Home » Archived » M2M (model-to-model transformation) » MOF2UML inheritance
MOF2UML inheritance [message #34541] Thu, 26 April 2007 11:19 Go to next message
Hello!
From http://www.eclipse.org/m2m/atl/atlTransformations/, i downloaded
MOF2UML example, but i did not find rule inheritance. Where could i find
the version with rule inheritance?
Thanks in adcance.
Re: MOF2UML inheritance [message #34575 is a reply to message #34541] Thu, 26 April 2007 11:27 Go to previous messageGo to next message
Originally posted by: mikael.barbero.gmail.com
Hi Kelly,
MOF2UML is a very old transformation (about 2 years) and rules
inheritance were not supported. There is no new version planned but any
contribution is welcome ;)
Mikael
Kelly Garcés wrote:
> Hello!
> Thanks in adcance.
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: MOF2UML inheritance [message #34609 is a reply to message #34575] Thu, 26 April 2007 13:47 Go to previous messageGo to next message
Originally posted by: touzitou.enstimac.fr
Hi Mikael !!
there is any documentation about rules inheritance ??
But fastly for wich reason we have to use Rules inheritance ??
Thxs
Mikaël Barbero a écrit :
> Hi Kelly,
> Best regards,
> Mikael
> Kelly Garcés wrote:
>> Hello!
>> find the version with rule inheritance?
>> Thanks in adcance.
Re: MOF2UML inheritance [message #34643 is a reply to message #34575] Fri, 27 April 2007 04:28 Go to previous messageGo to next message
> Hi Kelly,
> Best regards,
> Mikael
> Kelly Garcés wrote:
>> Hello!
>> Thanks in adcance.
Hello:
Are there any example of rule inheritance?
Where could i find them?
Thanks.
Re: MOF2UML inheritance [message #34676 is a reply to message #34643] Fri, 27 April 2007 07:20 Go to previous messageGo to next message
Hi Kelly and jihed,
I wrote a quick and dirty explanation about rule inheritance. It is
available here:
http://wiki.eclipse.org/index.php/ATL_Language_Troubleshoote r#Rule_inheritance
Do not hesitate to ask more questions about it. This will help me to
improve the documentation.
Mikael
>> Hi Kelly,
>> any contribution is welcome ;)
>> Best regards,
>> Mikael
>> Kelly Garcés wrote:
>>> Hello!
>>> downloaded MOF2UML example, but i did not find rule inheritance.
>>> Where could i find the version with rule inheritance?
>>> Thanks in adcance.
> Hello:
> Thanks.
Re: MOF2UML inheritance [message #36240 is a reply to message #34676] Mon, 07 May 2007 10:49 Go to previous messageGo to next message
Originally posted by: r.c.ladan.tue.nl
Mikaël Barbero wrote:
> Hi Kelly and jihed,
> available here:
Here's a question :)
Is it possible to override values in subrules which are set by
superrules? For example, to override atttribute b of class t:
rule A { -- superrule, either lazy or abstract
from s : mm!s
to t : mm!t(
a <- s.a,
b <- 'super'
rule B extends A {
from s : mm!s
to t : mm!t{
b <- 'sub'
Rene
Re: MOF2UML inheritance [message #36307 is a reply to message #36240] Mon, 07 May 2007 11:55 Go to previous messageGo to next message
> from s : mm!s
> to t : mm!t(
> a <- s.a,
> b <- 'super'
> rule B extends A {
> from s : mm!s
> to t : mm!t{
> b <- 'sub'
Yes, you can do this. However, rule inheritance is not implemented for
lazy rules yet.
Note that b <- 'super' will not be "executed" at all.
This means that if a lazy rule was called in the super rule, it will not
be called in the subrule unless you call it explicitly.
Moreover, you can definitely not reuse the value of t.b by writing
something like:
-- INCORRECT
rule B extends A {
from s : mm!s
to t : mm!t{
b <- t.b + '_sub'
, which is anyway incorrect because it also involves target model
navigation.
If you want to reuse a computed value, simply use an attribute helper
instead:
helper context mm!s def: value : String =
'super';
rule A {
from s : mm!s
to t : mm!t(
a <- s.a,
b <- s.value
rule B extends A {
from s : mm!s
to t : mm!t{
b <- s.value + '_sub'
Frédéric Jouault
Re: MOF2UML inheritance [message #36371 is a reply to message #36307] Tue, 08 May 2007 04:10 Go to previous messageGo to next message
Frédéric Jouault wrote:
> Hello,
> > from s : mm!s
> > to t : mm!t(
> > a <- s.a,
> > b <- 'super'
> > rule B extends A {
> > from s : mm!s
> > to t : mm!t{
> > b <- 'sub'
> lazy rules yet.
Is there a timeline for the implementation of lazy rule inheritance?
I have a superimposed ATL rule 'library' which contains lazy rules to be
executed on demand. As an alternative, I guess I can turn the lazy
superrules into abstract superrules since abstract rules aren't
standalone anyway.
So if rule A is lazy, the output of thisModule.A(s_in) would be {t.a =
s_in.a , t.b = <undefined>} ?
And if rule A is lazy and rule B (either lazy or normal) is executed
with s = s_in2, its output would be {t.a = s_in2.a (inherited from rule
), t.b = 'sub'} ?
> something like:
It wasn't my intention to reuse variables, but to have a "use the value
of the superrule if not set here" policy (just like imperative object
orientation).
Rene
Re: MOF2UML inheritance [message #36420 is a reply to message #36371] Wed, 09 May 2007 07:59 Go to previous messageGo to next message
>> lazy rules yet.
> standalone anyway.
I planned to have lazy rules in this 'library' extend other rules, but
unfortunately having lazy rules extend other rules crashes the ATL compiler.
Rene
Re: [ATL] MOF2UML inheritance [message #36629 is a reply to message #36371] Wed, 09 May 2007 11:43 Go to previous message
I have just noticed that we have been discussing in this thread without
prefixing its subject with [ATL]. This is now corrected. Please, keep
this in mind for your future posts ;-).
>> lazy rules yet.
So far, we have been delaying the implementation of lazy rule
inheritance because we wanted to integrate it with an improved resolving
algorithm.
However, if the interest in lazy rule inheritance is strong enough, we
may decide to work on a first (simpler) version, without needing the
improved resolving algorithm.
> ), t.b = 'sub'} ?
Rules A and B cannot be lazy because they use rule inheritance, which is
not implemented for lazy rules yet.
>> something like:
> orientation).
It was not my intention either to imply that you wanted to do this :-).
I was merely mentioning this fact here because it seemed relevant.
Sorry for the confusion.
Frédéric Jouault
Previous Topic:[ATL] Transformation BPEL - XPDL
Next Topic:Re: [ATL] Datatype mapping during Ecore to KM3 extraction
Current Time: Sat Jul 19 00:19:27 EDT 2025
Powered by FUDForum. Page generated in 0.05482 seconds
