Home » Archived » BIRT » stacked bar chart..
stacked bar chart.. [message #366201] Mon, 08 December 2008 00:12 Go to next message
Jason,
i am looking for solution for stacked bar chart with xml datasource.
i have tried but i couldn't able to achieve desired output.
i need the percentage in Y axis.. and the x axis should have the clicks
and impressions stacked bars with values for google ,yahoo and superpages.
The legend colors should display the names as Google, superpages and
yahoo..
could you please help me in this.. i am using 2.2 version...
Here is the link for the desired output for the stacked one..
<a href="http://img392.imageshack.us/img392/1285/stackedbarlj3.png"
target="_blank">dash board </a>
here is my xml..
<?xml version="1.0" encoding="UTF-8" ?> <reportMaster>
<graphDetails product="SMLD"><reportDetails><date
type="date">null</date><ednProductCode
type="string">Superpages</ednProductCode><clicks type="int">43</clicks>
<impressions type="int">7925</impressions>
<averagePosition type="double">4.87</averagePosition></reportDetails>
<reportDetails><date type="date">null</date><ednProductCode
type="string">Yahoo</ednProductCode><clicks type="int">30</clicks>
<averagePosition type="double">5.87</averagePosition></reportDetails>
type="string">Google</ednProductCode><clicks type="int">20</clicks>
<averagePosition type="double">3.87</averagePosition></reportDetails>
</graphDetails></reportMaster>
here the design xml :
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.15"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.2.r222_v20071226 Build &lt;2.2.2.v20080227-1131></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company Name
here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.datatools.enablement.oda.xml" name="Data Source"
id="7">
<property name="FILELIST">C:\Documents and
Settings\v658938\Desktop\test.xml</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.datatools.enablement.oda.xml.dataSet " name="Data
Set" id="11">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ednProductCode</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">clicks</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">impressions</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">averagePosition</property>
<property name="dataType">decimal</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ednProductCode</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">clicks</property>
</structure>
<structure>
<property name="nativeName">impressions</property>
</structure>
<structure>
<property name="nativeName">averagePosition</property>
<property name="nativeDataType">2</property>
</structure>
</list-property>
<property
name="queryText"> table0#-TNAME-#table0#:#[/reportMaster/graphDetails/reportDe tails/date]#:#{ednProductCode;STRING;../ednProductCode},{cli cks;STRING;../clicks},{impressions;STRING;../impressions},{a veragePosition;BIGDECIMAL;../averagePosition} </property>
<list-property name="privateDriverProperties">
<ex-property>
<name>MAX_ROW</name>
<value>-1</value>
</ex-property>
<ex-property>
<name>XML_FILE</name>
</ex-property>
</list-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="NewSimpleMasterPage" id="12"/>
</page-setup>
<body>
<extended-item extensionName="Chart" name="NewChart" id="10">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Bar Chart</Type>
<SubType>Percent Stacked</SubType>
<Description>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Description>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Label>
<Caption>
<Value>Bar Chart Title</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
<Visible>true</Visible>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Anchor>North_East</Anchor>
<Stretch>Horizontal</Stretch>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<WidthHint>-1.0</WidthHint>
<HeightHint>-1.0</HeightHint>
<HorizontalSpacing>1</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Outline>
<Color>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Left</Position>
<ItemType>Series</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
<ShowValue>false</ShowValue>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>211.5</Width>
<Height>129.75</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>254</Red>
<Green>254</Green>
<Blue>254</Blue>
</Background>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>'A','B','C'</DataSetRepresentation>
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5.0,4.0,12.0</DataSetRepresentation >
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
</SampleData>
<Interactivity/>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition>row[&quot;clicks&quot;]</Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>254</Red>
<Green>102</Green>
<Blue>0</Blue>
</Entries>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:BarSeries">
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
</DataDefinition>
<SeriesIdentifier></SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Inside</LabelPosition>
<Stacked>true</Stacked>
<Triggers>
<Condition>onclick</Condition>
<Action>
<Type>Toggle_DataPoint_Visibility</Type>
<Value xsi:type="attribute:SeriesValue">
<Name></Name>
</Value>
</Action>
</Triggers>
<Riser>Rectangle</Riser>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
<Sorting>Ascending</Sorting>
</SeriesDefinitions>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Style>Dotted</Style>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Left</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Value</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>true</Percent>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Red>254</Red>
<Green>102</Green>
<Blue>0</Blue>
</Entries>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
</SeriesPalette>
<Series>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>&quot;clicks&quot;</Definition>
</DataDefinition>
<DataPoint>
<Components>
</Components>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>false</Stacked>
</Series>
<Grouping>
</Grouping>
<Orientation>Horizontal</Orientation>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Below</LabelPosition>
<Staggered>false</Staggered>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Below</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<ShowOutside>false</ShowOutside>
<TickBetweenCategories>true</TickBetweenCategories>
</Scale>
<Origin>
<Type>Value</Type>
<Value>0.0</Value>
</Value>
</Origin>
<CategoryAxis>true</CategoryAxis>
<Percent>false</Percent>
</Axes>
<UnitSpacing>50.0</UnitSpacing>
<Rotation/>
</model:ChartWithAxes>
]]></xml-property>
<property name="outputFormat">SVG</property>
Re: stacked bar chart.. [message #366207 is a reply to message #366201] Mon, 08 December 2008 10:28 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Venkat,
Can you repost the image?
