Home » Archived » BIRT » Cross Tabs with empty columns/rows ? (please!)
Cross Tabs with empty columns/rows ? (please!) [message #362661] Tue, 20 May 2008 14:29 Go to next message
Originally posted by: thilo.bruesshaber.gmail.com
is it possible to have a cross table with rows or columns that have no
result values?
In my case only "valued" rows or columns are visible.
That means when at least one cell in a row or column has a value, the
row or column is visible.
Want I want, is to see all possible columns/rows even when there is no
result value in any cell of the column or row.
The column/row names would be retrieved from two different data sets.
Is there any way to achieve this?
Thank you,
Thilo
Re: Cross Tabs with empty columns/rows ? (please!) [message #362664 is a reply to message #362661] Tue, 20 May 2008 20:19 Go to previous messageGo to next message
Please use the new feature Show empty rows and columns in BIRT2.3.0. The
option is in Property Editor. Select your crosstab and specify which row
and column you want to show the empty rows/columns
Tianli
Re: Cross Tabs with empty columns/rows ? (please!) [message #362670 is a reply to message #362664] Wed, 21 May 2008 02:46 Go to previous message
Because BIRT 2.3.0 is not released yet it is not an option for me.
I think I have to use a table with "known" columns instead of cross tabs.
Does the new feature "Show empty rows and columns" in BIRT 2.3.0 mean
that I can take the column definitions from an "other" dateset?
Thank you,
Thilo
> Tianli
Previous Topic:params["date"].toLocaleString() in BIRT 2.2.2 ???
Next Topic:Problems with Custom ODA Data Set Page
Current Time: Tue Sep 16 21:12:13 EDT 2025
Powered by FUDForum. Page generated in 0.05097 seconds
