Home » Archived » BIRT » references to meta-model in another Eclipse project
references to meta-model in another Eclipse project [message #368546] Tue, 09 June 2009 05:58 Go to next message
Originally posted by: hoe.zurich.ibm.com
I am relatively new to BIRT and have the following question:
I'm trying to run from a report design that includes a data source which
references an (EMF) meta-model in another Eclipse (plug-in) project than
itself. The BIRT Report Designers translates this into a URI of the form
platform:/resource/..., as makes sense at development time.
However, at runtime there is no such resource in the (runtime)
workspace; but then an analogous URI of the form platform:/plugin/...
would work instead (as I can confirm by manually editing the URI),
because in the runtime environment the (Eclipse plug-in) project that
contains the meta-model has become a plug-in.
Is there a good way (best practice) for handling a situation like this?
Thanks for your help,
Christian
Re: references to meta-model in another Eclipse project [message #368548 is a reply to message #368546] Tue, 09 June 2009 06:43 Go to previous messageGo to next message
--------------080609030406070501080506
Content-Type: text/plain; charset=windows-1252; format=flowed
Christian,
The URIConverter could be used to redirect URIs in general
Map
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82Map ><URI
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82URI >,
URI
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82URI >>
org.eclipse.emf.ecore.resource.URIConverter
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter >.getURIMap()
Returns the map used for remapping a logical URI to a physical URI
when |normalizing
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82%E2%98%82normalize >|.
An implementation will typically also delegate to the |global
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82URIConverter%E2%98%82URI_MAP >|
map, so registrations made in this map are /local/ to this URI
converter, i.e., they augment or override those of the global map.
The map generally specifies instance to instance mapping, except for
the case that both the key URI and the value URI end with "/", which
specifies a folder to folder mapping. A folder mapping will remap
any URI that has the key as its |prefix
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82URI%E2%98%82replacePrefix >|,
e.g., if the map contains:
http://www.example.com/ -> platform:/resource/example/
then the URI
http://www.example.com/a/b/c.d
will map to
platform:/resource/example/a/b/c.d
A matching instance mapping is considered first. If there isn't one,
the folder mappings are considered starting with the |longest
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82URI%E2%98%82segmentCount%E2%98%82 >|
prefix.
A global mapping from platform:/resource/ to platform:/plugin/ might
well do the trick
Map
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%5EURI_MAP%E2%98%82Map ><URI
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%5EURI_MAP%E2%98%82URI >,
URI
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%5EURI_MAP%E2%98%82URI >>
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter >.URI_MAP
The global static URI map. Registrations made in this instance will
(typically) be available for |use
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%5EURI_MAP%E2%98%82URIConverter%E2%98%82normalize >|
by any URI converter. It is populated by URI mappings registered via
|plugin registration
< eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%5EURI_MAP%E2%98%82org.eclipse.emf.ecore.plugin.EcorePl ugin.Implementation%E2%98%82startup%E2%98%82 >|.
Note that if your serialized URIs were relative (i.e.,
.../../<project-name/plugin-id>/model/foo.bar) they out to work equally
well in the workspace or deployed in the plugins.
> which references an (EMF) meta-model in another Eclipse (plug-in)
> project than itself. The BIRT Report Designers translates this into a
> URI of the form platform:/resource/..., as makes sense at development
> time.
> Christian
Content-Type: text/html; charset=windows-1252
<html>
<head>
<meta content="text/html;charset=windows-1252"
http-equiv="Content-Type">
</head>
Christian,<br>
<br>
The URIConverter could be used to redirect URIs in general<br>
<blockquote>
<h5>
<div style="margin-top: 0px; margin-left: 22px;"><a class="header"
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82Map ">Map</a>&lt;<a
class="header"
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82URI ">URI</a>,
<a class="header"
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82URI ">URI</a>&gt;
org.eclipse.emf.ecore.resource.<a class="header"
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter ">URIConverter</a>.getURIMap()</div>
</h5>
<p>Returns the map used for remapping a logical URI to a physical URI
when <code><a
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82%E2%98%82normalize ">normalizing</a></code>.
</p>
<p>An implementation will typically also delegate to the <code><a
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82URIConverter%E2%98%82URI_MAP ">global</a></code>
map, so registrations made in this map are <em>local</em> to this URI
converter, i.e., they augment or override those of the global map. </p>
<p>The map generally specifies instance to instance mapping, except
for the case that both the key URI and the value URI end with "/",
which specifies a folder to folder mapping. A folder mapping will remap
any URI that has the key as its <code><a
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82URI%E2%98%82replacePrefix ">prefix</a></code>,
e.g., if the map contains: </p>
<pre> <a class="moz-txt-link-freetext" href="http://www.example.com/">http://www.example.com/</a> -&gt; platform:/resource/example/
</pre>
then the URI
<pre> <a class="moz-txt-link-freetext" href="http://www.example.com/a/b/c.d">http://www.example.com/a/b/c.d</a>
</pre>
will map to
<pre> platform:/resource/example/a/b/c.d
</pre>
the folder mappings are considered starting with the <code><a
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%7EgetURIMap%E2%98%82URI%E2%98%82segmentCount%E2%98%82 ">longest</a></code>
prefix. <br>
</blockquote>
well do the trick<br>
<blockquote>
<h5>
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%5EURI_MAP%E2%98%82Map ">Map</a>&lt;<a
class="header"
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%5EURI_MAP%E2%98%82URI ">URI</a>,
<a class="header"
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%5EURI_MAP%E2%98%82URI ">URI</a>&gt;
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter ">URIConverter</a>.URI_MAP</div>
</h5>
(typically) be available for <code><a
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%5EURI_MAP%E2%98%82URIConverter%E2%98%82normalize ">use</a></code>
by any URI converter. It is populated by URI mappings registered via <code><a
href=" eclipse-javadoc:%E2%98%82=org.eclipse.emf.ecore/src%3Corg.ec lipse.emf.ecore.resource%7BURIConverter.java%E2%98%83URIConv erter%5EURI_MAP%E2%98%82org.eclipse.emf.ecore.plugin.EcorePl ugin.Implementation%E2%98%82startup%E2%98%82 ">plugin
registration</a></code>.<br>
</blockquote>
<p>Note that if your serialized URIs were relative (i.e.,
.../../&lt;project-name/plugin-id&gt;/model/foo.bar) they out to work
equally well in the workspace or deployed in the plugins.<br>
</p>
<br>
<br>
<blockquote cite="mid:h0lbp3$o6s$1@build.eclipse.org" type="cite">I am
<br>
<br>
time.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Christian
<br>
</blockquote>
</body>
</html>
--------------080609030406070501080506--
Re: references to meta-model in another Eclipse project [message #368562 is a reply to message #368548] Wed, 10 June 2009 04:16 Go to previous message
Ed,
Thank you very much. Indeed this seems to make a difference.
For future reference: I'm now calling
URIConverter.URI_MAP.put(URI.createURI("platform:/resource/... "),
URI.createURI("platform:/plugin/...")); immediately before the call to
IRunAndRenderTask.run(), and then all URIConverter.URI_MAP.remove(...)
after IRunAndRenderTask.close().
Christian
> well do the trick
> Map
> URI
Previous Topic:Birt translation to italian
Next Topic:BIRT reports from an applet
Current Time: Sat Jul 19 01:38:47 EDT 2025
Powered by FUDForum. Page generated in 0.05516 seconds
