Home » Archived » OHF » bridge retrieveDocumentByUrl design question
bridge retrieveDocumentByUrl design question [message #35266] Thu, 18 October 2007 13:07 Go to next message
I just upgraded from the 0.2 release in May to the cvs contents from
yesterday. I see some great changes, but there's one that I have a
question on. For the retrieveDocumentByUrl method, it now takes a
patientId as a parameter. Previously it had only the url, why do you add
a patient id as a parameter when you're trying to retrieve by a url? At
first I thought maybe there was a new parallel query to the registry to
retrieve the document's metadata that required the patientid, but from the
response I got when I tried it all the metadata is still blank just as it
used to be when you were retrieving the doc by url. So I don't see the
benefit of adding this patient id?
thanks,
Jesse
Re: bridge retrieveDocumentByUrl design question [message #35336 is a reply to message #35266] Thu, 18 October 2007 13:25 Go to previous messageGo to next message
Good question - this was a bug we had to fix from EU Connectathon last
year. On the ATNA Import Event audit message, the patientId for whom
you're doing the import needs to be noted. The monitors didn't catch
the problem in Chicago but asked us to fix it in Berlin. When we
reconciled our changes from Berlin earlier this month, it was added in CVS.
The API in the XDS Consumer (Consumer.retrieveDocument) was also
modified to accept a patient ID.
-Matt
Jesse Pangburn wrote:
> add a patient id as a parameter when you're trying to retrieve by a
> url? At first I thought maybe there was a new parallel query to the
> registry to retrieve the document's metadata that required the
> patientid, but from the response I got when I tried it all the metadata
> is still blank just as it used to be when you were retrieving the doc by
> url. So I don't see the benefit of adding this patient id?
> thanks,
> Jesse
Re: bridge retrieveDocumentByUrl design question [message #35370 is a reply to message #35336] Thu, 18 October 2007 15:15 Go to previous message
Hi Matt,
Thanks for the quick answer, good to know!
Jesse
> -Matt
>> Hi,
>> thanks,
>> Jesse
Re: bridge retrieveDocumentByUrl design question [message #582299 is a reply to message #35266] Thu, 18 October 2007 13:25 Go to previous message
-Matt
> thanks,
> Jesse
Re: bridge retrieveDocumentByUrl design question [message #582312 is a reply to message #35336] Thu, 18 October 2007 15:15 Go to previous message
Hi Matt,
Jesse
> -Matt
>> Hi,
>> thanks,
>> Jesse
Previous Topic:international multibyte characters?
Next Topic:All PIX consumer tests are failing
Current Time: Fri Jul 25 22:55:38 EDT 2025
Powered by FUDForum. Page generated in 0.26929 seconds
