Home » Archived » BIRT » Web Service Data Sources
Web Service Data Sources [message #365330] |
Fri, 26 September 2008 10:26  |
Hi All,
I've been trying to get a web service to work as a data source but I've have
had a number of issues trying to get it to work. I've posted in
birt-exchange but haven't received any response so I'm trying this news
group before I give up on using birt for reporting in my application.
I've gone through the weather service demo and it works fine. I first tried
creating an axis2 web service using WTP and it worked as expected with a
java client. However in BIRT it connects ok as a data source but has issues
when defining a dataset. The input parameters show up but the table mapping
only shows "return" and not the xml data so the columns can't be mapped. So
I designed the web service in C#/ASP.NET and installed in on IIS. In this
case the table mapping page showed the xml structure and I was able to map
the output columns. I was able to open the service in a browser, enter
parameters and on clicking invoke it returned the xml response data set as
expected. However clicking on preview results in the data set editor fails
with a birt exception with the server returning HTTP 400.
So my question to the group is - has anyone successfully created a web
service and used it as a data source? If so could you please outline the
steps you took to create the web service so it works with birt?
Thanks in advance,
Jim
Re: Web Service Data Sources [message #365472 is a reply to message #365466] |
Fri, 03 October 2008 11:53   |
Originally posted by: jasonweathersby.alltel.net
Jim,
Good to hear. Using the web service dataset parameter should pass the
date as a string. Post if you have an issue with this.
Jason
jnorris wrote:
> Hi Jason,
> After some debugging where I added some other services that worked I found
> that the original web service was not even being hit. The main difference
> was that the original service used DateTime input parameters. Removing the
> dates as inputs solved the issue with the service. Now my next step is to
> figure out how to map a date input on the report to a string value that I
> can pass to the service.
> Jim
> "Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
> news:gc04u3$78m$1@build.eclipse.org...
>> Jim,
>> I am not sure why this is failing. A 400 error points to a syntax issue.
>> Do you have BIRT setup to debug? If not can you send me the axis service
>> you built? Just email it to me.
>> Jason
>> jnorris wrote:
>>> Hi Jason,
>>> I did try a preview and got the same error information which is what is
>>> shown in the log file included below. The request in the data source
>>> looks to be the same as the sample post request shown on the asp.net
>>> page:
>>> <?xml version="1.0"? encoding="utf-8">
>>> <SOAP-ENV:Envelope
>>> xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"
>>> xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/"
>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema">
>>> <SOAP-ENV:Body>
>>> <m:getNPTDataItems xmlns:m="http://com.test/services/2008/09">
>>> <m:startDate xsi:type="xsd:dateTime">&?startDate?&</m:startDate >
>>> <m:endDate xsi:type="xsd:dateTime">&?endDate?&</m:endDate>
>>> <m:siteId xsi:type="xsd:string">&?siteId?&</m:siteId>
>>> <m:machineId xsi:type="xsd:string">&?machineId?&</m:machineId>
>>> <m:operatorId xsi:type="xsd:string">&?operatorId?&</m:operatorId >
>>> </m:getNPTDataItems>
>>> </SOAP-ENV:Body>
>>> </SOAP-ENV:Envelope>
>>> At this point I can't rule out some .net permission problem although the
>>> ping test succeeds and the wsdl is retrieved.
>>> Jim
>>> log file info:
>>> !ENTRY org.eclipse.birt.data 4 1001 2008-09-26 09:14:59.096
>>> !MESSAGE A BIRT exception occurred.
>>> !STACK 0
>>> org.eclipse.birt.data.engine.core.DataException: Cannot execute the
>>> statement.
>>> Server returned HTTP response code: 400 for URL:
>>> http://localhost:1095/NPTDataService.asmx
>>> at
>>> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:570)
>>> at
>>> org.eclipse.birt.data.engine.executor.DataSourceQuery.execut e(DataSourceQuery.java:549)
>>> at
>>> org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu eryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:331)
>>> at
>>> org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:801)
>>> at
>>> org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:233)
>>> at
>>> org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:160)
>>> at
>>> org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.populateRecords(ResultSetPreviewPage.java:524)
>>> at
>>> org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.access$2(ResultSetPreviewPage.java:518)
>>> at
>>> org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage$5.run(ResultSetPreviewPage.java:474)
>>> at
>>> org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
>>> Caused by: org.eclipse.datatools.connectivity.oda.OdaException: Server
>>> at
>>> org.eclipse.datatools.enablement.oda.ws.util.RawMessageSende r.getSOAPResponse(RawMessageSender.java:107)
>>> at
>>> org.eclipse.datatools.enablement.oda.ws.impl.Query.getInputS tream(Query.java:183)
>>> at
>>> org.eclipse.datatools.enablement.oda.ws.impl.Query.initXMLQu ery(Query.java:135)
>>> at
>>> org.eclipse.datatools.enablement.oda.ws.impl.Query.executeQu ery(Query.java:127)
>>> at
>>> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.doExecuteQuery(OdaQuery.java:443)
>>> at
>>> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.executeQuery(OdaQuery.java:408)
>>> at
>>> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:556)
>>> ... 9 more
>>> news:gbteer$s1s$1@build.eclipse.org...
