Editor core plugin internal error: java.net.UnknownHostException [message #34465] |
Mon, 13 August 2007 21:38  |
I am running DTP 1.5 on Eclipse 3.3.
I defined a database connection profile.
A few times, I got the error below.
FYI, here is my JDBC connection URL:
jdbc:microsoft:sqlserver://localhost:1433;databaseName=Vaultus800
eclipse.buildId=I20070625-1500
java.version=1.5.0_11
Framework arguments: -vm C:\Java\jdk1.5.0_11\jre\bin\javaw.exe
Command-line arguments: -data C:\Documents and
Settings\cdoucette\Eclipse\new\workspace-trunk -os win32 -ws win32 -arch
x86 -vm C:\Java\jdk1.5.0_11\jre\bin\javaw.exe
Error
Mon Aug 13 16:40:47 EDT 2007
java.net.UnknownHostException: 1433;databaseName=Vaultus800
at java.net.InetAddress.getAllByName0(InetAddress.java:1133)
at java.net.InetAddress.getAllByName0(InetAddress.java:1098)
at java.net.InetAddress.getAllByName(InetAddress.java:1061)
at java.net.InetAddress.getByName(InetAddress.java:958)
at
org.eclipse.datatools.sqltools.core.ServerIdentifier.hashCod e(ServerIdentifier.java:136)
at java.util.Hashtable.get(Hashtable.java:336)
at
org.eclipse.datatools.sqltools.internal.core.ControlConnecti onManager.getControlConnections(ControlConnectionManager.jav a:383)
at
org.eclipse.datatools.sqltools.internal.core.ControlConnecti onManager.notifyChanged(ControlConnectionManager.java:439)
at
org.eclipse.datatools.connectivity.sqm.core.rte.RefreshManag er.referesh(RefreshManager.java:74)
at
org.eclipse.datatools.connectivity.sqm.core.rte.jdbc.JDBCPro cedure.refresh(JDBCProcedure.java:46)
at
org.eclipse.datatools.enablement.msft.sqlserver.profile.ui.l oaders.SQL2005RoutineLoader.loadRoutines(SQL2005RoutineLoade r.java:168)
at
org.eclipse.datatools.connectivity.sqm.core.rte.jdbc.JDBCSch ema.loadRoutines(JDBCSchema.java:191)
at
org.eclipse.datatools.connectivity.sqm.core.rte.jdbc.JDBCSch ema.getRoutines(JDBCSchema.java:152)
at
org.eclipse.datatools.sqltools.sql.util.ModelUtil.findProced uralObjectFromSchema(ModelUtil.java:586)
at
org.eclipse.datatools.sqltools.sql.util.ModelUtil.findProced uralObject(ModelUtil.java:530)
at
org.eclipse.datatools.sqltools.sql.util.ModelUtil.findProced uralObject(ModelUtil.java:496)
at
org.eclipse.datatools.sqltools.sql.util.ModelUtil.findProced uralObject(ModelUtil.java:485)
at
org.eclipse.datatools.sqltools.sql.util.ModelUtil.findProced uralObject(ModelUtil.java:113)
at
org.eclipse.datatools.sqltools.internal.core.AbstractControl Connection.createDBItem(AbstractControlConnection.java:351)
at
org.eclipse.datatools.sqltools.internal.core.AbstractControl Connection.getDBItem(AbstractControlConnection.java:320)
at
org.eclipse.datatools.sqltools.internal.core.AbstractControl Connection.getProcSource(AbstractControlConnection.java:286)
at
org.eclipse.datatools.sqltools.routineeditor.ProcEditorInput . <init>(ProcEditorInput.java:48)
at
org.eclipse.datatools.sqltools.routineeditor.ui.actions.Edit RoutineAction.run(EditRoutineAction.java:75)
at
org.eclipse.datatools.sqltools.routineeditor.ui.actions.Doub leClickActionProvider$1.run(DoubleClickActionProvider.java:5 9)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.jav a:220)
at
org.eclipse.ui.internal.navigator.CommonNavigatorManager$3.o pen(CommonNavigatorManager.java:181)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 3)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewe r.java:353)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
Re: Editor core plugin internal error: java.net.UnknownHostException [message #35327 is a reply to message #34465] |
Wed, 22 August 2007 12:00  |
I just reported this as Bug 200844
Chuck
"Chuck Doucette" <cdoucette@vaultus.com> wrote in message
news:f9r14n$sbi$1@build.eclipse.org...
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Editor core plugin internal error: java.net.UnknownHostException [message #587566 is a reply to message #34465] |
Chuck
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.03584 seconds
