Home » Archived » BIRT » barcode via Dynamic Image
barcode via Dynamic Image [message #364730] Tue, 19 August 2008 14:16 Go to next message
Originally posted by: spam2.logemann.org
i want to embed Barcodes by generating them on the fly as images with a
barcode java library and send the raw image data to Birt.
I saw that an image in birt can be from a dynamic source. Has anyone
ever done this? In Birt you can select a DataSet (why a dataset) or a
Report Item for an image.
So normally i would do in my calling java program:
task.getAppContext().put("imageRaw",
someByteArrayOutputStream.toByteArray());
So i would pass a byte[] to the birt context and bind this to a DataSet
or something else....
Do you think this will work? Anyone done something similar?
Marc
Re: barcode via Dynamic Image [message #364733 is a reply to message #364730] Tue, 19 August 2008 15:39 Go to previous messageGo to next message
its so nice when ideas instantly work. For all those interessted in the
solution. See this:
http://logemannreloaded.blogspot.com/2008/08/embed-barcodes- in-birt-wo-barcode-fonts.html
Marc
Marc Logemann schrieb:
> Marc
Re: barcode via Dynamic Image [message #364739 is a reply to message #364730] Tue, 19 August 2008 22:20 Go to previous messageGo to next message
Marc Logemann wrote:
> Marc
We're using BIRT to generate barcodes, but I've been using barcode fonts
and embedding the fonts in PDFs. We've gotten this font based method to
work with Code39 and Code 128 fonts.
I'd be interested in using images as you describe if you ever get it
working.
Steven
Re: barcode via Dynamic Image [message #364755 is a reply to message #364739] Wed, 20 August 2008 12:15 Go to previous messageGo to next message
i already postet the solution in this thread. Perhaps it also works for
you....
Marc
>> Hi,
>> a barcode java library and send the raw image data to Birt.
>> DataSet or something else....
>> Marc
> working.
> Steven
icon10.gif  Re: barcode via Dynamic Image [message #765989 is a reply to message #364730] Wed, 14 December 2011 22:15 Go to previous messageGo to next message
Razz Hi, Marc.
I have met the similar question as yours. You may have a try with Onbarcode's Java Barcode Generator for Eclipse BIRT which provides several methods to generate and print barcodes in Eclipse BIRT reports.Hope it helped you.Good luck for you!
Re: barcode via Dynamic Image [message #900980 is a reply to message #765989] Thu, 09 August 2012 05:48 Go to previous messageGo to next message
Onbarcode.com is a really excellent website which provides high quality linear and 2D barcode generator, reader and scanner in .NET AND JAVA applications. I conclude from what I have used. Recently, I find another one(Terrek.com) which is as good as Onbarcode. It is much cheaper with FREE version to try. You may have try it in someday! Good luck!
Re: barcode via Dynamic Image [message #1077061 is a reply to message #900980] Thu, 01 August 2013 03:42 Go to previous message
as for your question, you may try ka barcode generator for eclipse
[Updated on: Wed, 12 February 2014 02:08] by Moderator
Previous Topic:Does BIRT support XPath Axes?
Next Topic:Render while report is generated
Current Time: Sat Jul 19 04:41:16 EDT 2025
Powered by FUDForum. Page generated in 0.03678 seconds