>>>> Jim,
>>>> If you preview the report does it retrieve your data?
>>>> Also did you get anything in the workspace log file when you got the 400
>>>> error?
>>>> Jason
>>>> jnorris wrote:
>>>>> Hi All,
>>>>> have had a number of issues trying to get it to work. I've posted in
>>>>> tried creating an axis2 web service using WTP and it worked as expected
>>>>> with a java client. However in BIRT it connects ok as a data source
>>>>> but has issues when defining a dataset. The input parameters show up
>>>>> but the table mapping only shows "return" and not the xml data so the
>>>>> columns can't be mapped. So I designed the web service in C#/ASP.NET
>>>>> and installed in on IIS. In this case the table mapping page showed
>>>>> the xml structure and I was able to map the output columns. I was able
>>>>> to open the service in a browser, enter parameters and on clicking
>>>>> invoke it returned the xml response data set as expected. However
>>>>> clicking on preview results in the data set editor fails with a birt
>>>>> the steps you took to create the web service so it works with birt?
>>>>> Thanks in advance,
>>>>> Jim
Re: Web Service Data Sources [message #691054 is a reply to message #365472] |
Thu, 30 June 2011 11:56   |
Hello, I'm having a similar issue. I removed the dateTime parameters from my wsdl, made them strings instead. Now I'm getting a new error. I also can't get a preview to work, I generally get the same errors as when I'm running it on my server. Hopefully someone can help me, I have no idea how to fix this. Posting the stacktrace here (hope that's ok). It's saying no protocol, but I'm not sure what that means or what it relates to??
Thank you.
17:44:40,447 INFO [ReportManagerBean] Running report generation task
17:44:45,201 WARNING [ModelAdapter] handle type: org.eclipse.birt.report.model.api.OdaDataSetHandle
17:44:46,653 SEVERE [odaconsumer] Cannot execute statement.
org.eclipse.datatools.connectivity.oda.OdaException: no protocol:
at org.eclipse.datatools.enablement.oda.ws.util.RawMessageSender.getSOAPResponse(RawMessageSender.java:107)
at org.eclipse.datatools.enablement.oda.ws.impl.Query.getInputStream(Query.java:184)
at org.eclipse.datatools.enablement.oda.ws.impl.Query.initXMLQuery(Query.java:136)
at org.eclipse.datatools.enablement.oda.ws.impl.Query.executeQuery(Query.java:128)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doExecuteQuery(OdaQuery.java:464)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.executeQuery(OdaQuery.java:428)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:599)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:771)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:399)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1045)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:158)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init>(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1875)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:170)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:75)
at com.vls.reporting.ReportManagerBean.generateReport(ReportManagerBean.java:116)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:69)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor$InvocationContext.proceed(InvocationContextInterceptor.java:138)
at org.jboss.seam.intercept.EJBInvocationContext.proceed(EJBInvocationContext.java:44)
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:56)
at org.jboss.seam.transaction.RollbackInterceptor.aroundInvoke(RollbackInterceptor.java:28)
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:68)
at org.jboss.seam.core.MethodContextInterceptor.aroundInvoke(MethodContextInterceptor.java:44)
at org.jboss.seam.persistence.EntityManagerProxyInterceptor.aroundInvoke(EntityManagerProxyInterceptor.java:29)
at org.jboss.seam.persistence.HibernateSessionProxyInterceptor.aroundInvoke(HibernateSessionProxyInterceptor.java:30)
at org.jboss.seam.intercept.RootInterceptor.invoke(RootInterceptor.java:107)
at org.jboss.seam.intercept.SessionBeanInterceptor.aroundInvoke(SessionBeanInterceptor.java:50)
at sun.reflect.GeneratedMethodAccessor414.invoke(Unknown Source)
at org.jboss.ejb3.interceptors.aop.EJB3InterceptorInterceptor.invoke(EJB3InterceptorInterceptor.java:83)
at org.jboss.ejb3.interceptors.aop.EJB3InterceptorInterceptor.invoke(EJB3InterceptorInterceptor.java:70)
at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:59)
at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:73)
at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:59)
at sun.reflect.GeneratedMethodAccessor413.invoke(Unknown Source)
at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:72)
