Home » Archived » OHF » All PIX consumer tests are failing
All PIX consumer tests are failing [message #35404] Thu, 18 October 2007 20:24 Go to next message
Originally posted by: ralkire.ndorange.com
I am new to OHF so may not have things configured correctly. I turned of
auditing by setting AtnaAgent.java's doAudit flag to false, or I would not
have gotten these results.
The message is being sent ok, howerver all responses from all test result in
this ERR||QPD^1^3^1^4|204|W|
Please help me get past this problem, thanks....
Results follow:
[DEBUG][MESA10501Test.java:103] 10501a
MSH|^~\&|MESA_ADT|DOMAIN1_ADMITTING|MESA_XREF|XYZ_HOSPIT AL|20071018191131-0500||QBP^Q23^QBP_Q21|8702553853547660391| P|2.5
QPD|Q23^Get Corresponding
IDs|7814801327065385401696002755913|PIX10501^^^HIMSS2005& ;1.3.6.1.4.1.21367.2005.1.1&ISO^PI
RCP|I
[INFO ][MLLPDestination.java:308] *** Sending message to lsaix26.dfw.ibm.com
on port 3600
RCP|I
[INFO ][MLLPDestination.java:314] *** Response from lsaix26.dfw.ibm.com on
port 3600 was:
MSH|^~\&|MESA_XREF|XYZ_HOSPITAL|MESA_ADT|DOMAIN1_ADMITTI NG|20071018192243-0500||RSP^K23|11927533639853135lsa|P|2.5|
MSA|AE|8702553853547660391|
QAK|7814801327065385401696002755913|AE|
[DEBUG][MESA10501Test.java:135] Query Status: Application error
[DEBUG][MESA10501Test.java:136] ResponseACK Code: AE
[DEBUG][MESA10501Test.java:137] ResponseACK Desc: Original mode: Application
Error - Enhanced mode: Application acknowledgment: Error
[DEBUG][MESA10501Test.java:141] Sending App: MESA_XREF
[DEBUG][MESA10501Test.java:142] Sending Fac: XYZ_HOSPITAL
[DEBUG][MESA10501Test.java:143] Receiving App: MESA_ADT
[DEBUG][MESA10501Test.java:144] Receiving Fac: DOMAIN1_ADMITTING
[DEBUG][MESA10501Test.java:148] Control ID: 8702553853547660391
[DEBUG][MESA10501Test.java:156] Errors returned: seg-1 rpt-1
[DEBUG][MESA10501Test.java:162] Error location: QPD^1^3^1^4^
[DEBUG][MESA10501Test.java:163] Error code: 204
[DEBUG][MESA10501Test.java:164] Error severity: Warning
[DEBUG][MESA10501Test.java:179] Patients returned: 0
Re: All PIX consumer tests are failing [message #35439 is a reply to message #35404] Fri, 19 October 2007 10:15 Go to previous messageGo to next message
Morning Robert,
What we see here is a server destination issue. The messages you have
copied below are mesa test messages and should be directed to your mesa
server. You are currently sending the message to the IBM Dallas server
which has it's own configuration and message requirements.
If you desire to send messages to your MESA server you will need to
change the MLLP configuration (see TestConfiguration.java file in the
folder where you are running the MESA10501Test example).
Sondra
> Results follow:
> RCP|I
> on port 3600
> RCP|I
> port 3600 was:
Re: All PIX consumer tests are failing [message #35474 is a reply to message #35404] Fri, 19 October 2007 08:56 Go to previous messageGo to next message
I am using branch: OHF_IHE_2007_BRANCH
"Robert Alkire" <ralkire@ndorange.com> wrote in message
news:ff8thk$54d$1@build.eclipse.org...
> in this ERR||QPD^1^3^1^4|204|W|
> Results follow:
> RCP|I
> lsaix26.dfw.ibm.com on port 3600
> RCP|I
> port 3600 was:
> Application Error - Enhanced mode: Application acknowledgment: Error
Re: All PIX consumer tests are failing [message #35545 is a reply to message #35439] Fri, 19 October 2007 11:00 Go to previous messageGo to next message
------=_NextPart_000_0009_01C81236.E1EED9C0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Thanks for your quick response.
