Home » Eclipse Projects » DSDP - Target Management » RSE: Erreur when using Remote Systems view
RSE: Erreur when using Remote Systems view [message #35099] |
Tue, 19 May 2009 05:18  |
Here is my configuration:
- Windows XP PC running Eclipse 3.4.2 with plugin RSE (Remote System
Explorer End-User RunTime 3.0.3.v200902042310)
When I open the view "Remote Systems" (11:10 in the log file) I have some
informations displayed in the error log. After that, I close Eclipse and
restart (11:12 in the log file) and get other errors.
What's happen?
BR, Sylvain
Here is the log file:
!SESSION 2009-05-19 11:09:29.682
eclipse.buildId=M20090211-1700
java.version=1.5.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.rse.ui 1 0 2009-05-19 11:09:55.870
!MESSAGE Loading class org.eclipse.rse.ui.RSEUIPlugin
!ENTRY org.eclipse.osgi 2 0 2009-05-19 11:10:00.886
!MESSAGE While loading class
" org.eclipse.rse.ui.SystemPreferencesManager$ModelChangeListe ner ", thread
"Thread[Worker-1,5,main]" timed out waiting (5000ms) for thread
"Thread[main,6,main]" to finish starting bundle
" reference:file:plugins\org.eclipse.rse.ui_3.0.3.v20090204231 0.jar [242]".
To avoid deadlock, thread "Thread[Worker-1,5,main]" is proceeding but
" org.eclipse.rse.ui.SystemPreferencesManager$ModelChangeListe ner " may not
be fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle
" reference:file:plugins\org.eclipse.rse.ui_3.0.3.v20090204231 0.jar " by
thread "main".
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1144)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:263)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:370)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:446)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:387)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
org.eclipse.rse.ui.SystemPreferencesManager$1.run(SystemPref erencesManager.java:510)
Caused by:
org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 15 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.rse.ui 1 0 2009-05-19 11:10:01.167
!MESSAGE in SubSystemConfiguration.getSubSytems(conn, force) - returning
empty array
!ENTRY org.eclipse.rse.ui 1 0 2009-05-19 11:10:01.245
empty array
!SESSION 2009-05-19 11:12:45.605
!ENTRY org.eclipse.rse.ui 1 0 2009-05-19 11:12:49.512
!ENTRY org.eclipse.rse.ui 1 0 2009-05-19 11:12:50.574
empty array
!ENTRY org.eclipse.rse.ui 1 0 2009-05-19 11:12:50.934
empty array
Re: RSE: Erreur when using Remote Systems view [message #35456 is a reply to message #35099] |
Thu, 28 May 2009 14:42   |
Hello Sylvain,
the first problem is a known bug which only ever happens the first time
you open RSE in a new workspace. Searching bugzilla for comments with
the pattern
yields
https://bugs.eclipse.org/bugs/show_bug.cgi?id=246406
I'm very surprised about the other messages in your log. They look like
debug messages, but I've never seen them before.
The message is in SubSystemConfiguration.java line 878 -- I'm copying
DaveM for more insight. Could it be that you changed the configuration
of your Eclipse recently, adding or removing plugins? Or could it be
that the "Local" subsystem type is not installed for you? Please send
your configuration log (Help > About > Configuration details).
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Sylvain Tiberio wrote:
> some informations displayed in the error log. After that, I close
> Eclipse and restart (11:12 in the log file) and get other errors.
> What's happen?
> BR, Sylvain
> thread "Thread[Worker-1,5,main]" timed out waiting (5000ms) for thread
> [242]". To avoid deadlock, thread "Thread[Worker-1,5,main]" is
> proceeding but
> not be fully initialized.
> !STACK 0
> thread "main".
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Caused by:
> ... 15 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> empty array
> empty array
> empty array
> empty array
Re: RSE: Erreur when using Remote Systems view [message #35506 is a reply to message #35456] |
Fri, 29 May 2009 03:38   |
Hello Martin,
Thanks for your response.
As I am testing/trying eclipse, I have added and removed some pluggin...
Here is my configuration log (Help > About > Configuration details).
Sylvain
*** Date: vendredi 29 mai 2009 09:33:03 HEC
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
D:\Tiberio\Program
Files\eclipse\\plugins\org.eclipse.platform_3.3.101.v2009021 11700\splash.bmp
-launcher
D:\Tiberio\Program Files\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
D:\Tiberio\Program
Files\eclipse\plugins\org.eclipse.equinox.launcher.win32.win 32.x86_1.0.101.R34x_v20080731\eclipse_1115.dll
-startup
D:\Tiberio\Program
Files\eclipse\plugins\org.eclipse.equinox.launcher_1.0.101.R 34x_v20081125.jar
-framework
plugins\org.eclipse.osgi_3.4.3.R34x_v20081215-1030.jar
-vm
C:\Program Files\Java\jre1.5.0_04\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.home.location=file:/D:/Tiberio/Program Files/eclipse/
eclipse.launcher=D:\Tiberio\Program Files\eclipse\eclipse.exe
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=PlatformProfile
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1243582176012
eclipse.vm=C:\Program Files\Java\jre1.5.0_04\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx256m
-XX:MaxPermSize=256M
-Djava.class.path=D:\Tiberio\Program
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
http.nonProxyHosts=127.0.0.1|localhost
http.proxyHost=proxy.mycompany.com
http.proxyPort=8080
http.proxySet=true
https.nonProxyHosts=127.0.0.1|localhost
https.proxyHost=proxy.mycompany.com
https.proxyPort=8080
https.proxySet=true
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_04\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.5.0_04\lib\ext
java.home=C:\Program Files\Java\jre1.5.0_04
java.io.tmpdir=C:\DOCUME~1\tiberio\LOCALS~1\Temp\
java.library.path=D:\Tiberio\Program
Files\eclipse;.;C:\WINDOWS\system32;C:\WINDOWS;C:\ORANT\bin; C:\Program
Files\Oracle\jre\1.1.7\bin;C:\WINDOWS\system32;C:\WINDOWS;C: \WINDOWS\System32\Wbem;C:\Program
Files\QuickTime\QTSystem\;C:\Program Files\Utimaco\SafeGuard
Easy\;C:\Program Files\ActivIdentity\ActivClient\;C:\Program
Files\Rational\common
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_04-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_04-b05
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.NoOpLog
org.eclipse.equinox.launcher.splash.location=D:\Tiberio\Prog ram
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator\bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=fr
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.c ss,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3 c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,o rg.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=reference:file:org.eclipse.equinox.simpleconfigurator_1.0.0.v20080604.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=D:\Tiberio\Program
Files\eclipse\configuration\org.eclipse.osgi\bundles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/D:/Tiberio/Program
Files/eclipse/configuration/
osgi.framework=file:/d:/Tiberio/Program
Files/eclipse/plugins/org.eclipse.osgi_3.4.3.R34x_v20081215- 1030.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.4.3.R34x_v20081215-1030
osgi.install.area=file:/D:/Tiberio/Program Files/eclipse/
osgi.instance.area=file:/D:/Tiberio/Eclipse-workspace/
osgi.instance.area.default=file:/C:/Documents and
Settings/tiberio/workspace/
osgi.launcherIni=eclipse
osgi.launcherPath=.
