Home » Eclipse Projects » Buckminster dev » Tutorial for building an RCP from hudson
Tutorial for building an RCP from hudson [message #36181] |
Thu, 25 June 2009 08:45  |
--------------090108070904080601030105
since I know from my own experience now that it is a non trivial task to
build a working RCP application from a CI system like hudson, I'd like
to create a wiki page about that.
In this example I'd like to show the necessary steps to not only create
a p2 repository from the org.eclipse.buckminster.tutorial.mailapp but
actually build the product itself (utilizing the buckminster plugin for
hudson).
However, I ran into some problems when I tried to build the application.
Invoking to p2 director to create the product from the repository built
by buckminster produced the following error:
!MESSAGE Missing requirement: Equinox Provisioning Engine
1.0.100.v20090525 (org.eclipse.equinox.p2.engine 1.0.100.v20090525)
requires 'package org.eclipse.equinox.internal.p2.persistence 0.0.0' but
it could not be found
In order to make it run, I had to remove all plugins listed in
org.eclipse.buckminster.tutorial.rcpp2.feature and instead include the
org.eclipse.equinox.p2.user.ui feature and the
org.apache.commons.logging plugin.
On top of that I added a cspecx and an ant script that invokes the p2
director to the org.eclipse.buckminster.tutorial.mailapp.product.feature.
A patch with the modification and the 2 new files is attached.
Now while this was sufficient to build the product from eclipse using
Buckminster -> invoke action -> create.product.zip I'd like to get this
more "real world ready" by showing how I'd integrate that into Hudson CI
server.
For that demonstration I would like to use a new cquery and resource map
for two reasons:
1. on your company's build system you need complete control over your
artifacts so you probably don't want buckminster to fetch artifacts from
all over the world
2. In my opinion it is not the best approach to have buckminster
check-out stuff from your VCS if you are using a system like hudson. Not
only that it's not immediatly visible where your workspace materializes
from in the jobs configuration page, you're also losing the valuable
feature that hudson shows you the change logs since the last build.
In my build environment, I therefore let hudson check out the necessary
modules and do only a local resolution with buckminster. Spoken in terms
of rmaps, the only provider I'm using is this and it's always the same
for all my products:
<provider readerType="local"
componentTypes="osgi.bundle,eclipse.feature" mutable="true" source="true">
<uri format="file:///{0}/{1}/">
<bc:propertyRef key="workspace.root" />
<bc:propertyRef key="buckminster.component" />
</uri>
</provider>
All other resolutions are done with just the target platform provided by
the setPref command.
Now why I'm writing all this:
First of all, do you think a tutorial like that would make sense in the
wiki?
And if so, do you agree with the way I'm building things, or should I
change something for the wiki page?
To make the example really useful for people, the mail app would need to
be buildable and I'd need the extra files available in SVN (see attached
patch). Would you be willing to apply the patch and eventually host
the new cquery that points to the simplified local-resolution rmap (I'll
deliver both if you are ok with my general approach) so that they will
be available for public?
Best regards and thanks for your time,
Johannes
name="mailapp.patch"
Content-Disposition: inline;
filename="mailapp.patch"
IyMjIEVjbGlwc2UgV29ya3NwYWNlIFBhdGNoIDEuMA0KI1Agb3JnLmVjbGlw c2UuYnVja21p
bnN0ZXIudHV0b3JpYWwubWFpbGFwcC5wcm9kdWN0LmZlYXR1cmUNCkluZGV4 OiBidWNrbWlu
c3Rlci5jc3BleA0KPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PQ0KLS0tIGJ1Y2ttaW5zdGVyLmNz cGV4CShyZXZp
c2lvbiAwKQ0KKysrIGJ1Y2ttaW5zdGVyLmNzcGV4CShyZXZpc2lvbiAwKQ0K QEAgLTAsMCAr
MSwzNiBAQA0KKzw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04 Ij8+DQorPGNz
cGVjRXh0ZW5zaW9uDQorCXhtbG5zOmNvbT0iaHR0cDovL3d3dy5lY2xpcHNl Lm9yZy9idWNr
bWluc3Rlci9Db21tb24tMS4wIg0KKwl4bWxucz0iaHR0cDovL3d3dy5lY2xp cHNlLm9yZy9i
