Chart - Bar - Optional Y Series Grouping - Sorting [message #367525] |
Thu, 19 March 2009 10:16  |
Originally posted by: alexandre.petit.jaree.com
In "Edit Chart", I want to sort my "Optional Y Series Grouping".
I know that we can do it by clicking "Group and sorting" and "Data
Sorting" but we have just the choice between "Ascending" and "Descending".
My problem is that I have 3 choices:
- Yes
- No
- Neutral
And I want them like:
- Yes
- Neutral
- No
Alexandre Petit
Re: Chart - Bar - Optional Y Series Grouping - Sorting [message #367702 is a reply to message #367697] |
Wed, 01 April 2009 12:43  |
OK, so I have this problem.
I am not using three different Y - Series.
But just one.
I am currently using a .csv as database.
So my first problem was I couldn't order Yes No Neutral properly (Yes
then Neutral then No).
So I "changed" the input data as "Yes" = "1 - Yes".
(I know this is not well done, but I am testing all that we can do on
BIRT for the moment). But now in my chart the Legend is set:
1 - Yes
2 - Neutral
3 - No
And I need to have Yes, Neutral, No.
Alexandre Petit wrote:
> Found that:
> http://www.birt-exchange.com/devshare/designing-birt-reports /590-chart-script-example-of-modifying-series-entries-in-the -legend/#description
> Will try it later.
> Alexandre
> Scott Rosenbaum wrote:
>> How about just creating a computed field and using that?
>> Scott
>>> Ok, I have been changing my input Database.
>>> So no I am with "1 - Yes"...
>>> I have been happy because now I can sort "Optional Y Series Grouping"
>>> in the chart.
>>> But now I want to map my "1 - Yes" into "Yes".
>>> I know how to do it in a cell or a table: just go to "Map List" and
>>> then make a condition. I can't find it for a chart.
>>> So I have been making some grid to make my "Map List" but the chart
>>> doesn't care.
>>> Do you have any idea?
>>> NB: "Select Data" in the chart is "Inherit Data from Container", so
>>> it should work.
>>>> Has anyone an idea?
>>>> Is there a way or do I need to "change" my database.
>>>> Something like
>>>> - Yes = 1 - Yes
>>>> - No = 3 - No
>>>> - Neutral = 2 - Neutral
>>>>> Hi,
>>>>> "Descending".
>>>>> - Yes
>>>>> - No
>>>>> - Neutral
>>>>> - Yes
>>>>> - Neutral
>>>>> - No
>>>>> Thanks
>>>>> Alexandre Petit
FUDForum. Page generated in 0.05941 seconds
