| Building Hello world - builded even when problems [message #33894] |
Mon, 14 March 2005 08:07  |
I have simple Hello World java application and Ant makefile that packages it
into jar. file. The java file contains intentional syntactic bug. When I
select main menu, Project, Build Project, the Console window says "BULD
SUCCESSFUL" (In fact the build process generates .class file, so Ant just
includes it into jar). The Problems windows contains list of bugs.
How can I stop Eclipse from creating .class file from buggy .java file when
the file cannot be compiled??
BTW, why Eclipse doesn't automatically open/put forward the Problems window?
How can I check if the build was successful without investigating?
thanks, Jan
PS: I have Eclipse 3.1M5a. I am new to Eclipse and Java, comming from
C++/VS.NET IDE world.
| Re: Building Hello world - builded even when problems [message #35382 is a reply to message #33894] |
Wed, 16 March 2005 04:29   |
is this question unclear? Let me say it in another words. When .java file
contains bugs, it is still compiled into .class file. How java can compile
something uncompilable?
Jan
"Jan Bares" <herkule9s@yahoo.com> wrote in message
news:d142aa$cvh$1@www.eclipse.org...
it
when
window?
> thanks, Jan
| Re: Building Hello world - builded even when problems [message #35899 is a reply to message #35382] |
Wed, 16 March 2005 14:25   |
Originally posted by: jaredburns.no.spam.acm.org
I'm not a compiler expert, but I *think* that if you have a compilation
error in a method, the compiler will just create as many correct
bytecodes as it can and then it inserts an exception throw.
This allows you to still execute code that has compilation errors if
you're so inclined. If you're running in Debug mode, the debugger will
end up suspending at the compilation error when the exception is thrown.
If you're VM supports hot code replace, you can then fix the error on
the fly.
Personally, I associate this mindset (developing code in the debugger)
as very "Smalltalky".
- Jared
Jan Bares wrote:
> Jan
>>Hi,
> it
> when
> window?
>>thanks, Jan
| Re: Building Hello world - builded even when problems [message #36459 is a reply to message #35899] |
Thu, 17 March 2005 02:57  |
Hi Jared, tahnks for your answer,
your reasoning sounds logical, but what I can do to stop this behaviour? I
want to produce the .class only if the source compiles without errors. How
can I do that?
Jan
> the fly.
FUDForum. Page generated in 0.09274 seconds