dWNrbWluc3Rlci9DU3BlYy0xLjAiPg0KKw0KKwk8YWN0aW9ucz4NCisJCTxw dWJsaWMgbmFt
ZT0iY3JlYXRlLnByb2R1Y3QiIGFjdG9yPSJhbnQiPg0KKyAgICAgICAgICAg IDxhY3RvclBy
b3BlcnRpZXM+DQorICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBrZXk9ImJ1 aWxkRmlsZSIg
dmFsdWU9ImJ1aWxkL3Byb2R1Y3QuYW50Ii8+DQorICAgICAgICAgICAgICAg IDxwcm9wZXJ0
eSBrZXk9InRhcmdldHMiIHZhbHVlPSJjcmVhdGUucHJvZHVjdCIvPg0KKyAg ICAgICAgICAg
IDwvYWN0b3JQcm9wZXJ0aWVzPg0KKyAgICAgICAgICAgIDxwcm9wZXJ0aWVz Pg0KKyAgICAg
ICAgICAgICAgICA8cHJvcGVydHkga2V5PSJwcm9maWxlIiB2YWx1ZT0iTWFp bFByb2ZpbGUi
Lz4NCisgICAgICAgICAgICAgICAgPHByb3BlcnR5IGtleT0iaXUiIHZhbHVl PSJvcmcuZWNs
aXBzZS5idWNrbWluc3Rlci50dXRvcmlhbC5tYWlsYXBwLnByb2R1Y3QiLz4N CisgICAgICAg
ICAgICA8L3Byb3BlcnRpZXM+DQorCQkJPHByZXJlcXVpc2l0ZXMgYWxpYXM9 InJlcG9zaXRv
cnkiPg0KKwkJCQk8YXR0cmlidXRlIG5hbWU9InNpdGUucDIiLz4NCisJCQk8 L3ByZXJlcXVp
c2l0ZXM+DQorICAgICAgICAgICAgPHByb2R1Y3RzIGFsaWFzPSJkZXN0aW5h dGlvbiIgYmFz
ZT0iJHtidWNrbWluc3Rlci5vdXRwdXR9Ij4NCisgICAgICAgICAgICAJPHBh dGggcGF0aD0i
TWFpbEFwcC8iLz4NCisgICAgICAgICAgICA8L3Byb2R1Y3RzPg0KKwkJPC9w dWJsaWM+DQor
CQk8cHVibGljIG5hbWU9ImNyZWF0ZS5wcm9kdWN0LnppcCIgYWN0b3I9ImFu dCI+DQorICAg
ICAgICAgICAgPGFjdG9yUHJvcGVydGllcz4NCisgICAgICAgICAgICAgICAg PHByb3BlcnR5
IGtleT0iYnVpbGRGaWxlSWQiIHZhbHVlPSJidWNrbWluc3Rlci5wZGV0YXNr cyIvPg0KKyAg
ICAgICAgICAgICAgICA8cHJvcGVydHkga2V5PSJ0YXJnZXRzIiB2YWx1ZT0i Y3JlYXRlLnpp
cCIvPg0KKyAgICAgICAgICAgIDwvYWN0b3JQcm9wZXJ0aWVzPg0KKwkJCTxw cmVyZXF1aXNp
dGVzIGFsaWFzPSJhY3Rpb24ucmVxdWlyZW1lbnRzIj4NCisJCQkJPGF0dHJp YnV0ZSBuYW1l
PSJjcmVhdGUucHJvZHVjdCIvPg0KKwkJCTwvcHJlcmVxdWlzaXRlcz4NCisg ICAgICAgICAg
ICA8cHJvZHVjdHMgYWxpYXM9ImFjdGlvbi5vdXRwdXQiIGJhc2U9IiR7YnVj a21pbnN0ZXIu
b3V0cHV0fSI+DQorICAgICAgICAgICAgCTxwYXRoIHBhdGg9Ik1haWxBcHAu emlwIi8+DQor
ICAgICAgICAgICAgPC9wcm9kdWN0cz4NCisJCTwvcHVibGljPg0KKwk8L2Fj dGlvbnM+DQor
PC9jc3BlY0V4dGVuc2lvbj4NCkluZGV4OiBidWlsZC9wcm9kdWN0LmFudA0K PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09
PT09PQ0KLS0tIGJ1aWxkL3Byb2R1Y3QuYW50CShyZXZpc2lvbiAwKQ0KKysr IGJ1aWxkL3By
b2R1Y3QuYW50CShyZXZpc2lvbiAwKQ0KQEAgLTAsMCArMSw1MCBAQA0KKzxw cm9qZWN0Pg0K
KwkgPHBhdGhjb252ZXJ0IHByb3BlcnR5PSJlcXVpbm94LmxhdW5jaGVyLmph ciI+DQorCSAg
IDxmaXJzdCBjb3VudD0iMSI+DQorCSAgICAgPHNvcnQ+DQorCSAgICAgICA8 ZmlsZXNldCBk
aXI9IiR7ZWNsaXBzZS5ob21lfS9wbHVnaW5zIiBpbmNsdWRlcz0iKiovb3Jn LmVjbGlwc2Uu
ZXF1aW5veC5sYXVuY2hlcl8qLmphciIvPg0KKwkgICAgICAgPHJldmVyc2Ug eG1sbnM9ImFu
dGxpYjpvcmcuYXBhY2hlLnRvb2xzLmFudC50eXBlcy5yZXNvdXJjZXMuY29t cGFyYXRvcnMi
Pg0KKwkgICAgICAgICA8ZGF0ZS8+DQorCSAgICAgICA8L3JldmVyc2U+DQor CSAgICAgPC9z
b3J0Pg0KKwkgICA8L2ZpcnN0Pg0KKwkgPC9wYXRoY29udmVydD4NCisNCisJ PHRhcmdldCBu
YW1lPSJjcmVhdGUucHJvZHVjdCI+DQorCQk8cHJvcGVydHkgbmFtZT0iZGVz dGluYXRpb24i
IGxvY2F0aW9uPSIke3NwOmRlc3RpbmF0aW9ufSIvPg0KKwkJPGRlbGV0ZSBk aXI9IiR7ZGVz
dGluYXRpb259Ij48L2RlbGV0ZT4NCisJCTxtYWtldXJsIHByb3BlcnR5PSJy ZXBvc2l0b3J5
IiBmaWxlPSIke3NwOnJlcG9zaXRvcnl9Ii8+DQorCQk8bWtkaXIgZGlyPSIk e2Rlc3RpbmF0
aW9ufSIvPg0KKwkJPGVjaG9wcm9wZXJ0aWVzID48L2VjaG9wcm9wZXJ0aWVz Pg0KKwkJPGVj
aG8gbWVzc2FnZT0iJHtlcXVpbm94LmxhdW5jaGVyLmphcn0iLz4NCisJCTxl Y2hvIG1lc3Nh
Z2U9IiR7cmVwb3NpdG9yeX0iLz4NCisJCTxlY2hvIG1lc3NhZ2U9IiR7ZGVz dGluYXRpb259
Ii8+DQorCQk8amF2YSBqYXI9IiR7ZXF1aW5veC5sYXVuY2hlci5qYXJ9IiBm b3JrPSJ0cnVl
IiBmYWlsb25lcnJvcj0idHJ1ZSIgPg0KKwkJCTxhcmcgdmFsdWU9Ii1hcHBs aWNhdGlvbiIv
Pg0KKwkJCTxhcmcgdmFsdWU9Im9yZy5lY2xpcHNlLmVxdWlub3gucDIuZGly ZWN0b3IiLz4N
CisJCQk8YXJnIHZhbHVlPSItYXJ0aWZhY3RSZXBvc2l0b3J5Ii8+DQorCQkJ PGFyZyB2YWx1
ZT0iZmlsZToke3JlcG9zaXRvcnl9Ii8+DQorCQkJPGFyZyB2YWx1ZT0iLW1l dGFkYXRhUmVw
b3NpdG9yeSIvPg0KKwkJCTxhcmcgdmFsdWU9ImZpbGU6JHtyZXBvc2l0b3J5 fSIvPg0KKwkJ
CTxhcmcgdmFsdWU9Ii1kZXN0aW5hdGlvbiIvPg0KKwkJCTxhcmcgdmFsdWU9 IiR7ZGVzdGlu
YXRpb259Ii8+DQorCQkJPGFyZyB2YWx1ZT0iLWJ1bmRsZXBvb2wiLz4NCisJ CQk8YXJnIHZh
bHVlPSIke2Rlc3RpbmF0aW9ufSIvPg0KKwkJCTxhcmcgdmFsdWU9Ii1wcm9m aWxlIi8+DQor
CQkJPGFyZyB2YWx1ZT0iJHtwcm9maWxlfSIvPg0KKwkJCTxhcmcgdmFsdWU9 Ii1wcm9maWxl
UHJvcGVydGllcyIgLz4NCisJCQk8YXJnIHZhbHVlPSJvcmcuZWNsaXBzZS51 cGRhdGUuaW5z
dGFsbC5mZWF0dXJlcz10cnVlIiAvPg0KKwkJCTxhcmcgdmFsdWU9Ii1pbnN0 YWxsSVUiLz4N
CisJCQk8YXJnIHZhbHVlPSIke2l1fSIvPg0KKwkJCTxhcmcgdmFsdWU9Ii1w Mi5vcyIgLz4N
CisJCQk8YXJnIHZhbHVlPSIke3RhcmdldC5vc30iIC8+DQorCQkJPGFyZyB2 YWx1ZT0iLXAy
