Bug 280841 doesn't seem to be fixed for me.... [message #369137] |
Tue, 28 July 2009 16:09  |
Originally posted by: theycallmecoach.gmail.com
I have run into bug 280841 which is supposed to be fixed in the latest
release. (Unable to profile eclipse based applications, dies with null
pointer).
However, I'm running galileo with the latest tptp (4.6.0) so this bug
should be fixed. Is there any other reason I could be encountering this
bug? Or can someone point me to a description about how to work around
this problem?
FYI I can profile non-eclipse based applications. so I believe my
environment is setup correctly.
Kyle
Re: Bug 280841 doesn't seem to be fixed for me.... [message #375030 is a reply to message #369137] |
Wed, 29 July 2009 13:33  |
Hi Kyle,
The Galileo build does not contain the fix for the subject bug. It was
contained after the Galileo cutoff date, as a result, please run a software
update from your Galileo driver to pick up the latest code fix. You can also
try with the 4.6. all-in-one TPTP driver from the TPTP download site.
Eugene
"Kyle Girard" <theycallmecoach@gmail.com> wrote in message
news:837c02f727226d45362186217b8b343a$1@www.eclipse.org...
>pointer).
> this problem?
> Kyle
FUDForum. Page generated in 0.02659 seconds