osgi.logfile=D:\Tiberio\Eclipse-workspace\.metadata\.log
osgi.manifest.cache=D:\Tiberio\Program
Files\eclipse\configuration\org.eclipse.osgi\manifests
osgi.nl=fr_FR
osgi.os=win32
osgi.splashLocation=D:\Tiberio\Program
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=d:\Tiberio\Program Files\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.5.0_04\lib\rt.jar;C:\Program
Files\Java\jre1.5.0_04\lib\i18n.jar;C:\Program
Files\Java\jre1.5.0_04\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.5.0_04\lib\jsse.jar;C:\Program
Files\Java\jre1.5.0_04\lib\jce.jar;C:\Program
Files\Java\jre1.5.0_04\lib\charsets.jar;C:\Program
Files\Java\jre1.5.0_04\classes
sun.boot.library.path=C:\Program Files\Java\jre1.5.0_04\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386
i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=FR
user.dir=D:\Tiberio\Program Files\eclipse
user.home=C:\Documents and Settings\tiberio
user.language=fr
user.name=tiberio
user.timezone=Europe/Berlin
user.variant=
*** Features:
org.eclipse.cdt (5.0.2.200902130801) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.mylyn (5.0.2.200902130801) "Mylyn Plug-in"
org.eclipse.cvs (1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7) "Eclipse CVS
Client"
org.eclipse.help (1.0.2.R342_v20090122-7r7xEKaEJBZu5oGhP3u6nOmbM9VK) "Help
System Base"
org.eclipse.mylyn_feature (3.1.1.v20090411-0400-e3x) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.1.1.v20090411-0400-e3x) "Mylyn"
org.eclipse.mylyn.context_feature (3.1.1.v20090411-0400-e3x) "Mylyn"
org.eclipse.mylyn.ide_feature (3.1.1.v20090411-0400-e3x) "Mylyn"
org.eclipse.mylyn.team_feature (3.1.1.v20090411-0400-e3x) "Mylyn"
(3.4.2.R342_v20090122-9I96EiWElHi8lheoJKJIvhM3JfVsYbRrgVIWL) "Eclipse
Platform"
org.eclipse.rcp (3.4.200.R342_v20090122-989JESTEbig-SVaL8UJHcYBr4A63)
"Eclipse RCP"
org.eclipse.rse (3.0.3.v200902042310-7H37E8qfisI6diJKMbrhR-TV-a3) "Remote
System Explorer End-User Runtime"
org.eclipse.rse.core (3.0.3.v200902042310-7Z37HEB7sQSCRiULOVOE) "Remote
System Explorer Core"
org.eclipse.rse.dstore (3.0.3.v200902042310-7J378DUUEFGEpIz-AW8E) "RSE
DStore Services"
org.eclipse.rse.ftp (3.0.1.v200809171630-78479_kE77c7Q8b8T_F) "RSE FTP
Service"
org.eclipse.rse.local (2.1.1.v20080710-7_40AgI99m9d_O) "RSE Local Services"
org.eclipse.rse.remotecdt (2.1.1.v200809041200-4118s733I3J4F5C48) "Remote
System Explorer C/C++ Remote Debug Launcher"
org.eclipse.rse.ssh (2.1.1.v20080714-7830_kE77c7V8M) "RSE SSH Services"
org.eclipse.rse.telnet (2.1.1.v200809181500-6678AgI99m9W9X5J79) "RSE
Telnet Service"
org.eclipse.rse.terminals (0.1.3.v200902181600-2269sB9EP_M_W5B5B3822) "RSE
Terminals UI (Incubation)"
org.eclipse.rse.useractions (1.1.2.v200812041720-2138s733I573A5G73) "RSE
User Actions"
org.eclipse.tm.terminal (2.0.3.v200902181600-2-27w311_13292711) "Target
Management Terminal Widget"
*** Plug-in Registry:
com.ibm.icu (3.8.1.v20080530) "International Components for Unicode for
Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.37.v200803061811) "JSch" [Resolved]
javax.servlet (2.4.0.v200806031604) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle"
[Resolved]
org.apache.ant (1.7.0.v200803061910) "Apache Ant" [Resolved]
org.apache.commons.codec (1.3.0.v20080530-1600) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons
Httpclient" [Resolved]
org.apache.commons.lang (2.3.0.v200803061910) "Apache Jakarta Commons
Lang" [Resolved]
org.apache.commons.logging (1.0.4.v20080605-1930) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.net (1.4.1.v200803071935) "Apache Commons Net"
[Resolved]
org.apache.jasper (5.5.17.v200806031609) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis"
[Resolved]
org.apache.oro (2.0.8.v200803061811) "Apache Jakarta ORO" [Resolved]
org.eclipse.ant.core (3.2.0.v20080529) "Ant Build Tool Core" [Starting]
[Starting]
org.eclipse.cdt.core (5.0.2.200902130801) "C/C++ Development Tools Core"
[Active]
org.eclipse.cdt.core.win32 (5.0.0.200902130801) "C/C++ Development Tools
Core for Windows" [Resolved]
org.eclipse.cdt.debug.core (5.0.2.200902130801) "C/C++ Development Tools
Debug Model" [Starting]
org.eclipse.cdt.debug.mi.core (5.0.1.200902130801) "C/C++ Development
Tools GDB/MI CDI Debugger Core" [Starting]
org.eclipse.cdt.debug.mi.ui (5.0.1.200902130801) "C/C++ Development Tools
GDB/MI CDI Debugger UI" [Starting]
org.eclipse.cdt.debug.ui (5.0.1.200902130801) "C/C++ Development Tools
org.eclipse.cdt.doc.user (5.0.2.200902130801) "C/C++ Development User
Guide" [Starting]
org.eclipse.cdt.launch (5.0.2.200902130801) "C/C++ Development Tools
Launching Support" [Starting]
org.eclipse.cdt.make.core (5.0.2.200902130801) "C/C++ Standard make Build
Core" [Active]
org.eclipse.cdt.make.ui (5.0.1.200902130801) "C/C++ Standard make Build
UI" [Active]
org.eclipse.cdt.managedbuilder.core (5.0.2.200902130801) "CDT Build System
Core" [Active]
org.eclipse.cdt.managedbuilder.gnu.ui (5.0.0.200902130801) "GNU Managed
Build Definitions" [Starting]
org.eclipse.cdt.managedbuilder.ui (5.0.2.200902130801) "C/C++ Managed
Builder UI" [Starting]
org.eclipse.cdt.mylyn (1.0.0.200902130801) "Mylyn Plug-in" [Resolved]
org.eclipse.cdt.mylyn.ui (5.0.1.200902130801) "Mylyn CDT Integrator"
[Starting]
org.eclipse.cdt.ui (5.0.2.200902130801) "C/C++ Development Tools UI"
[Active]
org.eclipse.compare (3.4.1.r34x_20090121) "Compare Support" [Starting]