LndzIiAvPg0KKwkJCTxhcmcgdmFsdWU9IiR7dGFyZ2V0LndzfSIgLz4NCisJ CQk8YXJnIHZh
bHVlPSItcDIuYXJjaCIgLz4NCisJCQk8YXJnIHZhbHVlPSIke3RhcmdldC5h cmNofSIgLz4N
CisJCQk8YXJnIHZhbHVlPSItY29uc29sZUxvZyIvPg0KKwkJCTxqdm1hcmcg dmFsdWU9Ii1E
ZWNsaXBzZS5wMi5kYXRhLmFyZWE9JHtkZXN0aW5hdGlvbn0vcDIiLz4NCisJ CQk8anZtYXJn
IHZhbHVlPSItRGVjbGlwc2UucDIucHJvZmlsZT0ke3Byb2ZpbGV9Ii8+DQor CQk8L2phdmE+
DQorCTwvdGFyZ2V0Pg0KKzwvcHJvamVjdD4NClwgTm8gbmV3bGluZSBhdCBl bmQgb2YgZmls
ZQ0KI1Agb3JnLmVjbGlwc2UuYnVja21pbnN0ZXIudHV0b3JpYWwucmNwcDIu ZmVhdHVyZQ0K
SW5kZXg6IGZlYXR1cmUueG1sDQo9PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQotLS0gZmVhdHVy ZS54bWwJKHJl
dmlzaW9uIDEwNDA2KQ0KKysrIGZlYXR1cmUueG1sCSh3b3JraW5nIGNvcHkp DQpAQCAtMTYs
MjQyICsxNiwxMiBAQA0KICAgICAgIFtFbnRlciBMaWNlbnNlIERlc2NyaXB0 aW9uIGhlcmUu
XQogICAgPC9saWNlbnNlPgogCi0gICA8cGx1Z2luCi0gICAgICAgICBpZD0i b3JnLmVjbGlw
c2UuZXF1aW5veC5jb21tb24iCi0gICAgICAgICBkb3dubG9hZC1zaXplPSIw IgotICAgICAg
ICAgaW5zdGFsbC1zaXplPSIwIgotICAgICAgICAgdmVyc2lvbj0iMC4wLjAi Ci0gICAgICAg
ICB1bnBhY2s9ImZhbHNlIi8+Ci0KLSAgIDxwbHVnaW4KLSAgICAgICAgIGlk PSJvcmcuZWNs
aXBzZS5lY2YiCi0gICAgICAgICBkb3dubG9hZC1zaXplPSIwIgotICAgICAg ICAgaW5zdGFs
bC1zaXplPSIwIgotICAgICAgICAgdmVyc2lvbj0iMC4wLjAiCi0gICAgICAg ICB1bnBhY2s9
ImZhbHNlIi8+Ci0KLSAgIDxwbHVnaW4KLSAgICAgICAgIGlkPSJvcmcuZWNs aXBzZS5lY2Yu
ZmlsZXRyYW5zZmVyIgotICAgICAgICAgZG93bmxvYWQtc2l6ZT0iMCIKLSAg ICAgICAgIGlu
c3RhbGwtc2l6ZT0iMCIKLSAgICAgICAgIHZlcnNpb249IjAuMC4wIgotICAg ICAgICAgdW5w
YWNrPSJmYWxzZSIvPgotCi0gICA8cGx1Z2luCi0gICAgICAgICBpZD0ib3Jn LmVjbGlwc2Uu
ZXF1aW5veC5yZWdpc3RyeSIKLSAgICAgICAgIGRvd25sb2FkLXNpemU9IjAi Ci0gICAgICAg
ICBpbnN0YWxsLXNpemU9IjAiCi0gICAgICAgICB2ZXJzaW9uPSIwLjAuMCIK LSAgICAgICAg
IHVucGFjaz0iZmFsc2UiLz4KLQotICAgPHBsdWdpbgotICAgICAgICAgaWQ9 Im9yZy5lY2xp
cHNlLm9zZ2kuc2VydmljZXMiCi0gICAgICAgICBkb3dubG9hZC1zaXplPSIw IgotICAgICAg
aXBzZS5jb3JlLm5ldCIKLSAgICAgICAgIGRvd25sb2FkLXNpemU9IjAiCi0g ICAgICAgICBp
bnN0YWxsLXNpemU9IjAiCi0gICAgICAgICB2ZXJzaW9uPSIwLjAuMCIKLSAg ICAgICAgIHVu
cGFjaz0iZmFsc2UiLz4KKyAgIDxpbmNsdWRlcw0KKyAgICAgICAgIGlkPSJv cmcuZWNsaXBz
ZS5lcXVpbm94LnAyLnVzZXIudWkiDQorICAgICAgICAgdmVyc2lvbj0iMC4w LjAiLz4NCiAK
ICAgIDxwbHVnaW4KLSAgICAgICAgIGlkPSJvcmcuZWNsaXBzZS5lcXVpbm94 LnAyLmNvcmUi
Ci0gICAgICAgICBkb3dubG9hZC1zaXplPSIwIgotICAgICAgICAgaW5zdGFs bC1zaXplPSIw
IgotICAgICAgICAgdmVyc2lvbj0iMC4wLjAiCi0gICAgICAgICB1bnBhY2s9 ImZhbHNlIi8+
Ci0KLSAgIDxwbHVnaW4KLSAgICAgICAgIGlkPSJvcmcuZWNsaXBzZS5lcXVp bm94LnAyLmRp
cmVjdG9yIgotICAgICAgICAgZG93bmxvYWQtc2l6ZT0iMCIKLSAgICAgICAg IGluc3RhbGwt
c2l6ZT0iMCIKLSAgICAgICAgIHZlcnNpb249IjAuMC4wIgotICAgICAgICAg dW5wYWNrPSJm
YWxzZSIvPgotCi0gICA8cGx1Z2luCi0gICAgICAgICBpZD0ib3JnLmVjbGlw c2UuZXF1aW5v
eC5wMi5lbmdpbmUiCi0gICAgICAgICBkb3dubG9hZC1zaXplPSIwIgotICAg ICAgICAgaW5z
dGFsbC1zaXplPSIwIgotICAgICAgICAgdmVyc2lvbj0iMC4wLjAiCi0gICAg ICAgICB1bnBh
Y2s9ImZhbHNlIi8+Ci0KLSAgIDxwbHVnaW4KLSAgICAgICAgIGlkPSJvcmcu ZWNsaXBzZS5l
cXVpbm94LnAyLmdhcmJhZ2Vjb2xsZWN0b3IiCi0gICAgICAgICBkb3dubG9h ZC1zaXplPSIw
IgotICAgICAgICAgaW5zdGFsbC1zaXplPSIwIgotICAgICAgICAgdmVyc2lv bj0iMC4wLjAi
Ci0gICAgICAgICB1bnBhY2s9ImZhbHNlIi8+Ci0KLSAgIDxwbHVnaW4KLSAg ICAgICAgIGlk
PSJvcmcuZWNsaXBzZS5lcXVpbm94LnAyLm1ldGFkYXRhLnJlcG9zaXRvcnki Ci0gICAgICAg
ICBkb3dubG9hZC1zaXplPSIwIgotICAgICAgICAgaW5zdGFsbC1zaXplPSIw IgotICAgICAg
ICAgdmVyc2lvbj0iMC4wLjAiCi0gICAgICAgICB1bnBhY2s9ImZhbHNlIi8+ Ci0KLSAgIDxw
bHVnaW4KLSAgICAgICAgIGlkPSJvcmcuZWNsaXBzZS5lcXVpbm94LnAyLm1l dGFkYXRhIgot
ICAgICAgICAgZG93bmxvYWQtc2l6ZT0iMCIKLSAgICAgICAgIGluc3RhbGwt c2l6ZT0iMCIK
LSAgICAgICAgIHZlcnNpb249IjAuMC4wIgotICAgICAgICAgdW5wYWNrPSJm YWxzZSIvPgot
Ci0gICA8cGx1Z2luCi0gICAgICAgICBpZD0ib3JnLmVjbGlwc2UuZXF1aW5v eC5mcmFtZXdv
cmthZG1pbiIKLSAgICAgICAgIGRvd25sb2FkLXNpemU9IjAiCi0gICAgICAg ICBpbnN0YWxs
LXNpemU9IjAiCi0gICAgICAgICB2ZXJzaW9uPSIwLjAuMCIKLSAgICAgICAg IHVucGFjaz0i
ZmFsc2UiLz4KLQotICAgPHBsdWdpbgotICAgICAgICAgaWQ9Im9yZy5lY2xp cHNlLmVxdWlu
b3gucDIuYXJ0aWZhY3QucmVwb3NpdG9yeSIKLSAgICAgICAgIGRvd25sb2Fk LXNpemU9IjAi
Ci0gICAgICAgICBpbnN0YWxsLXNpemU9IjAiCi0gICAgICAgICB2ZXJzaW9u PSIwLjAuMCIK
LSAgICAgICAgIHVucGFjaz0iZmFsc2UiLz4KLQotICAgPHBsdWdpbgotICAg ICAgICAgaWQ9
Im9yZy5lY2xpcHNlLmVxdWlub3gucDIucHVibGlzaGVyIgotICAgICAgICAg ZG93bmxvYWQt
