Home » Archived » BIRT » Bar charts width
Bar charts width [message #367583] |
Mon, 23 March 2009 13:58  |
Hi all,
I have a question about bar charts.
Can I set the width of bars (Y series) ?
Thanks.
Chris.
Re: Bar charts width [message #367617 is a reply to message #367615] |
Thu, 26 March 2009 12:35   |
Originally posted by: jasonweathersby.alltel.net
Chris,
Not sure if this is what you want but attached is an example of two bar
series of different sizes. It uses the following script:
function beforeGeneration( chart, context )
chart.setUnitSpacing(20);
var oldSpacing;
function beforeDrawSeries( series, seriesRenderer, context )
oldSpacing = context.getChartInstance().getUnitSpacing();
if( series.getSeriesIdentifier() == "series one" ){
context.getChartInstance().setUnitSpacing(70);
function afterDrawSeries( series, seriesRenderer, context )
context.getChartInstance().setUnitSpacing(oldSpacing);
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.15"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.1.r221_v20070924 Build <2.2.0.v20070924-1550></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="7">
<list-property name="columnHints">
<structure>
<property name="columnName">CUSTOMERNAME</property>
<property name="displayName">CUSTOMERNAME</property>
</structure>
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<property name="displayName">CUSTOMERNUMBER</property>
</structure>
<structure>
<property name="columnName">CUSTOMERTOTAL</property>
<property name="displayName">CUSTOMERTOTAL</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CUSTOMERTOTAL</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERTOTAL</property>
<property name="nativeDataType">8</property>
</structure>
</list-property>
<property name="queryText">select CUSTOMERS.CUSTOMERNAME,
CUSTOMERS.CUSTOMERNUMBER,
sum(ORDERDETAILS.QUANTITYORDERED *
ORDERDETAILS.PRICEEACH) as CUSTOMERTOTAL
from CUSTOMERS, ORDERS, ORDERDETAILS
where CUSTOMERS.CUSTOMERNUMBER = ORDERS.CUSTOMERNUMBER
and ORDERS.ORDERNUMBER = ORDERDETAILS.ORDERNUMBER
group by CUSTOMERS.CUSTOMERNAME, CUSTOMERS.CUSTOMERNUMBER
order by CUSTOMERTOTAL</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>CUSTOMERNAME</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:formattingHints>
<design:displaySize>50</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:displaySize>11</design:displaySize>
<design:attributes>
<design:name>CUSTOMERTOTAL</design:name>
<design:position>3</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>CUSTOMERTOTAL</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERTOTAL</design:label>
<design:displaySize>22</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<extended-item extensionName="Chart" name="NewChart" id="8">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Bar Chart</Type>
<SubType>Side-by-side</SubType>
<Description>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Description>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>Bar Chart Title</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Categories</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>433.49999999759996</Width>
<Height>276.75</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Script>function beforeGeneration( chart, context )
var oldSpacing;
context.getChartInstance().setUnitSpacing(oldSpacing);&# xD;
}</Script>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>A, B, C</DataSetRepresentation>
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5,4,12</DataSetRepresentation>
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
<DataSetRepresentation>10.0,8.0,24.0</DataSetRepresentation >
<SeriesDefinitionIndex>1</SeriesDefinitionIndex>
</SampleData>
<Interactivity/>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:BarSeries">
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["CUSTOMERTOTAL"]</Definition >
</DataDefinition>
<SeriesIdentifier>series one</SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>false</Stacked>
<Riser>Rectangle</Riser>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
<Sorting>Ascending</Sorting>
</SeriesDefinitions>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
</SeriesPalette>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["CUSTOMERTOTAL"]/10</Definition >
</DataDefinition>
<SeriesIdentifier>series two</SeriesIdentifier>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue><
Re: Bar charts width [message #367733 is a reply to message #367712] |
Mon, 06 April 2009 11:24   |
Chris,
You can get the number of bars by using a script in the after data set
filled I believe. Other than that it may be a good idea to log an
enhancement bug for this.
Jason
Chris wrote:
> Thank Jason for your solution but in my case it's more difficult because
> in my report, each chart has much bars, and I don't know the number of
> bars ! (See attached files)
> I think the best way is to always fix the width of the bars, for all
> charts... Can I do that ?
> Do you have any other solutions ?
> cheers.
> Jason Weathersby a écrit :
>> Chris,
>> bar series of different sizes. It uses the following script:
>> var oldSpacing;
>> { oldSpacing = context.getChartInstance().getUnitSpacing();
>> Jason
>> <?xml version="1.0" encoding="UTF-8"?>
