Home » Modeling » TMF (Xtext) » Inserting editor generated by Xtext to FormPage
Inserting editor generated by Xtext to FormPage [message #60015] Fri, 17 July 2009 07:24 Go to next message
it is possible to insert editor generated by Xtext to
org.eclipse.ui.forms.editor.FormPage?
Now we use org.eclipse.swt.widgets.Text in this form page to enter part of
a configuration specified in our DSL. Our idea is to add support of syntax
coloring etc. by using editor generated by Xtext instead it.
David
Re: Inserting editor generated by Xtext to FormPage [message #60255 is a reply to message #60015] Fri, 17 July 2009 14:11 Go to previous messageGo to next message
Hi David,
I'm not that familiar with all this SWT and JFace stuff, but it should
be possible to reuse the XtextEditor.
Usually one would try to obtain the SourceViewer from the editor and use
the underlying widget directly.
Hope that helps,
Sebastian
Am 17.07.2009 13:24 Uhr, schrieb David:
> Hello,
> of a configuration specified in our DSL. Our idea is to add support of
> syntax coloring etc. by using editor generated by Xtext instead it.
> David
Re: Inserting editor generated by Xtext to FormPage [message #63011 is a reply to message #60255] Sun, 26 July 2009 13:09 Go to previous messageGo to next message
Hi Sebastian,
thank you very much for your help.
Yes, if it would be possible to get instance of SourceViewer, one could
get instance of StyledText and place it to a container in FormPage.
Unfortunately, method getSourceViewer of class AbstractTextEditor is
protected and it is not accessible from an instance of XtextEditor.
It is possible to get SourceViewer from an instance of XtextEditor?
Thank you,
David
Sebastian Zarnekow wrote:
> Hi David,
> Hope that helps,
> Sebastian
Re: Inserting editor generated by Xtext to FormPage [message #63018 is a reply to message #63011] Mon, 27 July 2009 03:19 Go to previous messageGo to next message
Hi David,
it is possible to exchange the concrete class of the XtextEditor via
google guice. You should create a subclass and introduce a method that
exposes the SourceViewer.
The binding in your UIModule should look like this:
Class<? extends XtextEditor> bindEditor() {
return MyEditor.class;
and the editor class may look as follows.
public class MyEditor extends XtextEditor {
public ISourceViewer publicGetSourceViewer() {
return getSourceViewer(); // final and protected in super class
Sebastian
Am 26.07.2009 19:09 Uhr, schrieb David:
> Hi Sebastian,
> Thank you,
> David
>> Hi David,
>> use the underlying widget directly.
>> Hope that helps,
>> Sebastian
Re: Inserting editor generated by Xtext to FormPage [message #361994 is a reply to message #63018] Tue, 28 July 2009 09:55 Go to previous messageGo to next message
Hi Sebastian,
thank you very much. I created the concrete class and registered it in
UIModule. However, opening file in our DSL still creates an instance of
XTextEditor.
Following code results in printing "Not an instance of TBPEditor":
IWorkspaceRoot root= ResourcesPlugin.getWorkspace().getRoot();
IProject project = root.getProject("Test-Project-1");
IFile file = project.getFile(new Path("test.tbp"));
file.create(new ByteArrayInputStream("".getBytes()), true, null);
FileEditorInput editorInput = new FileEditorInput(file);
XtextEditor editor = (XtextEditor) getPage().openEditor(editorInput,
"org.objectweb.dsrg.sofa.tbp.TBP");
if (editor instanceof TBPEditor) {
System.out.println("Instance of TBPEditor.")
} else {
System.out.println("Not an instance of TBPEditor");
Best wishes,
David
> Hi David,
> Regards,
> Sebastian
Re: Inserting editor generated by Xtext to FormPage [message #369096 is a reply to message #361994] Tue, 28 July 2009 10:50 Go to previous message
Hi David,
sorry, my previous post was misleading. The bind-Method in your UIModule
has to be public.
Hope that helps,
Sebastian
Am 28.07.2009 15:55 Uhr, schrieb David:
> Hi Sebastian,
> XTextEditor.
> } else {
> Best wishes,
> David
>> Hi David,
>> Regards,
>> Sebastian
Previous Topic:Hidden Terminals
Next Topic:[XText] about grammar ambiguity, left recursion
Current Time: Fri Nov 07 18:39:02 EST 2025
Powered by FUDForum. Page generated in 0.07032 seconds