c2l6ZT0iMCIKLSAgICAgICAgIGluc3RhbGwtc2l6ZT0iMCIKLSAgICAgICAg IHZlcnNpb249
IjAuMC4wIgotICAgICAgICAgdW5wYWNrPSJmYWxzZSIvPgotCi0gICA8cGx1 Z2luCi0gICAg
ICAgICBpZD0ib3JnLmVjbGlwc2UuZXF1aW5veC5wMi51aSIKLSAgICAgICAg IGRvd25sb2Fk
LXNpemU9IjAiCi0gICAgICAgICBpbnN0YWxsLXNpemU9IjAiCi0gICAgICAg ICB2ZXJzaW9u
PSIwLjAuMCIKLSAgICAgICAgIHVucGFjaz0iZmFsc2UiLz4KLQotICAgPHBs dWdpbgotICAg
ICAgICAgaWQ9Im9yZy5lY2xpcHNlLmVxdWlub3guZnJhbWV3b3JrYWRtaW4u ZXF1aW5veCIK
LSAgICAgICAgIGRvd25sb2FkLXNpemU9IjAiCi0gICAgICAgICBpbnN0YWxs LXNpemU9IjAi
Ci0gICAgICAgICB2ZXJzaW9uPSIwLjAuMCIKLSAgICAgICAgIHVucGFjaz0i ZmFsc2UiLz4K
LQotICAgPHBsdWdpbgotICAgICAgICAgaWQ9Im9yZy5lY2xpcHNlLmVxdWlu b3guc2ltcGxl
Y29uZmlndXJhdG9yIgotICAgICAgICAgZG93bmxvYWQtc2l6ZT0iMCIKLSAg ICAgICAgIGlu
ZWNmLnByb3ZpZGVyLmZpbGV0cmFuc2ZlciIKLSAgICAgICAgIGRvd25sb2Fk LXNpemU9IjAi
Im9yZy5lY2xpcHNlLmVxdWlub3gucDIuZXhlbXBsYXJ5c2V0dXAiCi0gICAg ICAgICBkb3du
bG9hZC1zaXplPSIwIgotICAgICAgICAgaW5zdGFsbC1zaXplPSIwIgotICAg ICAgICAgdmVy
c2lvbj0iMC4wLjAiCi0gICAgICAgICB1bnBhY2s9ImZhbHNlIi8+Ci0KLSAg IDxwbHVnaW4K
LSAgICAgICAgIGlkPSJvcmcuZWNsaXBzZS5lcXVpbm94LnAyLnRvdWNocG9p bnQuZWNsaXBz
ZSIKLSAgICAgICAgIGRvd25sb2FkLXNpemU9IjAiCi0gICAgICAgICBpbnN0 YWxsLXNpemU9
IjAiCi0gICAgICAgICB2ZXJzaW9uPSIwLjAuMCIKLSAgICAgICAgIHVucGFj az0iZmFsc2Ui
Lz4KLQotICAgPHBsdWdpbgotICAgICAgICAgaWQ9Im9yZy5lY2xpcHNlLmVx dWlub3gucDIu
dG91Y2hwb2ludC5uYXRpdmVzIgotICAgICAgICAgZG93bmxvYWQtc2l6ZT0i MCIKLSAgICAg
ICAgIGluc3RhbGwtc2l6ZT0iMCIKLSAgICAgICAgIHZlcnNpb249IjAuMC4w IgotICAgICAg
ICAgdW5wYWNrPSJmYWxzZSIvPgotCi0gICA8cGx1Z2luCi0gICAgICAgICBp ZD0ib3JnLmVj
bGlwc2UuZXF1aW5veC5wMi51aS5zZGsiCi0gICAgICAgICBkb3dubG9hZC1z aXplPSIwIgot
ICAgICAgICAgaW5zdGFsbC1zaXplPSIwIgotICAgICAgICAgdmVyc2lvbj0i MC4wLjAiCi0g
ICAgICAgICB1bnBhY2s9ImZhbHNlIi8+Ci0KLSAgIDxwbHVnaW4KLSAgICAg ICAgIGlkPSJv
cmcuZWNsaXBzZS5lcXVpbm94LnNpbXBsZWNvbmZpZ3VyYXRvci5tYW5pcHVs YXRvciIKLSAg
ICAgICAgIGRvd25sb2FkLXNpemU9IjAiCi0gICAgICAgICBpbnN0YWxsLXNp emU9IjAiCi0g
ICAgICAgICB2ZXJzaW9uPSIwLjAuMCIKLSAgICAgICAgIHVucGFjaz0iZmFs c2UiLz4KLQot
ICAgPHBsdWdpbgotICAgICAgICAgaWQ9Im9yZy5zYXQ0ai5jb3JlIgotICAg ICAgICAgZG93
bmxvYWQtc2l6ZT0iMCIKLSAgICAgICAgIGluc3RhbGwtc2l6ZT0iMCIKLSAg ICAgICAgIHZl
cnNpb249IjAuMC4wIgotICAgICAgICAgdW5wYWNrPSJmYWxzZSIvPgotCi0g ICA8cGx1Z2lu
Ci0gICAgICAgICBpZD0ib3JnLnNhdDRqLnBiIgotICAgICAgICAgZG93bmxv YWQtc2l6ZT0i
MCIKLSAgICAgICAgIGluc3RhbGwtc2l6ZT0iMCIKLSAgICAgICAgIHZlcnNp b249IjAuMC4w
IgotICAgICAgICAgdW5wYWNrPSJmYWxzZSIvPgotCi0gICA8cGx1Z2luCi0g ICAgICAgICBp
ZD0ib3JnLmVjbGlwc2UuZXF1aW5veC5zZWN1cml0eSIKLSAgICAgICAgIGRv d25sb2FkLXNp
emU9IjAiCi0gICAgICAgICBpbnN0YWxsLXNpemU9IjAiCi0gICAgICAgICB2 ZXJzaW9uPSIw
LjAuMCIKLSAgICAgICAgIHVucGFjaz0iZmFsc2UiLz4KLQotICAgPHBsdWdp bgotICAgICAg
ICAgaWQ9Im9yZy5lY2xpcHNlLmVxdWlub3guc2VjdXJpdHkubWFjb3N4Igot ICAgICAgICAg
b3M9Im1hY29zeCIKLSAgICAgICAgIGFyY2g9InBwYyx4ODYseDg2XzY0Igot ICAgICAgICAg
ZG93bmxvYWQtc2l6ZT0iMCIKLSAgICAgICAgIGluc3RhbGwtc2l6ZT0iMCIK LSAgICAgICAg
IHZlcnNpb249IjAuMC4wIgotICAgICAgICAgZnJhZ21lbnQ9InRydWUiCi0g ICAgICAgICB1
bnBhY2s9ImZhbHNlIi8+Ci0KLSAgIDxwbHVnaW4KLSAgICAgICAgIGlkPSJv cmcuZWNsaXBz
ZS5lcXVpbm94LnNlY3VyaXR5LnVpIgotICAgICAgICAgZG93bmxvYWQtc2l6 ZT0iMCIKLSAg
ICAgICAgIGluc3RhbGwtc2l6ZT0iMCIKLSAgICAgICAgIHZlcnNpb249IjAu MC4wIgotICAg
ICAgICAgdW5wYWNrPSJmYWxzZSIvPgotCi0gICA8cGx1Z2luCi0gICAgICAg ICBpZD0ib3Jn
LmVjbGlwc2UuZXF1aW5veC5wcmVmZXJlbmNlcyIKLSAgICAgICAgIGRvd25s b2FkLXNpemU9
IjAiCi0gICAgICAgICBpbnN0YWxsLXNpemU9IjAiCi0gICAgICAgICB2ZXJz aW9uPSIwLjAu
MCIKLSAgICAgICAgIHVucGFjaz0iZmFsc2UiLz4KLQotICAgPHBsdWdpbgot ICAgICAgICAg
aWQ9Im9yZy5lY2xpcHNlLmVxdWlub3gucDIuamFycHJvY2Vzc29yIgotICAg ICAgICAgZG93
Ci0gICAgICAgICBpZD0ib3JnLmVjbGlwc2UuZXF1aW5veC5hcHAiCi0gICAg ICAgICBkb3du
LSAgICAgICAgIGlkPSJvcmcuZWNsaXBzZS5lY2YuaWRlbnRpdHkiCi0gICAg ICAgICBkb3du
LSAgICAgICAgIGlkPSJjb20uaWJtLmljdSIKKyAgICAgICAgIGlkPSJvcmcu YXBhY2hlLmNv
bW1vbnMubG9nZ2luZyINCiAgICAgICAgICBkb3dubG9hZC1zaXplPSIwIgog ICAgICAgICAg
aW5zdGFsbC1zaXplPSIwIgogICAgICAgICAgdmVyc2lvbj0iMC4wLjAiCg==
--------------090108070904080601030105--
Re: Tutorial for building an RCP from hudson [message #36286 is a reply to message #36181] |
Thu, 25 June 2009 09:29   |
Hi Johannes,
Comments inline...
