Home » Language IDEs » PHP Development Tools (PDT) » Debugger needed to run a script?
Debugger needed to run a script? [message #36266] Tue, 17 July 2007 09:38 Go to next message
Originally posted by: dserodio.gmail.com
When I choose Run As... > PHP Script, Eclipse complains about the
debugger not being correctly configured in php.ini
Do I really need a debugger in order to run (as opposed to debug) a
simple PHP script?
Daniel Serodio
Re: Debugger needed to run a script? [message #36299 is a reply to message #36266] Tue, 17 July 2007 09:41 Go to previous messageGo to next message
> simple PHP script?
> Daniel Serodio
You'll need a PHP executable. One that should work comes with the
installation of the Zend debugger plugin (get it at zend.com/pdt) . With
this you can debug PHP scripts locally.
If you then also want to debug on a remote server, you'll need an
additional dll / .so file in the server directories, as well as setting
it up.
Re: Debugger needed to run a script? [message #36332 is a reply to message #36299] Tue, 17 July 2007 09:50 Go to previous messageGo to next message
>> simple PHP script?
>> Thanks,
>> Daniel Serodio
Thanks for your reply.
I already have a PHP executable (installed by XAMPP), and I've created
an entry in "PHP Executables" Eclipse preferences pointing to this
directory (C:\xampp\php).
> it up.
Re: Debugger needed to run a script? [message #36621 is a reply to message #36332] Wed, 18 July 2007 08:29 Go to previous messageGo to next message
Originally posted by: Patrick.Schulz.brand-implementation-group.de
I think it goes into more detailed questions, (also that it iterests me
and I'm new in PDT).
Which executeable will be used when I'm going to run or debug a script,
not a web page?
What parameters are passed?
Is it needed to have / use different php.inis for that (like php-cli.ini)?
Any help is highly appreciated.
Regrds,
Patrick
Re: Debugger needed to run a script? [message #36655 is a reply to message #36621] Wed, 18 July 2007 09:20 Go to previous message
> not a web page?
I think I can answer this one.
It's the php.exe under the directory selected in Window > Preferences >
PHP > PHP Executables
The only parameter passed (according to Process Explorer) is "-c
/full/path/to/script.php"
HTH,
Daniel Serodio
Previous Topic:xdebug, vhosts, and server roots
Next Topic:xdebug/PDT-RC3/xampp Apache dies- help?
Current Time: Thu Sep 18 10:15:59 EDT 2025
Powered by FUDForum. Page generated in 0.04938 seconds
