Home » Language IDEs » Java Development Tools (JDT) » PDE JUnit Plugin - is this the place to ask on that matter?
PDE JUnit Plugin - is this the place to ask on that matter? [message #26453] Fri, 16 May 2003 13:08 Go to next message
Originally posted by: junmar.web.de
Hi there,
I'm looking for information/support on the PDE JUnit Plugin. Is this the
place where I can address that?
cheers,
Martin
Re: PDE JUnit Plugin - is this the place to ask on that matter? [message #26545 is a reply to message #26453] Fri, 16 May 2003 13:20 Go to previous messageGo to next message
Originally posted by: adam_kiezun.ch.ibm.spam.protection.com
this is the right place
a.
PDE JUnit Plugin - "no test case found in..." [message #26706 is a reply to message #26453] Fri, 16 May 2003 14:31 Go to previous messageGo to next message
Here we go,
according to the "Contributing to Eclipse" draft ("030410.pdf") I set up my
own TestCase to run jdt-related tests using the JDE JUnit plugin (and
thereby understanding the principles behind the plugin/Eclipse). The test
case is quite simple: Plugin plugin = ResourcesPlugin.getPlugin();
assertNotNull(plugin);
I always get the following error:
junit.framework.AssertionFailedError: No tests found in
test.de.mju.eclipse.junitTestCoverage.internal.TestJDTTypeAd apterFactory
The reported type is the one defining the test case (and extending
junit.framework.TestCase). The problem seems to be due to the TestSuite
constructor, where the while-loop
<cut>
while (Test.class.isAssignableFrom(superClass)) { // line 73
</cut>
is never entered since the condition always evals to false.
This is what I dont understand: debugging tells me that the passed
(final) Class object indeed has the 2 relevant test case methods. I
couldn't find any obvios cause such as configuration (at least during
plugin-building everything is fine), so I guess there must be hidden ones.
Has anyone encountered the same problem?
setup: Eclipse 2.1, pde-version 2.1.5 (also tried 2.1.3 and 2.1.4), junit
3.8 (Eclipse-shipped; also tried 3.7)
cheers,
Martin
Re: PDE JUnit Plugin - "no test case found in..." [message #27065 is a reply to message #26706] Sat, 17 May 2003 07:13 Go to previous messageGo to next message
Originally posted by: erich_gamma.oti.com
The following test passes. Can you please try
this code. If it still fails please file a bug
report against JDT UI.
--erich
import junit.framework.TestCase;
import org.eclipse.core.resources.ResourcesPlugin;
import org.eclipse.core.runtime.Plugin;
public class FooTest extends TestCase {
public void testFoo() {
Martin Jung wrote:
> Here we go,
> <cut>
> </cut>
> cheers,
> Martin
Re: PDE JUnit Plugin - "no test case found in..." - Feedback [message #35375 is a reply to message #27065] Thu, 22 May 2003 10:47 Go to previous message
Originally posted by: dummy.dummy.de
after finding that your test example was failing as well I thought it
hardly can't be a bug and the problem must very likely reside here on my
side.
So, I set up the plugin ecplipse project from scratch (the development
environment). Good news: it works now. Bad news: Deleted the 'old'
workspace permanently, so I have no way to identify the detail reason
afterwards.
cheers,
Martin
> --erich
Previous Topic:Tomcat 4.x won't work with JDK 1.4
Next Topic:How to open single Java file
Current Time: Tue Sep 16 22:35:58 EDT 2025
Powered by FUDForum. Page generated in 0.04759 seconds