org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
org.eclipse.core.commands (3.4.0.I20080509-2000) "Commands" [Resolved]
org.eclipse.core.contenttype (3.3.0.v20080604-1400) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.databinding (1.1.1.M20080827-0800b) "JFace Data Binding"
[Active]
org.eclipse.core.databinding.beans (1.1.1.M20080827-0800a) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.4.1.r342_v20081203-0800) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.4.0.v20080603-2000) "File Buffers" [Active]
org.eclipse.core.filesystem (1.2.0.v20080604-1400) "Core File Systems"
[Active]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20080604-1400) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.4.1.R34x_v20081128) "Eclipse Jobs Mechanism"
[Active]
org.eclipse.core.net (1.1.0.I20080604) "Internet Connection Management"
[Active]
org.eclipse.core.net.win32.x86 (1.0.0.I20080521) "Proxy for Windows"
[Resolved]
org.eclipse.core.resources (3.4.2.R34x_v20090126) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.4.0.v20080604-1400) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32.x86 (3.4.0.v20071204) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.4.0.v20080512) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.0.v20071008) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.200.v20080610)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.100.v20080529-1300) "Core Variables"
[Active]
org.eclipse.cvs (1.0.200.R342_v20090206) "Eclipse CVS Client" [Starting]
org.eclipse.debug.core (3.4.1.v20090106_r342) "Debug Core" [Active]
org.eclipse.debug.ui (3.4.2.v20090110_r342) "Debug UI" [Starting]
org.eclipse.dstore.core (3.0.3.v200902101918) "RSE DStore Core" [Active]
org.eclipse.dstore.extra (2.1.0.v20080406) "RSE DStore Platform Support"
[Starting]
org.eclipse.ecf (2.0.0.v20080611-1715) "Eclipse Communication Framework
(ECF)" [Starting]
org.eclipse.ecf.filetransfer (2.0.0.v20080611-1715) "ECF Filetransfer API"
[Starting]
org.eclipse.ecf.identity (2.0.0.v20080611-1715) "ECF Identity API"
[Starting]
org.eclipse.ecf.provider.filetransfer (2.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.0.v20080611-1715) "Eclipse Communication
Framework (ECF)" [Resolved]
org.eclipse.epp.usagedata.gathering (1.0.1.R200809220400) "Usage Data
Gathering Plug-in" [Active]
org.eclipse.epp.usagedata.recording (1.0.1.R200809220400) "Usage Data
Recording Plug-in" [Active]
org.eclipse.epp.usagedata.ui (1.0.1.R200809220400) "Usage Data UI Plug-in"
[Starting]
org.eclipse.equinox.app (1.1.0.v20080421-2006) "Equinox Application
Container" [Active]
org.eclipse.equinox.common (3.4.0.v20080421-2006) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.frameworkadmin (1.0.2.R34x_v20081007) "Equinox
Framework Admin" [Active]
org.eclipse.equinox.frameworkadmin.equinox (1.0.4.v20080930) "Equinox
Framework Admin for Equinox" [Active]
org.eclipse.equinox.http.jetty (1.1.0.v20080425) "Jetty Http Service"
[Starting]
org.eclipse.equinox.http.registry (1.0.100.v20080427-0830) "Http Service
Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.100.v20080427-0830) "Http Services
Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.100.v20080427-0830) "Jasper Jsp
Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20080427-0830) "Jasper Jsp
Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.101.R34x_v20081125) "Equinox Launcher"
[Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.101.R34x_v20080731)
"Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.0.4.v20080930) "Equinox
Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.0.v20080514-1900) "Equinox
Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (1.0.4.v20081112-1019) "Equinox Provisioning
Core" [Active]
org.eclipse.equinox.p2.director (1.0.4.v20081112-1019) "Equinox
Provisioning Director" [Active]
org.eclipse.equinox.p2.director.app (1.0.1.R34x_v20080729) "Equinox
Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.0.2.v20080806-1619) "Equinox
Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.engine (1.0.4.v20080930) "Equinox Provisioning
Engine" [Active]
org.eclipse.equinox.p2.exemplarysetup (1.0.0.v20080427-2136) "Equinox
Provisioning Exemplary Setup" [Active]
org.eclipse.equinox.p2.extensionlocation (1.0.4.v20081027-2115) "Extension
Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.1.R34x_v20080818)
"Provisioning Garbage Collector" [Active]
org.eclipse.equinox.p2.jarprocessor (1.0.0.v20080514-1900) "Equinox
Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (1.0.0.v20080514-1900) "Equinox
Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.generator (1.0.4.v20081217) "Equinox
Provisioning Metadata Generator" [Starting]
org.eclipse.equinox.p2.metadata.repository (1.0.0.v20080604) "Equinox
Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.reconciler.dropins (1.0.4.v20081027-2115) "Dropin
Reconciler Plug-in" [Active]
org.eclipse.equinox.p2.touchpoint.eclipse (1.0.2.v20081119-1055) "Equinox
Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.0.0.v20080505-1850) "Equinox
Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.ui (1.0.4.R34x_v20090123) "Equinox Provisioning UI
Support" [Active]
org.eclipse.equinox.p2.ui.sdk (1.0.1.R34x_v20081029) "Equinox Provisioning
Platform Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.0.0.v20080427-2136) "Equinox
Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.1.R34x_v20080808-1156) "Update site
repository adapter bundle (Incubation)" [Starting]
org.eclipse.equinox.preferences (3.2.201.R34x_v20080709) "Eclipse
Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.4.0.v20080516-0950) "Extension Registry
Support" [Active]
org.eclipse.equinox.security (1.0.1.R34x_v20080721) "Equinox Java
Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.0.0.v20080603-1810) "Equinox Security
Default UI" [Starting]
org.eclipse.equinox.security.win32.x86 (1.0.0.v20080529-1600) "Windows
Data Protection services integration" [Resolved]
org.eclipse.equinox.simpleconfigurator (1.0.0.v20080604) "Simple
Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (1.0.4.v20080930)
"Simple Configurator Manipulator" [Active]
org.eclipse.help (3.3.102.v20081014_34x) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.300.v20080507) "Help Application Server"
[Starting]
org.eclipse.help.base (3.3.103.v20090128_34x) "Help System Base" [Starting]
org.eclipse.help.ui (3.3.102.v20081014_34x) "Help System UI" [Starting]
org.eclipse.help.webapp (3.3.101.M20080805_34x) "Help System Webapp"
[Starting]
org.eclipse.jface (3.4.2.M20090107-0800) "JFace" [Active]
org.eclipse.jface.databinding (1.2.1.M20080827-0800a) "JFace Data Binding
for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.4.2.r342_v20081119-0800) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.1.100.I20080604) "JSch Core" [Active]
org.eclipse.jsch.ui (1.1.100.I20080415) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.4.2.r342_v20081028-0800) "Refactoring
Core" [Active]
org.eclipse.ltk.ui.refactoring (3.4.1.r341_v20080716-0800) "Refactoring
UI" [Starting]
org.eclipse.mylyn (3.0.5.v20090218-1800-e3x) "Mylyn" [Starting]
org.eclipse.mylyn (3.1.1.v20090411-0400-e3x) "Mylyn" [Starting]
org.eclipse.mylyn.bugzilla.core (3.1.1.v20090411-0400-e3x) "Mylyn Bugzilla
Connector Core" [Active]
org.eclipse.mylyn.bugzilla.ide (3.1.1.v20090411-0400-e3x) "Mylyn Bugzilla
IDE Extensions" [Starting]
org.eclipse.mylyn.bugzilla.ui (3.1.1.v20090411-0400-e3x) "Mylyn Bugzilla
Connector UI" [Active]
org.eclipse.mylyn.commons.core (3.1.1.v20090411-0400-e3x) "Mylyn Commons
Core" [Resolved]
org.eclipse.mylyn.commons.net (3.1.1.v20090411-0400-e3x) "Mylyn Commons
Net" [Active]
org.eclipse.mylyn.commons.ui (3.1.1.v20090411-0400-e3x) "Mylyn Commons UI"
[Active]
org.eclipse.mylyn.compatibility (3.1.1.v20090411-0400-e3x) "Java 5
Compatibility Checker" [Resolved]
org.eclipse.mylyn.context.core (3.1.1.v20090411-0400-e3x) "Mylyn Context
Core" [Active]
org.eclipse.mylyn.context.ui (3.1.1.v20090411-0400-e3x) "Mylyn Context UI"
[Active]
org.eclipse.mylyn.help.ui (3.1.1.v20090411-0400-e3x) "Mylyn Help"
[Starting]
org.eclipse.mylyn.ide.ui (3.1.1.v20090411-0400-e3x) "Mylyn IDE UI"
[Starting]
org.eclipse.mylyn.monitor.core (3.1.1.v20090411-0400-e3x) "Mylyn Monitor
Core" [Resolved]
org.eclipse.mylyn.monitor.ui (3.1.1.v20090411-0400-e3x) "Mylyn Monitor UI"
[Active]
org.eclipse.mylyn.resources.ui (3.1.1.v20090411-0400-e3x) "Mylyn Resources
UI" [Starting]
org.eclipse.mylyn.tasks.bugs (3.1.1.v20090411-0400-e3x) "Mylyn Bug
Reporting" [Starting]
org.eclipse.mylyn.tasks.core (3.1.1.v20090411-0400-e3x) "Mylyn Tasks Core"
[Resolved]
org.eclipse.mylyn.tasks.ui (3.1.1.v20090411-0400-e3x) "Mylyn Tasks UI"
[Active]
org.eclipse.mylyn.team.cvs (3.1.1.v20090411-0400-e3x) "Mylyn CVS
org.eclipse.mylyn.team.ui (3.1.1.v20090411-0400-e3x) "Mylyn Team UI"
[Active]
org.eclipse.osgi (3.4.3.R34x_v20081215-1030) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.1.200.v20071203) "OSGi Release 4.0.1
Services" [Resolved]
org.eclipse.osgi.util (3.1.300.v20080303) "OSGi Release 4.0.1 Utility
Classes" [Resolved]
org.eclipse.platform (3.3.101.v200902111700) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.user (3.4.2.r342_v20081031-0800) "Eclipse
Workbench User Guide" [Resolved]
org.eclipse.rcp (3.4.1.R342_v20090205) "Eclipse RCP" [Starting]
org.eclipse.rse (3.0.3.v200902042310) "Remote System Explorer End-User
Runtime" [Resolved]
org.eclipse.rse.connectorservice.dstore (3.0.1.v200809181500) "RSE DStore
Connector Service" [Starting]
org.eclipse.rse.connectorservice.local (2.1.0.v20080604) "RSE Local
Connector Service" [Active]
org.eclipse.rse.connectorservice.ssh (2.1.0.v20080604) "RSE SSH Connector
Service" [Starting]
org.eclipse.rse.connectorservice.telnet (1.1.0.v20080604) "RSE Telnet
org.eclipse.rse.core (3.0.3.v200902042310) "Remote System Explorer Core"
[Active]
org.eclipse.rse.doc.user (3.0.1.v200809041200) "RSE User Guide" [Resolved]
org.eclipse.rse.dstore.security (3.0.0.v20080609) "RSE DStore SSL Support"
[Starting]
org.eclipse.rse.efs (2.1.1.v200809041200) "RSE Eclipse Filesystem (EFS)
org.eclipse.rse.efs.ui (2.1.0.v20080606) "RSE Eclipse Filesystem (EFS)
Provider UI Support" [Resolved]
org.eclipse.rse.files.ui (3.0.3.v200902050040) "RSE Files UI" [Starting]
org.eclipse.rse.importexport (1.1.0.v20080604) "RSE Import/Export"
[Starting]
org.eclipse.rse.processes.ui (3.0.1.v20080714) "RSE Processes UI"
[Starting]
org.eclipse.rse.remotecdt (2.1.1.v200808191815) "Remote System Explorer
C/C++ Remote Debug Launcher" [Starting]
org.eclipse.rse.remotecdt.source (2.1.1.v200809041200) "Remote System
Explorer C/C++ Remote Debug Launcher Source" [Resolved]
org.eclipse.rse.services (3.0.1.v200809091230) "RSE Services Framework"