>> version="3.2.15" id="1">
>> <data-sources>
>> <oda-data-source
>> id="6">
>> <property
>> <property
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> <structure>
>> </structure>
>> <structure>
>> <property
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <model:DesignValues
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> <design:attributes>
>> <design:uiHints>
>> </design:uiHints>
>> <design:usageHints>
>> </oda-data-set>
>> </data-sets>
>> <styles>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> <text-property
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <xml-property
>> <Description>
>> <Value></Value>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Description>
>> <Block>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> <Width>0.0</Width>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Label>
>> <Caption>
>> <Font>
>> <Size>16.0</Size>
>> <Bold>true</Bold>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Label>
>> </Children>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> <Width>0.0</Width>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <ClientArea>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>0.0</Left>
>> <Right>0.0</Right>
>> </Insets>
>> </ClientArea>
>> </Children>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> <Width>0.0</Width>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <ClientArea>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>2.0</Top>
>> <Left>2.0</Left>
>> <Right>2.0</Right>
>> </Insets>
>> </ClientArea>
>> <Text>
>> <Value></Value>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Text>
>> <Separator>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Separator>
>> <Title>
>> <Caption>
>> <Value></Value>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Title>
>> </Children>
>> <Bounds>
>> <Left>0.0</Left>
>> <Top>0.0</Top>
>> </Bounds>
>> <Insets>
>> <Top>3.0</Top>
>> <Left>3.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> <Row>-1</Row>
>> <Column>-1</Column>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> </Block>
>> var oldSpacing;
>> }</Script>
>> <SampleData>
>> <BaseSampleData>
>> </BaseSampleData>
>> </SampleData>
>> <Interactivity/>
>> <Axes>
>> <Type>Text</Type>
>> <Title>
>> <Caption>
>> <Font>
>> <Size>14.0</Size>
>> <Bold>true</Bold>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Title>
>> <AssociatedAxes>
>> <Type>Linear</Type>
>> <Title>
>> <Caption>
>> <Font>
>> <Size>14.0</Size>
>> <Bold>true</Bold>
>> <Alignment>
>> </Alignment>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Title>
>> <SeriesDefinitions>
>> <Query>
>> </Query>
>> <SeriesPalette>
>> <Red>80</Red>
>> <Green>166</Green>
>> <Blue>218</Blue>
>> </Entries>
>> <Red>242</Red>
>> <Green>88</Green>
>> <Blue>106</Blue>
>> </Entries>
>> <Red>232</Red>
>> <Green>172</Green>
>> <Blue>57</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>255</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>64</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>170</Red>
>> <Green>85</Green>
>> <Blue>85</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>0</Blue>
>> </Entries>
>> <Red>192</Red>
>> <Green>192</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>192</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>7</Red>
>> <Green>146</Green>
>> <Blue>94</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>128</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>0</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>64</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>80</Red>
>> <Green>240</Green>
>> <Blue>120</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>64</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>0</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>0</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>64</Green>
>> <Blue>0</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>0</Blue>
>> </Entries>
>> </SeriesPalette>
>> <Label>
>> <Caption>
>> <Value></Value>
>> <Font>
>> <Alignment/>
>> </Font>
>> </Caption>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Background>
>> <Outline>
>> <Color>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Color>
>> </Outline>
>> <Insets>
>> <Top>0.0</Top>
>> <Left>2.0</Left>
>> <Right>3.0</Right>
>> </Insets>
>> </Label>
>> <DataDefinition>
>> </DataDefinition>
>> <DataPoint>
>> <Components>
>> </Components>
>> </DataPoint>
>> </Series>
>> <Grouping>
>> </Grouping>
>> <SeriesDefinitions>
>> <Query>
>> </Query>
>> <SeriesPalette>
>> <Red>242</Red>
>> <Green>88</Green>
>> <Blue>106</Blue>
>> </Entries>
>> <Red>232</Red>
>> <Green>172</Green>
>> <Blue>57</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>255</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>64</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>170</Red>
>> <Green>85</Green>
>> <Blue>85</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>0</Blue>
>> </Entries>
>> <Red>192</Red>
>> <Green>192</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>192</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>7</Red>
>> <Green>146</Green>
>> <Blue>94</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>128</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>192</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>0</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>64</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>80</Red>
