Home » Archived » BIRT » Several table filters : "or" condition
Several table filters : "or" condition [message #368618] |
Tue, 16 June 2009 05:59  |
Hi all,
When adding several items to a Table Filters, an "and" condition is
applied between each of them (ie the result is the intersection of each
filter).
Is there a way to indicate that an "or" condition should be applied (ie
the result is the addition of each filter) ?
Loïc
Re: Several table filters : "or" condition [message #892593 is a reply to message #892434] |
Thu, 28 June 2012 12:12   |
Stephane,
Can you try one more thing. Modify your filter expression to something
like:
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/temp/filterevents.txt", true ) );
out.println( "--"+row["PRODUCTCODE"]);
out.println( "---"+BirtComp.like(row["PRODUCTCODE"], "%S18%"));
out.close();
BirtComp.like(row["PRODUCTCODE"], "%S18%");
Kind of a bad way to debug, but while birt has javascript event handler
debugging, filtering does not.
Jason
On 6/28/2012 4:32 AM, Stephane Turpin wrote:
> sorry for the delay.
> I tried your report design and indeed the filter applied on the table
> works.
> The only difference I see between you report and mine is the data
> source, but I do not see how it could interfere in the result set.
> So, I am still stuck.
> Even if it works in an "AND" clause, we cannot reasonably explain to our
> clients that they can use it in an "AND" but not in an "OR" clause.
> So in the mean time, I took off the option of "Like" and "Between" in
> the filter choices of our product.
> My last resort is to download BIRT sources and in debugging mode try to
> see why it does not work.
Re: Several table filters : "or" condition [message #892978 is a reply to message #892593] |
Mon, 02 July 2012 04:21   |
Hi Jason,
ok, I tried your debugging code on a simple report design with a column "routingMode" with values in ("Electronique", "Sans routage", "Trade blotter").
If I put this code in the filter expression (Operator still at "Equal to" and value1 at "true):
out = new PrintWriter( new FileWriter( "c:/Temp/filterevents.txt", true ) );
out.println( "---" + row["routingMode"] + "---");
out.close();
true
In the filterevents.txt I have:
---Electronique---
---Trade blotter---
---Electronique---
---Electronique---
---Sans routage---
etc...
and my report is complete (normal, I put "true" in the last line of the filter expression)
But if I had to the filter expression a dummy BirtComp.like like this:
out.println( "---" + BirtComp.like("Electronique", "%ctro%") + "---");
out.close();
true
then the filterevents.txt is created but empty, so is the report.
It seems that something in my environment does not recognize the BirtComp and stop processing the report.
Stephane
Re: Several table filters : "or" condition [message #893151 is a reply to message #892978] |
Mon, 02 July 2012 18:25   |
Are you running 3.7.0? Can you try the attached?
Jason
On 7/2/2012 4:21 AM, Stephane Turpin wrote:
> Hi Jason,
> blotter").
> out.close();
> true
> ---Electronique---
> ---Trade blotter---
> ---Electronique---
> ---Electronique---
> ---Sans routage---
> etc...
> filter expression)
> out.close();
> true
> Stephane
Re: Several table filters : "or" condition [message #893152 is a reply to message #892978] |
Jason
> Hi Jason,
> blotter").
> out.close();
> true
> ---Electronique---
> ---Trade blotter---
> ---Electronique---
> ---Electronique---
> ---Sans routage---
> etc...
> filter expression)
> out.close();
> true
> Stephane
Re: Several table filters : "or" condition [message #893153 is a reply to message #892978] |
Jason
> Hi Jason,
> blotter").
> out.close();
> true
> ---Electronique---
> ---Trade blotter---
> ---Electronique---
> ---Electronique---
> ---Sans routage---
> etc...
> filter expression)
> out.close();
> true
> Stephane
Re: Several table filters : "or" condition [message #893155 is a reply to message #892978] |
Jason
> Hi Jason,
> blotter").
> out.close();
> true
> ---Electronique---
> ---Trade blotter---
> ---Electronique---
> ---Electronique---
> ---Sans routage---
> etc...
> filter expression)
> out.close();
> true
> Stephane
Current Time: Sat Jul 26 22:24:37 EDT 2025
Powered by FUDForum. Page generated in 0.08537 seconds