[Active]
org.eclipse.rse.services.dstore (3.0.3.v200902181600) "RSE DStore
Services" [Starting]
org.eclipse.rse.services.files.ftp (3.0.1.v200808191815) "RSE FTP Service"
[Active]
org.eclipse.rse.services.local (2.1.1.v20080710) "RSE Local Services"
[Active]
org.eclipse.rse.services.ssh (2.1.1.v20080714) "RSE SSH Services" [Active]
org.eclipse.rse.services.telnet (1.1.0.v20080604) "RSE Telnet Service"
[Starting]
org.eclipse.rse.shells.ui (3.0.1.v20080710) "RSE Shells UI" [Starting]
org.eclipse.rse.subsystems.files.core (3.0.1.v200809041200) "RSE Files
Core" [Active]
org.eclipse.rse.subsystems.files.dstore (2.1.2.v200902181600) "RSE DStore
Files" [Active]
org.eclipse.rse.subsystems.files.ftp (2.1.0.v20080609) "RSE FTP Files"
[Active]
org.eclipse.rse.subsystems.files.local (2.1.0.v20080604) "RSE Local Files"
[Active]
org.eclipse.rse.subsystems.files.ssh (2.1.0.v20080604) "RSE SSH Files"
[Starting]
org.eclipse.rse.subsystems.processes.core (3.0.3.v200902042310) "RSE
Processes Core" [Active]
org.eclipse.rse.subsystems.processes.dstore (2.1.0.v20080604) "RSE DStore
Processes" [Active]
org.eclipse.rse.subsystems.processes.local (2.1.0.v20080604) "RSE Local
Processes" [Starting]
org.eclipse.rse.subsystems.processes.shell.linux (1.1.1.v20080714) "RSE
Linux Shell Processes" [Starting]
org.eclipse.rse.subsystems.shells.core (3.0.0.v20080604) "RSE Shells Core"
[Active]
org.eclipse.rse.subsystems.shells.dstore (2.1.0.v20080604) "RSE DStore
Shells" [Starting]
org.eclipse.rse.subsystems.shells.local (2.1.0.v20080604) "RSE Local
Shells" [Active]
org.eclipse.rse.subsystems.shells.ssh (2.1.0.v20080604) "RSE SSH Shells"
[Starting]
org.eclipse.rse.subsystems.shells.telnet (1.1.0.v20080604) "RSE Telnet
Shells" [Starting]
org.eclipse.rse.subsystems.terminals.core (0.1.1.v20080714) "RSE Terminals
Core (Incubation)" [Active]
org.eclipse.rse.subsystems.terminals.ssh (0.1.0.v20080604) "RSE SSH
Terminals (Incubation)" [Active]
org.eclipse.rse.terminals.ui (0.1.3.v200902181600) "RSE Terminals UI
org.eclipse.rse.ui (3.0.3.v200902042310) "RSE UI" [Active]
org.eclipse.rse.useractions (1.1.2.v200812041720) "RSE User Actions"
[Starting]
org.eclipse.rse.useractions.source (1.1.2.v200812041720) "RSE User Actions
Source" [Resolved]
org.eclipse.search (3.4.1.r341_v20080813-0800) "Search Support" [Starting]
org.eclipse.swt (3.4.2.v3452b) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.4.1.v3452b) "Standard Widget Toolkit
org.eclipse.team.core (3.4.2.r34x_20080115) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.101.r34x_20090115) "CVS Team Provider Core"
[Active]
org.eclipse.team.cvs.ssh (3.2.100.I20080604) "CVS SSH Core" [Starting]
org.eclipse.team.cvs.ssh2 (3.2.200.I20080604) "CVS SSH2" [Starting]
org.eclipse.team.cvs.ui (3.3.100.r34x_20090121) "CVS Team Provider UI"
[Active]
org.eclipse.team.ui (3.4.1.r34x_20080827) "Team Support UI" [Active]
org.eclipse.text (3.4.0.v20080605-1800) "Text" [Resolved]
org.eclipse.tm.terminal (2.0.3.v200902181600) "Target Management Terminal
Widget" [Starting]
org.eclipse.ui (3.4.2.M20090204-0800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.201.v20080708_34x) "Browser Support" [Starting]
org.eclipse.ui.cheatsheets (3.3.101.v20080702_34x) "Cheat Sheets"
[Starting]
org.eclipse.ui.console (3.3.1.v20090128_r342) "Console" [Active]
org.eclipse.ui.editors (3.4.0.v20080603-2000) "Default Text Editor"
[Active]
org.eclipse.ui.externaltools (3.2.0.v20080514-1542) "External Tools"
[Starting]
org.eclipse.ui.forms (3.3.103.v20081027_34x) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.4.2.M20090127-1700) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.1.M20090204-0800) "Eclipse IDE UI
Application" [Resolved]
org.eclipse.ui.intro (3.2.201.v20080702_34x) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.200.v20080508) "Universal Welcome"
[Starting]
org.eclipse.ui.navigator (3.3.102.M20090127-1700) "Common Navigator View"
[Active]
org.eclipse.ui.navigator.resources (3.3.101.M20080910-0800) "Navigator
Workbench Components" [Active]
org.eclipse.ui.net (1.0.0.I20080605) "Internet Connection Management UI"
[Active]
org.eclipse.ui.presentations.r21 (3.2.100.I20080512-2000) "R21
Presentation Plug-in" [Starting]
org.eclipse.ui.views (3.3.1.M20081112-0800) "Views" [Active]
org.eclipse.ui.views.log (1.0.0.v20080803-1700) "Log View" [Starting]
org.eclipse.ui.views.properties.tabbed (3.4.2.M20090127-1700) "Tabbed
Properties View" [Starting]
org.eclipse.ui.win32 (3.2.100.v20080408-0800) "Eclipse UI Win32
Enhancements" [Resolved]
org.eclipse.ui.workbench (3.4.2.M20090127-1700) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20080509-2000) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.4.1.r341_v20080827-1100) "Text
Editor Framework" [Active]
org.eclipse.update.configurator (3.2.201.R34x_v20080819) "Install/Update
org.eclipse.update.core (3.2.202.R34x_v20081128) "Install/Update Core"
[Active]
org.eclipse.update.core.win32 (3.2.100.v20080107) "Install/Update Core for
Windows" [Resolved]
org.eclipse.update.scheduler (3.2.100.v20080404) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.101.R34x_v20081128) "Install/Update UI"
[Starting]
org.mortbay.jetty (5.1.14.v200806031611) "Jetty WebServer" [Resolved]
org.sat4j.core (2.0.3.v20081021) "SAT4J Core" [Resolved]
org.sat4j.pb (2.0.3.v20081021) "SAT4J Pseudo" [Resolved]
