vector rendering of svg in pdf [message #367764] |
Tue, 07 April 2009 04:33  |
Originally posted by: piebe.de.vries.geodan.nl
hi,
Is any work being done on vector based rendering of svg in de pdf emitter?
If not, could anybody point me in the right direction of how to do it myself. I know how to get svg
into pdf using batik/itext. I had a quick look at the pdfemitter. But by the time the image data
arrives at PDFPage.drawImage(...) it is already transformed to a png image. So the svg data is not
available there. I am looking for an easy way to get the svg data available in the pdftransmitter
plugin, any hints?
greetings,
Piebe
Re: vector rendering of svg in pdf [message #367790 is a reply to message #367780] |
Wed, 08 April 2009 11:21   |
Originally posted by: jasonweathersby.alltel.net
Piebe,
Are you wanting a new report item that contains svg data instead of
normal image data? An SVG report item would be a good report item
extension.
If you are wanting to go this route take a look at:
rotated text example in the source code &
http://www.birt-exchange.com/devshare/designing-birt-reports /537-birt-extension-mechanism/
Jason
piebe wrote:
> No I need to include a svg image, I do not need to render a chart
> (actually I assumed that the chart would use the pdfemitter aswell to
> render its svg, in which case changing the emitter would solve two
> things at the same time, but appearantly I was wrong there :( ) Anyway
> at the moment I am just interested in an image not the chart.
> Piebe
> Jason Weathersby wrote:
>> Piebe,
>> Are you referring to charts?
>> Look at PageDeviceRender.drawImage
>> Also look at SvgFile.transSvgToArray
>> Jason
>> piebe wrote:
>>> hi,
>>> emitter?
>>> myself. I know how to get svg into pdf using batik/itext. I had a
>>> quick look at the pdfemitter. But by the time the image data arrives
>>> So the svg data is not available there. I am looking for an easy way
>>> to get the svg data available in the pdftransmitter plugin, any hints?
>>> greetings,
>>> Piebe
Re: vector rendering of svg in pdf [message #367812 is a reply to message #367790] |
Thu, 09 April 2009 05:14   |
No I do not want to define a new report item.
I put standard image reportitem in my report which refers to a SVG image.
When I look at the report as html, this image is displayed as a svg image and therefore drawn using
vectors.
When I look at the same report as pdf, this image is displayed as a png image and therefore drawn as
a bitmap and not using vectors. This does not look very nice, does not print very well, and it is
not a very efficient way of storage for the large pictures I want to use...
Therefore I want to change the pdf emitter so that it functions the same way as the html emitter
currently works, that is let it draw a svg image using vectors and not as a bitmap.
> Piebe,
> extension.
> Jason
>> Anyway at the moment I am just interested in an image not the chart.
>> Piebe
>>> Piebe,
>>> Jason
>>> piebe wrote:
>>>> hi,
>>>> emitter?
>>>> it myself. I know how to get svg into pdf using batik/itext. I had a
>>>> greetings,
>>>> Piebe
Re: vector rendering of svg in pdf [message #367819 is a reply to message #367812] |
Thu, 09 April 2009 10:53   |
Piebe,
Understood.
You need to look at
ImageLayout.java and SvgFile.java
ImgaeLayout.getIntrinsicDimension calls SvgFile.transSvgToArry which
converts svg to image for pdf.
Jason
> image and therefore drawn using vectors.
> image and therefore drawn as a bitmap and not using vectors. This does
> not look very nice, does not print very well, and it is not a very
> way as the html emitter currently works, that is let it draw a svg image
>> Piebe,
>> extension.
>> Jason
>>> Piebe
>>>> Piebe,
>>>> Jason
>>>> piebe wrote:
>>>>> hi,
>>>>> emitter?
>>>>> png image. So the svg data is not available there. I am looking for
>>>>> plugin, any hints?
>>>>> greetings,
>>>>> Piebe
FUDForum. Page generated in 0.04626 seconds