>> <Green>240</Green>
>> <Blue>120</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>64</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>0</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>0</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>64</Blue>
>> </Entries>
>> <Red>128</Red>
>> <Green>128</Green>
>> <Blue>128</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>128</Green>
>> <Blue>255</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>64</Green>
>> <Blue>0</Blue>
>> </Entries>
>> <Red>0</Red>
>> <Green>0</Green>
>> <Blue>0</Blue>
>> </Entries>
>> <Red>255</Red>
>> <Green>255</Green>
>> <Blue>255</Blue>
>> </Entries>
Re: Bar charts width [message #367795 is a reply to message #367733] |
Wed, 08 April 2009 13:11   |
Jason,
Could you help me to do that please ?
"You can get the number of bars by using a *script* in the after data
set filled I believe".
Chris.
> Chris,
> Jason
>> because in my report, each chart has much bars, and I don't know the
>> number of bars ! (See attached files)
>> cheers.
>>> Chris,
>>> var oldSpacing;
>>> Jason
>>> <data-sources>
>>> <oda-data-source
>>> Source" id="6">
>>> <property
>>> <property
>>> </oda-data-source>
>>> </data-sources>
>>> <data-sets>
>>> <oda-data-set
>>> <structure>
>>> </structure>
>>> <structure>
>>> <property
>>> <property
>>> </structure>
>>> <structure>
>>> <property
>>> </structure>
>>> </list-property>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> <property
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <model:DesignValues
>>> <design:attributes>
>>> <design:uiHints>
>>> </design:uiHints>
>>> <design:usageHints>
>>> <design:attributes>
>>> <design:uiHints>
>>> </design:uiHints>
>>> <design:usageHints>
>>> <design:attributes>
>>> <design:uiHints>
>>> </design:uiHints>
>>> <design:usageHints>
>>> </oda-data-set>
>>> </data-sets>
>>> <styles>
>>> </style>
>>> </style>
>>> </styles>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> <text-property
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <xml-property
>>> <Description>
>>> <Value></Value>
>>> <Font>
>>> <Alignment/>
>>> </Font>
>>> </Description>
>>> <Block>
>>> <Bounds>
>>> <Left>0.0</Left>
>>> <Top>0.0</Top>
>>> <Width>0.0</Width>
>>> </Bounds>
>>> <Insets>
>>> <Top>3.0</Top>
>>> <Left>3.0</Left>
>>> <Right>3.0</Right>
>>> </Insets>
>>> <Row>-1</Row>
>>> <Column>-1</Column>
>>> <Outline>
>>> <Color>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Color>
>>> </Outline>
>>> <Label>
>>> <Caption>
>>> <Font>
>>> <Size>16.0</Size>
>>> <Bold>true</Bold>
>>> <Alignment>
>>> </Alignment>
>>> </Font>
>>> </Caption>
>>> <Red>255</Red>
>>> <Green>255</Green>
>>> <Blue>255</Blue>
>>> </Background>
>>> <Outline>
>>> <Color>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Color>
>>> </Outline>
>>> <Insets>
>>> <Top>0.0</Top>
>>> <Left>2.0</Left>
>>> <Right>3.0</Right>
>>> </Insets>
>>> </Label>
>>> </Children>
>>> <Bounds>
>>> <Left>0.0</Left>
>>> <Top>0.0</Top>
>>> <Width>0.0</Width>
>>> </Bounds>
>>> <Insets>
>>> <Top>3.0</Top>
>>> <Left>3.0</Left>
>>> <Right>3.0</Right>
>>> </Insets>
>>> <Row>-1</Row>
>>> <Column>-1</Column>
>>> <Outline>
>>> <Color>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Color>
>>> </Outline>
>>> <ClientArea>
>>> <Outline>
>>> <Color>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Color>
>>> </Outline>
>>> <Insets>
>>> <Top>0.0</Top>
>>> <Left>0.0</Left>
>>> <Right>0.0</Right>
>>> </Insets>
>>> </ClientArea>
>>> </Children>
>>> <Bounds>
>>> <Left>0.0</Left>
>>> <Top>0.0</Top>
>>> <Width>0.0</Width>
>>> </Bounds>
>>> <Insets>
>>> <Top>3.0</Top>
>>> <Left>3.0</Left>
>>> <Right>3.0</Right>
>>> </Insets>
>>> <Row>-1</Row>
>>> <Column>-1</Column>
>>> <Outline>
>>> <Color>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Color>
>>> </Outline>
>>> <ClientArea>
>>> <Outline>
>>> <Color>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Color>
>>> </Outline>
>>> <Insets>
>>> <Top>2.0</Top>
>>> <Left>2.0</Left>
>>> <Right>2.0</Right>
>>> </Insets>
>>> </ClientArea>
>>> <Text>
>>> <Value></Value>
>>> <Font>
>>> <Alignment/>
>>> </Font>
>>> </Text>
>>> <Separator>
>>> <Color>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Color>
>>> </Separator>
>>> <Title>
>>> <Caption>
>>> <Value></Value>
>>> <Font>
>>> <Alignment/>
>>> </Font>
>>> </Caption>
>>> <Red>255</Red>
>>> <Green>255</Green>
>>> <Blue>255</Blue>
>>> </Background>
>>> <Outline>
>>> <Color>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Color>
>>> </Outline>
>>> <Insets>
>>> <Top>0.0</Top>
>>> <Left>2.0</Left>
>>> <Right>3.0</Right>
>>> </Insets>
>>> </Title>
>>> </Children>
>>> <Bounds>
>>> <Left>0.0</Left>
>>> <Top>0.0</Top>
>>> </Bounds>
>>> <Insets>
>>> <Top>3.0</Top>
>>> <Left>3.0</Left>
>>> <Right>3.0</Right>
>>> </Insets>
>>> <Row>-1</Row>
>>> <Column>-1</Column>
>>> <Outline>
>>> <Color>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Color>
>>> </Outline>
>>> </Block>
>>> var oldSpacing;
>>> }</Script>
>>> <SampleData>
>>> <BaseSampleData>
>>> </BaseSampleData>
>>> </SampleData>
>>> <Interactivity/>
>>> <Axes>
>>> <Type>Text</Type>