*** User Preferences:
#Fri May 29 09:33:05 CEST 2009
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_dsdp_nab_updates/ena bled=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/suffix=artifacts.xml
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0_/name=EPP
Usage Data Collector Update Site
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/version=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/name=http\://download.eclipse.org/tools/cdt/releases/ganymede
/instance/org.eclipse.cdt.core.prj-SERL-MEM/indexer/preferen ceScope=0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/file\:_D\:_Tiberio_Program\
Files_eclipse_.eclipseextension/type=org.eclipse.equinox.p2. extensionlocation.artifactRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/type=org.eclipse.equinox.p2.artifact.repository.simpleRe pository
/instance/org.eclipse.rse.ui/org.eclipse.rse.internal.ui.vie w.SystemViewConnectionAdapter\:org.eclipse.rse.ui.view.Syste mTableView=org.eclipse.rse.ui.profile;org.eclipse.rse.ui.sys temType;org.eclipse.rse.ui.connected;org.eclipse.rse.ui.host name;org.eclipse.rse.ui.defaultuserid;org.eclipse.rse.ui.des cription
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates/ena bled=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes_/enabled=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes/url=http\://download.eclipse.org/technology/emft/updates/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e xtras/url=http\://download.eclipse.org/tools/mylyn/update/extras
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_webtools_updates/url =http\://download.eclipse.org/webtools/updates
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/type=org.eclipse.equinox.p2.updatesite.metadataRepos itory
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_rt_rap_update-site/e nabled=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/na me=Ganymede
Artifacts
/instance/org.eclipse.rse.core/org.eclipse.rse.systemtype.lo cal.systemType.defaultUserId=tiberio
Files_eclipse/description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_rt_rap_update-site/i sSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_datatools_updates/en abled=false
Files_eclipse_p2_org.eclipse.equinox.p2.core_cache/name=down load cache
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/provider=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/file\:_D\:_Tiberio_Program\
Files_eclipse_configuration_org.eclipse.osgi_bundles_61_data _listener_-1250303469_/name=metadata
listener file\:/D\:/Tiberio/Program Files/eclipse/.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.org_tptp_updates/enabled=false
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates/isS ystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0/url=http\://download.eclipse.org/technology/epp/updates/1.0/
Files_eclipse_.eclipseextension/isSystem=true
Files_eclipse_configuration_org.eclipse.osgi_bundles_67_data _listener_1925729951_/suffix=content.xml
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/en abled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/description=
Files_eclipse_configuration_org.eclipse.osgi_bundles_67_data _listener_1925729951_/url=file\:/D\:/Tiberio/Program
Files/eclipse/configuration/org.eclipse.osgi/bundles/67/data /listener_1925729951/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/enabled=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__eclipse.org_tptp_updates_/isSystem=false
/instance/org.eclipse.core.resources/version=1
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_m2t_updates _/enabled=false
@org.eclipse.ui=3.4.2.M20090204-0800
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/enabled=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/name=Mylyn
for Eclipse 3.4
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_mdt_updates /url=http\://download.eclipse.org/modeling/mdt/updates/
/configuration/org.eclipse.core.net/proxyData/HTTP/port=8080
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ suffix=artifacts.xml
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_datatools_updates/is System=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/url=http\://download.eclipse.org/tools/buckminster/updates
Files_eclipse_configuration_org.eclipse.osgi_bundles_67_data _listener_1925729951/type=org.eclipse.equinox.p2.artifact.re pository.simpleRepository
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_mdt_updates _/isSystem=false
/instance/org.eclipse.rse.ui/org.eclipse.rse.preferences.ver ify.connection=false
@org.eclipse.mylyn.context.core=3.1.1.v20090411-0400-e3x
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_mdt_updates /isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_m2t_updates /url=http\://download.eclipse.org/modeling/m2t/updates/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /url=http\://download.eclipse.org/birt/update-site/2.3
Files_eclipse_p2_org.eclipse.equinox.p2.core_cache_/type=org .eclipse.equinox.internal.p2.metadata.repository.LocalMetada taRepository
/configuration/org.eclipse.core.net/proxiesEnabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/pr ovider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ type=org.eclipse.equinox.p2.artifact.repository.simpleReposi tory
Files_eclipse_p2_org.eclipse.equinox.p2.director_rollback/na me=Agent
rollback repository
