Using privileged ports for RSE [message #36693] |
Wed, 01 July 2009 07:47  |
Is there a limitation on using privileged ports (<1024) for the
serverPortRange for RSE? We can use a privileged port for the daemon port
but when we tried using privileged ports for the serverPortRange, it looks
like it answers the connection request, but the connection fails.
We are attempting this in an effort to make the connections more secure so
if there is some limitation, we are interested in how we could remove the
limitation.
Thanks.
Re: Using privileged ports for RSE [message #36964 is a reply to message #36930] |
Thu, 02 July 2009 14:23  |
"Denise Schmidt" <denise.schmidt@lmco.com> wrote in message
news:863819bfe4506ac862880afe40272127$1@www.eclipse.org...
> In order to bind a socket to a privileged port, the process must be
> running as root. So I think it must be failing because the server process
> is running as the client user ID (auth.pl does an "su" to the client user
> ID to spawn the server). I assume that the server runs as the client user
> ID for a reason (exporting the client environment, client permissions,
> etc).
That would explain it then. The daemon needs to be run as root but the
servers that gets started as run as the client user.
> So my next question would be is there a way that the server could maybe
> start executing as root to bind the socket and make the connection, then
> switch to the client user ID to get the proper environment and do the
> remaining "real" work? Could that work or would there still be problems
> sending data over the port?
At the moment there is no ability to for the server to start executing as
root and then switch to the client user.
Re: Using privileged ports for RSE [message #581650 is a reply to message #36693] |
Thu, 02 July 2009 11:06  |
Hi Denise,
The RSE dstore server doesn't distinguish between privileged and
non-privileged ports so I'm not sure what's causing the connection to fail
in this case.
Dave
news:54182907978dce56be59393be8a5b7bb$1@www.eclipse.org...
> limitation.
> Thanks.
Re: Using privileged ports for RSE [message #581662 is a reply to message #36897] |
Thu, 02 July 2009 12:04  |
etc).
Re: Using privileged ports for RSE [message #581678 is a reply to message #36930] |
> etc).
FUDForum. Page generated in 0.05182 seconds