at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_3318565.invoke(InvocationContextInterceptor_z_fillMethod_3318565.java)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:88)
at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_3318565.invoke(InvocationContextInterceptor_z_setup_3318565.java)
at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
at org.jboss.ejb3.stateless.StatelessInstanceInterceptor.invoke(StatelessInstanceInterceptor.java:68)
at org.jboss.aspects.tx.TxPolicy.invokeInCallerTx(TxPolicy.java:126)
at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterceptor.java:194)
at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
at org.jboss.ejb3.security.RoleBasedAuthorizationInterceptorv2.invoke(RoleBasedAuthorizationInterceptorv2.java:201)
at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:186)
at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:176)
at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:216)
at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:207)
at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:164)
at $Proxy725.generateReport(Unknown Source)
at org.jboss.seam.util.Reflections.invoke(Reflections.java:22)
at org.jboss.seam.intercept.RootInvocationContext.proceed(RootInvocationContext.java:32)
at org.jboss.seam.intercept.ClientSideInterceptor$1.proceed(ClientSideInterceptor.java:76)
at org.jboss.seam.intercept.ClientSideInterceptor.invoke(ClientSideInterceptor.java:54)
at org.javassist.tmp.java.lang.Object_$$_javassist_seam_17.generateReport(Object_$$_javassist_seam_17.java)
at com.vls.reports.ReportActionBean.generateReport(ReportActionBean.java:143)
at org.jboss.seam.core.BijectionInterceptor.aroundInvoke(BijectionInterceptor.java:77)
at org.jboss.seam.core.ConversationInterceptor.aroundInvoke(ConversationInterceptor.java:65)
at org.jboss.ejb3.entity.ExtendedPersistenceContextPropagationInterceptor.invoke(ExtendedPersistenceContextPropagationInterceptor.java:60)
at org.jboss.ejb3.stateful.StatefulInstanceInterceptor.invoke(StatefulInstanceInterceptor.java:81)
at $Proxy820.generateReport(Unknown Source)
at org.jboss.seam.ejb.RemoveInterceptor.aroundInvoke(RemoveInterceptor.java:43)
at org.javassist.tmp.java.lang.Object_$$_javassist_seam_16.generateReport(Object_$$_javassist_seam_16.java)
at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:335)
at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:280)
at org.jboss.el.parser.AstMethodSuffix.getValue(AstMethodSuffix.java:59)
at org.jboss.el.parser.AstMethodSuffix.invoke(AstMethodSuffix.java:65)
at org.jboss.el.parser.AstValue.invoke(AstValue.java:96)
at org.jboss.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:276)
at com.sun.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:68)
at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:88)
at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102)
at javax.faces.component.UICommand.broadcast(UICommand.java:387)
at org.ajax4jsf.component.AjaxViewRoot.processEvents(AjaxViewRoot.java:329)
at org.ajax4jsf.component.AjaxViewRoot.broadcastEventsForPhase(AjaxViewRoot.java:304)
at org.ajax4jsf.component.AjaxViewRoot.processPhase(AjaxViewRoot.java:261)
at org.ajax4jsf.component.AjaxViewRoot.processApplication(AjaxViewRoot.java:474)
at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:82)
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:100)
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:265)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:83)
at org.jboss.seam.web.IdentityFilter.doFilter(IdentityFilter.java:40)
at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:69)
at org.jboss.seam.web.MultipartFilter.doFilter(MultipartFilter.java:90)
at org.jboss.seam.web.ExceptionFilter.doFilter(ExceptionFilter.java:64)
at org.jboss.seam.web.RedirectFilter.doFilter(RedirectFilter.java:45)
at org.ajax4jsf.webapp.BaseXMLFilter.doXmlFilter(BaseXMLFilter.java:206)
at org.ajax4jsf.webapp.BaseFilter.handleRequest(BaseFilter.java:290)
at org.ajax4jsf.webapp.BaseFilter.processUploadsAndHandleRequest(BaseFilter.java:388)
at org.ajax4jsf.webapp.BaseFilter.doFilter(BaseFilter.java:515)
at org.jboss.seam.web.Ajax4jsfFilter.doFilter(Ajax4jsfFilter.java:56)
at org.jboss.seam.web.LoggingFilter.doFilter(LoggingFilter.java:60)
at org.jboss.seam.web.HotDeployFilter.doFilter(HotDeployFilter.java:53)
at org.jboss.seam.servlet.SeamFilter.doFilter(SeamFilter.java:158)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:433)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:662)
[Updated on: Thu, 21 July 2011 08:28] by Moderator
Re: Web Service Data Sources [message #691067 is a reply to message #691054] |
Thu, 30 June 2011 12:11   |
Is this a report that you could post and is the web service public?