I still have the same result however:
[INFO ][MLLPDestination.java:314] *** Response from localhost on port =
3600 was:
MSH|^~\&|MESA_XREF|XYZ_HOSPITAL|MESA_ADT|DOMAIN1_ADMITTI NG|||RSP^K23|MESA=
4718c5e9|P|2.5||||||||
MSA|AE|6642318773569983059||||
ERR||QPD^1^3^1^4|204|W||
QAK|7636703179575166145616347872164|AE
QPD|Q23^Get Corresponding =
IDs|7636703179575166145616347872164|PIX10501^^^HIMSS2005& ;1.3.6.1.4.1.2136=
7.2005.1.1&ISO^PI|||||
"Sondra Renly" <srrenly@us.ibm.com> wrote in message =
news:4718BC03.5050702@us.ibm.com...
> Morning Robert,
>=20
> What we see here is a server destination issue. The messages you have=20
> copied below are mesa test messages and should be directed to your =
mesa=20
> server. You are currently sending the message to the IBM Dallas server =
>=20
>=20
> If you desire to send messages to your MESA server you will need to=20
> change the MLLP configuration (see TestConfiguration.java file in the=20
>=20
> Sondra
>=20
>=20
>> I am new to OHF so may not have things configured correctly. I =
turned of=20
>> auditing by setting AtnaAgent.java's doAudit flag to false, or I =
would not=20
>>=20
>> The message is being sent ok, howerver all responses from all test =
result in=20
>>=20
>>=20
>>=20
>>=20
>> Results follow:
>>=20
>> =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
>>=20
>>=20
>>=20
>>=20
MSH|^~\&|MESA_ADT|DOMAIN1_ADMITTING|MESA_XREF|XYZ_HOSPIT AL|20071018191131=
-0500||QBP^Q23^QBP_Q21|8702553853547660391|P|2.5
>>=20
>> QPD|Q23^Get Corresponding=20
IDs|7814801327065385401696002755913|PIX10501^^^HIMSS2005& ;1.3.6.1.4.1.2136=
7.2005.1.1&ISO^PI
>>=20
>> RCP|I
>>=20
>>=20
>> [INFO ][MLLPDestination.java:308] *** Sending message to =
lsaix26.dfw.ibm.com=20
>> on port 3600
>>=20
>>=20
7.2005.1.1&ISO^PI
>>=20
>> RCP|I
>>=20
>>=20
>> [INFO ][MLLPDestination.java:314] *** Response from =
lsaix26.dfw.ibm.com on=20
>> port 3600 was:
>>=20
MSH|^~\&|MESA_XREF|XYZ_HOSPITAL|MESA_ADT|DOMAIN1_ADMITTI NG|20071018192243=
>>=20
>>=20
>>=20
>>=20
7.2005.1.1&ISO^PI
>>=20
>>=20
>>=20
>>=20
>> [DEBUG][MESA10501Test.java:137] ResponseACK Desc: Original mode: =
Application=20
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.6000.16414" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Thanks for your quick =
response.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I still have the same result =
however:</FONT></DIV>
<DIV>
<P align=3Dleft><FONT face=3DArial size=3D2>[INFO =
][MLLPDestination.java:314] ***=20
Response from <FONT color=3D#ff0000>localhost</FONT> on port 3600 =
was:</FONT></P>
<P align=3Dleft><FONT face=3DArial=20
size=3D2> MSH|^~\&amp;|MESA_XREF|XYZ_HOSPITAL|MESA_ADT|DOMAIN1_ADM ITTING||=
|RSP^K23|MESA4718c5e9|P|2.5||||||||</FONT></P>
<P align=3Dleft><FONT face=3DArial =
size=3D2>MSA|AE|6642318773569983059||||</FONT></P>
size=3D2>ERR||QPD^1^3^1^4|204|W||</FONT></P>
size=3D2>QAK|7636703179575166145616347872164|AE</FONT></P >
