Home » Archived » XML Schema Definition (XSD) » use="required"/use="optional"
use="required"/use="optional" [message #35452] Mon, 12 January 2004 10:28 Go to next message
Originally posted by: crscca.bol.net.in
Hi!
OK how does one get the following:-
Raghu
Re: use="required"/use="optional" [message #35487 is a reply to message #35452] Mon, 12 January 2004 13:45 Go to previous messageGo to next message
raster wrote:
> Hi!
Hi Raghu,
XSDAttributeUse.getUse() returns an instance of the XSDAttributeUseCategory
enum, with value OPTIONAL_LITERAL, PROHIBITED_LITERAL, or REQUIRED_LITERAL.
XSDAttributeUse represents a use of an attribute (by declaration, by
reference, or via an attribute group). Its role is analogous to XSDParticle.
XSDAttributeUses are generally accessed from an XSDComplexTypeDefinition or
XSDAttributeGroupDefinition via their attributeUses references.
Dave
Re: use="required"/use="optional" [message #35594 is a reply to message #35487] Tue, 13 January 2004 08:19 Go to previous messageGo to next message
We seem to be done with our code's xsd portion. Having some trouble with
the compositors when we are extending complex types. Will sort it out
later.
Have 1 question
1. Does xsd plugin work fine inside M6? So far used it inside M5.
Thanks.
Raster
Dave Steinberg wrote:
> raster wrote:
> > Hi!
> Hi Raghu,
> Cheers,
> Dave
Re: use="required"/use="optional" [message #35661 is a reply to message #35594] Tue, 13 January 2004 15:14 Go to previous messageGo to next message
Raster wrote:
> Have 1 question
Hi Raster,
EMF doesn't yet work in M6, so XSD doesn't either. You'll have to stick with
M5 until we get it working. Unfortunately, we're stretched very thing right now.
Dave
Re: use="required"/use="optional" [message #35763 is a reply to message #35661] Wed, 14 January 2004 01:34 Go to previous messageGo to next message
Hi Dave,
What do you mean by- "we're stretched very thing right now"?
Raster
> Raster wrote:
> > Have 1 question
> Hi Raster,
now.
> Cheers,
> Dave
Re: use="required"/use="optional" [message #35797 is a reply to message #35661] Wed, 14 January 2004 01:38 Go to previous messageGo to next message
Hi Dave,
I hope eclipse team plans to continue with xsd beyond M5. (No need for me
to panic I hope on that count.)
Raster
> Raster wrote:
> > Have 1 question
> Hi Raster,
now.
> Cheers,
> Dave
Re: use="required"/use="optional" [message #35864 is a reply to message #35797] Wed, 14 January 2004 09:30 Go to previous messageGo to next message
Hi Raster,
Sorry, I didn't mean to alarm you. I just meant that the EMF/XSD team isn't
at full strength right now, due to vacations and to other responsibilities.
Things should be picking up again in the coming weeks. Yes, we certainly
intend to continue with XSD well beyond M5.
Oh, and "thing" was a typo; I meant "thin." :)
Dave
Re: use="required"/use="optional" [message #35898 is a reply to message #35864] Thu, 15 January 2004 08:21 Go to previous message
Thank Goodness 4 that.
> Hi Raster,
> Cheers,
> Dave
Re: use="required"/use="optional" [message #582514 is a reply to message #35452] Mon, 12 January 2004 13:45 Go to previous message
raster wrote:
> Hi!
Hi Raghu,
Dave
Re: use="required"/use="optional" [message #582577 is a reply to message #35487] Tue, 13 January 2004 08:19 Go to previous message
later.
Have 1 question
Thanks.
Raster
> raster wrote:
> > Hi!
> Hi Raghu,
> Cheers,
> Dave
Re: use="required"/use="optional" [message #582618 is a reply to message #35594] Tue, 13 January 2004 15:14 Go to previous message
Raster wrote:
> Have 1 question
Hi Raster,
Dave
Re: use="required"/use="optional" [message #582689 is a reply to message #35661] Wed, 14 January 2004 01:34 Go to previous message
Hi Dave,
Raster
> Raster wrote:
> > Have 1 question
> Hi Raster,
now.
> Cheers,
> Dave
Re: use="required"/use="optional" [message #582705 is a reply to message #35661] Wed, 14 January 2004 01:38 Go to previous message
Hi Dave,
Raster
> Raster wrote:
> > Have 1 question
> Hi Raster,
now.
> Cheers,
> Dave
Re: use="required"/use="optional" [message #582728 is a reply to message #35797] Wed, 14 January 2004 09:30 Go to previous message
Hi Raster,
Dave
Re: use="required"/use="optional" [message #582743 is a reply to message #35864] Thu, 15 January 2004 08:21 Go to previous message
> Hi Raster,
> Cheers,
> Dave
Previous Topic:how to modify the XSD using the Xpath
Next Topic:how to find the element that is refered using ref attribute.
Current Time: Sat Jul 26 20:33:33 EDT 2025
Powered by FUDForum. Page generated in 0.09732 seconds