Jason
venkat wrote:
> Jason,
> superpages. The legend colors should display the names as Google,
> superpages and yahoo..
> here is my xml..
> id="1">
> Name here>></property>
> <data-sources>
> <oda-data-source
> Source" id="7">
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> name="Data Set" id="11">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <property
> <ex-property>
> <value>-1</value>
> </ex-property>
> <ex-property>
> </ex-property>
> </list-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </styles>
> <page-setup>
> </page-setup>
> <body>
> <xml-property
> <Description>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Description>
> <Block>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Label>
> <Caption>
> <Font>
> <Size>16.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>0.0</Left>
> <Right>0.0</Right>
> </Insets>
> </ClientArea>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>2.0</Top>
> <Left>2.0</Left>
> <Right>2.0</Right>
> </Insets>
> </ClientArea>
> <Text>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Text>
> <Separator>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Separator>
> <Title>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Red>254</Red>
> <Green>254</Green>
> <Blue>254</Blue>
> </Background>
> </Block>
> <SampleData>
> <BaseSampleData>
> </BaseSampleData>
> </SampleData>
> <Interactivity/>
> <Axes>
> <Type>Text</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <AssociatedAxes>
> <Type>Linear</Type>
> <Title>
> <Caption>
> <Font>
> <Size>14.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> <SeriesDefinitions>
> <Query>
> </Query>
> <SeriesPalette>
> <Red>254</Red>
> <Green>102</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>80</Red>
> <Green>166</Green>
> <Blue>218</Blue>
> </Entries>
> <Red>242</Red>
> <Green>88</Green>
> <Blue>106</Blue>
> </Entries>
> <Red>232</Red>
> <Green>172</Green>
> <Blue>57</Blue>
> </Entries>
> <Red>128</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>64</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>170</Red>
> <Green>85</Green>
> <Blue>85</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>192</Red>
> <Green>192</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>192</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>7</Red>
> <Green>146</Green>
> <Blue>94</Blue>
> </Entries>
> <Red>0</Red>
> <Green>128</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>0</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>0</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>0</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>128</Red>
> <Green>64</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>80</Red>
> <Green>240</Green>
> <Blue>120</Blue>
> </Entries>
> <Red>0</Red>
> <Green>64</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>0</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>255</Red>
> <Green>0</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>0</Red>
> <Green>64</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> </SeriesPalette>
> <Label>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <DataDefinition>
> </DataDefinition>
> <DataPoint>
> <Components>
> </Components>
> </DataPoint>
> <Triggers>
> <Action>
> <Name></Name>
> </Value>
> </Action>
> </Triggers>
> </Series>
> <Grouping>
> </Grouping>
> <LineAttributes>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </LineAttributes>
> <Label>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <MajorGrid>
> <LineAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>196</Red>
> <Green>196</Green>
> <Blue>196</Blue>
> </Color>
> </TickAttributes>
> </MajorGrid>
> <MinorGrid>
> <LineAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </LineAttributes>
> <TickAttributes>
> <Color>
> <Red>225</Red>
> <Green>225</Green>
> <Blue>225</Blue>
> </Color>
> </TickAttributes>
> </MinorGrid>
> <Scale>
> </Scale>
> <Origin>
> <Type>Value</Type>
> <Value>0.0</Value>
> </Value>
> </Origin>
> </AssociatedAxes>
> <SeriesDefinitions>
> <Query>
> </Query>
> <SeriesPalette>
> <Red>254</Red>
> <Green>102</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>80</Red>
