x100b0000)
tenured generation total 4628K, used 3178K [0x104f0000, 0x10975000,
0x14010000)
the space 4628K, 68% used [0x104f0000, 0x1080a910, 0x1080aa00,
0x10975000)
compacting perm gen total 8704K, used 8682K [0x14010000, 0x14890000,
0x18010000)
the space 8704K, 99% used [0x14010000, 0x1488abd8, 0x1488ac00,
0x14890000)
Local Time = Sun Jul 13 18:37:42 2003
Elapsed Time = 3
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2-b28 mixed mode)
Re: unable to start eclipse with j2sdk 1.4.2 [message #371663 is a reply to message #371654] Mon, 14 July 2003 06:06 Go to previous message
Originally posted by: hcs33.egon.gyaloglo.hu
This is https://bugs.eclipse.org/bugs/show_bug.cgi?id=34940. You should
upgrade to Eclipse 2.1.1 where this bug is fixed.
HTH,
Csaba
"Stefan Flick" <devsteff@gmx.de> wrote in message
news:bes3eb$5b4$1@eclipse.org...
> no problems at all.
> Any hints? Thanks.
> PC=0x77D5C059
> Function=[Unknown.]
> at
> at
> at
a:831)
> Dynamic libraries:
-win32-2052.dll
..10.0_x-ww_f7fb5805\comctl32.dll
> Heap at VM Abort:
> Heap
> 0x104f0000)
> 0x14010000)
> 0x10975000)
> 0x18010000)
> 0x14890000)
> Elapsed Time = 3
Previous Topic:why are certain components final?
Next Topic:PageIncrement (ScrollBar)
Current Time: Sun Jul 27 11:56:40 EDT 2025
Powered by FUDForum. Page generated in 0.04570 seconds