<P><FONT face=3DArial size=3D2>QPD|Q23^Get Corresponding=20
IDs|7636703179575166145616347872164|PIX10501^^^HIMSS2005& ;amp;1.3.6.1.4.1.=
21367.2005.1.1&amp;ISO^PI|||||</FONT></P>
<P><FONT face=3DArial size=3D2></FONT>&nbsp;</P>
<P><FONT face=3DArial size=3D2></FONT>&nbsp;</P></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>"Sondra Renly" &lt;</FONT><A=20
href=3D"mailto:srrenly@us.ibm.com"><FONT face=3DArial=20
size=3D2>srrenly@us.ibm.com</FONT></A><FONT face=3DArial size=3D2>&gt; =
wrote in=20
message </FONT><A href=3D"news:4718BC03.5050702@us.ibm.com"><FONT =
face=3DArial=20
size=3D2>news:4718BC03.5050702@us.ibm.com</FONT></A><FONT face=3DArial=20
size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>&gt; Morning =
Robert,<BR>&gt;=20
<BR>&gt; What we see here is a server destination issue. The messages =
you have=20
<BR>&gt; copied below are mesa test messages and should be directed to =
your mesa=20
<BR>&gt; server. You are currently sending the message to the IBM Dallas =
server=20
<BR>&gt; which has it's own configuration and message =
requirements.<BR>&gt;=20
<BR>&gt;&nbsp; *** Sending message to lsaix26.dfw.ibm.com<BR>&gt; =
<BR>&gt; If=20
you desire to send messages to your MESA server you will need to =
<BR>&gt; change=20
the MLLP configuration (see TestConfiguration.java file in the <BR>&gt; =
folder=20
where you are running the MESA10501Test example).<BR>&gt; <BR>&gt;=20
Sondra<BR>&gt; <BR>&gt; <BR>&gt; Robert Alkire wrote:<BR>&gt;&gt; I am =
new to=20
OHF so may not have things configured correctly.&nbsp; I turned of =
<BR>&gt;&gt;=20
auditing by setting AtnaAgent.java's&nbsp; doAudit flag to false, or I =
would not=20
<BR>&gt;&gt; have gotten these results.<BR>&gt;&gt; <BR>&gt;&gt; The =
message is=20
being sent ok, howerver all responses from all test result in =
<BR>&gt;&gt; this=20
ERR||QPD^1^3^1^4|204|W|<BR>&gt;&gt; <BR>&gt;&gt; Please help me get past =
this=20
problem, thanks....<BR>&gt;&gt; <BR>&gt;&gt; <BR>&gt;&gt; <BR>&gt;&gt; =
Results=20
follow:<BR>&gt;&gt; <BR>&gt;&gt; =
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D <BR>&gt;&gt; =
<BR>&gt;&gt;=20
<BR>&gt;&gt; <BR>&gt;&gt; [DEBUG][MESA10501Test.java:103] =
10501a<BR>&gt;&gt;=20
<BR>&gt;&gt;=20
MSH|^~\&amp;|MESA_ADT|DOMAIN1_ADMITTING|MESA_XREF|XYZ_HO SPITAL|2007101819=
1131-0500||QBP^Q23^QBP_Q21|8702553853547660391|P|2.5<BR>&gt;&gt;=20
<BR>&gt;&gt; QPD|Q23^Get Corresponding <BR>&gt;&gt;=20
IDs|7814801327065385401696002755913|PIX10501^^^HIMSS2005& ;amp;1.3.6.1.4.1.=
21367.2005.1.1&amp;ISO^PI<BR>&gt;&gt;=20
<BR>&gt;&gt; RCP|I<BR>&gt;&gt; <BR>&gt;&gt; <BR>&gt;&gt; [INFO=20
][MLLPDestination.java:308] *** Sending message to lsaix26.dfw.ibm.com=20
<BR>&gt;&gt; on port 3600<BR>&gt;&gt; <BR>&gt;&gt;=20
][MLLPDestination.java:314] *** Response from lsaix26.dfw.ibm.com on=20
<BR>&gt;&gt; port 3600 was:<BR>&gt;&gt; <BR>&gt;&gt;=20
