Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Convert Everything from VB Form!
Convert Everything from VB Form! [message #371273] Thu, 26 June 2003 13:12 Go to next message
Originally posted by: thousandvb.yeah.net
Hi all ,I just wrote a VB2SWT convertor tonight which converts
everything(menu, instinct vb controls) to SWT Source Code Format. Those that
can not be converted control become swt.label.
Anyone insterested in it, reply to this post.
See screenshots here:
http://tonyyang.3322.org/swt/index.html
Tony Yang
Below is a sample:
import org.eclipse.swt.*;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.events.*;
import org.eclipse.swt.graphics.*;
class Test4
public static void main(String[] args)
Display display = new Display();
Shell shell = new Shell(display, SWT.CLOSE );
shell.setSize(450 ,272);
shell.setText("New Project");
Group Frame1 = new Group(shell, SWT.NONE);
Frame1.setText("Database Connection");
Frame1.setBounds(8, 9, 430, 106);
Label Label2 = new Label(Frame1, SWT.NONE);
Label2.setText("Connect String:");
Label2.setBounds(13, 23, 73, 13);
Label Label1 = new Label(Frame1, SWT.NONE);
Label1.setText("Login Name:");
Label1.setBounds(13, 49, 60, 13);
Label Label3 = new Label(Frame1, SWT.NONE);
Label3.setText("Login Password:");
Label3.setBounds(13, 75, 78, 13);
Button cmdGetConnectStr = new Button(Frame1, SWT.PUSH);
cmdGetConnectStr.setText("...");
cmdGetConnectStr.setBounds(396, 21, 21, 19);
Combo cboConnectString = new Combo(Frame1, SWT.NONE);
cboConnectString.setBounds(99, 20, 297, 21);
Text txtUsername = new Text(Frame1, SWT.SINGLE |SWT.BORDER );
txtUsername.setText("");
txtUsername.setBounds(99, 47, 118, 20);
Text txtPassword = new Text(Frame1, SWT.SINGLE |SWT.BORDER );
txtPassword.setText("");
txtPassword.setBounds(99, 73, 118, 20);
Button chkSavePass = new Button(Frame1, SWT.CHECK);
chkSavePass.setText("&Save password");
chkSavePass.setBounds(225, 72, 97, 22);
Group Frame2 = new Group(shell, SWT.NONE);
Frame2.setText("Project Information");
Frame2.setBounds(8, 123, 430, 84);
Label Label4 = new Label(Frame2, SWT.NONE);
Label4.setText("Database Type:");
Label4.setBounds(12, 24, 76, 13);
Label Label5 = new Label(Frame2, SWT.NONE);
Label5.setText("Project Path:");
Label5.setBounds(12, 52, 61, 13);
Combo cboDBType = new Combo(Frame2, SWT.DROP_DOWN | SWT.READ_ONLY);
cboDBType.setBounds(98, 22, 122, 21);
Button chkUseAddin = new Button(Frame2, SWT.CHECK);
chkUseAddin.setText("&Use Available Addin");
chkUseAddin.setBounds(225, 24, 136, 18);
Text txtProjectPath = new Text(Frame2, SWT.SINGLE |SWT.BORDER );
txtProjectPath.setText("");
txtProjectPath.setBounds(98, 50, 297, 20);
Button cmdGetPath = new Button(Frame2, SWT.PUSH);
cmdGetPath.setText("...");
cmdGetPath.setBounds(396, 50, 21, 20);
Button cmdOK = new Button(shell, SWT.PUSH);
cmdOK.setText("OK");
cmdOK.setBounds(259, 215, 84, 24);
Button cmdCancel = new Button(shell, SWT.PUSH);
cmdCancel.setText("Cancel");
cmdCancel.setBounds(354, 215, 84, 24);
Button cmdWizard = new Button(shell, SWT.PUSH);
cmdWizard.setText("&Wizard...");
cmdWizard.setBounds(8, 215, 110, 24);
shell.open();
while(!shell.isDisposed()){
if(!display.readAndDispatch())
display.sleep();
display.dispose();
Re: Convert Everything from VB Form! [message #371288 is a reply to message #371273] Thu, 26 June 2003 17:37 Go to previous messageGo to next message
Originally posted by: steve_northover.ca.ibm.com
Please check to see if https://bugs.eclipse.org/bugs/show_bug.cgi?id=12220
is the problem you are seeing.
If so, it has just been fixed so please retry your code.
"Tony Yang" <thousandvb@yeah.net> wrote in message
news:bdf9hp$qj7$1@rogue.oti.com...
that
> Tony Yang
> Below is a sample:
> class Test4
> shell.open();
> display.sleep();
> display.dispose();
Re: Convert Everything from VB Form! [message #371300 is a reply to message #371288] Fri, 27 June 2003 13:52 Go to previous messageGo to next message
Oops, missed. My clicking aim is bad.
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:bdfp2p$9fo$1@rogue.oti.com...
> that
> > Tony Yang
> > Below is a sample:
> > class Test4
> > shell.open();
> > display.sleep();
> > display.dispose();
Re: Convert Everything from VB Form! [message #371303 is a reply to message #371273] Fri, 27 June 2003 14:32 Go to previous messageGo to next message
Originally posted by: agcolston.buckman.com
I am interested... looks like nice work.
Tony
that
> Tony Yang
> Below is a sample:
> class Test4
> shell.open();
> display.sleep();
> display.dispose();
Re: Convert Everything from VB Form! [message #371321 is a reply to message #371273] Sat, 28 June 2003 14:40 Go to previous message
Originally posted by: ilias_solo.yahoo.com
I am really interested in what it seems a good work from you.
Elias
> Tony Yang
> Below is a sample:
> class Test4
> shell.open();
> display.sleep();
> display.dispose();
Previous Topic:Defferent between Eclipse 2 and 2.1
Next Topic:Re: Use VB Designer to generate SWT UI source code
Current Time: Sun Sep 21 14:21:25 EDT 2025
Powered by FUDForum. Page generated in 0.04019 seconds