Attached is an example Web Service report, although the web service is
public it is slow.
Jason
> relates to??
> Thank you.
> org.eclipse.datatools.connectivity.oda.OdaException: no protocol: at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> com.volvo.vls.reporting.ReportManagerBean.generateReport(ReportManagerBean.java:116)
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> com.volvo.vls.reports.ReportActionBean.generateReport(ReportActionBean.java:143)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Web Service Data Sources [message #694439 is a reply to message #694431] |
Fri, 08 July 2011 11:23   |
Deesha,
Does your web service require authentication credentials?
This may be the issue. You may have to use the custom class feature of
the web service. Take a look at the article here:
http://www.birt-exchange.org/org/devshare/designing-birt-reports/461-birt-web-service-oda-article/
Take a look at this thread as well.
http://www.birt-exchange.org/org/forum/index.php/topic/12013-basic-authentication/
Jason
On 7/8/2011 11:14 AM, Jason Weathersby wrote:
> Deesha,
> Can you open your browser and enter:
> http://localhost:8080/vls-web/services/BIRTServicePort?wsdl
> and take a screen shot and post it? Right now the datasource is defined
> to use the wsdl on the local file system. Can you change it to use
> Jason
> On 7/7/2011 10:17 AM, forums-noreply@eclipse.org wrote:
>> Hi Jason,
>> Re the logging thing, I'm not sure I know how to do that at all, sorry.
>> I added the @WebMethod annotation and a few other things, now the
>> error is different. i'll include the whole stacktrace here, it happens
>> after the fonts are initialized..
>> This is getting really annoying, I can't get a report to generate
>> properly.
>> Any idea what this could be?
>> Deesha
Re: Web Service Data Sources [message #699443 is a reply to message #699356] |
Thu, 21 July 2011 10:38  |
Is js.jar in the classpath? What BIRT runtime version are you using?
Jason
On 7/21/2011 8:27 AM, forums-noreply@eclipse.org wrote:
> Also, what do you do if you get this error:
> 14:20:06,724 FATAL [ReportManagerBean] Reporting engine exception:Error
> happened while running the report
> 14:20:06,738 SEVERE [application] java.lang.Exception: Error happened
> javax.faces.el.EvaluationException: java.lang.Exception: Error happened
> at
> javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:102)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by: java.lang.Exception: Error happened while running the report
> at
> com.vls.reporting.ReportManagerBean.generateReport(ReportManagerBean.java:119)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_10751758.invoke(InvocationContextInterceptor_z_fillMethod_10751758.java)
> at
> at
> at
> org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_10751758.invoke(InvocationContextInterceptor_z_setup_10751758.java)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at $Proxy533.generateReport(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> org.javassist.tmp.java.lang.Object_$$_javassist_seam_19.generateReport(Object_$$_javassist_seam_19.java)
> at
> com.vls.reports.ReportActionBean.generateReport(ReportActionBean.java:133)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at $Proxy632.generateReport(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.javassist.tmp.java.lang.Object_$$_javassist_seam_18.generateReport(Object_$$_javassist_seam_18.java)
> at
> at
> at
> at
> ... 53 more
> Caused by: java.lang.NoClassDefFoundError:
> org/mozilla/javascript/ScriptableObject
> at java.lang.ClassLoader.defineClass1(Native Method)
> at java.lang.ClassLoader.defineClassCond(ClassLoader.java:632)
> at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
> at
> org.jboss.classloader.spi.base.BaseClassLoader.access$200(BaseClassLoader.java:63)
> at
> org.jboss.classloader.spi.base.BaseClassLoader$2.run(BaseClassLoader.java:572)
> at
> org.jboss.classloader.spi.base.BaseClassLoader$2.run(BaseClassLoader.java:532)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.jboss.classloader.spi.base.BaseClassLoader.loadClassLocally(BaseClassLoader.java:530)
> at
> org.jboss.classloader.spi.base.BaseClassLoader.loadClassLocally(BaseClassLoader.java:507)
> at
> org.jboss.classloader.spi.base.BaseDelegateLoader.loadClass(BaseDelegateLoader.java:134)
> at
> org.jboss.classloader.spi.filter.FilteredDelegateLoader.loadClass(FilteredDelegateLoader.java:131)