>>> <Title>
>>> <Caption>
>>> <Font>
>>> <Size>14.0</Size>
>>> <Bold>true</Bold>
>>> <Alignment>
>>> </Alignment>
>>> </Font>
>>> </Caption>
>>> <Red>255</Red>
>>> <Green>255</Green>
>>> <Blue>255</Blue>
>>> </Background>
>>> <Outline>
>>> <Color>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Color>
>>> </Outline>
>>> <Insets>
>>> <Top>0.0</Top>
>>> <Left>2.0</Left>
>>> <Right>3.0</Right>
>>> </Insets>
>>> </Title>
>>> <AssociatedAxes>
>>> <Type>Linear</Type>
>>> <Title>
>>> <Caption>
>>> <Font>
>>> <Size>14.0</Size>
>>> <Bold>true</Bold>
>>> <Alignment>
>>> </Alignment>
>>> </Font>
>>> </Caption>
>>> <Red>255</Red>
>>> <Green>255</Green>
>>> <Blue>255</Blue>
>>> </Background>
>>> <Outline>
>>> <Color>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Color>
>>> </Outline>
>>> <Insets>
>>> <Top>0.0</Top>
>>> <Left>2.0</Left>
>>> <Right>3.0</Right>
>>> </Insets>
>>> </Title>
>>> <SeriesDefinitions>
>>> <Query>
>>> </Query>
>>> <SeriesPalette>
>>> <Red>80</Red>
>>> <Green>166</Green>
>>> <Blue>218</Blue>
>>> </Entries>
>>> <Red>242</Red>
>>> <Green>88</Green>
>>> <Blue>106</Blue>
>>> </Entries>
>>> <Red>232</Red>
>>> <Green>172</Green>
>>> <Blue>57</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>255</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>64</Red>
>>> <Green>128</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>128</Green>
>>> <Blue>192</Blue>
>>> </Entries>
>>> <Red>170</Red>
>>> <Green>85</Green>
>>> <Blue>85</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>128</Green>
>>> <Blue>0</Blue>
>>> </Entries>
>>> <Red>192</Red>
>>> <Green>192</Green>
>>> <Blue>192</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>255</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>192</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>7</Red>
>>> <Green>146</Green>
>>> <Blue>94</Blue>
>>> </Entries>
>>> <Red>0</Red>
>>> <Green>128</Green>
>>> <Blue>255</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>128</Green>
>>> <Blue>192</Blue>
>>> </Entries>
>>> <Red>0</Red>
>>> <Green>255</Green>
>>> <Blue>255</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>128</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>0</Red>
>>> <Green>128</Green>
>>> <Blue>192</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>128</Green>
>>> <Blue>192</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>0</Green>
>>> <Blue>255</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>64</Green>
>>> <Blue>64</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>128</Green>
>>> <Blue>64</Blue>
>>> </Entries>
>>> <Red>80</Red>
>>> <Green>240</Green>
>>> <Blue>120</Blue>
>>> </Entries>
>>> <Red>0</Red>
>>> <Green>64</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>0</Green>
>>> <Blue>64</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>0</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>128</Green>
>>> <Blue>64</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>128</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>128</Green>
>>> <Blue>255</Blue>
>>> </Entries>
>>> <Red>0</Red>
>>> <Green>64</Green>
>>> <Blue>0</Blue>
>>> </Entries>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>255</Green>
>>> <Blue>255</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>128</Green>
>>> <Blue>0</Blue>
>>> </Entries>
>>> </SeriesPalette>
>>> <Label>
>>> <Caption>
>>> <Value></Value>
>>> <Font>
>>> <Alignment/>
>>> </Font>
>>> </Caption>
>>> <Red>255</Red>
>>> <Green>255</Green>
>>> <Blue>255</Blue>
>>> </Background>
>>> <Outline>
>>> <Color>
>>> <Red>0</Red>
>>> <Green>0</Green>
>>> <Blue>0</Blue>
>>> </Color>
>>> </Outline>
>>> <Insets>
>>> <Top>0.0</Top>
>>> <Left>2.0</Left>
>>> <Right>3.0</Right>
>>> </Insets>
>>> </Label>
>>> <DataDefinition>
>>> </DataDefinition>
>>> <DataPoint>
>>> <Components>
>>> </Components>
>>> </DataPoint>
>>> </Series>
>>> <Grouping>
>>> </Grouping>
>>> <SeriesDefinitions>
>>> <Query>
>>> </Query>
>>> <SeriesPalette>
>>> <Red>242</Red>
>>> <Green>88</Green>
>>> <Blue>106</Blue>
>>> </Entries>
>>> <Red>232</Red>
>>> <Green>172</Green>
>>> <Blue>57</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>255</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>64</Red>
>>> <Green>128</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>128</Green>
>>> <Blue>192</Blue>
>>> </Entries>
>>> <Red>170</Red>
>>> <Green>85</Green>
>>> <Blue>85</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>128</Green>
>>> <Blue>0</Blue>
>>> </Entries>
>>> <Red>192</Red>
>>> <Green>192</Green>
>>> <Blue>192</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>255</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>192</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>7</Red>
>>> <Green>146</Green>
>>> <Blue>94</Blue>
>>> </Entries>
>>> <Red>0</Red>
>>> <Green>128</Green>
>>> <Blue>255</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>128</Green>
>>> <Blue>192</Blue>
>>> </Entries>
>>> <Red>0</Red>
>>> <Green>255</Green>
>>> <Blue>255</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>128</Green>
>>> <Blue>128</Blue>
>>> </Entries>
>>> <Red>0</Red>
>>> <Green>128</Green>
>>> <Blue>192</Blue>
>>> </Entries>
>>> <Red>128</Red>
>>> <Green>128</Green>
>>> <Blue>192</Blue>
>>> </Entries>
