Home » Archived » OHF » STEM - editing included scenarios, etc?
STEM - editing included scenarios, etc? [message #35049] Tue, 16 October 2007 05:54 Go to next message
Originally posted by: icos.atropa.gmail.com
I'm trying to use STEM for a modeling class. At this point, all I want to
do is edit an existing scenario, model, etc. and then run it. I've gone
through the help files, online docs, google, wiki, etc. It seems that, at
this point, most of the docs are geared primarily towards implementation.
Specifically, I've created a new project and viewed it in the "STEM
Project Explorer" window, but I can't drag-and-drop any of the included
objects into the new project's folders. I did create a scenario,
drag-and-drop a model into it, create a sequencer, and drag-and-drop the
sequencer into the editor window of the scenario. Still, I get the error
"Scenario cannot be run because it doesn't have a sequencer error". I've
tried drag-and-dropping the sequencer elsewhere, but nothing else
"accepts" it. Any thoughts?
thanks,
christian
university of new mexico
Re: STEM - editing included scenarios, etc? [message #35194 is a reply to message #35049] Thu, 18 October 2007 11:33 Go to previous message
> error "Scenario cannot be run because it doesn't have a sequencer
> error". I've tried drag-and-dropping the sequencer elsewhere, but
> nothing else "accepts" it. Any thoughts?
Did you save the project before running it. It is not obvious but you
need to do a "Ctrl-s" to save the model after you have done a drag/drop
and before running it.
It may also be helpful to look at the instructions that Jamie added to
the wiki
http://wiki.eclipse.org/STEM_Design_Document#Example:_Creati ng_your_own_STEM_Scenario_from_a_user_defined_disease_model
Re: STEM - editing included scenarios, etc? [message #582242 is a reply to message #35049] Thu, 18 October 2007 11:33 Go to previous message
the wiki
Previous Topic:international multibyte characters?
Next Topic:MESA test 11350 bridge problem
Current Time: Wed Jul 23 18:26:20 EDT 2025
Powered by FUDForum. Page generated in 0.38266 seconds
