Home » Eclipse Projects » DSDP - Target Management » Folder/File rights (chwon/chmod)
Folder/File rights (chwon/chmod) [message #36186] Wed, 24 June 2009 06:02 Go to next message
Originally posted by: mnm.criion.net
When I upload or create a new folder or file through RSE ownership and
rights are default set to the user I am logged in as and to 644.
Where do I define what RSE should set?
This is a SSL connection on a FreeBSD OS server.
-michael
Re: Folder/File rights (chwon/chmod) [message #36287 is a reply to message #36186] Fri, 26 June 2009 09:51 Go to previous messageGo to next message
I'm not quite sure what you question is. With SSH, the user and group
values are based on what you would get from doing an echo $UID and echo $GID
in the shell.
"Michael Madsen" <mnm@criion.net> wrote in message
news:h1stju$fle$1@build.eclipse.org...
> -michael
Re: Folder/File rights (chwon/chmod) [message #36558 is a reply to message #36287] Mon, 29 June 2009 16:24 Go to previous messageGo to next message
Oh my bad I meant a SSH connection, of cause.
When I import (upload) a file through the RSE explorer, the ownership
(chown) are set to "michael" if that is the user I am signed on as. The
rights (chmod) are set to (0)644 (rw-r-r).
And my question is:
Where in RSE or otherwise do I define what the ownership and rights are
set to, when I use RSE to create or import files or folders?
-michael
Re: Folder/File rights (chwon/chmod) [message #36626 is a reply to message #36558] Tue, 30 June 2009 11:47 Go to previous messageGo to next message
I believe the ownership and rights should be set to whatever it would be set
to if you tried to create a file from an SSH shell (i.e. via touch) under
the userid that you connected with. RSE does not explicitly change the
rights or ownership after a file has been created on a host.
news:h2b7th$4qm$1@build.eclipse.org...
> And my question is:
> -michael
Re: Folder/File rights (chwon/chmod) [message #37065 is a reply to message #36626] Fri, 03 July 2009 12:46 Go to previous message
Ah ok, thanks
-michael
Re: Folder/File rights (chwon/chmod) [message #581312 is a reply to message #36186] Fri, 26 June 2009 09:51 Go to previous message
in the shell.
> -michael
Re: Folder/File rights (chwon/chmod) [message #581495 is a reply to message #36287] Mon, 29 June 2009 16:24 Go to previous message
And my question is:
-michael
Re: Folder/File rights (chwon/chmod) [message #581511 is a reply to message #36558] Tue, 30 June 2009 11:47 Go to previous message
> And my question is:
> -michael
Re: Folder/File rights (chwon/chmod) [message #581778 is a reply to message #36626] Fri, 03 July 2009 12:46 Go to previous message
Ah ok, thanks
-michael
Previous Topic:Cygwin Support?
Next Topic:TM 3.1 is released with Galileo
Current Time: Sat Jul 26 10:44:05 EDT 2025
Powered by FUDForum. Page generated in 0.18695 seconds