> <Green>166</Green>
> <Blue>218</Blue>
> </Entries>
> <Red>242</Red>
> <Green>88</Green>
> <Blue>106</Blue>
> </Entries>
> <Red>232</Red>
> <Green>172</Green>
> <Blue>57</Blue>
> </Entries>
> <Red>128</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>64</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>170</Red>
> <Green>85</Green>
> <Blue>85</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>192</Red>
> <Green>192</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>192</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>7</Red>
> <Green>146</Green>
> <Blue>94</Blue>
> </Entries>
> <Red>0</Red>
> <Green>128</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>0</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>0</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>0</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>128</Red>
> <Green>64</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>80</Red>
> <Green>240</Green>
> <Blue>120</Blue>
> </Entries>
> <Red>0</Red>
> <Green>64</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>0</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>255</Red>
> <Green>0</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>64</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>0</Red>
> <Green>64</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> </SeriesPalette>
> <Series>
> <Label>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> <DataDefinition>
> </DataDefinition>
> <DataPoint>
> <Components>
> </Components>
> </DataPoint>
> </Series>
> <Grouping>
> </Grouping>
Re: stacked bar chart.. [message #366209 is a reply to message #366207] Mon, 08 December 2008 10:33 Go to previous messageGo to next message
in the image the left bar is what i am talking about
Re: stacked bar chart.. [message #366213 is a reply to message #366209] Mon, 08 December 2008 12:08 Go to previous messageGo to next message
Venkat,
For some reason I can not see this image. Can you zip it and just email
it to me at jasonweathersby at alltel.net.
Jason
Re: stacked bar chart.. [message #366216 is a reply to message #366213] Mon, 08 December 2008 12:33 Go to previous messageGo to next message
Yes i did.
Re: stacked bar chart.. [message #366217 is a reply to message #366216] Mon, 08 December 2008 14:00 Go to previous messageGo to next message
Venkat,
Take a look at this example off your data. Make sure to reset your ds.
Also look at the script on the chart. The legend shows entries twice,
so I used some script to clear second legend.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
id="1">
2.3.1.v20080911 Build &lt;2.3.1.v20080922-1151></property>
<data-sources>
<oda-data-source
Source" id="7">
<property name="FILELIST">C:\test\test.xml</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<list-property name="computedColumns">
<structure>
<property name="name">clickint</property>
<expression
name="expression">row["clicks"]</expression>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="name">impint</property>
<expression
name="expression">row["impressions"]</expression>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="position">5</property>
</structure>
<structure>
<property name="position">6</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<property
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</styles>
<page-setup>
</page-setup>
<body>
<extended-item extensionName="Chart" name="NewChart1" id="16">
<xml-property
<Description>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Description>
<Block>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Label>
<Caption>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>435.0</Width>
<Height>265.5</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
</Block>
<Script>datainx=0;
function beforeDrawAxisLabel( axis, label, icsc )
importPackage(Packages.org.eclipse.birt.chart.model.attribut e);
//LINEAR_LITERAL
//LOGARITHMIC_LITERAL
//TEXT_LITERAL
//DATE_TIME_LITERAL
if (axis.getType() == AxisType.TEXT_LITERAL){
label.getCaption().setValue(&quot;impressions\r\n\r\ncli cks&quot;);
* Called before drawing the legend item.