>>> <Red>255</Red>
>>> <Green>0</Green>
>>> <Blue>255</Blue>
>>> </Entries>
>>> <Red>128</Red>
Re: Bar charts width [message #367804 is a reply to message #367795] |
Wed, 08 April 2009 14:56   |
Chris,
Sorry I just saw this.
In the afterdataset filled event do something like:
barcnt = 0;
function afterDataSetFilled(series, dataSet, icsc)
importPackage( Packages.java.io );
importPackage( Packages.org.eclipse.birt.chart.model.type.impl );
if( series.getClass() == LineSeriesImpl ){
series.getLineAttributes().setThickness(5);
if( series.getClass() == BarSeriesImpl ){
if( series.getSeriesIdentifier() == "mybar" ){
var list = dataSet.getValues();
barcnt = list.length;
Noticed that I named my series to mybar in the third tab of the chart
wizard. I can then add this count to the y axis label like:
function beforeDrawAxisTitle( axis, label, icsc )
importPackage(Packages.org.eclipse.birt.chart.model.attribut e);
if (axis.getType() == AxisType.LINEAR_LITERAL)
label.getCaption( ).setValue( "Total Bars = " + barcnt);
Jason
Chris wrote:
> Jason,
> Chris.
>> Chris,
>> Jason
>>> cheers.
>>>> Chris,
>>>> var oldSpacing;
>>>> Jason
>>>> Company Name here>></property>
>>>> <data-sources>
>>>> <oda-data-source
>>>> Source" id="6">
>>>> <property
>>>> <property
>>>> </oda-data-source>
>>>> </data-sources>
>>>> <data-sets>
>>>> <oda-data-set
>>>> <structure>
>>>> <property
>>>> </structure>
>>>> <structure>
>>>> <property
>>>> <property
>>>> </structure>
>>>> <structure>
>>>> <property
>>>> <property
>>>> </structure>
>>>> </list-property>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> <property
>>>> </structure>
>>>> <structure>
>>>> <property
>>>> </structure>
>>>> </list-property>
>>>> <model:DesignValues
>>>> <design:attributes>
>>>> <design:uiHints>
>>>> </design:uiHints>
>>>> <design:usageHints>
>>>> <design:attributes>
>>>> <design:uiHints>
>>>> </design:uiHints>
>>>> <design:usageHints>
>>>> <design:attributes>
>>>> <design:uiHints>
>>>> </design:uiHints>
>>>> <design:usageHints>
>>>> </oda-data-set>
>>>> </data-sets>
>>>> <styles>
>>>> </style>
>>>> </style>
>>>> </styles>
>>>> <page-setup>
>>>> <page-footer>
>>>> <text id="3">
>>>> <text-property
>>>> </text>
>>>> </page-footer>
>>>> </page-setup>
>>>> <body>
>>>> <xml-property
>>>> <Description>
>>>> <Value></Value>
>>>> <Font>
>>>> <Alignment/>
>>>> </Font>
>>>> </Description>
>>>> <Block>
>>>> <Bounds>
>>>> <Left>0.0</Left>
>>>> <Top>0.0</Top>
>>>> <Width>0.0</Width>
>>>> </Bounds>
>>>> <Insets>
>>>> <Top>3.0</Top>
>>>> <Left>3.0</Left>
>>>> <Right>3.0</Right>
>>>> </Insets>
>>>> <Row>-1</Row>
>>>> <Column>-1</Column>
>>>> <Outline>
>>>> <Color>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Color>
>>>> </Outline>
>>>> <Label>
>>>> <Caption>
>>>> <Font>
>>>> <Size>16.0</Size>
>>>> <Bold>true</Bold>
>>>> <Alignment>
>>>> </Alignment>
>>>> </Font>
>>>> </Caption>
>>>> <Red>255</Red>
>>>> <Green>255</Green>
>>>> <Blue>255</Blue>
>>>> </Background>
>>>> <Outline>
>>>> <Color>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Color>
>>>> </Outline>
>>>> <Insets>
>>>> <Top>0.0</Top>
>>>> <Left>2.0</Left>
>>>> <Right>3.0</Right>
>>>> </Insets>
>>>> </Label>
>>>> </Children>
>>>> <Bounds>
>>>> <Left>0.0</Left>
>>>> <Top>0.0</Top>
>>>> <Width>0.0</Width>
>>>> </Bounds>
>>>> <Insets>
>>>> <Top>3.0</Top>
>>>> <Left>3.0</Left>
>>>> <Right>3.0</Right>
>>>> </Insets>
>>>> <Row>-1</Row>
>>>> <Column>-1</Column>
>>>> <Outline>
>>>> <Color>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Color>
>>>> </Outline>
>>>> <ClientArea>
>>>> <Outline>
>>>> <Color>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Color>
>>>> </Outline>
>>>> <Insets>
>>>> <Top>0.0</Top>
>>>> <Left>0.0</Left>
>>>> <Right>0.0</Right>
>>>> </Insets>
>>>> </ClientArea>
>>>> </Children>
>>>> <Bounds>
>>>> <Left>0.0</Left>
>>>> <Top>0.0</Top>
>>>> <Width>0.0</Width>
>>>> </Bounds>
>>>> <Insets>
>>>> <Top>3.0</Top>
>>>> <Left>3.0</Left>
>>>> <Right>3.0</Right>
>>>> </Insets>
>>>> <Row>-1</Row>
>>>> <Column>-1</Column>
>>>> <Outline>
>>>> <Color>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Color>
>>>> </Outline>
>>>> <ClientArea>
>>>> <Outline>
>>>> <Color>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Color>
>>>> </Outline>
>>>> <Insets>
>>>> <Top>2.0</Top>
>>>> <Left>2.0</Left>
>>>> <Right>2.0</Right>
>>>> </Insets>
>>>> </ClientArea>
>>>> <Text>
>>>> <Value></Value>
>>>> <Font>
>>>> <Alignment/>
>>>> </Font>
>>>> </Text>
>>>> <Separator>
>>>> <Color>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Color>
>>>> </Separator>
>>>> <Title>
>>>> <Caption>
>>>> <Value></Value>
>>>> <Font>
>>>> <Alignment/>
>>>> </Font>
>>>> </Caption>
>>>> <Red>255</Red>
>>>> <Green>255</Green>
>>>> <Blue>255</Blue>
>>>> </Background>
>>>> <Outline>
>>>> <Color>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Color>
>>>> </Outline>
>>>> <Insets>
>>>> <Top>0.0</Top>
>>>> <Left>2.0</Left>
>>>> <Right>3.0</Right>
>>>> </Insets>
>>>> </Title>
>>>> </Children>
>>>> <Bounds>
>>>> <Left>0.0</Left>
>>>> <Top>0.0</Top>
>>>> </Bounds>
>>>> <Insets>
>>>> <Top>3.0</Top>
>>>> <Left>3.0</Left>
>>>> <Right>3.0</Right>
>>>> </Insets>
>>>> <Row>-1</Row>
>>>> <Column>-1</Column>
>>>> <Outline>
>>>> <Color>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Color>
