Home » Eclipse Projects » DSDP - Target Management » "C/C++ Remote Application" not available in run configurations
"C/C++ Remote Application" not available in run configurations [message #35739] |
Wed, 17 June 2009 14:34  |
I've been developing a plugin that integrates a cross-compile
toolchain and uses RSE for an easy, almost-no-configuration remote
debugging environment for an ARM remote target. One major issue I've
run into is although a user has the RSE End-User Runtime installed,
creates a remote connection, and connects (tests by launching a
shell), when they create a project and select Run Configurations (or
Debug Configurations), C/C++ Remote Application is not there (only
C/C++ Local Application, Eclipse Application, etc). It's not that it
is never there, it will sometimes be an option but I can't determine
what makes that bit flip, so to speak.
Any help would be appreciated. Below are the instructions given to the
user, he failed at #21 as there was no "C/C++ Remote Application" option
in Run or Debug Configurations.
-Alex Styler
*** Instructions:
1. Install the latest Eclipse for C/C++ Developers
2. Launch Eclipse, goto Help -> Software Updates
3. Check the Remote System Explorer End-User Runtime box in the
Ganymede Update Site -> Remote Access and Device Development
directory and Install.
4. Download the SDK from Dave, and mv it to the root directory (/)
5. Extract it here (sudo tar -xvf ****os.....)
6. Copy ***_1.0.0.jar into the dropins directory located in the eclipse
install
directory (eclipse/dropins/)
(All of the above could be achieved from a CD installer)
(One Time Connection Setup)
7. Launch Eclipse
8. Goto Window -> Open Perspective -> Other and select Remote System
Explorer
9. Right click Remote Systems and select New Connection
10. Choose "SSH Only" and input the IP Address of the *** into the
Hostname Box
(e.g. 192.168.1.2).
11. Change the Connection Name to *** or something similar.
12. Test the connection to the *** (right click the connection in the
Remote
Systems window and hit Connect).
13. Input the user credentials (root /// *****) and have it save both the
user
and password.
14. Switch back the the C/C++ development perspective (either top right
icon or
Window -> Open Perspective ...)
15. If the IP of your *** changes, you will have to come back to the
remote
systems explorer and edit the hostname for your *** connection
(Per Project setup)
15. Goto File -> New Project -> C Project
16. Name the project PROJECTNAME
16. In project type, select Hello World ANSI C Project
17. In Toolchain, select Custom *** Linux GCC
18. Hit Finish.
19. Hit Project -> Build All to build the binaries for the project
(only if automatic building is turned off)
20. Goto Run -> Run Configurations
21. Double Click C/C++ Remote Application
22. In the Remote Absolute Path box of your new configuration, type
/PROJECTNAME
Re: "C/C++ Remote Application" not available in run configurations [message #35913 is a reply to message #35739] |
Mon, 22 June 2009 08:13  |
Hi Alex,
what versions of RSE / CDT are you using? Note that since recently
(RSE 3.1m7 I believe), the remoteCDT functionality is no longer part
of RsE but must be installed from the CDT Repository.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> -Alex Styler
> *** Instructions:
> 3. Check the Remote System Explorer End-User Runtime box in the Ganymede
> install
> 7. Launch Eclipse
> Explorer
> Hostname Box
> (e.g. 192.168.1.2).
> Remote Systems window and hit Connect).
> the user
> and password.
> icon or
> remote systems explorer and edit the hostname for your *** connection
> (Per Project setup)
> 18. Hit Finish.
> /PROJECTNAME
Re: "C/C++ Remote Application" not available in run configurations [message #581127 is a reply to message #35739] |
Hi Alex,
> -Alex Styler
> *** Instructions:
> install
> 7. Launch Eclipse
> Explorer
> Hostname Box
> (e.g. 192.168.1.2).
> the user
> and password.
> icon or
> (Per Project setup)
> 18. Hit Finish.
> /PROJECTNAME
Current Time: Wed Jul 23 08:50:43 EDT 2025
Powered by FUDForum. Page generated in 0.10654 seconds
