Home » Archived » BIRT » Rhino warning setting parameter value in parameter task
Rhino warning setting parameter value in parameter task [message #368354] Fri, 22 May 2009 17:43 Go to next message
I have integrated BIRT into an application. We have a custom UI for
running/scheduling a report and when the parameters for a report are
captured and validated I get the following warning for datetime values.
"RHINO USAGE WARNING: Missed Context.javaToJS() conversion:
Rhino runtime detected object 2009-05-28 21:02:00.0 of class
java.sql.Timestamp where it expected String, Number, Boolean or
Scriptable instance. Please check your code for missing
Context.javaToJS() call."
The code I am using to validate the parameters looks something like the
following.
final IGetParameterDefinitionTask parameterTask =
_reportGenerator.getParameterTask(
getLocaleContext().getLocale(),
getSession().getTimeZone());
try
for(final ModelValueHelper helper : _paramModelHelpers.values())
final String paramName = helper.getParam().getName();
final Object paramValue = helper.getParamValue();
parameterTask.setParameterValue(paramName, paramValue);
validParameters = parameterTask.validateParameters();
finally
parameterTask.close();
In the above code "paramValue" will be one of "Boolean, Date, Time,
Timestamp, Integer, Float, BigDecimal, or String".
Is this the correct way to validate parameters? Do I need to convert
...sql.(Date|Time)* and BigDecimal to a Scriptable? When I run the
report, I don't get these warnings. Also, I'm not sure if this is the
same issue as https://bugs.eclipse.org/bugs/show_bug.cgi?id=274500
Thanks for any help.
Russ
Re: Rhino warning setting parameter value in parameter task [message #368370 is a reply to message #368354] Tue, 26 May 2009 10:50 Go to previous messageGo to next message
Originally posted by: jasonweathersby.windstream.net
Russ,
This does appear to be that same bug.
BTW on the runtask or runtandrendertask you can call
validateParameters(). Just wondering if the same issues happens if you
do it this way.
Jason
> following.
> try
> finally
> Russ
Re: Rhino warning setting parameter value in parameter task [message #368375 is a reply to message #368370] Tue, 26 May 2009 11:55 Go to previous message
I do not get this warning for the run task, just the parameter task. Thanks.
Jason Weathersby wrote:
> Russ,
> do it this way.
> Jason
Previous Topic:Master page header and footer content visibility
Next Topic:Format Number using a Style
Current Time: Sun Nov 09 01:57:10 EST 2025
Powered by FUDForum. Page generated in 0.03962 seconds
