| Home » Eclipse Projects » Standard Widget Toolkit (SWT) » tabletree cell
 Goto Forum:|
| tabletree cell [message #369585] | Mon, 05 May 2003 07:22  |  |
| Eclipse User  |  |  |  |  | Originally posted by: monicas.noida.hcltech.com
 I have a TreeTable. i want that when ever i right click on any cell then i
 should be able to have a popup menu visible also i should be able to get
 the item in that particular cell.
 can u suggest something.
 Thanks and Regards,
 Monica
| Re: tabletree cell [message #369598 is a reply to message #369585] | Mon, 05 May 2003 10:25   |  |
| Eclipse User  |  |  |  |  | Originally posted by: veronika_irvine.oti.com
 Setting a popup menu on a TableTree is fairly simple:
 TableTree tree = new TableTree(shell, SWT.BORDER);
 Table table = tree.getTable();
 Menu menu = new Menu (shell, SWT.POP_UP);
 MenuItem item = new MenuItem (menu, SWT.PUSH);
 item.setText ("menu item");
 item.addSelectionListener(new SelectionAdapter() {
 public void widgetSelected(SelectionEvent e) {
 System.out.println("hello");
 table.setMenu(menu);
 However, knowing what cell you are over is not.  The problem is that the
 popmenu can be activated by the keyboard (Shift F10 on Windows) or by the
 mouse.  If the menu is activated by the keyboard, it pops up wherever the
 cursor is (which may not be over the TableTree at all).  You could find out
 where the cursor is and use that to find an item but it doesn't really work
 because you move the cursor to select the menu item and loose your place:
 Point p = display.getCursorLocation();
 p = table.toControl(p);
 TableTreeItem item = tree.getItem(p);
 if (item == null) return;
 int count = table.getColumnCount();
 for (int i = 0; i < count; i++) {
 if (item.getBounds(i).contains(p)) {
 System.out.println(item.getText(i));
 break;
 In 3.0, we have introduced the MenuDetect event.  It is much better to use
 this event rather than detecting a right mouse down event because different
 platforms bring up menus on different events (e,g, Windows uses mouse up and
 motif uses mouse down) and there are also keyboard accelerators to consider.
 The MenuDetect event gives the x, y, coordinates of where the menu will
 appear which you could use to locate a cell.  It still has the problem that
 when a keyboard accelerator is used, the x and y coordinates are just the
 location of the cursor which could be anywhere and is therefore not very
 useful to people with accessibility problems.
 final TableTreeItem[] menuItem = new TableTreeItem[1];
 final int[] menuItemColumn = new int[1];
 final Menu menu = new Menu (shell, SWT.POP_UP);
 if (menuItem[0] != null) {
 System.out.println(menuItem[0].getText(menuItemColumn[0]));
 table.addListener(SWT.MenuDetect, new Listener() {
 public void handleEvent(org.eclipse.swt.widgets.Event event) {
 menuItem[0] = null;
 Point p = new Point(event.x, event.y);
 menu.setLocation(event.x, event.y);
 menu.setVisible(true);
 menuItem[0] = item;
 menuItemColumn[0] = i;
 break;
 "Monica" <monicas@noida.hcltech.com> wrote in message
 news:b95hht$50k$1@rogue.oti.com...
 > Thanks and Regards,
 > Monica
| Re: tabletree cell [message #369622 is a reply to message #369598] | Tue, 06 May 2003 01:36   |  |
 Thanks for the reply. but it isnt able to solve my problem.
 Actually, i have a decoration on which i have a couple of things like a
 menu bar, a tabletree.
 it looks somethink like
 |Menu1                       |
 | |     Table Tree        |  |
 Now, the objective is that whenever i click on any cell of the tabletree
 then firstly i should be able to retrieve the value in that particular
 cell and then depending on that retrieved value a pop up menu should be
 displayed. this pop up menu has some menuitems which are enabled or
 diabled depending on the value in the tabletree cell.
 i think now i am able to tell the problem i am facing properly.
 can u tell some way out to achieve the desired objective,
 Thanks and Regards,
 Monica
 >                         break;
 >                 menuItem[0] = null;
 >                                 menuItem[0] = item;
 >                                 break;
 > > Hi,
 > > Thanks and Regards,
 > > Monica
| Re: tabletree cell [message #369636 is a reply to message #369622] | Tue, 06 May 2003 09:19  |  |
 The mouse event has x and y coordinates.  You can use this to identify the
 cell you clicked on:
 Point p = new Point(mouseEvent.x, mouseEvent.y);
 System.out.println("Cell contains "+item.getText(i));
 break;
 Note that by relying on a mouse click you have made your application
 inaccessible to users who can not use a mouse.
 news:b97hk8$h4f$1@rogue.oti.com...
 > |Menu1                       |
 > | |     Table Tree        |  |
 > Thanks and Regards,
 > Monica
 the
 the
 out
 work
 place:
 > >                         break;
 use
 different
 and
 consider.
 that
 the
 > >                 menuItem[0] = null;
 > >                                 menuItem[0] = item;
 > >                                 break;
 > > > Hi,
 then i
 get
 > > > Thanks and Regards,
 > > > Monica
 Current Time: Fri Oct 31 06:50:05 EDT 2025
 Powered by FUDForum . Page generated in 0.04387 seconds |