MSH|^~\&amp;|MESA_XREF|XYZ_HOSPITAL|MESA_ADT|DOMAIN1_ADM ITTING|2007101819=
2243-0500||RSP^K23|11927533639853135lsa|P|2.5|<BR>&gt;&gt;=20
<BR>&gt;&gt; MSA|AE|8702553853547660391|<BR>&gt;&gt; <BR>&gt;&gt;=20
ERR||QPD^1^3^1^4|204|W|<BR>&gt;&gt; <BR>&gt;&gt;=20
QAK|7814801327065385401696002755913|AE|<BR>&gt;&gt; <BR>&gt;&gt; =
QPD|Q23^Get=20
<BR>&gt;&gt; <BR>&gt;&gt; [DEBUG][MESA10501Test.java:135] Query Status:=20
Application error<BR>&gt;&gt; <BR>&gt;&gt; =
[DEBUG][MESA10501Test.java:136]=20
ResponseACK Code: AE<BR>&gt;&gt; <BR>&gt;&gt; =
[DEBUG][MESA10501Test.java:137]=20
ResponseACK Desc: Original mode: Application <BR>&gt;&gt; Error - =
Enhanced mode:=20
Application acknowledgment: Error<BR>&gt;&gt; <BR>&gt;&gt;=20
[DEBUG][MESA10501Test.java:141] Sending App: MESA_XREF<BR>&gt;&gt; =
<BR>&gt;&gt;=20
[DEBUG][MESA10501Test.java:142] Sending Fac: XYZ_HOSPITAL<BR>&gt;&gt;=20
<BR>&gt;&gt; [DEBUG][MESA10501Test.java:143] Receiving App: =
MESA_ADT<BR>&gt;&gt;=20
<BR>&gt;&gt; [DEBUG][MESA10501Test.java:144] Receiving Fac:=20
DOMAIN1_ADMITTING<BR>&gt;&gt; <BR>&gt;&gt; =
[DEBUG][MESA10501Test.java:148]=20
Control ID: 8702553853547660391<BR>&gt;&gt; <BR>&gt;&gt;=20
[DEBUG][MESA10501Test.java:156] Errors returned: seg-1 rpt-1<BR>&gt;&gt; =
<BR>&gt;&gt; [DEBUG][MESA10501Test.java:162] Error location:=20
QPD^1^3^1^4^<BR>&gt;&gt; <BR>&gt;&gt; [DEBUG][MESA10501Test.java:163] =
Error=20
code: 204<BR>&gt;&gt; <BR>&gt;&gt; [DEBUG][MESA10501Test.java:164] Error =
severity: Warning<BR>&gt;&gt; <BR>&gt;&gt; =
[DEBUG][MESA10501Test.java:179]=20
Patients returned: 0<BR>&gt;&gt; <BR>&gt;&gt;</FONT></BODY></HTML>
------=_NextPart_000_0009_01C81236.E1EED9C0--
Re: All PIX consumer tests are failing [message #35579 is a reply to message #35439] Fri, 19 October 2007 11:05 Go to previous messageGo to next message
I figured it out....
I had to prime it by running the script
perl scripts/xref_cons_pix.pl 10501 4
and then hitting enter till I see the message following:
PID: PIX10501^^^HIMSS2005&1.3.6.1.4.1.21367.2005.1.1&ISO^ PI
Your XRef Consumer is expected to send a query with this identifier
to the MESA Cross Reference Manager.
Then run the test.
Thanks for your help again...
> Morning Robert,
> If you desire to send messages to your MESA server you will need to change
> the MLLP configuration (see TestConfiguration.java file in the folder
> Sondra
>> not have gotten these results.
>> Results follow:
>> RCP|I
>> RCP|I
>> on port 3600 was:
Re: All PIX consumer tests are failing [message #35613 is a reply to message #35579] Fri, 19 October 2007 11:33 Go to previous messageGo to next message
Robert,
Glad to hear it is working for you.
I will add for the group that each mesa test folder in the pix/pdq
plugins has a file called MESA2007.txt that does a step-by-step walk
through of the script and includes notes about "enter" key presses, etc.
Sondra
> Then run the test.