* @param lerh
* LegendEntryRenderingHints
* @param bounds
* Bounds
* @param icsc
* IChartScriptContext
* @since Version 2.2.0
function beforeDrawLegendItem( lerh, bounds, icsc )
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( &quot;c:/test/jiii.txt&quot;,
true ) );
out.println( lerh.getDataIndex() + lerh.getLabel().getCaption().getValue());
out.close();
if( datainx > 2 ){
bounds.setHeight(0);
bounds.setWidth(0);
lerh.getFill().setTransparency( 0 );
lerh.getLabel().setVisible(false);
datainx = datainx+1;
</Script>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>'A','B','C','D','E'</DataSetRepresentation >
</BaseSampleData>
<DataSetRepresentation>5,4,12</DataSetRepresentation>
<DataSetRepresentation>10.0,8.0,24.0</DataSetRepresentation >
<SeriesDefinitionIndex>1</SeriesDefinitionIndex>
</SampleData>
<Interactivity/>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<SeriesDefinitions>
<Query>
<Definition>row[&quot;ednProductCode&quot;]</Definition >
</Query>
<SeriesPalette>
<Red>0</Red>
<Green>204</Green>
<Blue>254</Blue>
</Entries>
<Red>254</Red>
<Green>153</Green>
<Blue>0</Blue>
</Entries>
<Red>204</Red>
<Green>254</Green>
<Blue>204</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row[&quot;clickint&quot;]</Definition>
</DataDefinition>
<SeriesIdentifier>Series 1</SeriesIdentifier>
<DataPoint>
<Components>
</Components>
<Components>
<Type>Percentile_Orthogonal_Value</Type>
<FormatSpecifier
xsi:type="attribute:JavaNumberFormatSpecifier">
<Pattern>##.##%</Pattern>
</FormatSpecifier>
</Components>
</DataPoint>
</Series>
<Grouping>
<GroupingInterval>1.0</GroupingInterval>
</Grouping>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>0</Red>
<Green>204</Green>
<Blue>254</Blue>
</Entries>
<Red>254</Red>
<Green>153</Green>
<Blue>0</Blue>
</Entries>
<Red>204</Red>
<Green>254</Green>
<Blue>204</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>50</Green>
<Blue>100</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
</SeriesPalette>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row[&quot;impint&quot;]</Definition>
</DataDefinition>
<SeriesIdentifier>Series 2</SeriesIdentifier>
<DataPoint>
<Components>
<FormatSpecifier
</FormatSpecifier>
</Components>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<LineAttributes>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
</Scale>
<Origin>
<Type>Min</Type>
<Value>0.0</Value>
</Value>
</Origin>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue><
Re: stacked bar chart.. [message #366221 is a reply to message #366217] Mon, 08 December 2008 22:13 Go to previous messageGo to next message
Jason,
Thanks.. I have tried with your code.one more thing is i am using version
birt runtime 2.2
Getting following error.
org.eclipse.birt.report.service.api.ReportServiceException: Error happened
while running the report; nested exception is:
org.eclipse.emf.ecore.util.EcoreUtil$Copier.createCopy(Ecore Util.java:510)
org.eclipse.emf.ecore.util.EcoreUtil$Copier.copy(EcoreUtil.j ava:460)
org.eclipse.emf.ecore.util.EcoreUtil.copy(EcoreUtil.java:357 )
org.eclipse.birt.chart.factory.Generator.prepare(Generator.j ava:627)
org.eclipse.birt.chart.reportitem.ChartReportItemGenerationI mpl.onRowSets(ChartReportItemGenerationImpl.java:142)
org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor.generateContent(ExtendedGenerateExecutor.java:113)
org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor.execute(ExtendedGenerateExecutor.java:72)
org.eclipse.birt.report.engine.executor.ExtendedItemExecutor .execute(ExtendedItemExecutor.java:60)
org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:42)
org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 5)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:33)
org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:63)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:85)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:106)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:140)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:68)
org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(Unknown
i see some code for ..what is the path c:/test/jiii.txt does here
out = new PrintWriter( new FileWriter( &quot;c:/test/jiii.txt&quot;, true
out.close();
if( datainx > 2 ){
bounds.setWidth(0);
and also following error in my console
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Value '1.0' is
not legal. ( file:///C:/Documents%20and%20Settings/v658938/workspace/spre por
ts/test.chart, 658, 52)
at
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLL oadImpl.java:80)
at
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:190)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:179)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1094)
at
org.eclipse.birt.chart.model.impl.SerializerImpl.fromXml(Ser ializerImpl.java:393)
at
org.eclipse.birt.chart.reportitem.ChartReportItemImpl.deseri alize(ChartReportItemImpl.java:245)
at
org.eclipse.birt.report.model.extension.PeerExtensibilityPro vider.initializeReportItem(PeerExtensibilityProvider.java:49 2)
at
org.eclipse.birt.report.model.elements.ExtendedItem.initiali zeReportItem(ExtendedItem.java:300)
Re: stacked bar chart.. [message #366232 is a reply to message #366217] Tue, 09 December 2008 16:37 Go to previous messageGo to next message
Jason,
Can you send me the file with version 2.2 i am not able to run as i am
using 2.2
Version.
Venkat
Re: stacked bar chart.. [message #366240 is a reply to message #366232] Wed, 10 December 2008 12:05 Go to previous messageGo to next message
Venkat,
Are you using 2.2.0 or 2.2.1?
Jason
venkat wrote:
> Jason,
> using 2.2
> Version.
