Home » Archived » BIRT » Span group data across detail rows?
Span group data across detail rows? [message #366407] Mon, 22 December 2008 11:57 Go to next message
I have a dataset that is being grouped, and needs some of the grouping
information to appear on the detail row - however, this group info needs
to be in a single cell spanning across all of the detail rows for each
group. As such:
Group A
group A | 1 | 1 | 1
info | 2 | 2 | 2
I have tried using a filtered embedded crosstab or table for this effect
- in both cases the performance suffered tremendously for larger
datasets. Is there a way to do rowspan merge in a single table via
scripting? Or perhaps does anyone know of a way to filter an embedded
table without the performance hit (this is a 4th level group)?
Re: Span group data across detail rows? [message #366416 is a reply to message #366407] Tue, 23 December 2008 09:58 Go to previous messageGo to next message
I believe the solution (using the embedded table technique) would be to
leave the inner table as unbound statically - and then bind dynamically
for each group header instance in the outer table. This would avoid the
need for filtering completely, and would probably perform much better.
However, I'm not quite sure how (or if) I can access the collection of
dataSetRows contained within the current group - can anyone provide some
code that does something similar?
> group. As such:
> Group A
> group A | 1 | 1 | 1
> info | 2 | 2 | 2
Re: Span group data across detail rows? [message #366417 is a reply to message #366416] Tue, 23 December 2008 10:06 Go to previous message
The solution turned out to be much simpler than that :) - leaving the
inner table as unbound and referencing the outer table items directly
(without using row._outer) works like a charm. Hope this helps somebody.
>> needs to be in a single cell spanning across all of the detail rows
>> for each group. As such:
>> Group A
>> group A | 1 | 1 | 1
>> info | 2 | 2 | 2
>> effect - in both cases the performance suffered tremendously for
>> larger datasets. Is there a way to do rowspan merge in a single table
>> via scripting? Or perhaps does anyone know of a way to filter an
>> embedded table without the performance hit (this is a 4th level group)?
Previous Topic:get/set sql query of a report
Next Topic:New to BIRT, checking the possibilities
Current Time: Fri Oct 24 11:29:34 EDT 2025
Powered by FUDForum. Page generated in 0.03671 seconds