> at
> org.jboss.classloader.spi.base.ClassLoadingTask$ThreadTask.run(ClassLoadingTask.java:452)
> at
> org.jboss.classloader.spi.base.ClassLoaderManager.nextTask(ClassLoaderManager.java:251)
> at
> org.jboss.classloader.spi.base.ClassLoaderManager.process(ClassLoaderManager.java:150)
> at
> org.jboss.classloader.spi.base.BaseClassLoaderDomain.loadClass(BaseClassLoaderDomain.java:265)
> at
> org.jboss.classloader.spi.base.BaseClassLoaderDomain.loadClass(BaseClassLoaderDomain.java:1119)
> at
> org.jboss.classloader.spi.base.BaseClassLoader.loadClassFromDomain(BaseClassLoader.java:798)
> at
> org.jboss.classloader.spi.base.BaseClassLoader.loadClass(BaseClassLoader.java:441)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
> at
> org.eclipse.birt.core.framework.osgi.OSGILauncher$ChildFirstURLClassLoader.loadClass(OSGILauncher.java:688)
> at
> org.eclipse.osgi.internal.loader.SystemBundleLoader.findLocalClass(SystemBundleLoader.java:115)
> at
> org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:33)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:454)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:398)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:105)
> at
> org.eclipse.birt.core.internal.function.impl.FunctionProviderImpl.getWrapperedCategories(FunctionProviderImpl.java:405)
> at
> org.eclipse.birt.core.internal.function.impl.FunctionProviderImpl.registerScriptFunction(FunctionProviderImpl.java:120)
> at
> org.eclipse.birt.core.script.functionservice.impl.FunctionProvider.registerScriptFunction(FunctionProvider.java:76)
> at
> org.eclipse.birt.core.script.CoreJavaScriptInitializer.initialize(CoreJavaScriptInitializer.java:26)
> at
> org.eclipse.birt.report.engine.javascript.JavascriptEngine.initWrapFactory(JavascriptEngine.java:161)
> at
> org.eclipse.birt.report.engine.javascript.JavascriptEngine.<init>(JavascriptEngine.java:131)
> at
> org.eclipse.birt.report.engine.javascript.JavascriptEngineFactory.createScriptEngine(JavascriptEngineFactory.java:98)
> at
> org.eclipse.birt.core.script.ScriptContext.createEngine(ScriptContext.java:238)
> at
> org.eclipse.birt.core.script.ScriptContext.getScriptEngine(ScriptContext.java:227)
> at
> org.eclipse.birt.report.engine.adapter.ModelDteApiAdapter.<init>(ModelDteApiAdapter.java:176)
> at
> org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.<init>(AbstractDataEngine.java:107)
> at
> org.eclipse.birt.report.engine.data.dte.DteDataEngine.<init>(DteDataEngine.java:85)
> at
> org.eclipse.birt.report.engine.data.DataEngineFactory.createDataEngine(DataEngineFactory.java:100)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.openDataEngine(ExecutionContext.java:843)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.getDataEngine(ExecutionContext.java:865)
> at
> org.eclipse.birt.report.engine.executor.ReportExecutor.execute(ReportExecutor.java:123)
> at
> org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportExecutor.execute(WrappedReportExecutor.java:60)
> at
> org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplciateReportExecutor.execute(SuppressDuplciateReportExecutor.java:42)
> at
> at
> org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportExecutor.execute(LocalizedReportExecutor.java:61)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:168)
> at
> at
> com.vls.reporting.ReportManagerBean.generateReport(ReportManagerBean.java:112)
> ... 238 more
> Caused by: java.lang.ClassNotFoundException:
> org.mozilla.javascript.ScriptableObject
> at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
> at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
> at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
> at java.lang.Class.forName0(Native Method)
> at java.lang.Class.forName(Class.java:247)
> at
> org.jboss.classloader.spi.base.BaseClassLoaderDomain.loadClass(BaseClassLoaderDomain.java:292)
> at
> at
> at
> ... 289 more
> 14:20:06,745 WARNING [lifecycle] #{reportAction.generateReport()}:
> javax.faces.FacesException: #{reportAction.generateReport()}:
> at
> com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:118)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by: javax.faces.el.EvaluationException: java.lang.Exception:
> at
> at
> ... 52 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Current Time: Wed Jul 23 07:31:57 EDT 2025
Powered by FUDForum. Page generated in 0.45600 seconds
