Home » Archived » EPF » Another nullpointer on saving resources
Another nullpointer on saving resources [message #35931] Mon, 23 July 2007 13:45 Go to next message
This is more or less what I did.
I created an activity from an activity diagram and got an error (sorry for
not writing down the code).
I went back to the WBS, changed the name of the activity from there.
Later on, I started copying task descriptors to the new created activity.
The following message happened after deleting the old descriptors. While
showing the message (a saving resources dialog), the epf-composer froze
completely.
at
org.eclipse.epf.diagram.core.providers.SharedResourceDiagram DocumentProvider.reverseToSaved(Unknown
Source)
at
org.eclipse.epf.diagram.core.part.AbstractDiagramEditor.reve rseToSaved(Unknown
Source)
at
org.eclipse.epf.diagram.core.part.AbstractDiagramEditor.disp ose(Unknown
Source)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:689)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2721)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
at org.eclipse.ui.internal.WorkbenchPage.access$1
(WorkbenchPage.java:2625)
at
org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
at
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2547)
at
org.eclipse.epf.diagram.core.part.util.DiagramEditorUtil.ope nDiagramEditor(Unknown
Source)
at
org.eclipse.epf.diagram.ad.custom.policies.OpenADDEditPolicy .getOpenCommand(Unknown
Source)
at
org.eclipse.gmf.runtime.diagram.ui.editpolicies.OpenEditPoli cy.getCommand(OpenEditPolicy.java:58)
at
org.eclipse.gef.editparts.AbstractEditPart.getCommand(Abstra ctEditPart.java:473)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.access$
(GraphicalEditPart.java:1)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt$1.run(GraphicalEditPart.java:463)
at
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExclusive(TransactionalEditingDomainImpl.java:262)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.getCommand(GraphicalEditPart.java:458)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.performRequest(GraphicalEditPart.java:1096)
at
org.eclipse.gef.tools.SelectEditPartTracker.performOpen(Sele ctEditPartTracker.java:187)
at
org.eclipse.gef.tools.SelectEditPartTracker.handleDoubleClic k(SelectEditPartTracker.java:131)
at
org.eclipse.gef.tools.AbstractTool.mouseDoubleClick(Abstract Tool.java:944)
at
org.eclipse.gef.tools.SelectionTool.mouseDoubleClick(Selecti onTool.java:501)
at org.eclipse.gef.EditDomain.mouseDoubleClick(EditDomain.java: 204)
at
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse DoubleClicked(DomainEventDispatcher.java:285)
at
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDoubl eClick(LightweightSystem.java:508)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:182)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
at
org.eclipse.epf.rcp.ui.MainApplication.createWorkbenchAdviso r(Unknown
Source)
at org.eclipse.epf.rcp.ui.MainApplication.start(Unknown Source)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Re: Another nullpointer on saving resources [message #35967 is a reply to message #35931] Mon, 23 July 2007 15:55 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
Which build are you using ? We need build # or date
I would suggest to file Bugzilla if you can reproduce this.
Shilpa
Re: Another nullpointer on saving resources [message #36000 is a reply to message #35967] Tue, 24 July 2007 07:55 Go to previous message
The build label is 20070719-1836 for version 1.2.0, and the OS is linux.
I did not in first place because I could not find the sequence of steps that
led to the failure, yet. Not that I tried much, just a couple of naive
attempts. So, by now, this is just a warning.
Jorge
Re: Another nullpointer on saving resources [message #580754 is a reply to message #35931] Mon, 23 July 2007 15:55 Go to previous message
Shilpa
Re: Another nullpointer on saving resources [message #580774 is a reply to message #35967] Tue, 24 July 2007 07:55 Go to previous message
Jorge
Previous Topic:Another nullpointer on saving resources
Next Topic:Problem with a method specification
Current Time: Thu Jul 24 21:27:10 EDT 2025
Powered by FUDForum. Page generated in 0.06294 seconds