Re: All PIX consumer tests are failing [message #35647 is a reply to message #35439] Fri, 19 October 2007 12:11 Go to previous messageGo to next message
Well 10501 worked. 10502 and 10503 fail.
Here is 10503, the script sets it up.
C:\mesa\mesa_tests\iti\actors\xref_consumer>perl scripts/xref_cons_pix.pl
10503 4
Clearing XRef Mgr database
Exiting...
MESA XRef Mgr Port HL7 = 3600
MESA XRef Mgr Host HL7 = localhost
This is ITI test 10503.
It is designed to test the PIX Integretation Profile.
The query case is #4.
References:
ITI TF-2: 3.9.4.2.2
Hit <ENTER> when ready (q to quit) -->
mesa::delete_directory about to delete 10503/102/test
mesa::delete_directory about to delete 10503/102/mesa
mesa::create_directory about to create 10503/102/test
mesa::create_directory about to create 10503/102/mesa
c:\mesa/bin/hl7_get_value -d ihe-iti -f
.../../msgs/qbp/10503/10503.102.q23.hl7 QPD 3 0
IHE Transaction 9: ABC10503^^^XXXX
MESA Patient ID Consumer will send QBP message to MESA XRef Mgr.
The event type is: Q23-QUERY
host: localhost, port 3600
PID: ABC10503^^^XXXX
[INFO ][MLLPDestination.java:314] *** Response from localhost on port 3600
was:
MSH|^~\&|MESA_XREF|XYZ_HOSPITAL|MESA_ADT|DOMAIN1_ADMITTI NG|||RSP^K23|MESA4718d53a|P|2.5||||||||
MSA|AE|6614378968605693472||||
QAK|2805985778643333212435535902908|AE
IDs|2805985778643333212435535902908|ABC10503^^^XXXX|||||
Tells me that XXXX was not found...
Any ideas why this is occuring?
> Morning Robert,
> Sondra
>> Results follow:
>> RCP|I
>> RCP|I
>> on port 3600 was:
Re: All PIX consumer tests are failing [message #35680 is a reply to message #35647] Fri, 19 October 2007 13:03 Go to previous messageGo to next message
Robert,
Please include the initial message as well as the response in your
correspondence. I can't tell much from this response.
Sondra
> 10503 4
> Exiting...
> References:
> ITI TF-2: 3.9.4.2.2
> was:
>> Morning Robert,
>> Sondra
>>> Results follow:
>>> RCP|I
>>> RCP|I
>>> on port 3600 was:
Re: All PIX consumer tests are failing [message #35748 is a reply to message #35680] Fri, 19 October 2007 13:38 Go to previous messageGo to next message
SETUP 10502:
10502 4
Exiting...
This is ITI test 10502.
The query case is #3.
References:
ITI TF-2: 3.9.4.2.2
.../../msgs/adt/10502/10502.102.a04.hl7 PID 3 0
.../../msgs/adt/10502/10502.102.a04.hl7 PID 5 0
Patient Name: BETA^BETTY
Patient ID: PIX10502^^^HIMSS2005&1.3.6.1.4.1.21367.2005.1.1&ISO^ PI
.../../msgs/adt/10502/10502.104.a04.hl7 PID 3 0
.../../msgs/adt/10502/10502.104.a04.hl7 PID 5 0
Patient Name: CROSS^KEN
Patient ID: XYZ10502^^^HIMSS2005&1.3.6.1.4.1.21367.2005.1.1&ISO^ PI
IHE Transaction 8: PIX10502^^^HIMSS2005&1.3.6.1.4.1.21367.2005.1.1&ISO^ PI
BETA^BETTY
MESA Patient ID Source will send ADT message to the MESA XRef Mgr.