This sounds like a regression of some kind. It used to work but it's been a while since anyone tried it.
> wiki?
Yes, absolutely. I think it's great that you do this. We are in a bad shape when it comes to examples and tutorials so a
contribution like that is very valuable and appreciated.
I agree that the sample should have an RMAP of its own but I'm not too keen about using an approach where Hudson
populates the workspace. By doing that, you bypass the whole resolution/materialization piece in Buckminster. Not so
good if the purpose is to use it all as an example. It would also impede future examples of more advanced features such
as CQUERY based branch/tag selection.
Would it be possible to make Hudson understand that it should use Buckminster as the check-out tool? Or perhaps we could
make Hudson use the information that it finds in a BOM file (the intermediate file that Buckminster creates when it runs
the resolver) to do the check-out?
> patch). Would you be willing to apply the patch and eventually host the
Yes, we'd be willing to do that. I think you should open a bugzilla where you can paste a copy of this discussion and
then attach patches. The reason for that is that Eclipse.org cannot accept patches unless they come as proper bugzilla
attachments. An accepted patch also means that your name is added to the contributor list of our IP-log.
Thomas Hallgren
Re: Tutorial for building an RCP from hudson [message #36319 is a reply to message #36286] |
Thu, 25 June 2009 10:40   |
Hi Thomas,
comments inline as well
Thomas Hallgren schrieb:
> Hi Johannes,
> Comments inline...
>> but it could not be found
I see :)
>> the wiki?
> shape when it comes to examples and tutorials so a contribution like
I'm glad you like the idea
> keen about using an approach where Hudson populates the workspace. By
> Buckminster. Not so good if the purpose is to use it all as an example.
> It would also impede future examples of more advanced features such as
I don't think it's really bypassing. Materialization takes still place
(kinda :) )since there is no workspace, just checked out modules.
Resolution also takes place, just a simplified version with only two
possible location: filesystem or target platform (other would be
possible as well if you want for example some maven artifacts from your
company's repository).
The simple file-system resolution makes a lot of things easier for
Hudson in my opinion:
-you do not need to configure VCS credentials since this is done
globally (by the administrator) in the hudson config
-you get the change log on every build
-the logs can be used to do advanced automated stuff like blaming test
failures, updating bugzilla, report and changelog generation...
-workspaces do not usually get deleted in hudson before/after a build
and I'm not even sure if buckminster can do a cvs/svn update, or if you
always have to do a full checkout (which is way slower). If it can, the
only way to achieve this would be to maintain an additional mspec, or is
there another way?
But I definetly do get your point, for an example it would make sense to
demonstrate the buckminster capabilities, I'm just not so sure if it
really is the best, or rather, easiest approach in a CI server.
> Buckminster as the check-out tool? Or perhaps we could make Hudson use
> Buckminster creates when it runs the resolver) to do the check-out?
That actually sounds very interesting. I can't answer that just now, but
I will think about how that could be done.
However, if for example the buckminster hudson plugin would also
register itself as as SCM plugin there's still the question I asked
above: can buckminster currently do svn, cvs, perforce,... updates, or
only checkout? Can the commit comments be retrieved? Can it be done
without an additional mspec?
Without commit logs, updates in favor of full check-outs and globally
configured credientials, I doubt that many hudson users would do the
check out with buckminster.
But I definetly like the idea, and if you think that there is a way to
preserve those features, then I'd be in.
About the later (using the bom to check-out) I'm not completly sure, but
I don't think it will work because SCM plugins always run before build
plugins run and all the check-out/update stuff is not done by the hudson
core, but specific plugins depending on the SCM in use. I'll have a look
but I don't think it could currently be done without changing a lot of
hudson code for this very special use-case.
>> to be buildable and I'd need the extra files available in SVN (see
>> attached patch). Would you be willing to apply the patch and
>> eventually host the new cquery that points to the simplified
>> local-resolution rmap (I'll deliver both if you are ok with my general
>> approach) so that they will be available for public?
> where you can paste a copy of this discussion and then attach patches.
> they come as proper bugzilla attachments. An accepted patch also means
> Regards,
> Thomas Hallgren
Ok, done. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=281503
I hope it is ok like that...
Johannes
Re: Tutorial for building an RCP from hudson [message #36353 is a reply to message #36319] |
Thu, 25 June 2009 12:06   |
Johannes,
I totally agree that the best strategy for integration builds is to have the
CI server checkout/update the source. Buckminster can populate the workspace
using a local resolver. This is much faster than having Buckminster perform
the checkout.
Having said that, I see the point in the example showing SVN checkout
instead of local resolution. Maybe we can have _both_ resolvers in the RMAP
and select the appropriate one using a resolutionFilter? It would default to
SVN checkout, but in the presence of a "integrationBuild" property, the RMAP
could then select the local resolver.
I'd like to bring up another point for a _really_ comprehensive example:
target platform. I am a strong proponent for defining a target platform up
front that everybody, i.e. all developers and the integration build, compile
against. So the first step in a build process would be to populate the
target platform. We're currently using Buckminster to do this, although I
really like PDE's new target platform story. At the moment, though, it can
only deal with exact bundle versions, which is not really what I want. A
combination of Buckminster and PDE would be great. Maybe we can hook
Buckminster into PDE as a target platform source. I'll investigate that...
Achim
> Hi Thomas,
>> Hi Johannes,
>> Comments inline...
> I see :)
>>> the wiki?
> there another way?
>> Regards,
>> Thomas Hallgren
> Best regards,
> Johannes
Re: Tutorial for building an RCP from hudson [message #36382 is a reply to message #36353] |
Thu, 25 June 2009 12:40   |
Hi Achim and Johannes,
Achim Demelt wrote:
> Johannes,
> the checkout.
While it might be faster and give some advantages for the Hudson user, it also has serious implications:
1. The Hudson build is no longer the same build as you would run locally (reproducibility is key).
2. You no longer maintain the data about the SCM's in one place (the build model is scattered).
3. You cannot control the resolution/materialization with a CQUERY.
4. The list of material to check-out will be static.
Using Hudson to check out is perhaps faster but remember that the reason it takes a bit longer when Buckminster does it
is that Buckminster doesn't maintain a list of things to check out. The list is computed dynamically. AFAIK, Hudson is
not capable of doing that. This feature is of some importance since the developer that adds a bundle to a feature might
have insufficient privileges to change the Hudson configuration.
That's better, but you still need to maintain a static list and you still have issues with permissions.
I would much rather see a solution where Hudson can actually benefit from what Buckminster finds. Which makes me
curious, what does Hudson need in terms of functionality in order to maintain its workspace + changelog? Perhaps it's
not that hard to accomplish.
IMO, Buckminster now has an even better way to populate the target platform. Simply use the eclipse.import reader and
the p2 materializer. The advantage is that the provisioning that takes place when you do it that way can be platform
independent and very exact (based on the resolution). The target platform provision mechanism provided with PDE will use
the planner when installing from a remote repository. The planner is unfortunately always bound to a particular platform
configuration. The PDE provider must also be told explicitly what features to include from the repository.
Also, Buckminster will provision the target platform in parallel with the SCM checkouts. How's that for speed ;-)
Thomas Hallgren
Re: [buckminster-dev] Re: Tutorial for building an RCP from hudson [message #36408 is a reply to message #36382] |
Thu, 25 June 2009 12:53   |
I generally structure my rmaps to prioritize local providers and then if
they fail, fall back to SCM checkout providers. This makes for fast
local builds for me, but for CI builds, I always check out from the
SCM. I don't use a resolutionFilter to do this - I just have the providers
in series, i.e.
