Home » Archived » BIRT » Reportparameter (Date) and getYear() in computed column
Reportparameter (Date) and getYear() in computed column [message #360781] Fri, 22 February 2008 10:01 Go to next message
I get an error using a report parameter (type Date) in a computed column
of a dataset. If I use following expression: params["xyz"].getYear();
I'll get the following error: "The data type of computed column "xyz" is
java.lang.Integer, but one of its value is "null", which cannot be
converted to java.lang.Integer". Anyone know how to solve this problem?
The report parameter has a default value.
Thanks for help!
Re: Reportparameter (Date) and getYear() in computed column [message #360788 is a reply to message #360781] Fri, 22 February 2008 13:40 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Helmut,
try params["xyz"].value.getYear();
Jason
Helmut Neubauer wrote:
> Hello,
> Thanks for help!
Re: Reportparameter (Date) and getYear() in computed column [message #360815 is a reply to message #360788] Mon, 25 February 2008 03:16 Go to previous messageGo to next message
there is no change, same error.
- The report parameter has a default value.
- I tried to use a format for the report parameter.
- I tried to use Integer as Data Type for the column (i also tried the
other types, although they shoudn't be the right ones).
Helmut
Jason Weathersby schrieb:
> Helmut,
> Jason
>> Hello,
>> Thanks for help!
Re: Reportparameter (Date) and getYear() in computed column [message #360831 is a reply to message #360815] Mon, 25 February 2008 09:43 Go to previous message
Helmut,
Can you post your report?
The error you are getting usually happens when one of the data set
values is null and it is used in a calculation.
Jason
> Hello,
> Helmut
>> Helmut,
>> Jason
>>> Hello,
>>> Thanks for help!
Previous Topic:Storing report parameters configuration with the web viewer
Next Topic:Urgent: No images/charts with RunAndRenderTask within a SwingWorker
Current Time: Wed Oct 15 04:20:31 EDT 2025
Powered by FUDForum. Page generated in 0.04760 seconds