>>>> </Outline>
>>>> </Block>
>>>> var oldSpacing;
>>>> }</Script>
>>>> <SampleData>
>>>> <BaseSampleData>
>>>> </BaseSampleData>
>>>> </SampleData>
>>>> <Interactivity/>
>>>> <Axes>
>>>> <Type>Text</Type>
>>>> <Title>
>>>> <Caption>
>>>> <Font>
>>>> <Size>14.0</Size>
>>>> <Bold>true</Bold>
>>>> <Alignment>
>>>> </Alignment>
>>>> </Font>
>>>> </Caption>
>>>> <Red>255</Red>
>>>> <Green>255</Green>
>>>> <Blue>255</Blue>
>>>> </Background>
>>>> <Outline>
>>>> <Color>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Color>
>>>> </Outline>
>>>> <Insets>
>>>> <Top>0.0</Top>
>>>> <Left>2.0</Left>
>>>> <Right>3.0</Right>
>>>> </Insets>
>>>> </Title>
>>>> <AssociatedAxes>
>>>> <Type>Linear</Type>
>>>> <Title>
>>>> <Caption>
>>>> <Font>
>>>> <Size>14.0</Size>
>>>> <Bold>true</Bold>
>>>> <Alignment>
>>>> </Alignment>
>>>> </Font>
>>>> </Caption>
>>>> <Red>255</Red>
>>>> <Green>255</Green>
>>>> <Blue>255</Blue>
>>>> </Background>
>>>> <Outline>
>>>> <Color>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Color>
>>>> </Outline>
>>>> <Insets>
>>>> <Top>0.0</Top>
>>>> <Left>2.0</Left>
>>>> <Right>3.0</Right>
>>>> </Insets>
>>>> </Title>
>>>> <SeriesDefinitions>
>>>> <Query>
>>>> </Query>
>>>> <SeriesPalette>
>>>> <Red>80</Red>
>>>> <Green>166</Green>
>>>> <Blue>218</Blue>
>>>> </Entries>
>>>> <Red>242</Red>
>>>> <Green>88</Green>
>>>> <Blue>106</Blue>
>>>> </Entries>
>>>> <Red>232</Red>
>>>> <Green>172</Green>
>>>> <Blue>57</Blue>
>>>> </Entries>
>>>> <Red>128</Red>
>>>> <Green>255</Green>
>>>> <Blue>128</Blue>
>>>> </Entries>
>>>> <Red>64</Red>
>>>> <Green>128</Green>
>>>> <Blue>128</Blue>
>>>> </Entries>
>>>> <Red>128</Red>
>>>> <Green>128</Green>
>>>> <Blue>192</Blue>
>>>> </Entries>
>>>> <Red>170</Red>
>>>> <Green>85</Green>
>>>> <Blue>85</Blue>
>>>> </Entries>
>>>> <Red>128</Red>
>>>> <Green>128</Green>
>>>> <Blue>0</Blue>
>>>> </Entries>
>>>> <Red>192</Red>
>>>> <Green>192</Green>
>>>> <Blue>192</Blue>
>>>> </Entries>
>>>> <Red>255</Red>
>>>> <Green>255</Green>
>>>> <Blue>128</Blue>
>>>> </Entries>
>>>> <Red>128</Red>
>>>> <Green>192</Green>
>>>> <Blue>128</Blue>
>>>> </Entries>
>>>> <Red>7</Red>
>>>> <Green>146</Green>
>>>> <Blue>94</Blue>
>>>> </Entries>
>>>> <Red>0</Red>
>>>> <Green>128</Green>
>>>> <Blue>255</Blue>
>>>> </Entries>
>>>> <Red>255</Red>
>>>> <Green>128</Green>
>>>> <Blue>192</Blue>
>>>> </Entries>
>>>> <Red>0</Red>
>>>> <Green>255</Green>
>>>> <Blue>255</Blue>
>>>> </Entries>
>>>> <Red>255</Red>
>>>> <Green>128</Green>
>>>> <Blue>128</Blue>
>>>> </Entries>
>>>> <Red>0</Red>
>>>> <Green>128</Green>
>>>> <Blue>192</Blue>
>>>> </Entries>
>>>> <Red>128</Red>
>>>> <Green>128</Green>
>>>> <Blue>192</Blue>
>>>> </Entries>
>>>> <Red>255</Red>
>>>> <Green>0</Green>
>>>> <Blue>255</Blue>
>>>> </Entries>
>>>> <Red>128</Red>
>>>> <Green>64</Green>
>>>> <Blue>64</Blue>
>>>> </Entries>
>>>> <Red>255</Red>
>>>> <Green>128</Green>
>>>> <Blue>64</Blue>
>>>> </Entries>
>>>> <Red>80</Red>
>>>> <Green>240</Green>
>>>> <Blue>120</Blue>
>>>> </Entries>
>>>> <Red>0</Red>
>>>> <Green>64</Green>
>>>> <Blue>128</Blue>
>>>> </Entries>
>>>> <Red>128</Red>
>>>> <Green>0</Green>
>>>> <Blue>64</Blue>
>>>> </Entries>
>>>> <Red>255</Red>
>>>> <Green>0</Green>
>>>> <Blue>128</Blue>
>>>> </Entries>
>>>> <Red>128</Red>
>>>> <Green>128</Green>
>>>> <Blue>64</Blue>
>>>> </Entries>
>>>> <Red>128</Red>
>>>> <Green>128</Green>
>>>> <Blue>128</Blue>
>>>> </Entries>
>>>> <Red>255</Red>
>>>> <Green>128</Green>
>>>> <Blue>255</Blue>
>>>> </Entries>
>>>> <Red>0</Red>
>>>> <Green>64</Green>
>>>> <Blue>0</Blue>
>>>> </Entries>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Entries>
>>>> <Red>255</Red>
>>>> <Green>255</Green>
>>>> <Blue>255</Blue>
>>>> </Entries>
>>>> <Red>255</Red>
>>>> <Green>128</Green>
>>>> <Blue>0</Blue>
>>>> </Entries>
>>>> </SeriesPalette>
>>>> <Label>
>>>> <Caption>
>>>> <Value></Value>
>>>> <Font>
>>>> <Alignment/>
>>>> </Font>
>>>> </Caption>
>>>> <Red>255</Red>
>>>> <Green>255</Green>
>>>> <Blue>255</Blue>
>>>> </Background>
>>>> <Outline>
>>>> <Color>
>>>> <Red>0</Red>
>>>> <Green>0</Green>
>>>> <Blue>0</Blue>
>>>> </Color>
>>>> </Outline>
>>>> <Insets>
>>>> <Top>0.0</Top>
>>>> <Left>2.0</Left>
>>>> <Right>3.0</Right>
>>>> </Insets>
>>>> </Label>
>>>> <DataDefinition>
>>>> </DataDefinition>
>>>> <DataPoint>
>>>> <Components>
>>>> </Components>
>>>> </DataPoint>
>>>> </Series>
>>>> <Grouping>
>>>> </Grouping>
>>>> <SeriesDefinitions>
>>>> <Query>
>>>> </Query>
>>>> <SeriesPalette>
>>>> <Red>242</Red>
>>>> <Green>88</Green>
>>>> <Blue>106</Blue>
>>>> </Entries>
>>>> <Red>232</Red>
>>>> <Green>172</Green>
>>>> <Blue>57</Blue>
>>>> </Entries>
>>>> <Red>128</Red>
>>>> <Green>255</Green>
>>>> <Blue>128</Blue>
>>>> </Entries>
>>>> <Red>64</Red>
>>>> <Green>128</Green>
>>>> <Blue>128</Blue>
>>>> </Entries>
>>>> <Red>128</Red>
>>>> <Green>128</Green>
>>>> <Blue>192</Blue>
>>>> </Entries>
>>>> <Red>170</Red>
&g
Re: Bar charts width [message #367858 is a reply to message #367804] |
Tue, 14 April 2009 04:48  |
Thank Jason,
It's perfect.
Cheers.
> Chris,
> barcnt = 0;
> Jason
> Chris wrote:
>> Jason,
>> Chris.
>>> Chris,
>>> set filled I believe. Other than that it may be a good idea to log
>>> an enhancement bug for this.
>>> Jason
>>>> cheers.