The event type is: A04-REGISTER
c:\mesa/bin/send_hl7 -d ihe-iti -l 4 -c localhost 3600
IHE Transaction 8: XYZ10502^^^HIMSS2005&1.3.6.1.4.1.21367.2005.1.1&ISO^ PI
CROSS^KEN
Name: CROSS^KEN, PID: XYZ10502^^^HIMSS2005&1.3.6.1.4.1.21367.2005.1.1&ISO^ PI
mesa::delete_directory about to delete 10502/106/test
mesa::delete_directory about to delete 10502/106/mesa
mesa::create_directory about to create 10502/106/test
mesa::create_directory about to create 10502/106/mesa
.../../msgs/qbp/10502/10502.106.q23.hl7 QPD 3 0
IHE Transaction 9: ABC10502^^^HIMSS2005&1.3.6.1.4.1.21367.2005.1.1&ISO
PID: ABC10502^^^HIMSS2005&1.3.6.1.4.1.21367.2005.1.1&ISO
[DEBUG][MESA10502Test.java:83] 10501a
MSH|^~\&|MESA_ADT|DOMAIN1_ADMITTING|MESA_XREF|XYZ_HOSPIT AL|20071019123615-0500||QBP^Q23^QBP_Q21|8082242564334923244| P|2.5
IDs|3654648219208846724720326266258|ABC10502^^^HIMSS2005& ;1.3.6.1.4.1.21367.2005.1.1&ISO^PI
RCP|I
[INFO ][MLLPDestination.java:308] *** Sending message to localhost on port
3600
RCP|I
was:
MSH|^~\&|MESA_XREF|XYZ_HOSPITAL|MESA_ADT|DOMAIN1_ADMITTI NG|||RSP^K23|MESA4718eb0f|P|2.5||||||||
MSA|AE|8082242564334923244||||
ERR||QPD^1^3^1^1|204|W||
QAK|3654648219208846724720326266258|AE
IDs|3654648219208846724720326266258|ABC10502^^^HIMSS2005& ;1.3.6.1.4.1.21367.2005.1.1&ISO^PI|||||
[DEBUG][MESA10502Test.java:115] Query Status: Application error
[DEBUG][MESA10502Test.java:116] ResponseACK Code: AE
[DEBUG][MESA10502Test.java:117] ResponseACK Desc: Original mode: Application
[DEBUG][MESA10502Test.java:121] Sending App: MESA_XREF
[DEBUG][MESA10502Test.java:122] Sending Fac: XYZ_HOSPITAL
[DEBUG][MESA10502Test.java:123] Receiving App: MESA_ADT
[DEBUG][MESA10502Test.java:124] Receiving Fac: DOMAIN1_ADMITTING
[DEBUG][MESA10502Test.java:128] Control ID: 8082242564334923244
[DEBUG][MESA10502Test.java:136] Errors returned: seg-1 rpt-1
[DEBUG][MESA10502Test.java:142] Error location: QPD^1^3^1^1^
[DEBUG][MESA10502Test.java:143] Error code: 204
[DEBUG][MESA10502Test.java:144] Error severity: Warning
[DEBUG][MESA10502Test.java:159] Patients returned: 0
Setup 10503
10503 4
Exiting...
References:
ITI TF-2: 3.9.4.2.2
Eishay comment: output file is
C:\workspace\org.eclipse.ohf.ihe.pix.consumer\resources\log\ pixquery.log
with append attribute = true
[DEBUG][MESA10503Test.java:83] 10503
MSH|^~\&|MESA_ADT|DOMAIN1_ADMITTING|MESA_XREF|XYZ_HOSPIT AL|20071019123829-0500||QBP^Q23^QBP_Q21|1320358823142504346| P|2.5
IDs|8150221623533844298028227989881|ABC10503^^^XXXX
RCP|I
3600
RCP|I
was:
MSH|^~\&|MESA_XREF|XYZ_HOSPITAL|MESA_ADT|DOMAIN1_ADMITTI NG|||RSP^K23|MESA4718eb95|P|2.5||||||||
MSA|AE|1320358823142504346||||
QAK|8150221623533844298028227989881|AE
IDs|8150221623533844298028227989881|ABC10503^^^XXXX|||||
[DEBUG][MESA10503Test.java:109] Query Status: Application error
[DEBUG][MESA10503Test.java:110] ResponseACK Code: AE
[DEBUG][MESA10503Test.java:111] ResponseACK Desc: Original mode: Application
[DEBUG][MESA10503Test.java:115] Sending App: MESA_XREF
[DEBUG][MESA10503Test.java:116] Sending Fac: XYZ_HOSPITAL
[DEBUG][MESA10503Test.java:117] Receiving App: MESA_ADT
[DEBUG][MESA10503Test.java:118] Receiving Fac: DOMAIN1_ADMITTING
[DEBUG][MESA10503Test.java:122] Control ID: 1320358823142504346
[DEBUG][MESA10503Test.java:130] Errors returned: seg-1 rpt-1
[DEBUG][MESA10503Test.java:136] Error location: QPD^1^3^1^4^
[DEBUG][MESA10503Test.java:137] Error code: 204
[DEBUG][MESA10503Test.java:138] Error severity: Warning
[DEBUG][MESA10503Test.java:153] Patients returned: 0
Re: All PIX consumer tests are failing [message #35782 is a reply to message #35748] Mon, 22 October 2007 13:03 Go to previous messageGo to next message
Hi Robert,
Sorry for the frustration, MESA testing does take some work. We have
been able to successfully run the OHF junits for tests 10501, 10502,
10503 through the 2008 MESA. Still working through the other tests, hope
to get more done today.
