Home » Archived » OHF » bridge using registry url instead of repository url
bridge using registry url instead of repository url [message #36550] Thu, 08 November 2007 16:34 Go to next message
I'm trying to test 11746 which is the XDS provide and registry
transaction. However, it appears that the bridge is using the registry
url instead of the repository url. The following is a relevant snippet
from the bridge's log where it examines my rhioConfig.xml and displays the
config info:
mXdsRepositoryConfig=[{mesa=XdsRepositoryConfig ( XDS Type=[a]
retrieveUrl=[null] provideRegisterUrl=[IheUri (
mUnsecured=[http://129.6.24.109:9080/axis2/services/repositoryAonedoc]
mSecured=[null] )] )}]
mXdsRegistryConfig=[XdsRegistryConfig ( XDS Type=[a]
nonStoredQueryUrl=[IheUri (
mUnsecured=[http://129.6.24.109:9080/axis2/services/xdsregistrya]
mSecured=[null] )] storedQueriesUrl=[IheUri (
mUnsecured=[http://129.6.24.109:9080/axis2/services/xdsregistryb]
mSecured=[null] )]
And then there's the part where it logs where the transaction is actually
being sent to (from a couple different sections of the log in case it was
just one wrong print statement):
[INFO ][2007-11-08T12:15:39.067-0800][ipse.ohf.ihe.xds.source.Sour ce]
Submitting Provide and Register Document Set transaction to Repository:
[DEBUG][2007-11-08T12:15:40.379-0800][httpclient.wire.header ] >>
"POST /axis2/services/xdsregistrya HTTP/1.1[\r][\n]"
You can see the url listed there is from the registry's nonStoredQueryUrl
parameter, not from the repository url.
Let me know if you agree this is a bug, and I'll submit one to the
bugzilla.
thanks,
Jesse
Re: bridge using registry url instead of repository url [message #36658 is a reply to message #36550] Thu, 08 November 2007 18:05 Go to previous messageGo to next message
Jesse,
Please submit this as a bug and we can look into it in more detail.
Please additionally submit your debug log as an attachment.
Thanks!
- Sarah
Jesse Pangburn wrote:
> the config info:
> mSecured=[null] )]
> actually being sent to (from a couple different sections of the log in
> case it was just one wrong print statement):
> nonStoredQueryUrl parameter, not from the repository url.
> bugzilla.
> thanks,
> Jesse
Re: bridge using registry url instead of repository url [message #36762 is a reply to message #36658] Fri, 09 November 2007 14:42 Go to previous messageGo to next message
Hi Sarah,
OK, it is submitted as Bug 209378
https://bugs.eclipse.org/bugs/show_bug.cgi?id=209378
thank you!
Jesse
Sarah Knoop wrote:
> Jesse,
> Thanks!
> - Sarah
>> Hi,
>> the config info:
>> mSecured=[null] )]
>> "POST /axis2/services/xdsregistrya HTTP/1.1[r][n]"
>> bugzilla.
>> thanks,
>> Jesse
Re: bridge using registry url instead of repository url [message #36898 is a reply to message #36762] Sun, 11 November 2007 20:02 Go to previous message
I have committed a fix to the main branch of the OHF code in the CVS.
Please update from there. This fix may have some logic issues pending
(related to how the bridge manages the concept of a "defalut repository"
in it's support of both XDS.a and XDS.b) ... but try it for now. If
difficulties arise, please submit a new bug related to the repository
URL issues experienced.
- Sarah
> Hi Sarah,
> thank you!
> Jesse
> Sarah Knoop wrote:
>> Jesse,
>> Thanks!
>> - Sarah
>>> Hi,
>>> registry url instead of the repository url. The following is a
>>> relevant snippet from the bridge's log where it examines my
>>> rhioConfig.xml and displays the config info:
>>> mSecured=[null] )]
>>> in case it was just one wrong print statement):
>>> Repository: http://129.6.24.109:9080/axis2/services/xdsregistrya
>>> bugzilla.
>>> thanks,
>>> Jesse
Re: bridge using registry url instead of repository url [message #582940 is a reply to message #36550] Thu, 08 November 2007 18:05 Go to previous message
Jesse,
Thanks!
- Sarah
> the config info:
> mSecured=[null] )]
> bugzilla.
> thanks,
> Jesse
Re: bridge using registry url instead of repository url [message #582966 is a reply to message #36658] Fri, 09 November 2007 14:42 Go to previous message
Hi Sarah,
thank you!
Jesse
Sarah Knoop wrote:
> Jesse,
> Thanks!
> - Sarah
>> Hi,
>> the config info:
>> mSecured=[null] )]
>> bugzilla.
>> thanks,
>> Jesse
Re: bridge using registry url instead of repository url [message #583017 is a reply to message #36762] Sun, 11 November 2007 20:02 Go to previous message
- Sarah
> Hi Sarah,
> thank you!
> Jesse
> Sarah Knoop wrote:
>> Jesse,
>> Thanks!
>> - Sarah
>>> Hi,
>>> mSecured=[null] )]
>>> bugzilla.
>>> thanks,
>>> Jesse
Previous Topic:confidentiality code when submitting CDA works strangely
Next Topic:Re: OHF bridge for IHE project
Current Time: Sat Jul 26 16:55:38 EDT 2025
Powered by FUDForum. Page generated in 0.04316 seconds
