Home » Eclipse Projects » Subversive » Accessing the Revision Properties view
Accessing the Revision Properties view [message #36896] Wed, 12 November 2008 08:03 Go to next message
Hello Igor,
quoting from thread "pre-revprop-change hook and changing log messages"
> There is a Revision Properties view which allows to edit revision properties
> including comments.
> You can access it in the following way:
> - access History View. You can do it by calling "Show History" action, e.g.
> from Synchronize view or from Package Explorer, for any resource which is
> under version control(SVN).
> - select needed revision in History view and right click, then call "Show
> Revision Properties" action. As a result you'll have "Revision Properties"
> view where you can add new or edit existing revision properties. For
> instance, you'll have svn:date and svn:log properties, where svn:log
> property corresponds to comment.
I cannot see any menu entry "Show Revision Properties", just
- Open
- Compare Current with ...
- Get Contents
- Get Sticky Revision
- Tag with Existing...
- Show Annotation
- Refresh View
- Add to Task Context
- Open Corresponding Task
I am using Eclipse 3.3.2 with Mylyn 3.0.3 and Subversive 7.0.3.I20080814-1500.
Shall I use another perspective or view etc., enable some property?
Cheers, Jörg
Re: Accessing the Revision Properties view [message #36965 is a reply to message #36896] Wed, 12 November 2008 09:39 Go to previous message
Hello J
Previous Topic:using subversive
Next Topic:Want archived svn-connectors(2.0.4)
Current Time: Wed Jul 23 11:43:28 EDT 2025
Powered by FUDForum. Page generated in 0.03752 seconds
