| FontDialog hangs on MacOS X under Java 1.4.1 [message #370847] |
Wed, 11 June 2003 13:30  |
I'm having problems running an application I am building with Eclipse on
MacOS X. I'm
running the application using JDK 1.4.1 from Apple, but when I come to
raise the
FontDialog (or ColorDialog) using Eclipse 2.1 M1 (June 5), the application
hangs and I
get the following error message in the console:
2003-06-11 13:13:04.880 JavaApplicationStub[1058] ***
_NSAutoreleaseNoPool():
Object 0x14996490 of class NSCFArray autoreleased with no pool in place -
just
leaking
If I run it under JDK 1.3.1, I do not get this problem (though, some parts
of my app that
require 1.4.1 can't be used).
It all works OK on Win XP.
Also, if I use the Eclipse build for Eclipse 3 (I20030611), I get the same
error plus
additional errors and the application crashes. Under Eclipse 3, the errors
are:
just
leaking
2003-06-11 13:13:05.292 JavaApplicationStub[1058] An uncaught exception
was
raised
2003-06-11 13:13:05.295 JavaApplicationStub[1058] *** -[NSCFArray
objectAtIndex:]: index (1) beyond bounds (1)
2003-06-11 13:13:05.296 JavaApplicationStub[1058] *** Uncaught exception: <
NSRangeException> *** -[NSCFArray objectAtIndex:]: index (1) beyond bounds (1)
Can anyone tell me what's going on, and how the problem can be fixed? Any
help
would be appreciated.
Bradley Schmerl
Systems Scientist
School of Computer Science
Carnegie Mellon University
Pittsburgh PA 15221
| Re: FontDialog hangs on MacOS X under Java 1.4.1 [message #370848 is a reply to message #370847] |
Wed, 11 June 2003 14:23  |
Originally posted by: veronika_irvine.oti.com
See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=30021
"Bradley Schmerl" <schmerl@cs.cmu.edu> wrote in message
news:bc7p0j$77c$1@rogue.oti.com...
> MacOS X. I'm
> raise the
> hangs and I
> just
> leaking
> of my app that
> error plus
> are:
> just
> leaking
> was
> raised
(1)
> help
> Bradley Schmerl
> Systems Scientist
> Pittsburgh PA 15221
FUDForum. Page generated in 0.03764 seconds