> Thanks
> Venkat
Re: stacked bar chart.. [message #366249 is a reply to message #366240] Wed, 10 December 2008 14:31 Go to previous messageGo to next message
Venkat,
Same example in 2.2.1.
Jason
id="1">
2.2.1.r221_v20070924 Build &lt;2.2.0.v20070924-1550></property>
<data-sources>
<oda-data-source
Source" id="6">
<text-property name="displayName"></text-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
name="Data Set" id="7">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeDataType">4</property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeDataType">8</property>
</structure>
</list-property>
<property
name="queryText"> table0#-TNAME-#table0#:#[/reportMaster/graphDetails/reportDe tails/date]#:#{ednProductCode;STRING;../ednProductCode},{cli cks;INT;../clicks},{impressions;INT;../impressions},{average Position;DOUBLE;../averagePosition} </property>
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<extended-item extensionName="Chart" name="NewChart" id="9">
<xml-property
<Block>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Label>
<Caption>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>395.25</Width>
<Height>269.25</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
</Block>
<Script>datainx=0;&#xD;
function beforeDrawAxisLabel( axis, label, icsc )&#xD;
{&#xD;
importPackage(Packages.org.eclipse.birt.chart.model.attribut e);&#xD;
//LINEAR_LITERAL&#xD;
//LOGARITHMIC_LITERAL&#xD;
//TEXT_LITERAL&#xD;
//DATE_TIME_LITERAL&#xD;
if (axis.getType() == AxisType.TEXT_LITERAL){&#xD;
label.getCaption().setValue(&quot;impressions\r\n\r\ncli cks&quot;);&#xD;
&#xD;
}&#xD;
}&#xD;
&#xD;
&#xD;
function beforeDrawLegendItem( lerh, bounds, icsc )&#xD;
{&#xD;
if( datainx > 2 ){&#xD;
bounds.setHeight(0);&#xD;
bounds.setWidth(0);&#xD;
lerh.getFill().setTransparency( 0 );&#xD;
lerh.getLabel().setVisible(false);&#xD;
}&#xD;
datainx = datainx+1;&#xD;
&#xD;
}</Script>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>A, B, C</DataSetRepresentation>
</BaseSampleData>
</SampleData>
<Interactivity/>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>51</Red>
<Green>102</Green>
<Blue>254</Blue>
</Entries>
<Red>254</Red>
<Green>204</Green>
<Blue>0</Blue>
</Entries>
<Red>204</Red>
<Green>254</Green>
<Blue>254</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
</DataDefinition>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>51</Red>
<Green>102</Green>
<Blue>254</Blue>
</Entries>
<Red>254</Red>
<Green>204</Green>
<Blue>0</Blue>
</Entries>
<Red>204</Red>
<Green>254</Green>
<Blue>254</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
</SeriesPalette>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row[&quot;impressions&quot;]</Definition >
</DataDefinition>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
</Scale>
<Origin>
<Type>Min</Type>
<Value>0.0</Value>
</Value>
</Origin>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
Re: stacked bar chart.. [message #366257 is a reply to message #366249] Thu, 11 December 2008 00:49 Go to previous messageGo to next message
Thanks Jason..its working now
i have tuned it little bit.. i have two issues in this.
1) two series/bars are tied closely. i have used to have some space
between the bar. didnt work. even i have tried unit spacing it didnt
work.
2) i need the legend outline. so i have selected it. but it is leaving
some
space in the outline bcoz of duplicate entries..
let me know if there is any option to set this.
Re: stacked bar chart.. [message #366269 is a reply to message #366257] Thu, 11 December 2008 13:17 Go to previous messageGo to next message
Venkat,
Try this version. It uses no scripting but uses a joint data set.