One reference I want to provide for everyone doing MESA work is that
MESA does include the sample it wants to see. For test 10502 there is a
file in:
/mesa_tests/iti/msgs/qbp/10502/10502.106.q23 (hl7 or txt files)
Also - if you have questions about the underlying MESA system (such as
DB questions), please do direct those to Steve Moore through the MESA
bug tracking system (flyspray).
I hope this helps.
Sondra
> SETUP 10502:
> 10502 4
> Exiting...
> References:
> ITI TF-2: 3.9.4.2.2
> BETA^BETTY
> CROSS^KEN
> RCP|I
> 3600
> RCP|I
> was:
> Setup 10503
> 10503 4
> Exiting...
> References:
> ITI TF-2: 3.9.4.2.2
> RCP|I
> 3600
> RCP|I
> was:
Re: All PIX consumer tests are failing [message #35991 is a reply to message #35782] Thu, 25 October 2007 16:27 Go to previous message
Turns out the patient wasn't being put in my DB, thanks for all the help.
news:471CD7FC.8030108@us.ibm.com...
> Hi Robert,
> Sorry for the frustration, MESA testing does take some work. We have been
> able to successfully run the OHF junits for tests 10501, 10502, 10503
> through the 2008 MESA. Still working through the other tests, hope to get
> more done today.
> One reference I want to provide for everyone doing MESA work is that MESA
> does include the sample it wants to see. For test 10502 there is a file
> in:
> Also - if you have questions about the underlying MESA system (such as DB
> questions), please do direct those to Steve Moore through the MESA bug
> I hope this helps.
> Sondra
>> SETUP 10502:
>> 10502 4
>> Exiting...
>> References:
>> ITI TF-2: 3.9.4.2.2
>> BETA^BETTY
>> CROSS^KEN
>> RCP|I
>> port 3600
>> RCP|I
>> 3600 was:
>> Setup 10503
>> 10503 4
>> Exiting...
>> References:
>> ITI TF-2: 3.9.4.2.2
>> RCP|I
>> port 3600
>> RCP|I
>> 3600 was:
Re: All PIX consumer tests are failing [message #582358 is a reply to message #35404] Fri, 19 October 2007 10:15 Go to previous message
Morning Robert,
Sondra
> Results follow:
> RCP|I
> on port 3600
> RCP|I
> port 3600 was:
Re: All PIX consumer tests are failing [message #582377 is a reply to message #35404] Fri, 19 October 2007 08:56 Go to previous message
> Results follow:
> RCP|I
> RCP|I
> port 3600 was:
Re: All PIX consumer tests are failing [message #582415 is a reply to message #35439] Fri, 19 October 2007 11:00 Go to previous message
3600 was:
> Morning Robert,
>=20
mesa=20
>=20
>=20
>=20
> Sondra
>=20
>=20
turned of=20
would not=20
>>=20
result in=20
>>=20
>>=20
>>=20
>>=20
>> Results follow:
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
7.2005.1.1&ISO^PI
>>=20
>> RCP|I
>>=20
>>=20
>> on port 3600
>>=20
>>=20
7.2005.1.1&ISO^PI
>>=20
>> RCP|I
>>=20
>>=20
>> port 3600 was:
>>=20
>>=20
>>=20
>>=20
>>=20
7.2005.1.1&ISO^PI
>>=20
>>=20
>>=20
>>=20
Application=20
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
>>=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV>
was:</FONT></P>
wrote in=20
face=3DArial=20
Robert,<BR>&gt;=20
you have=20
your mesa=20
server=20
<BR>&gt; If=20
<BR>&gt; change=20
folder=20
new to=20
<BR>&gt;&gt;=20
would not=20
message is=20
this=20
Results=20
<BR>&gt;&gt;=20
<BR>&gt;&gt;=20
QPD|Q23^Get=20
Enhanced mode:=20
<BR>&gt;&gt;=20
Error=20
Re: All PIX consumer tests are failing [message #582455 is a reply to message #35439] Fri, 19 October 2007 11:05 Go to previous message
Then run the test.