<searchPath name="sca.features">
componentTypes="eclipse.feature,osgi.bundle" mutable="true"
source="false">
<uri format="{0}/org.eclipse.stp.sca/features/{1}">
<bc:propertyRef key="project.root" />
</uri>
</provider>
<provider readerType="svn"
componentTypes="osgi.bundle,eclipse.feature,buckminster"
<uri format=" http://dev.eclipse.org/svnroot/stp/org.eclipse.stp.sca-tools /org.eclipse.stp.sca/trunk/features/{0}">
</uri>
</provider>
</searchPath>
Am I missing some supercool Buckminster feature I could be using
instead? (most likely ;)
> Simply use the eclipse.import reader and the p2 materializer.
The eclipse.import reader I know about, but not the p2 materializer
- is there an example of how to use this anywhere I could look at?
I usually create the platforms manually, and stick with them - changes
occur infrequently (except with release train :) - but I don't want to
keep doing that, automation being the goal.
cheers
--oh
Re: [buckminster-dev] Re: Tutorial for building an RCP from hudson [message #36451 is a reply to message #36408] |
Thu, 25 June 2009 13:48   |
Hi Oisin,
turns out that we're doing the exact same thing, just the order is
differently. I also use an rmap that is capable of resolving everything
through SCM, but in CI build the local resolution kicks in, whereas the
developers can use the cquery + rmap to populate their workspace from SCM.
As for target platforms, I also maintain them manually so far (install
everything I want, and copy them to the build server). This is not
perfect, just simply faster than any other way I found so far (and
target platform changes only once or twice a year fo me).
So if there are better ways now, I'd also love to hear about them.
> in series, i.e.
> source="false">
> </uri>
> </provider>
> </uri>
> </provider>
> </searchPath>
> cheers
> --oh
Re: Tutorial for building an RCP from hudson [message #36456 is a reply to message #36382] |
Thu, 25 June 2009 14:06   |
Hi Thomas,
more comments inline
> Achim Demelt wrote:
>> Johannes,
>> have the CI server checkout/update the source. Buckminster can
>> populate the workspace using a local resolver. This is much faster
>> than having Buckminster perform the checkout.
Well, it is, as long as the target platform is the same. Doesn't matter
who checks something out, as long as it is the same thing that's checked
out.
My rmap contains both the local resolver and the SCM resolver actually.
A new developer resolves the query to populate the workspace from SCM
and once that's set up, just invokes the action which will act in
exactly the same way as it does in the CI environment.
A cquery is involved and maintains what's getting resolved. The only
thing that's controled by the CI system is the availablity of certain
artifacts
Not necessarily static. I'd say it is a very common scenario that all
the bundles involved in a specific build job reside in one common module
in the SCM. In the hudson job you check out that parent module and let
buckminster resolve whatever other artifacts are necessary and allowed.
You add a new bundle to the scm -> the checkout job will get it, throw
it into the hudson workspace, buckminster will resolve try to resolve
the query again, notices a new dependency and tries to pick it up.
> it takes a bit longer when Buckminster does it is that Buckminster
> dynamically. AFAIK, Hudson is not capable of doing that. This feature is
> might have insufficient privileges to change the Hudson configuration.
See above, most of the time you'll just check out the parent module, and
even if that's more than you actually need, buckminster won't even see
the additional artifacts.
>> RMAP and select the appropriate one using a resolutionFilter? It would
>> default to SVN checkout, but in the presence of a "integrationBuild"
>> property, the RMAP could then select the local resolver.
> from what Buckminster finds. Which makes me curious, what does Hudson
> changelog? Perhaps it's not that hard to accomplish.
I'd really be interested in that option.
It should be possible since AFAIK it is the SCM plugin's responsibility
to fill the hudson workspace with content and hudson shouldn't care at
all how that happens and where everything comes from.
The thing really is: how to make buckminster behave well as a 'meta scm'
for hudson? How to force an update on every build, how to retrieve the
commit logs? If you show me the way , I'll do my best to implement the
dirty little details.
>> example: target platform. I am a strong proponent for defining a
>> target platform up front that everybody, i.e. all developers and the
>> integration build, compile against. So the first step in a build
>> process would be to populate the target platform. We're currently
>> using Buckminster to do this, although I really like PDE's new target
>> platform story. At the moment, though, it can only deal with exact
>> bundle versions, which is not really what I want. A combination of
>> Buckminster and PDE would be great. Maybe we can hook Buckminster into
> platform. Simply use the eclipse.import reader and the p2 materializer.
> that way can be platform independent and very exact (based on the
> will use the planner when installing from a remote repository. The
> Regards,
> Thomas Hallgren
Johannes
Re: [buckminster-dev] Re: Tutorial for building an RCP from hudson [message #36478 is a reply to message #36451] |
Thu, 25 June 2009 14:23   |
> Hi Oisin,
I'm working on getting a Buckminster build of Buckminster itself running using Hudson at Eclipse.org. You can look at
the files here:
http://build.eclipse.org/tools/buckminster/hudson/
I'm not finished yet but some things might be of interest, for instance, the tp.mspec (tp == target platform):
<mspec
xmlns="http://www.eclipse.org/buckminster/MetaData-1.0"
name="Target Platform MSPEC"
materializer="p2"
installLocation="${targetPlatformPath}"
url="tp.cquery">
<property key="target.arch" value="*"/>
<property key="target.os" value="*"/>
<property key="target.ws" value="*"/>
</mspec>
vouches for a platform independent materialization into the target platform.
The tp.cquery:
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="tp.rmap">
<cq:rootRequest name="org.eclipse.platform" componentType="eclipse.feature"/>
<cq:advisorNode namePattern=".*" useTargetPlatform="false" useWorkspace="false"/>
<cq:property key="target.arch" value="*"/>
<cq:property key="target.os" value="*"/>
<cq:property key="target.ws" value="*"/>
</cq:componentQuery>
NOTE: The advisor node is important. It ensures that nothing is resolved against the current runtime.
The tp.rmap. This one will only find the Eclipse platform but that can be extended of course:
<rmap xmlns="http://www.eclipse.org/buckminster/RMap-1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
xmlns:pmp="http://www.eclipse.org/buckminster/PDEMapProvider-1.0"
xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0">
<searchPath name="org.eclipse.platform">
<provider readerType="eclipse.import" componentTypes="osgi.bundle,eclipse.feature" mutable="false" source="false">
<uri format=" http://download.eclipse.org/eclipse/updates/3.5?importType=b inary"/>
</provider>
</searchPath>
<locator searchPathRef="org.eclipse.platform"/>
</rmap>
The intersting target from the build.xml file:
<target name="build.tp" unless="tp.exists" depends="install.buckminster,init.workspace">
<echo message="Importing binaries into target platform ${tp}"/>
<buckminster command="import">
<globargs>
<jvmarg value="-DtargetPlatformPath=${tp}"/>
</globargs>
<cmdargs>
<arg value="${basedir}/tp.mspec" />
</cmdargs>
</buckminster>
<echo message="Setting target platform path to ${tp}"/>
<buckminster command="setpref">
<cmdargs>
<arg value="targetPlatformPath=${tp}" />
</cmdargs>
</buckminster>
</target>
'buckminster' is a macro defined further up.
HTH,
- thomas
Re: [buckminster-dev] Re: Tutorial for building an RCP from hudson [message #36508 is a reply to message #36478] |
Thu, 25 June 2009 16:18   |
Hi Thomas,
> using Hudson at Eclipse.org. You can look at the files here:
So what this does is essentially:
-download p2 director
-create a headless buckminster with the features necessary for the build
with p2
-import an mspec into a not-yet-existing target platform? Did I get this
part right? That sounds really nice, I didn't know that was possible...
-import the buckminster sources with the dev-query
-build the site
Well, that surely is an interesting example, thank you for sharing it.
For the tutorial things would be somewhat easier though, because
buckminster would already be up and running.