>>>>> Chris,
>>>>> var oldSpacing;
>>>>> Jason
>>>>> no predefined content.</html-property>
>>>>> <data-sources>
>>>>> <oda-data-source
>>>>> Source" id="6">
>>>>> <property
>>>>> <property
>>>>> </oda-data-source>
>>>>> </data-sources>
>>>>> <data-sets>
>>>>> <oda-data-set
>>>>> <structure>
>>>>> <property
>>>>> <property
>>>>> </structure>
>>>>> <structure>
>>>>> <property
>>>>> <property
>>>>> </structure>
>>>>> <structure>
>>>>> <property
>>>>> <property
>>>>> </structure>
>>>>> </list-property>
>>>>> <structure>
>>>>> </structure>
>>>>> <structure>
>>>>> <property
>>>>> </structure>
>>>>> <structure>
>>>>> </structure>
>>>>> </list-property>
>>>>> </structure>
>>>>> <structure>
>>>>> <property
>>>>> </structure>
>>>>> <structure>
>>>>> <property
>>>>> </structure>
>>>>> <structure>
>>>>> <property
>>>>> </structure>
>>>>> </list-property>
>>>>> <model:DesignValues
>>>>> <design:attributes>
>>>>> <design:uiHints>
>>>>> </design:uiHints>
>>>>> <design:usageHints>
>>>>> <design:attributes>
>>>>> <design:uiHints>
>>>>> </design:uiHints>
>>>>> <design:usageHints>
>>>>> <design:attributes>
>>>>> <design:uiHints>
>>>>> </design:uiHints>
>>>>> <design:usageHints>
>>>>> </oda-data-set>
>>>>> </data-sets>
>>>>> <styles>
>>>>> </style>
>>>>> </style>
>>>>> </styles>
>>>>> <page-setup>
>>>>> <page-footer>
>>>>> <text id="3">
>>>>> <text-property
>>>>> </text>
>>>>> </page-footer>
>>>>> </page-setup>
>>>>> <body>
>>>>> <xml-property
>>>>> <Description>
>>>>> <Value></Value>
>>>>> <Font>
>>>>> <Alignment/>
>>>>> </Font>
>>>>> </Description>
>>>>> <Block>
>>>>> <Bounds>
>>>>> <Left>0.0</Left>
>>>>> <Top>0.0</Top>
>>>>> <Width>0.0</Width>
>>>>> </Bounds>
>>>>> <Insets>
>>>>> <Top>3.0</Top>
>>>>> <Left>3.0</Left>
>>>>> <Right>3.0</Right>
>>>>> </Insets>
>>>>> <Row>-1</Row>
>>>>> <Column>-1</Column>
>>>>> <Outline>
>>>>> <Color>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Color>
>>>>> </Outline>
>>>>> <Label>
>>>>> <Caption>
>>>>> <Font>
>>>>> <Size>16.0</Size>
>>>>> <Bold>true</Bold>
>>>>> <Alignment>
>>>>> </Alignment>
>>>>> </Font>
>>>>> </Caption>
>>>>> <Red>255</Red>
>>>>> <Green>255</Green>
>>>>> <Blue>255</Blue>
>>>>> </Background>
>>>>> <Outline>
>>>>> <Color>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Color>
>>>>> </Outline>
>>>>> <Insets>
>>>>> <Top>0.0</Top>
>>>>> <Left>2.0</Left>
>>>>> <Right>3.0</Right>
>>>>> </Insets>
>>>>> </Label>
>>>>> </Children>
>>>>> <Bounds>
>>>>> <Left>0.0</Left>
>>>>> <Top>0.0</Top>
>>>>> <Width>0.0</Width>
>>>>> </Bounds>
>>>>> <Insets>
>>>>> <Top>3.0</Top>
>>>>> <Left>3.0</Left>
>>>>> <Right>3.0</Right>
>>>>> </Insets>
>>>>> <Row>-1</Row>
>>>>> <Column>-1</Column>
>>>>> <Outline>
>>>>> <Color>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Color>
>>>>> </Outline>
>>>>> <ClientArea>
>>>>> <Outline>
>>>>> <Color>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Color>
>>>>> </Outline>
>>>>> <Insets>
>>>>> <Top>0.0</Top>
>>>>> <Left>0.0</Left>
>>>>> <Right>0.0</Right>
>>>>> </Insets>
>>>>> </ClientArea>
>>>>> </Children>
>>>>> <Bounds>
>>>>> <Left>0.0</Left>
>>>>> <Top>0.0</Top>
>>>>> <Width>0.0</Width>
>>>>> </Bounds>
>>>>> <Insets>
>>>>> <Top>3.0</Top>
>>>>> <Left>3.0</Left>
>>>>> <Right>3.0</Right>
>>>>> </Insets>
>>>>> <Row>-1</Row>
>>>>> <Column>-1</Column>
>>>>> <Outline>
>>>>> <Color>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Color>
>>>>> </Outline>
>>>>> <ClientArea>
>>>>> <Outline>
>>>>> <Color>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Color>
>>>>> </Outline>
>>>>> <Insets>
>>>>> <Top>2.0</Top>
>>>>> <Left>2.0</Left>
>>>>> <Right>2.0</Right>
>>>>> </Insets>
>>>>> </ClientArea>
>>>>> <Text>
>>>>> <Value></Value>
>>>>> <Font>
>>>>> <Alignment/>
>>>>> </Font>
>>>>> </Text>
>>>>> <Separator>
>>>>> <Color>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Color>
>>>>> </Separator>
>>>>> <Title>
>>>>> <Caption>
>>>>> <Value></Value>
>>>>> <Font>
>>>>> <Alignment/>
>>>>> </Font>
>>>>> </Caption>
>>>>> <Red>255</Red>
>>>>> <Green>255</Green>
>>>>> <Blue>255</Blue>
>>>>> </Background>
>>>>> <Outline>
>>>>> <Color>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Color>
>>>>> </Outline>
>>>>> <Insets>
>>>>> <Top>0.0</Top>
>>>>> <Left>2.0</Left>
>>>>> <Right>3.0</Right>
>>>>> </Insets>
>>>>> </Title>
>>>>> </Children>
>>>>> <Bounds>
>>>>> <Left>0.0</Left>
>>>>> <Top>0.0</Top>
>>>>> </Bounds>
>>>>> <Insets>
>>>>> <Top>3.0</Top>
>>>>> <Left>3.0</Left>
>>>>> <Right>3.0</Right>
>>>>> </Insets>
>>>>> <Row>-1</Row>
>>>>> <Column>-1</Column>
>>>>> <Outline>
>>>>> <Color>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Color>
>>>>> </Outline>
>>>>> </Block>
>>>>> var oldSpacing;
>>>>> }</Script>
>>>>> <SampleData>
