Home » Eclipse Projects » Buckminster dev » [buckminster-dev] Vote for Committer status for Achim Demelt has started
[buckminster-dev] Vote for Committer status for Achim Demelt has started [message #34769] Tue, 16 June 2009 07:41
tools.buckminster Committers,
This automatically generated message signals that Thomas Hallgren has
nominated Achim Demelt as a Committer on the tools.buckminster project. The
reason given is as follows:
Achim is very active in the buckminster community. He drew a full house on
his Buckminster presentation at Eclipse Summit last year and he has
submitted several non-trivial patches:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241623
https://bugs.eclipse.org/bugs/show_bug.cgi?id=242782
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244850
https://bugs.eclipse.org/bugs/show_bug.cgi?id=272789
https://bugs.eclipse.org/bugs/show_bug.cgi?id=279270
https://bugs.eclipse.org/bugs/show_bug.cgi?id=280250
Right now Achim is working on helping the JDT/PDE team separating pure
headless code from UI code to enable real support for headless execution of
JUnit tests in Buckminster. See
http://code.google.com/p/buckminster-contrib/ for more info.
I think Achim has a lot to add to our domain. It's high time he becomes a
committer.
The vote is being held via the MyFoundation portal: voters *must* use the
portal for the votes to be properly recorded. The voting will continue
until either all 9 existing Committers have voted or until they have been
given enough time to vote, even if they do not do so (defined as at least
one week). Achim Demelt must receive at least three +1s and no -1s for a
successful election.
Eligible Committers must cast their votes through their My Foundation
portal page (do NOT just reply to this email; your vote will not be
correctly recorded unless you use the portal):
http://portal.eclipse.org/
The project Committers eligible to vote are:
Karel Brezina
Guillaume CHATELET
Stefan Daume
Thomas Hallgren
Filip Hrbek
Henrik Lindberg
Michal Ruzicka
Adrian Skehill
Mitch Sonies
*NOTE*: Successful elections are left open for a maximum of 60 days to
allow for processing of paperwork. After that time the election will be
expired, regardless of its current status. Should papework processing on
the part of the candidate take more time than allowed, a new election will
have to be held.
If you have any questions, please do not hesitate to contact your project
lead, PMC member, or the EMO <emo@eclipse.org>
Previous Topic:Version override with type Triplet vs. Omni Version
Next Topic:[buckminster-dev] +1 for Achim Demelt on tools.buckminster
Current Time: Sat May 10 10:41:35 EDT 2025
Powered by FUDForum. Page generated in 0.04549 seconds
