Home » Archived » BIRT » avoid/clean up BIRT runtime images files
avoid/clean up BIRT runtime images files [message #368270] Fri, 15 May 2009 16:14 Go to next message
I am new to BIRT and just created a simple web app with BIRT report.
It works fine.
Because my report contains charts, it generates a png image file on the
system every time I generate the report in html output.
The pdf output doesn't seem to generate the image. It would generate
thousands of images as time goes by.
Just wonder if there is a way to avoid or clean up this kind of BIRT
runtime images files.
Thanks for your time and help.
Alex
Re: avoid/clean up BIRT runtime images files [message #368287 is a reply to message #368270] Mon, 18 May 2009 12:15 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Alex,
The images should be getting removed automatically when the session expires.
Jason
Alex wrote:
> Hello,
> It works fine.
> Regards,
> Alex
Re: avoid/clean up BIRT runtime images files [message #368337 is a reply to message #368287] Thu, 21 May 2009 17:22 Go to previous messageGo to next message
Hi Jason,
Those images are still there even after I shut down my Tomcat server.
The following code shows how I specified the BIRT image URL and directory:
HTMLRenderOption options = new HTMLRenderOption();
options.setImageHandler(new HTMLServerImageHandler());
options.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_HTML) ;
options.setBaseImageURL(req.getContextPath() + "/BIRTimages");
options.setImageDirectory(sc.getRealPath("/BIRTimages"));
Is there anything else I need to do in order for BIRT engine to remove
those images after session expires?
Thanks again for all your time and help.
Best Regards,
Alex
Re: avoid/clean up BIRT runtime images files [message #368350 is a reply to message #368337] Fri, 22 May 2009 11:09 Go to previous messageGo to next message
Originally posted by: jasonweathersby.windstream.net
Alex,
I should have clarified, the WebViewer does the temp image clean. If
you wrote your own servlet you will need to do this yourself.
You may want to add a session listener to your servlet
<listener>
<listener-class>org.mytest.com.MySessionListener</listener-class >
</listener>
public class MySessionListener implements HttpSessionListener
public void sessionCreated( HttpSessionEvent event )
public void sessionDestroyed( HttpSessionEvent event )
//Delete temp files
You could also just delete them on the servlet destroy method.
You could also checkout the source for the web viewer and copy its code.
Jason
Alex wrote:
> Hi Jason,
> Best Regards,
> Alex
Re: avoid/clean up BIRT runtime images files [message #368351 is a reply to message #368350] Fri, 22 May 2009 11:12 Go to previous messageGo to next message
BTW if you look at the viewer checkout
ViewingSessionManager.java
Jason Weathersby wrote:
> Alex,
> <listener>
> </listener>
> //Delete temp files
> Jason
> Alex wrote:
>> Hi Jason,
>> directory:
>> Best Regards,
>> Alex
Re: avoid/clean up BIRT runtime images files [message #368390 is a reply to message #368351] Wed, 27 May 2009 10:52 Go to previous messageGo to next message
Jason,
I will try to implement the HttpSessionListener. I really appreciate all
your time and help.
Alex
Re: avoid/clean up BIRT runtime images files [message #1775079 is a reply to message #368390] Tue, 24 October 2017 07:19 Go to previous message
I know this is a older post, by any chances can anyone guide me how to remove the temporary file which is avaibale in document folder.
How to add listenter.java in the birt viewer
Previous Topic:Report of a label specs
Next Topic:The view session is not available or expired
Current Time: Sat Jul 26 20:29:09 EDT 2025
Powered by FUDForum. Page generated in 0.04216 seconds