Files_eclipse_configuration_org.eclipse.osgi_bundles_61_data _listener_-1250303469/version=1.0.0
/instance/org.eclipse.rse.ui/org.eclipse.rse.preferences.ord er.connections=idf10nb286640.Local;idf10nb286640.LAITUE
@org.eclipse.rse.ui=3.0.3.v200902042310
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_webtools_updates/isS ystem=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_m2m_updates _/isSystem=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates_/is System=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_datatools_updates/is System=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ur l=http\://download.eclipse.org/releases/ganymede
Files_eclipse/url=file\:/D\:/Tiberio/Program Files/eclipse/
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=D\:\\Tib erio\\Eclipse-workspace
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ url=http\://download.eclipse.org/eclipse/updates/3.4
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /isSystem=false
Files_eclipse_configuration_org.eclipse.osgi_bundles_67_data _listener_1925729951_/name=metadata
listener dropins
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/url=http\://download.eclipse.org/tools/cdt/releases/ganymede
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes/enabled=false
/instance/org.eclipse.cdt.ui/spelling_locale_initialized=tru e
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_stp_updates/enabled= false
Files_eclipse_.eclipseextension/name=D\:\\Tiberio\\Program
Files\\eclipse\\.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/name=Mylyn
for Eclipse 3.4
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_gef_update-sit e_releases_site.xml/url= http\://download.eclipse.org/tools/gef/update-site/releases/ site.xml
/configuration/org.eclipse.core.net/proxyData/HTTPS/hasAuth= false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emf_updates /url=http\://download.eclipse.org/modeling/emf/updates/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/url=http\://download.eclipse.org/tools/cdt/releases/ganymede
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/name=http\://download.eclipse.org/tools/cdt/releases/ganymede
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_dsdp_dd_updates/isSy stem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ur l=http\://download.eclipse.org/releases/ganymede
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_stp_updates/isSystem =false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ description=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_dsdp_dd_updates/url=http\://download.eclipse.org/dsdp/dd/updates
@org.eclipse.team.cvs.ui=3.3.100.r34x_20090121
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes/enabled=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_gef_update-sit e_releases_site.xml/url= http\://download.eclipse.org/tools/gef/update-site/releases/ site.xml
Files_eclipse_.eclipseextension/suffix=eclipse
Files_eclipse_configuration_org.eclipse.osgi_bundles_67_data _listener_1925729951/description=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_rt_rap_update-site/u rl=http\://download.eclipse.org/rt/rap/update-site
Files_eclipse_configuration_org.eclipse.osgi_bundles_61_data _listener_-1250303469_/suffix=content.xml
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/version=1.0.0
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/isSystem=false
@org.eclipse.cdt.managedbuilder.core=5.0.2.200902130801
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates_/ur l=http\://www.eclipse.org/modeling/emft/updates/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s_/url=http\://download.eclipse.org/modeling/emft/updates/
/instance/org.eclipse.ui.ide/platformState=1242140752563
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_gmf_updates _releases/url=http\://download.eclipse.org/modeling/gmf/updates/releases/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_gef_update-sit e_releases_site.xml/enabled=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /url=http\://download.eclipse.org/birt/update-site/2.3
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_stp_updates/enabled= false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ty pe=org.eclipse.equinox.internal.p2.metadata.repository.Local MetadataRepository
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s_/enabled=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/version=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/enabled=false
/configuration/org.eclipse.core.net/proxyData/HTTPS/host=pro xy.mycompany.com
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_mdt_updates _/url=http\://download.eclipse.org/modeling/mdt/updates/
/instance/org.eclipse.cdt.managedbuilder.core/properties/SER L-MEM.null.540804321/0.567025142=\#\r\n\#Mon
May 25 18\:18\:37 CEST
2009\r\norg.eclipse.cdt.build.core.prefbase.toolchain.205061 2378\=\\\#\\r\\n\\\#Mon
May 25 18\\\:18\\\:37 CEST
2009\\r\\nrebuildState\\\=false\\r\\n\r\norg.eclipse.cdt.bui ld.core.settings.holder.734077448\=\\\#\\r\\n\\\#Mon
2009\\r\\nrebuildState\\\=false\\r\\n\r\n0.567025142\=\\\#\\ r\\n\\\#Mon
2009\\r\\nrcState\\\=0\\r\\nrebuildState\\\=false\\r\\n\r\no rg.eclipse.cdt.build.core.settings.holder.820921565\=\\\#\\r \\n\\\#Mon
2009\\r\\nrebuildState\\\=false\\r\\n\r\norg.eclipse.cdt.bui ld.core.settings.holder.1825060513\=\\\#\\r\\n\\\#Mon