Jason
id="1">
<data-sources>
<oda-data-source
Source" id="6">
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<property name="name">ds</property>
<expression name="expression">1</expression>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<property
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
<oda-data-set
name="Data Set1" id="10">
<structure>
<expression name="expression">2</expression>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<property
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
<joint-data-set name="JointDS" id="11">
<structure>
<expression name="expression">if( row["Data
Set::clicks"] == null ){
row["Data Set1::clicks"]
}else{
row["Data Set::clicks"]
}</expression>
</structure>
<structure>
<property name="name">impr</property>
<expression name="expression">if(row["Data
Set::impressions"] == null ){
row["Data Set1::impressions"]
}else{
row["Data Set::impressions"]
}</expression>
</structure>
<structure>
<property name="name">endp</property>
Set::ednProductCode"] == null ){
row["Data Set1::ednProductCode"]
}else{
row["Data Set::ednProductCode"]
}</expression>
</structure>
<structure>
Set::ds"] == null ){
"Clicks"
}else{
"Impressions"
}</expression>
</structure>
</list-property>
<structure>
<property name="name">Data
Set::ednProductCode</property>
</structure>
<structure>
<property name="name">Data Set::clicks</property>
</structure>
<structure>
Set::impressions</property>
</structure>
<structure>
Set::averagePosition</property>
</structure>
<structure>
<property name="name">Data Set::ds</property>
</structure>
<structure>
Set1::ednProductCode</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">Data Set1::clicks</property>
</structure>
<structure>
<property name="position">8</property>
Set1::impressions</property>
</structure>
<structure>
<property name="position">9</property>
Set1::averagePosition</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">Data Set1::ds</property>
</structure>
<structure>
<property name="position">11</property>
</structure>
<structure>
<property name="position">12</property>
</structure>
<structure>
<property name="position">13</property>
</structure>
<structure>
<property name="position">14</property>
</structure>
</list-property>
</structure>
<simple-property-list name="dataSets">
<value>Data Set</value>
<value>Data Set1</value>
</simple-property-list>
<list-property name="joinConditions">
<structure>
<property name="joinType">full-out</property>
<property name="joinOperator">eq</property>
<property name="leftDataSet">Data Set</property>
<property name="rightDataSet">Data Set1</property>
<expression
name="leftExpression">dataSetRow["ds"]</expression>
<expression
name="rightExpression">dataSetRow["ds"]</expression>
</structure>
</list-property>
</joint-data-set>
</data-sets>
<styles>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<extended-item extensionName="Chart" name="NewChart" id="12">
<xml-property
<Block>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Label>
<Caption>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>450.75</Width>
<Height>294.75</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
</Block>
<SampleData>
<BaseSampleData>
</BaseSampleData>
</SampleData>
<Interactivity/>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
<Visible>false</Visible>
</Title>
<SeriesDefinitions>
<Query>
<Definition>row[&quot;endp&quot;]</Definition>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Visible>true</Visible>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>if( row[&quot;ds&quot;] == &quot;Clicks&quot;
){&#xD;
row[&quot;clicks&quot;];&#xD;
}else{&#xD;
row[&quot;impr&quot;];&#xD;
}</Definition>
</DataDefinition>
<DataPoint>
<Components>
</Components>
</DataPoint>
</Series>
<Grouping>
</Grouping>
<Orientation>Vertical</Orientation>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
</Scale>
<Origin>
<Type>Min</Type>
<Value>0.0</Value>
</Value>
</Origin>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Entries xsi:type="attribute:ColorDefinition">
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
Re: stacked bar chart.. [message #366284 is a reply to message #366269] Fri, 12 December 2008 10:44 Go to previous messageGo to next message
Thanks Jason,
It works perfect. This is one of the complex one i came across.
Good solution.
Re: stacked bar chart.. [message #719642 is a reply to message #366249] Sun, 28 August 2011 02:31 Go to previous messageGo to next message
Hi Jason,
How I can use this sample. I tried copying the XML and create a .rptdesign. But it gives incorrect XML syntax error when trying to open the file.
Thanks.
Raj
(no subject) [message #719646 is a reply to message #366249] Sun, 28 August 2011 02:31 Go to previous messageGo to next message
Hi Jason,
Thanks.
Raj
(no subject) [message #719647 is a reply to message #366249] Sun, 28 August 2011 02:31 Go to previous messageGo to next message
Hi Jason,
Thanks.
Raj
(no subject) [message #719648 is a reply to message #366249] Sun, 28 August 2011 02:31 Go to previous messageGo to next message
Hi Jason,
Thanks.
Raj
Re: stacked bar chart.. [message #719961 is a reply to message #719646] Mon, 29 August 2011 11:00 Go to previous message
What version of BIRT are you using? You should be able to remove the
Build &lt;2.2.0.v20070924-1550 portion of the created by property or
just delete the whole created by field. I can upload again as an
attachment if you specify the version you need.
Jason
On 8/28/2011 2:31 AM, jkamaraj wrote:
> Hi Jason,
> the file.
> Thanks.
> Raj
Previous Topic:Different results by generating PDF-Documents
Next Topic:Does BIRT have a Mondrian or XMLA data source?
Current Time: Sat Jul 26 18:42:37 EDT 2025
Powered by FUDForum. Page generated in 0.29020 seconds