>>>>> <BaseSampleData>
>>>>> </BaseSampleData>
>>>>> </SampleData>
>>>>> <Interactivity/>
>>>>> <Axes>
>>>>> <Type>Text</Type>
>>>>> <Title>
>>>>> <Caption>
>>>>> <Font>
>>>>> <Size>14.0</Size>
>>>>> <Bold>true</Bold>
>>>>> <Alignment>
>>>>> </Alignment>
>>>>> </Font>
>>>>> </Caption>
>>>>> <Red>255</Red>
>>>>> <Green>255</Green>
>>>>> <Blue>255</Blue>
>>>>> </Background>
>>>>> <Outline>
>>>>> <Color>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Color>
>>>>> </Outline>
>>>>> <Insets>
>>>>> <Top>0.0</Top>
>>>>> <Left>2.0</Left>
>>>>> <Right>3.0</Right>
>>>>> </Insets>
>>>>> </Title>
>>>>> <AssociatedAxes>
>>>>> <Type>Linear</Type>
>>>>> <Title>
>>>>> <Caption>
>>>>> <Font>
>>>>> <Size>14.0</Size>
>>>>> <Bold>true</Bold>
>>>>> <Alignment>
>>>>> </Alignment>
>>>>> </Font>
>>>>> </Caption>
>>>>> <Red>255</Red>
>>>>> <Green>255</Green>
>>>>> <Blue>255</Blue>
>>>>> </Background>
>>>>> <Outline>
>>>>> <Color>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Color>
>>>>> </Outline>
>>>>> <Insets>
>>>>> <Top>0.0</Top>
>>>>> <Left>2.0</Left>
>>>>> <Right>3.0</Right>
>>>>> </Insets>
>>>>> </Title>
>>>>> <SeriesDefinitions>
>>>>> <Query>
>>>>> </Query>
>>>>> <SeriesPalette>
>>>>> <Red>80</Red>
>>>>> <Green>166</Green>
>>>>> <Blue>218</Blue>
>>>>> </Entries>
>>>>> <Red>242</Red>
>>>>> <Green>88</Green>
>>>>> <Blue>106</Blue>
>>>>> </Entries>
>>>>> <Red>232</Red>
>>>>> <Green>172</Green>
>>>>> <Blue>57</Blue>
>>>>> </Entries>
>>>>> <Red>128</Red>
>>>>> <Green>255</Green>
>>>>> <Blue>128</Blue>
>>>>> </Entries>
>>>>> <Red>64</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>128</Blue>
>>>>> </Entries>
>>>>> <Red>128</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>192</Blue>
>>>>> </Entries>
>>>>> <Red>170</Red>
>>>>> <Green>85</Green>
>>>>> <Blue>85</Blue>
>>>>> </Entries>
>>>>> <Red>128</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>0</Blue>
>>>>> </Entries>
>>>>> <Red>192</Red>
>>>>> <Green>192</Green>
>>>>> <Blue>192</Blue>
>>>>> </Entries>
>>>>> <Red>255</Red>
>>>>> <Green>255</Green>
>>>>> <Blue>128</Blue>
>>>>> </Entries>
>>>>> <Red>128</Red>
>>>>> <Green>192</Green>
>>>>> <Blue>128</Blue>
>>>>> </Entries>
>>>>> <Red>7</Red>
>>>>> <Green>146</Green>
>>>>> <Blue>94</Blue>
>>>>> </Entries>
>>>>> <Red>0</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>255</Blue>
>>>>> </Entries>
>>>>> <Red>255</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>192</Blue>
>>>>> </Entries>
>>>>> <Red>0</Red>
>>>>> <Green>255</Green>
>>>>> <Blue>255</Blue>
>>>>> </Entries>
>>>>> <Red>255</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>128</Blue>
>>>>> </Entries>
>>>>> <Red>0</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>192</Blue>
>>>>> </Entries>
>>>>> <Red>128</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>192</Blue>
>>>>> </Entries>
>>>>> <Red>255</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>255</Blue>
>>>>> </Entries>
>>>>> <Red>128</Red>
>>>>> <Green>64</Green>
>>>>> <Blue>64</Blue>
>>>>> </Entries>
>>>>> <Red>255</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>64</Blue>
>>>>> </Entries>
>>>>> <Red>80</Red>
>>>>> <Green>240</Green>
>>>>> <Blue>120</Blue>
>>>>> </Entries>
>>>>> <Red>0</Red>
>>>>> <Green>64</Green>
>>>>> <Blue>128</Blue>
>>>>> </Entries>
>>>>> <Red>128</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>64</Blue>
>>>>> </Entries>
>>>>> <Red>255</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>128</Blue>
>>>>> </Entries>
>>>>> <Red>128</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>64</Blue>
>>>>> </Entries>
>>>>> <Red>128</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>128</Blue>
>>>>> </Entries>
>>>>> <Red>255</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>255</Blue>
>>>>> </Entries>
>>>>> <Red>0</Red>
>>>>> <Green>64</Green>
>>>>> <Blue>0</Blue>
>>>>> </Entries>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Entries>
>>>>> <Red>255</Red>
>>>>> <Green>255</Green>
>>>>> <Blue>255</Blue>
>>>>> </Entries>
>>>>> <Red>255</Red>
>>>>> <Green>128</Green>
>>>>> <Blue>0</Blue>
>>>>> </Entries>
>>>>> </SeriesPalette>
>>>>> <Label>
>>>>> <Caption>
>>>>> <Value></Value>
>>>>> <Font>
>>>>> <Alignment/>
>>>>> </Font>
>>>>> </Caption>
>>>>> <Red>255</Red>
>>>>> <Green>255</Green>
>>>>> <Blue>255</Blue>
>>>>> </Background>
>>>>> <Outline>
>>>>> <Color>
>>>>> <Red>0</Red>
>>>>> <Green>0</Green>
>>>>> <Blue>0</Blue>
>>>>> </Color>
>>>>> </Outline>
>>>>> <Insets>
>>>>> <Top>0.0</Top>
>>>>> <Left>2.0</Left>
>>>>> <Right>3.0</Right>
>>>>> </Insets>
>>>>> </Label>
>>>>> <DataDefinition>
Current Time: Sat Sep 13 22:32:07 EDT 2025
Powered by FUDForum. Page generated in 0.05532 seconds