I'm not sure I'm completly understanding all of this just yet, so let me
try to put it together. For the tutorial this would mean:
1. buckminster uses an mspec to materialize a platform independant
target platform out of thin air
2. set the target platform to the output of 1
3. resolve a cquery for mailapp.product.feature (bundles and features
will be fetched from SVN, the rest comes from the target platform)
4. build site
5. create product with p2 director
Is that kinda what you meant?
If the RCP needs more than the bare platform, would you write several
mspecs to import or introduce another component (cspec, or feature?) to
describe the contents of the target platform?
Johannes
Re: [buckminster-dev] Re: Tutorial for building an RCP from hudson [message #36551 is a reply to message #36508] |
Thu, 25 June 2009 17:13   |
Yes, that's right.
> 4. build site
Yes.
No, I would use one mspec and make the rmap richer. Or perhaps appoint the Galileo release instead of just the Eclipse
Platform (Galileo includes the platform). If need be, appoint Galileo+ http://download.cloudsmith.com/galileoplus/
(Galileo plus a lot of stuff that isn't hosted at Eclipse.org. Subversion connectors for instance).
Thomas Hallgren
Re: Tutorial for building an RCP from hudson [message #36615 is a reply to message #36581] |
Thu, 25 June 2009 18:42   |
>> ... how to make buckminster behave well as a 'meta scm' for hudson?
>> How to force an update on every build, how to retrieve the commit
>> logs? If you show me the way , I'll do my best to implement the dirty
>> little details.
> OK, let's try and resolve this. My knowledge of Hudson is very limited
> so I think we need to meet half way here. Can you give me some pointers
> to where and how an SCM would be hooked in?
> I know you said that the check-out is made before the build, but perhaps
> this could be set up as two builds? The first would just produce a list
> of things to check-out/update and Hudson would uses that the second. The
> way to accomplish that would be to run a buckminster import that just
> produces a BOM (no materialization), then extract the relevant SCM
> entries from the BOM and feed that list to Hudson.
> Regards,
> Thomas Hallgren
The Hudson philosophy (for a freestyle project) is fairly simple.
A job uses 0 to 1 SCM plugins that can be configured in the job
configuration to check out things into the job's workspace.
After that 0 to n build steps are performed on that workspace.
Once the build is done 0 to n publishers can be invoked that do stuff
like gathering test result, checking for TODOs in the source code, and
so on.
So hooking up a new SCM plugin is fairly simple from what I know. You
write a plugin, add some configuration settings and are free to execute
code. I could try doing that if I'd know how to force update behavior
and which part of buckminster I'd have to patch to be able to receive
the change logs.
For a proof of concept however, it might be sufficient to force a
replace and ignore the commit logs. That would result in the required
behavior and the rest could be added later.
The bom idea would IMO not work because the existing SCM plugins are
meant to be configured in the job configuration (i.e. which modules they
should check out for the job). I don't think it really fits into the
concept to have a pre-scm step that actually changes the job
configuration for the scm plugin that's invoked after. More so: I don't
think it's currently even possible to check out stuff from let's say
both CVS and SVN for the same job.
With a completely new job kind specific to buckminster projects it might
be possible to create a bom and feed SCM plugins from that, but that's
beyond my so far gathered hudson-knowledge and would be more of a long
term goal.
Johannes
Re: Tutorial for building an RCP from hudson [message #36716 is a reply to message #36581] |
Fri, 26 June 2009 04:19   |
Hi Thomas,
I was reading some more and here is what I found out so far:
For the buckminster case we'd have very few configuration options (no
urls or anything) which is good.
Hudson expects an SCM plugin to behave like that:
let hudson know if the SCM supports polling, if a workspace is necessary
for polling and if polling is supported, determine if there have been
changes since the last build that would require an update/check-out. In
easiest case we could simply not support polling.
If there are changes, or polling is unsupported, hudson will ask to SCM
plugin to populate the workspace and passes the configuration of the
form your plugin added to the job configuration.
In buckminster case this would be a list of cquerys or mspecs I'd say.
If an update can be implemented in favor of a 'replace', the plugin
should gather the changes (which files, comment, author, time,
action,...) and persist those into a file changelog.xml which will be
evaluated by hudson to present it to the user.
Optionally an scm plugin could also offer a repository viewer if the SCM
system supports that (like the web viewer for SVN + Apache). The user
would use that feature to click on entries in the change log. This would
be rather difficult for a buckminster meta-scm since there might be
different systems involved, but I don't think it's that important.
So yes, I'm pretty sure I could implement something like that in hudson
if only there are ways to have buckminster update things and tell me
about the changes.
In fact this approach would be quite appealing since there'd be almost
no configuration effort in hudson, just query what you want and have
buckminster worry about how to get that.
One thing I don't like too much though, I hate leaking SCM credentials
in a resource map. It should be possible to write a buckminster
extension that accepts credentials with the setpref commands, right? If
so (and if we can solve the other issues), I'd rather code this logic
into the hudson plugin. Credentials for repositories are entered into
the global hudson configuration and the plugin sets the credentials
silently with 'setpref' before executing the actual 'resolve' the user
wanted.
Johannes
Re: Tutorial for building an RCP from hudson [message #36750 is a reply to message #36716] |
Sat, 27 June 2009 05:23   |
Hi Johannes,
Answers inline.
> Hi Thomas,
>> pointers to where and how an SCM would be hooked in?
I think polling can be supported later. Let's start without.
Yes, that sounds reasonable.
This should be added to the CVS and SVN providers in Buckminster. It cannot currently handle that.
Perhaps we can use change-log entries that will tell Buckminster how to redirect to a proper viewer. The viewer as such
is of course beyond Buckminsters scope.
> about the changes.
OK, so I read this to mean that if a buckminster query is re-run on a workspace, it should have the ability to update
that workspace and collect a change-log of the updated entries. That log must then be available (using some command) so
that Hudson can obtain it. Does that sound OK?
One question here is how to handle things that are not source (binaries imported to the project or added to the target
platform).
> wanted.
I agree. This is something that needs to be resolved in a much better way. A first cut could simply pass credentials on
the command line (using -Dsvn.user=xxx -Dsvn.pass=yyy). A corresponding RMAP entry can then look like this:
<uri format="svn+ssh://{0}:{1}@oursvn/path/trunk/{2}">
<bc:propertyRef key="svn.user" />
<bc:propertyRef key="svn.pass" />
</uri>
- thomas
Re: Tutorial for building an RCP from hudson [message #36785 is a reply to message #36750] |
Sat, 27 June 2009 09:47   |
Hi Thomas,
comments inline
> Hi Johannes,
> Answers inline.
>> Hi Thomas,
>>> limited so I think we need to meet half way here. Can you give me
>>> some pointers to where and how an SCM would be hooked in?
>> necessary for polling and if polling is supported, determine if there
>> have been changes since the last build that would require an
>> update/check-out. In easiest case we could simply not support polling.
Yeah, polling really is no big deal at first. I'm not even sure if it
makes much sense for buckminster since you'd have to poll possibly many
different kinds of source repositories.
>> SCM plugin to populate the workspace and passes the configuration of
>> the form your plugin added to the job configuration.
As long as you think it's possible. I'll have a look at the
implementation to get an impression on how big the changes would have to
be. Might take a few days though until I can get to that, though.
>> SCM system supports that (like the web viewer for SVN + Apache). The
>> user would use that feature to click on entries in the change log.
>> This would be rather difficult for a buckminster meta-scm since there
>> might be different systems involved, but I don't think it's that
>> important.
> redirect to a proper viewer. The viewer as such is of course beyond
> Buckminsters scope.
A viewer is a very optional thing, like the polling, I only mentioned it
to sum up how things currently work in hudson (to the best I know). I
mean, it could be kinda nice to have the svn repository url together
with the change logs, but it's really not that important I think.
Besides, the viewer is also out of scope for hudson itself, I think it's
meant to be just a link to for example the webfrontend of e.g SVN.
>> hudson if only there are ways to have buckminster update things and
>> tell me about the changes.