2009\\r\\nrebuildState\\\=false\\r\\n\r\norg.eclipse.cdt.bui ld.core.settings.holder.libs.812961199\=\\\#\\r\\n\\\#Mon
May 25 18\\\:18\\\:37 CEST 2009\\r\\nrebuildState\\\=false\\r\\n\r\n
Files_eclipse_configuration_org.eclipse.osgi_bundles_67_data _listener_1925729951/name=artifact
listener dropins
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/enabled=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_dsdp_dd_updates/url=http\://download.eclipse.org/dsdp/dd/updates
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_gef_update-sit e_releases_site.xml/enabled=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_gmf_updates _releases/enabled=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ enabled=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_m2t_updates _/url=http\://download.eclipse.org/modeling/m2t/updates/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0/suffix=artifacts.xml
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/url=http\://download.eclipse.org/tools/mylyn/update/e3.4
Files_eclipse_.eclipseextension/provider=
Files_eclipse_configuration_org.eclipse.osgi_bundles_61_data _listener_-1250303469/suffix=artifacts.xml
/instance/org.eclipse.ui/showIntro=false
@org.eclipse.team.ui=3.4.1.r34x_20080827
Files_eclipse_p2_org.eclipse.equinox.p2.core_cache_/name=Age nt Metadata
Cache
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ name=file\:/builds/M/org.eclipse.releng.eclipsebuilder/../sr c/repo
- artifacts
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.core.resources=3.4.2.R34x_v20090126
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/provider=
/instance/org.eclipse.epp.usagedata.recording/org.eclipse.ep p.usagedata.recording.last-upload=1243268149225
/configuration/org.eclipse.core.net/nonProxiedHosts=127.0.0. 1|localhost
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/url=http\://download.eclipse.org/modeling/emft/updates/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_webtools_updates/ena bled=false
Files_eclipse_configuration_org.eclipse.osgi_bundles_61_data _listener_-1250303469/isSystem=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_dsdp_nab_updates/isS ystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.org_tptp_updates/isSystem=false
Files_eclipse_configuration_org.eclipse.osgi_bundles_67_data _listener_1925729951/isSystem=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_webtools_updates/url =http\://download.eclipse.org/webtools/updates/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0_/url=http\://download.eclipse.org/technology/epp/updates/1.0/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_rt_rap_update-site/u rl=http\://download.eclipse.org/rt/rap/update-site
[Updated on: Fri, 22 October 2010 16:39] by Moderator
Re: RSE: Erreur when using Remote Systems view [message #580893 is a reply to message #35099] |
Hello Sylvain,
the pattern
yields
> What's happen?
> BR, Sylvain
> proceeding but
> !STACK 0
> thread "main".
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> ... 15 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> empty array
> empty array
> empty array
> empty array
Re: RSE: Erreur when using Remote Systems view [message #580920 is a reply to message #35456] |
Hello Martin,
Sylvain
win32
-ws
win32
-arch
x86
-showsplash
D:\Tiberio\Program
-launcher
-name
Eclipse
--launcher.library
D:\Tiberio\Program
-startup
D:\Tiberio\Program
-framework
-vm
-Xms40m
-Xmx256m
file.separator=\
http.proxyPort=8080
http.proxySet=true
https.proxySet=true
line.separator=
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.launcherPath=.
osgi.nl=fr_FR
osgi.os=win32
osgi.ws=win32
path.separator=;
i86
sun.desktop=windows
user.country=FR
user.language=fr
user.name=tiberio
user.variant=
*** Features:
Client"
System Base"
Platform"
"Eclipse RCP"
DStore Services"
Service"
Telnet Service"
User Actions"
[Resolved]
Plug-in" [Resolved]
Lang" [Resolved]
Plug-in" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Starting]
[Active]
Guide" [Starting]
Core" [Active]
UI" [Active]
Core" [Active]
[Starting]
[Active]
Mechanism" [Active]
[Active]
Language" [Active]
[Active]
[Active]
[Active]
[Resolved]
[Active]
[Starting]
(ECF)" [Starting]
[Starting]
[Starting]
[Starting]
Container" [Active]
[Active]
[Starting]
Servlet" [Starting]
[Resolved]
Core" [Active]
Engine" [Active]
Support" [Active]
Support" [Active]
[Starting]
[Starting]
Core" [Active]
UI" [Starting]
Core" [Resolved]
Net" [Active]
[Active]
Core" [Active]
[Active]
[Starting]
[Starting]
Core" [Resolved]
[Active]
UI" [Starting]
[Resolved]
[Active]
[Active]
Classes" [Resolved]
Runtime" [Resolved]
Service" [Starting]
[Active]
[Starting]
[Starting]
[Starting]
[Active]
[Active]
[Active]
[Starting]
Core" [Active]
Files" [Active]
[Active]
[Active]
[Starting]
Processes" [Active]
[Active]
Shells" [Starting]
Shells" [Active]
[Starting]
Shells" [Starting]
[Starting]
Source" [Resolved]
[Active]
[Active]
Widget" [Starting]
[Starting]
[Active]
[Starting]
[Starting]
[Active]
[Active]
[Active]
Windows" [Resolved]
Scheduler" [Active]
[Starting]
Artifacts
for Eclipse 3.4
rollback repository
listener dropins
for Eclipse 3.4
listener dropins
Cache
- artifacts
[Updated on: Fri, 22 October 2010 16:36] by Moderator
Current Time: Wed Jul 23 06:06:19 EDT 2025
Powered by FUDForum. Page generated in 0.05044 seconds
