Home » Eclipse Projects » Nebula » CompositeTable and Databinding
CompositeTable and Databinding [message #36744] Sun, 24 June 2007 09:44 Go to next message
Originally posted by: stefan.schedl.gmx.de
Hi All,
I want to use a CompositeTable with JFace Datbinding 3.3. But there are
only dead files in the eclipse cvs
(org.eclipse.jface.examples.databinding/src/org/eclipse/
jface/examples/databinding/compositetable).
Is it possible to use JFace Databinding 3.3 with the CompositeTables?
Will you update the examples?
Thank you in advance.
Stefan Schedl
Re: CompositeTable and Databinding [message #36948 is a reply to message #36744] Sun, 01 July 2007 08:24 Go to previous messageGo to next message
Originally posted by: christoph.abwesend.de
I think this question is very interesting. I'm looking for JFace
Databinding 3.3 with CompositeTables too.
Can anyone give me an example?
Thanks!
Christoph
Stefan Schedl schrieb:
> Hi All,
> Stefan Schedl
Re: CompositeTable and Databinding [message #38042 is a reply to message #36948] Fri, 03 August 2007 17:33 Go to previous message
CompositeTable was designed from the beginning to work with DataBinding
and the Eclipse Visual Editor. The original author/maintainer of
CompositeTable (Dave Orme) is a major contributor to both of those
projects.
The code you want is in the
org.eclipse.swt.nebula/org.eclipse.swt.nebula.widgets module.
Unfortunately, it isn't quite in a runnable state. You need to apply
several patches from CVS to get it up and running. Dave's been falling
behind with keeping CompositeTable up to date for the past few months, but
hopefully he will take care of things soon.
Once you get past the initial setup issues, CompositeTable works quite
nicely with DataBinding in practice. You basically just implement the
IRowContentProvider.refresh() method to lookup your data element by index
and bind the view and model together. This code would be exactly the same
as what you'd use to bind a basic Composite panel to a data model. In
fact, if you already have a panel to display data in a static form, you
should be able to reuse the logic for one row of the CompositeTable. This
makes it very easy to refactor a to-one relationship into a to-many
relationship.
Peter
Re: CompositeTable and Databinding [message #583335 is a reply to message #36744] Sun, 01 July 2007 08:24 Go to previous message
Thanks!
Christoph
> Hi All,
> Stefan Schedl
Re: CompositeTable and Databinding [message #583792 is a reply to message #36948] Fri, 03 August 2007 17:33 Go to previous message
projects.
relationship.
Peter
Previous Topic:Formattted Text Widget
Next Topic:CDateTime bugs
Current Time: Sat Jul 26 18:21:44 EDT 2025
Powered by FUDForum. Page generated in 0.03506 seconds
