Home » Archived » M2M (model-to-model transformation) » MOF2UML inheritance
Re: MOF2UML inheritance [message #36307 is a reply to message #36240] |
Mon, 07 May 2007 11:55   |
> Is it possible to override values in subrules which are set by
> superrules? For example, to override atttribute b of class t:
> rule A { -- superrule, either lazy or abstract
> from s : mm!s
> to t : mm!t(
> a <- s.a,
> b <- 'super'
> rule B extends A {
> from s : mm!s
> to t : mm!t{
> b <- 'sub'
Yes, you can do this. However, rule inheritance is not implemented for
lazy rules yet.
Note that b <- 'super' will not be "executed" at all.
This means that if a lazy rule was called in the super rule, it will not
be called in the subrule unless you call it explicitly.
Moreover, you can definitely not reuse the value of t.b by writing
something like:
-- INCORRECT
rule B extends A {
from s : mm!s
to t : mm!t{
b <- t.b + '_sub'
, which is anyway incorrect because it also involves target model
navigation.
If you want to reuse a computed value, simply use an attribute helper
instead:
helper context mm!s def: value : String =
'super';
rule A {
from s : mm!s
to t : mm!t(
a <- s.a,
b <- s.value
rule B extends A {
from s : mm!s
to t : mm!t{
b <- s.value + '_sub'
Frédéric Jouault
Re: MOF2UML inheritance [message #36371 is a reply to message #36307] |
Tue, 08 May 2007 04:10   |
Originally posted by: r.c.ladan.tue.nl
Frédéric Jouault wrote:
> Hello,
> > from s : mm!s
> > to t : mm!t(
> > a <- s.a,
> > b <- 'super'
> > rule B extends A {
> > from s : mm!s
> > to t : mm!t{
> > b <- 'sub'
> lazy rules yet.
Is there a timeline for the implementation of lazy rule inheritance?
I have a superimposed ATL rule 'library' which contains lazy rules to be
executed on demand. As an alternative, I guess I can turn the lazy
superrules into abstract superrules since abstract rules aren't
standalone anyway.
So if rule A is lazy, the output of thisModule.A(s_in) would be {t.a =
s_in.a , t.b = <undefined>} ?
And if rule A is lazy and rule B (either lazy or normal) is executed
with s = s_in2, its output would be {t.a = s_in2.a (inherited from rule
), t.b = 'sub'} ?
> something like:
It wasn't my intention to reuse variables, but to have a "use the value
of the superrule if not set here" policy (just like imperative object
orientation).
Rene
Re: [ATL] MOF2UML inheritance [message #36629 is a reply to message #36371] |
Wed, 09 May 2007 11:43  |
I have just noticed that we have been discussing in this thread without
prefixing its subject with [ATL]. This is now corrected. Please, keep
this in mind for your future posts ;-).
>> lazy rules yet.
So far, we have been delaying the implementation of lazy rule
inheritance because we wanted to integrate it with an improved resolving
algorithm.
However, if the interest in lazy rule inheritance is strong enough, we
may decide to work on a first (simpler) version, without needing the
improved resolving algorithm.
> ), t.b = 'sub'} ?
Rules A and B cannot be lazy because they use rule inheritance, which is
not implemented for lazy rules yet.
>> something like:
> orientation).
It was not my intention either to imply that you wanted to do this :-).
I was merely mentioning this fact here because it seemed relevant.
Sorry for the confusion.
Frédéric Jouault
Current Time: Fri Jul 18 21:01:53 EDT 2025
Powered by FUDForum. Page generated in 0.05669 seconds