> Morning Robert,
> Sondra
>> Results follow:
>> RCP|I
>> RCP|I
>> on port 3600 was:
Re: All PIX consumer tests are failing [message #582464 is a reply to message #35579] Fri, 19 October 2007 11:33 Go to previous message
Robert,
Sondra
> Then run the test.
Re: All PIX consumer tests are failing [message #582489 is a reply to message #35439] Fri, 19 October 2007 12:11 Go to previous message
10503 4
Exiting...
References:
ITI TF-2: 3.9.4.2.2
was:
> Morning Robert,
> Sondra
>> Results follow:
>> RCP|I
>> RCP|I
>> on port 3600 was:
Re: All PIX consumer tests are failing [message #582502 is a reply to message #35647] Fri, 19 October 2007 13:03 Go to previous message
Robert,
Sondra
> 10503 4
> Exiting...
> References:
> ITI TF-2: 3.9.4.2.2
> was:
>> Morning Robert,
>> Sondra
>>> Results follow:
>>> RCP|I
>>> RCP|I
>>> on port 3600 was:
Re: All PIX consumer tests are failing [message #582533 is a reply to message #35680] Fri, 19 October 2007 13:38 Go to previous message
SETUP 10502:
10502 4
Exiting...
References:
ITI TF-2: 3.9.4.2.2
BETA^BETTY
CROSS^KEN
RCP|I
3600
RCP|I
was:
Setup 10503
10503 4
Exiting...
References:
ITI TF-2: 3.9.4.2.2
RCP|I
3600
RCP|I
was:
Re: All PIX consumer tests are failing [message #582549 is a reply to message #35748] Mon, 22 October 2007 13:03 Go to previous message
Hi Robert,
file in:
I hope this helps.
Sondra
> SETUP 10502:
> 10502 4
> Exiting...
> References:
> ITI TF-2: 3.9.4.2.2
> BETA^BETTY
> CROSS^KEN
> RCP|I
> 3600
> RCP|I
> was:
> Setup 10503
> 10503 4
> Exiting...
> References:
> ITI TF-2: 3.9.4.2.2
> RCP|I
> 3600
> RCP|I
> was:
Re: All PIX consumer tests are failing [message #582665 is a reply to message #35782] Thu, 25 October 2007 16:27 Go to previous message
> Hi Robert,
> more done today.
> in:
> I hope this helps.
> Sondra
>> SETUP 10502:
>> 10502 4
>> Exiting...
>> References:
>> ITI TF-2: 3.9.4.2.2
>> BETA^BETTY
>> CROSS^KEN
>> RCP|I
>> port 3600
>> RCP|I
>> 3600 was:
>> Setup 10503
>> 10503 4
>> Exiting...
>> References:
>> ITI TF-2: 3.9.4.2.2
>> RCP|I
>> port 3600
>> RCP|I
>> 3600 was:
Previous Topic:POJO error from initiating user not set
Next Topic:POJO error from initiating user not set
Current Time: Wed Jul 23 12:06:40 EDT 2025
Powered by FUDForum. Page generated in 1.57242 seconds