> workspace, it should have the ability to update that workspace and
> available (using some command) so that Hudson can obtain it. Does that
> sound OK?
Yes, that's exactly what I meant. Some way to tell buckminster "do a
cvs/svn update on the stuff that was previously resolved into this
workspace and tell me what happened meanwhile". I think that could also
make sense for regular buckminster usage from within eclipse. Re-run a
cquery/mspec and have the option of fetching updates from the SCM on the
way (not the default option though, but it would be a nice quick way to
get up to date with two clicks).
> imported to the project or added to the target platform).
I don't think that matters at all. Let's say a maven artifact got
updated. I wouldn't expect to see an actual SCM change log for that. The
change log is interesting for CI because of the automated unit testing.
Out of a sudden one of your tests fails. You click on the build that
failed, click on the change log in hudson and see 'ah, developer XY
changed the class that failed in the test-runs since the last build' and
you know immediately what's wrong with your build. The other cool thing
about the change log is reporting. I think most companies have some kind
of naming scheme for commit comment on fixed bugs. You can parse the log
entries for something like [BUG#12345] and automatically generate change
logs from that to let people know what has been improved from 1.0.0 to
1.0.1.
Binary artifacts don't count for much there because
1. you usually don't add a comment to whatever artifact repository you
are using when you deploy a new version, so what information would you
expect to see there
2. binary artifacts are out of scope for unit testing (they'd only
matter for integration tests).
>> If so (and if we can solve the other issues), I'd rather code this
>> logic into the hudson plugin. Credentials for repositories are entered
>> into the global hudson configuration and the plugin sets the
>> credentials silently with 'setpref' before executing the actual
>> 'resolve' the user wanted.
> way. A first cut could simply pass credentials on the command line
> </uri>
> - thomas
This sounds perfectly fine to me, simple properties would be the easiest
way to get the desired behaviour.
This could really be a very cool feature and with hudson getting the
most popular CI server on the market, I'm sure tight integration can be
a boost for buckminster's popularity (just think of the cool demos you
could do with that :) ).
However, it looks like there's still a bit to do before we got all the
pieces together, but an RCP build tutorial + CI system integration could
be done much earlier already, even though without the cool meta-scm feature.
So how would you like it to look like?
Since you'd like to see buckminster do the actual checkout, the
workspace needs to be cleaned up on every build. Therefore the first
hudson build step would be a shell invokation that wipes the hudson
workspace.
The next build step will invoke buckminster and place 4 commands:
1. passes an mspec to materialize the target platform for the MailApp.
similar to what you've shown me, right?
2. The 2nd will be setPref to set the target platform location to the
newly created one
3. The next command will be resolve mailapp.product.feature to do the
checkout from svn
4. the last command will be a mailapp.product.feature#create.product.zip
to build the actual RCP with the ant script from the patch submitted to
bugzilla.
Does that sound ok to you? If the patch is ok to you we'd only need the
rmap, cquery and mspec then. I'm not too familiar with the mspecs yet
because I could find virtually no documentation for their usage except
for the schema, but I'll I'll do my best to deliver those three pieces
within the next days.
Johannes
Re: Tutorial for building an RCP from hudson [message #479107 is a reply to message #479068] |
Sun, 09 August 2009 05:44   |
Hi Henrik,
I'm not sure I understand you right. A patch against the tutorial
project? I already added a patch to make it buildable for the tutorial
and it has been applied, or are you talking about the MSPECs, CSPECs and
the RMAP? Should they live in the releng project of the tutorial? If so,
I can create a patch for that of course, just wasn't sure if that's what
you meant because the other demo queries and rmaps seem to live in
http://www.eclipse.org/buckminster/samples...
If you guys are ok with the general approach and the tutorial can be
added to the buckminster examples section, I think it could
incrementally demonstrate more advanced features of CI. I could think of
-unit testing
-code coverage
-benchmarks
-metrics (like sonar)
-build triggers on commit action
-building specific branches/tags
-qualifier replacement
What do you think?
It's also quite handy IMO to see the current pains of buckminster
integration in real life.
-no changelog for checkout
-no update functionality (which forces the user to delete the workspace
prior to a build)
-no polling support (which makes it hard to trigger a build on commit
actions)
-plugin unit tests are currently difficult to execute
Until Peter has finished the 'Buckminster updating / change-list
generation' and issue 243293 (JUnit support) is resolved, the tutorial
can help explaining how that's currently done, and once those features
are in place, the tutorial can be an example on how those new
capabilities can be utilized.
Btw: The eclipse foundation has a hudson up and running as well, right?
Would it maybe be possible to set up an example job for the Mail-App RCP
and give anonymous users the right to view the job configuration?
Johannes
Henrik Lindberg schrieb:
> Great!
> We should make this part of the mailapp RCP tutorial.
> So, a patch against the tutorial project is much appreciated.
> (track IP etc.)
> Then we can host the necessary files separately as well.
>> Hi,
>> I made some additions to the tutorial and I was hoping that you could
>> host the cquerys/mspecs/rmap along with the other buckminster demo
>> material to make this thing actually executable without any additional
>> files.
>> If the tutorial is missing anything or if I should do something
>> differently, please let me know.
>> The necessary files are attached to this mail.
>> http://wiki.eclipse.org/Building_an_RCP_application_with_hud son_(Buckminster)
>> Best regards,
>> Johannes
Re: Tutorial for building an RCP from hudson [message #479349 is a reply to message #479107] |
Mon, 10 August 2009 14:04   |
> Hi Henrik,
That is what I had in mind.
>If so,
The artifacts that need to be easily shareable (i.e. starting from
nothing) should be published there as well.
> -unit testing
> -code coverage
> -benchmarks
> What do you think?
I think it is an excellent idea. We have to decide on if we want
something that builds up gradually (different instances), or if there is
one that includes everything. Maybe have two? The current mailapp
tutorial as it is to not overload it with stuff, and then one with
everything (and extra mayo :).
> prior to a build)
> actions)
Issues understood - do you think that is worth while? Isn't it better to
wait for the proper solution and document that?
Hm, not sure if that is doable (permission to view some jobs). Maybe
Thomas knows...
Meanwhile, would it be possible to store the job config in mailapps
releng component?
> Best regards,
> Johannes
Re: Tutorial for building an RCP from hudson [message #479489 is a reply to message #479349] |
Tue, 11 August 2009 06:17  |
Hi Henrik,
>> Hi Henrik,
>> and the RMAP? Should they live in the releng project of the tutorial?
Ok, I will create a patch for that and open a bugzilla.
>> If so, I can create a patch for that of course, just wasn't sure if
>> that's what you meant because the other demo queries and rmaps seem to
>> live in http://www.eclipse.org/buckminster/samples...
ok, that would indeed be the mspecs, cspecs and the rmap then.
>> of -unit testing
>> -code coverage
>> -benchmarks
>> What do you think?
That makes sense (although I hate mayo :)). Once the rest is in place I
can open a new bugzilla and attach a simple test fragment for example.
The advanced stuff can go into a new wiki page then.
>> workspace prior to a build)
>> actions)
That depends a little on the timeline I'd say. Unit testing is crucial
for CI and it's currently not super easy to get it up and running. If
the JUnit support is in place relatively soon (including plugin unit
tests) then it would be easier to wait, however, if it will take some
months until the changes are done and actually released, then I think a
little guidance on how to set it up 'the hard way' would help people a lot.
>> RCP and give anonymous users the right to view the job configuration?
> Thomas knows...
> releng component?
I haven't tried it before, but I think it should be possible since
hudson is completely file based. I can zip up a minimal job (with just
the configuration) and the user should be able to extract that into
hudson's job directory. However, the configuration will have to include
the location of the MSPECs, CSPECs, RMAP, so I can't create the patch
until I know the final location of those files (i.e. until you actually
uploaded it to eclipse.org and told me their whereabouts).
Johannes
Current Time: Wed Jul 23 11:23:29 EDT 2025
Powered by FUDForum. Page generated in 0.09981 seconds
